Other Parts Discussed in Thread: DAC8750, DAC8775
Hi TI Team,
As per datasheet DAC8760 the voltage and current outputs are enabled simultaneously.
But the Data resistor is common so How can we differential which data for Vout and Iout?
Means I want to generate Iout with different data values and Vout with different values but parallel.
If I change the Iout value then the Vout value will not be changed. Is it possible? If yes then how?
