Planning to oversample with this ADC and use a digital low pass filter, so I'm trying to understand how much the noise will reduce. Is there any way I can estimate the noise density of this converter? For example, using the transition noise spec I get near 11.5uV-RMS. If I assume this is wideband (white) noise, and I assume that the small signal bandwidth is valid (23MHz), then I get 11.5uV-RMS / sqrt(23MHz) = 2.4nV/sqrt(Hz). Is this a valid estimate, or is there a valid method to estimate the impact of a digital low pass filter given the transition noise?
Thank you,
Erik
