Hello team,
Customer will monitor the input voltage with resistor divider circuit.
Are there any concern on the above ?
Thank you and best regards,
Michiaki
Hello team,
Michiaki
There aren't fundamental concerns when monitoring a resistor divider input with the ADS1015. Just make sure the divided voltage is within the input and supply range of the ADC.
The non-zero input impedance will be in parallel with the bottom leg resistor of the divider and will result in a small gain error. The smaller the bottom resistor is, the smaller the gain error will be.
