AMC1306E25: PWMx pin usage consult
Part Number: AMC1306E25
Hi Team,
Can you explain what's the usage of PWMx here in simplified schematic of datasheet? If customer don't have enough resources to connect here, what's influence it will cause?
B&R.
Stanley
  • Hi Stanley,
    Your picture did not come through, however I'll assume you are talking about the PWMx signal being used to generate the clock for the AMC1306E25.  In Manchester mode, the C2K uses an internal clock for the SDFM - you don't need that connection.  Please consult with the C2000 team for proper Manchester mode operation on the controller.
