From my customer...
We just observed an unexpected behavior. When we switch the input configuration (Mode4 register) e.g from AIN0-AINCOM to AIN0-AIN1 we observe a negative pulse on AIN0.
We have a big analog mux in front of AIN0 that is switched first (transition from 5.5V to ~ 2V. Then when the Mode4 register is written we can see a edge down to 1V and then a slow ramp back to the intended value.
The slow ramp is most likely due to the selected source which is high impedance in this case. When we switch to a low impedance source ( e.g. a power supply) the ramp up is much faster but the negative edge remains.
I couldn’t find any information on that behavior in the datasheet.
Can you explain what’s happening there?
