Our customer need to use the Altert Pin as comparator function, but he didn't get the waveform of Figure 28, his configuration is as following:
1.Config registers: high Byte 0x42 ,low Byte 0xF8;
2. Setting the threshold value: LowThresholdValue 1800,HighThresholdValue 2500
3. ADS1115 Conversion data changes between 1200 and 3000,but the output ALERT is always low, so how to get the Figure 28 waveform:
I read the datasheet, it describes that to use the comparator function , the Hi_thresh register value must always be greater than the Lo_thresh register value.
Could you please help to analyze?
Best regards
Kailyn
