Hello Dear,
May I ask if the different versions of the 'ADS5400IPZP' will influence its performance?
According to the datasheet page 31. 'SYNC’ mode can be turned on by using Micro Controller, normally, this IC will put out 'SYNC', but the version '8CCEKITG4' didn't putout 'SYNC', but the version '49CP4QTG4' is no problem.
I've tested a few pieces of this part with these two different versions on the same board and the same position with the same setting. The result is the same.
Can you please help me?
Thank you very much.
Beatrice
