I am using the sample code provided for ADS1261. I am able to write the configuration registers and also read back it with correct data.
But when i try to read the status byte (add: 01h), I am getting REFL_ALM bit getting set which means reference voltage is below the low limit. I have enable internal reference voltage by setting REFENB bit in REF Register.
Can you help me with possible reasons for REFL_ALM getting set.
Thanks in advance.
