I want to know if this chip can work in on several task in the the same time?
for example, closed mode works continually + approach to AUXILIARY DAC + operate single end ADC and use GPIO all in the same time?
Hi Michael,
You can use the other features in closed-loop operation (read other ADC channels, use aux DACs, GPIOs, etc.), though you must take care not to stop closed loop operation by disabling the ADC auto-conversion mode. You can stop the auto conversion mode by writing to the trigger register, changing the ADC mux, or disabling the ADC. If you avoid these you should be fine.
Paul
