ADC12DL3200: Interleaving spurious: how to reduce its power level
Part Number: ADC12DL3200
i'm testing the ADC12DL3200 with a sampling clock of 2 GHz in single channel mode.
I have attached the data and the FFT plot for an input frequency of 3691.406 MHz.
As you can see from the and the plot, there is an interleaving spurious at Fs-Fin= (2000 MHz - 308.595 MHz =1691.405 MHz). This spurious limits the SFDR parameter.
How is it possible to reduce the spurious level?
What is the origin of this spurious?
Gain or timing mismatching between the two ADC's core can be the cause of this spurious?
From the data in the txt file can you tell if there a gain or timing mismatch?
From the datasheet there is a Fine Gain Adjust for bank 0,1 ecc..
Is it useful in this case?
410
864
1574
2424
3176
3674
3788
3514
2882
2076
1254
606
328
432
866
1634
2464
3212
3672
3794
3490
2872
2046
1212
620
314
418
904
1642
2500
3206
3706
3766
3460
2852
2000
1224
578
310
436
920
1684
2510
3260
3694
3774
3450
2790
1992
1168
560
304
464
956
1700
2564
3260
3716
3766
3442
2770
1946
1136
538
310
482
954
1750
2570
3300
3704
3756
3422
2746
1922
1128
548
290
476
1008
1768
2608
3312
3734
3754
3410
2728
1884
1098
540
304
496
1038
1808
2636
3362
3724
3750
3368
2674
1858
1052
504
308
512
1058
1832
2672
3372
3746
3740
3350
2676
1800
1030
488
314
532
1078
1876
2706
3392
3748
3738
3334
2622
1776
1002
494
308
526
1106
1894
2748
3406
3758
3732
3310
2596
1728
980
452
312
554
1132
1940
2768
3438
3766
3712
3278
2574
1736
962
450
312
574
1162
1950
2802
3432
3770
3712
3262
2536
1688
922
426
323
589
1177
1995
2826
3470
3758
3690
3256
2508
1654
898
426
334
606
1218
2032
2856
3476
3770
3674
3216
2488
1640
910
410
318
620
1240
2088
2874
3506
3790
3676
3198
2436
1614
848
396
342
634
1290
2086
2922
3524
3794
3672
3146
2424
1576
838
394
328
670
1296
2142
2924
3534
3778
3650
3156
2378
1542
804
406
352
662
1316
2154
2974
3534
3790
3644
3120
2350
1492
814
368
344
698
1364
2198
2978
3578
3796
3622
3106
2312
1478
768
366
346
716
1392
2222
3024
3584
3804
3600
3058
2278
1440
750
360
362
744
1420
2266
3052
3598
3782
3598
3052
2276
1416
720
358
366
750
1468
2284
3076
3592
3798
3592
3004
2210
1378
728
350
376
784
1488
2328
3088
3628
3784
3560
2986
2176
1362
694
348
376
804
1512
2358
3124
3628
3784
3548
2952
2166
1318
672
324
398
828
1532
2392
3142
3670
3782
3540
2934
2118
1300
660
342
402
824
1564
2420
3186
3656
3796
3522
2900
2096
1244
630
328
402
876
1586
2454
3190
3684
3788
3494
2858
2046
1244
596
318
430
890
1648
2476
3230
3688
3778
3466
2838
2026
1206
592
314
432
920
1684
2528
3252
3704
3764
3470
2806
1982
1176
564
332
452
950
1708
2526
3276
3690
3776
3442
2796
1956
1138
574
304
456
966
1722
2584
3288
3716
3754
3418
2774
1916
1148
538
298
478
996
1770
2614
3330
3722
3762
3388
2714
1898
1084
514
302
472
1020
1780
2664
3330
3734
3748
3378
2684
1852
1064
508
314
492
1040
1850
2666
3358
3734
3748
3358
2666
1822
1054
506
314
504
1062
1848
2708
3374
3768
3738
3338
2646
1798
1026
482
302
526
1094
1898
2722
3394
3760
3720
3318
2604
1780
978
462
294
544
1126
1928
2786
3410
3778
3728
3286
2595
1717
961
457
316
582
1150
1970
2786
3434
3762
3712
3284
2544
1704
940
440
314
584
1190
2004
2822
3450
3772
3696
3254
2538
1672
938
428
320
598
1198
2022
2828
3492
3786
3676
3204
2480
1662
884
430
312
612
1242
2040
2878
3494
3788
3676
3200
2450
1606
858
396
326
632
1268
2076
2902
3528
3788
3680
3174
2418
1570
830
412
340
664
1288
2122
2940
3516
3794
3652
3158
2410
1540
846
406
332
672
1330
2154
2946
3562
3786
3652
3118
2370
1532
788
372
338
702
1364
2160
2996
3564
3802
3622
3110
2338
1466
770
352
344
710
1390
2226
3010
3588
3786
3612
3090
2290
1468
750
366
350
738
1408
2252
3044
3580
3798
3596
3050
2240
1408
748
346
348
768
1430
2298
3064
3616
3800
3584
3036
2200
1406
718
338
360
772
1482
2318
3082
3612
3792
3568
2974
2202
1348
694
332
382
796
1496
2360
3128
3632
3804
3558
2986
2162
1334
670
334
386
810
1538
2374
3140
3650
3792
3540
2922
2132
1292
672
332
410
848
1558
2418
3150
3682
3790
3526
2896
2094
1282
626
332
418
856
1596
2420
3180
3666
3782
3502
2882
2090
1220
612
328
424
900
1630
2484
3216
3680
3788
3478
2856
2022
1222
584
330
438
910
1670
2506
3246
3692
3788
3458
2828
1990
1180
590
318
436
936
1688
2556
3260
3712
3770
3450
2798
1966
1156
560
314
462
962
1746
2570
3296
3710
3776
3430
2764
1932
1130
552
306
464
996
1748
2602
3300
3722
3756
3404
2736
1920
1110
528
322
494
1008
1790
2618
3336
3726
3744
3378
2708
1868
1064
518
312
488
1050
1814
2668
3342
3756
3750
3354
2700
1828
1072
492
304
506
1070
1848
2670
3372
3754
3756
3342
2642
1806
1002
480
314
526
1100
1884
2722
3387
3763
3729
3321
2622
1768
982
456
314
546
1132
1918
2722
3420
3756
3720
3286
2588
1756
960
456
316
558
1170
1948
2792
3428
3760
3710
3272
2566
1696
974
446
308
576
1172
1980
2802
3464
3766
3704
3250
2528
1700
918
434
320
596
1208
2008
2844
3462
3774
3686
3220
2500
1644
884
420
306
616
1206
2044
2848
3496
3764
3670
3218
2458
1606
882
412
326
622
1266
2062
2898
3506
3796
3670
3178
2438
1584
872
392
328
654
1276
2124
2910
3530
3776
3656
3154
2384
1554
834
398
326
662
1312
2132
2952
3528
3792
3638
3138
2394
1524
818
374
346
704
1344
2170
2960
3564
3798
3628
3110
2340
1500
786
372
354
704
1384
2190
3002
3574
3798
3624
3084
2312
1442
764
352
352
728
1398
2238
3028
3582
3780
3618
3062
2284
1430
730
356
360
764
1448
2276
3068
3594
3796
3592
3022
2232
1388
724
344
364
786
1468
2308
3086
3618
3770
3580
3006
2200
1376
692
344
376
800
1498
2338
3120
3626
3770
3550
2970
2180
1328
692
322
382
822
1540
2388
3130
3652
3792
3546
2932
2120
1320
674
332
402
824
1558
2392
3164
3656
3788
3514
2914
2116
1282
650
322
406
866
1570
2452
3174
3666
3778
3514
2890
2072
1256
620
322
424
858
1628
2464
3208
3676
3784
3502
2858
2046
1224
618
318
440
920
1640
2484
3216
3702
3768
3466
2846
1996
1216
584
320
436
926
1680
2528
3258
3700
3776
3454
2808
1990
1164
580
326
442
962
1724
2582
3266
3710
3760
3424
2770
1938
1150
554
312
470
958
1758
2584
3304
3724
3766
3412
2744
1910
1100
550
304
466
1018
1766
2614
3316
3736
3748
3392
2716
1882
1112
520
318
494
1030
1810
2658
3352
3744
3748
3364
2708
1850
1060
508
320
515
1059
1845
2675
3358
3760
3748
3352
2660
1822
1036
490
314
512
1086
1862
2702
3392
3746
3744
3334
2622
1780
1000
496
300
538
1112
1902
2726
3386
3758
3744
3294
2608
1754
978
472
310
558
1122
1936
2770
3428
3770
3704
3282
2566
1738
958
454
314
566
1180
1960
2788
3434
3778
3692
3260
2548
1692
930
440
330
586
1200
2028
2816
3472
3772
3682
3234
2526
1650
886
438
322
600
1222
2026
2864
3478
3788
3690
3206
2476
1626
892
424
314
634
1244
2076
2896
3512
3784
3672
3200
2434
1610
860
396
326
652
1274
2090
2908
3508
3794
3652
3168
2402
1570
834
404
320
670
1314
2150
2924
3534
3796
3648
3142
2360
1532
818
390
334
670
1348
2168
2978
3550
3808
3638
3114
2342
1500
800
374
340
706
1356
2198
2992
3590
3792
3612
3090
2314
1472
754
386
356
708
1394
2202
3010
3578
3790
3614
3070
2310
1426
736
352
352
738
1428
2266
3050
3616
3788
3576
3040
2234
1414
724
354
364
746
1478
2308
3088
3606
3806
3568
3006
2222
1378
700
338
370
794
1500
2348
3114
3626
3786
3562
2976
2188
1354
678
342
388
808
1524
2358
3132
3632
3786
3538
2956
2150
1320
660
322
384
826
1534
2382
3150
3650
3786
3532
2942
2116
1276
638
336
408
846
1592
2416
3178
3660
3788
3522
2912
2074
1260
642
324
412
876
1590
2462
3196
3690
3774
3482
2874
2062
1246
600
316
426
894
1642
2488
3222
3690
3776
3460
2840
2020
1182
594
320
428
930
1684
2524
3228
3696
3780
3462
2812
1998
1180
570
302
454
952
1692
2544
3266
3698
3766
3438
2784
1950
1150
552
306
470
984
1744
2586
3300
3718
3770
3418
2752
1904
1134
536
310
476
990
1778
2608
3322
3726
3764
3402
2726
1885
1089
539
327
494
1036
1794
2652
3330
3732
3742
3380
2708
1854
1070
512
310
506
1034
1822
2662
3368
3740
3748
3362
2658
1830
1030
500
306
518
1076
1852
2708
3366
3756
3748
3332
2644
1794
1022
476
322
532
1088
1900
2722
3420
3746
3734
3296
2606
1766
974
468
310
548
1128
1922
2768
3408
3758
3714
3282
2576
1724
974
456
308
562
1148
1978
2784
3440
3758
3716
3272
2542
1712
938
456
316
586
1192
1990
2818
3458
3786
3710
3228
2512
1676
928
430
312
584
1202
2032
2844
3492
3776
3672
3230
2490
1642
888
418
336
618
1240
2054
2878
3492
3782
3666
3186
2464
1612
868
410
334
638
1274
2104
2904
3520
3786
3664
3160
2420
1570
842
388
334
660
1304
2120
2932
3514
3804
3646
3148
2390
1544
836
374
324
672
1312
2154
2934
3560
3772
3630
3122
2346
1530
802
374
340
692
1378
2182
2998
3546
3800
3626
3100
2338
1486
774
378
348
712
1382
2264
3010
3578
3788
3606
3080
2274
1448
756
370
360
730
1406
2234
3068
3590
3800
3606
3028
2270
1424
748
328
346
762
1450
2292
3060
3632
3792
3572
3000
2222
1410
706
328
370
774
1478
2324
3094
3616
3796
3578
2974
2206
1342
690
346
388
800
1506
2366
3120
3638
3780
3550
2964
2166
1334
666
354
386
812
1552
2364
3152
3640
3788
3532
2924
2132
1306
658
324
404
848
1562
2408
3174
3664
3790
3504
2906
2104
1272
660
318
404
870
1620
2452
3206
3676
3804
3506
2884
2098
1254
608
322
422
896
1638
2500
3218
3714
3770
3476
2876
2038
1212
598
330
430
888
1678
2516
3276
3692
3762
3460
2820
2004
1186
588
322
442
938
1680
2550
3248
3718
3770
3434
2788
1952
1172
564
310
450
966
1744
2578
3298
3713
3767
3417
2763
1938
1118
556
300
462
998
1750
2604
3308
3732
3748
3396
2712
1910
1098
508
310
484
1002
1792
2626
3334
3718
3754
3382
2694
1846
1070
526
306
474
1048
1826
2664
3342
3748
3750
3354
2690
1818
1066
502
312
516
1062
1856
2678
3384
3752
3742
3336
2640
1818
1012
484
322
522
1100
1868
2724
3388
3756
3722
3300
2628
1746
976
462
322
546
1106
1936
2764
3426
3754
3730
3298
2582
1748
974
468
320
552
1166
1934
2786
3430
3764
3714
3258
2546
1708
952
446
314
574
1182
1980
2808
3476
3770
3694
3252
2510
1696
912
424
310
596
1202
2004
2858
3478
3782
3684
3228
2496
1650
902
418
324
616
1234
2042
2850
3506
3776
3686
3204
2466
1628
860
436
320
620
1268
2056
2894
3490
3788
3682
3182
2434
1580
852
400
324
648
1284
2108
2908
3528
3792
3660
3160
2406
1562
828
388
338
668
1330
2144
2962
3540
3788
3640
3124
2370
1518
798
378
354
686
1342
2180
2970
3572
3796
3636
3120
2330
1498
776
388
344
702
1392
2206
3006
3566
3812
3624
3084
2312
1464
768
362
362
754
1406
2250
3034
3596
3796
3602
3062
2254
1440
742
354
356
752
1454
2284
3076
3592
3806
3594
3036
2234
1372
728
348
394
796
1482
2308
3078
3614
3794
3572
3002
2184
1364
688
338
378
806
1506
2322
3128
3630
3796
3558
2980
2166
1336
686
336
384
818
1538
2378
3140
3648
3788
3520
2938
2136
1318
660
322
404
838
1568
2390
3162
3658
3784
3532
2898
2124
1276
638
316
414
866
1594
2450
3178
3678
3774
3496
2888
2080
1260
614
318
422
886
1628
2458
3192
3678
3800
3496
2864
2034
1216
612
316
422
920
1664
2516
3228
3712
3782
3470
2822
2000
1182
578
308
456
923
1715
2547
3269
3690
3768
3438
2792
1984
1172
574
308
454
974
1710
2574
3274
3710
3760
3434
2786
1938
1154
540
330
476
992
1740
2602
3298
3726
3760
3418
2752
1926
1104
538
296
482
1016
1776
2632
3322
3740
3756
3394
2708
1888
1098
520
310
506
1018
1824
2652
3362
3738
3752
3364
2678
1864
1054
512
306
506
1056
1834
2694
3364
3742
3746
3342
2678
1806
1024
478
306
532
1088
1896
2714
3392
3742
3744
3330
2610
1800
1002
484
310
540
1108
1890
2766
3410
3776
3726
3288
2594
1720
992
466
304
554
1146
1952
2770
3430
3770
3706
3288
2544
1728
950
448
308
570
1182
1974
2804
3442
3776
3704
3252
2536
1674
938
440
328
588
1202
2036
2812
3462
3762
3702
3246
2500
1654
888
428
308
596
1224
2060
2880
3470
3782
3692
3212
2472
1628
898
422
334
624
1260
2076
2888
3508
3778
3658
3180
2436
1592
842
422
340
632
1286
2108
2934
3516
3800
3644
3150
2408
1560
828
370
330
662
1298
2148
2932
3542
3770
3658
3138
2362
1522
812
402
334
690
1340
2156
2970
3532
3792
3618
3102
2342
1486
784
374
328
706
1350
2196
2992
3574
3788
3608
3084
2308
1492
752
366
352
722
1416
2238
3028
3580
3798
3604
3044
2280
1428
746
360
364
746
1424
2290
3038
3620
3788
3584
3044
2242
1424
722
350
380
770
1458
2296
3072
3604
3786
3572
2988
2210
1368
708
356
368
790
1502
2344
3084
3640
3794
3556
2966
2172
1374
676
336
386
826
1528
2338
3138
3642
3806
3546
2962
2158
1314
674
348
392
840
1528
2398
3142
3666
3776
3522
2934
2096
1292
648
328
402
846
1588
2426
3188
3678
3796
3514
2896
2088
1266
632
336
404
884
1620
2464
3206
3680
3784
3500
2876
2048
1257
613
323
423
898
1662
2492
3244
3692
3774
3480
2846
2022
1176
580
322
438
938
1682
2530
3248
3694
3776
3446
2822
1980
1166
568
312
452
944
1704
2548
3280
3708
3762
3442
2766
1950
1150
560
322
456
976
1756
2592
3292
3732
3772
3414
2740
1896
1134
546
312
472
1010
1766
2600
3318
3726
3762
3390
2728
1900
1098
524
320
496
1024
1782
2660
3328
3732
3748
3368
2686
1850
1074
496
312
510
1040
1838
2658
3376
3744
3750
3368
2670
1820
1034
492
318
518
1080
1872
2728
3370
3760
3746
3338
2626
1766
1018
460
312
538
1090
1910
2744
3414
3754
3738
3304
2602
1758
984
474
308
552
1130
1922
2776
3420
3766
3716
3310
2596
1730
954
446
312
572
1162
1982
2778
3460
3764
3716
3268
2536
1704
932
446
322
572
1198
1992
2826
3448
3766
3684
3244
2506
1650
916
430
314
602
1206
2044
2864
3488
3790
3696
3216
2464
1638
870
416
326
620
1262
2060
2894
3490
3766
3676
3194
2452
1590
858
406
344
632
1270
2124
2900
3522
3788
3668
3184
2406
1564
848
414
330
674
1288
2136
2930
3530
3780
3634
3150
2372
1520
812
384
342
686
1320
2164
2958
3568
3792
3626
3108
2344
1530
812
386
338
698
1366
2188
3008
3564
3796
3622
3088
2324
1488
770
360
358
712
1362
2234
3000
3588
3794
3608
3076
2272
1440
750
366
362
728
1422
2248
3044
3600
3800
3602
3046
2264
1408
736
348
356
758
1446
2308
3066
3606
3804
3576
3018
2204
1404
704
344
370
776
1498
2312
3114
3614
3790
3562
2970
2194
1340
684
320
394
814
1508
2370
3112
3646
3780
3528
2964
2168
1312
678
340
398
814
1560
2374
3158
3644
3788
3540
2920
2124
1300
668
320
400
854
1582
2436
3172
3680
3785
3515
2907
2089
1282
620
314
408
872
1596
2452
3200
3682
3798
3504
2884
2080
1226
626
326
408
902
1628
2490
3214
3682
3778
3472
2840
2032
1220
588
326
438
910
1698
2514
3248
3688
3774
3460
2832
1980
1188
596
314
438
964
1694
2550
3264
3716
3770
3432
2798
1980
1158
562
310
458
958
1740
2562
3306
3728
3770
3406
2748
1936
1122
552
302
470
990
1738
2610
3310
3736
3744
3406
2744
1896
1096
532
320
492
1010
1804
2634
3342
3732
3750
3384
2682
1848
1062
524
310
500
1038
1830
2682
3344
3746
3744
3370
2674
1822
1064
482
326
520
1066
1880
2680
3402
3746
3734
3318
2650
1810
998
482
304
530
1096
1886
2742
3392
3776
3736
3314
2608
1750
968
460
316
546
1118
1926
2748
3430
3762
3722
3288
2584
1734
974
466
324
548
1154
1954
2792
3430
3768
3706
3270
2540
1712
956
452
314
584
1172
1992
2816
3458
3768
3696
3268
2506
1690
914
432
320
604
1206
2026
2864
3458
3784
3694
3226
2504
1640
902
420
314
620
1234
2050
2874
3506
3770
3674
3206
2468
1616
874
414
324
620
1270
2088
2910
3500
3786
3664
3180
2430
1574
848
404
338
650
1298
2124
2926
3538
3800
3636
3152
2386
1548
840
386
338
676
1326
2166
2960
3534
3802
3644
3134
2366
1512
792
380
342
696
1340
2206
2978
3562
3790
3620
3102
2336
1466
770
364
366
706
1386
2212
3016
3566
3788
3612
3056
2298
1448
762
360
348
728
1420
2252
3038
3596
3780
3604
3046
2260
1438
736
356
362
750
1436
2288
3074
3590
3792
3578
3020
2258
1404
698
346
362
780
1480
2330
3080
3624
3788
3582
3008
2204
1348
688
350
380
784
1506
2344
3132
3628
3794
3550
2966
2180
1342
666
336
406
824
1543
2381
3121
3645
3786
3542
2948
2132
1326
650
330
396
846
1560
2398
3192
3650
3800
3518
2908
2102
1254
650
312
390
868
1598
2446
3192
3660
3772
3498
2906
2066
1244
616
322
422
888
1650
2458
3234
3672
3778
3480
2848
2038
1216
604
334
426
916
1654
2514
3226
3702
3770
3468
2840
1996
1186
568
312
436
934
1698
2514
3270
3714
3768
3442
2804
1984
1164
580
308
440
964
1724
2566
3274
3710
3746
3426
2778
1924
1142
548
314
466
964
1766
2592
3304
3728
3760
3388
2750
1908
1120
540
296
474
1018
1776
2626
3324
3742
3740
3378
2716
1868
1078
508
312
490
1040
1820
2648
3360
3730
3756
3364
2678
1850
1038
510
300
516
1072
1854
2706
3352
3756
3728
3336
2656
1798
1020
474
316
530
1096
1884
2724
3380
3762
3716
3334
2612
1776
992
482
314
532
1098
1910
2746
3404
3766
3716
3314
2588
1744
998
458
310
572
1128
1944
2762
3438
3760
3716
3274
2538
1734
942
432
322
566
1172
1962
2804
3440
3766
3700
3250
2560
1668
930
436
330
604
1180
2018
2814
3478
3768
3704
3236
2510
1652
888
424
326
618
1210
2034
2872
3478
3794
3690
3206
2468
1610
888
418
330
626
1244
2070
2866
3494
3780
3664
3186
2418
1606
852
404
318
646
1304
2096
2924
3520
3778
3638
3170
2412
1550
832
402
330
682
1312
2168
2956
3542
3796
3636
3136
2366
1528
812
400
344
686
1354
2172
2996
3548
3790
3642
3110
2338
1488
790
366
338
720
1368
2188
2992
3574
3784
3620
3086
2300
1464
762
362
346
730
1416
2226
3026
3576
3794
3596
3048
2266
1428
740
354
354
746
1434
2288
3058
3608
3786
3590
3046
2250
1400
720
346
368
762
1452
2302
3086
3606
3794
3588
3004
2234
1364
707
363
385
799
1504
2344
3076
3620
3778
3576
2972
2184
1348
676
344
386
816
1520
2366
3134
3644
3790
3528
2962
2158
1310
654
324
400
828
1540
2408
3140
3648
3766
3518
2918
2102
1282
656
334
398
864
1580
2430
3176
3660
3772
3512
2892
2072
1222
632
324
410
898
1602
2464
3194
3690
3780
3486
2876
2050
1238
608
326
428
900
1646
2482
3242
3676
3778
3464
2830
2026
1180
586
312
438
942
1684
2528
3260
3702
3776
3456
2818
1984
1178
576
316
448
954
1700
2530
3274
3702
3770
3428
2784
1946
1116
564
314
468
974
1740
2602
3294
3732
3758
3420
2736
1924
1130
552
318
476
990
1780
2608
3326
3716
3758
3390
2702
1900
1090
528
294
504
1036
1808
2656
3336
3740
3740
3372
2698
1860
1064
506
314
498
1040
1842
2670
3362
3746
3740
3342
2662
1824
1032
506
320
510
1090
1852
2710
3380
3758
3726
3320
2626
1776
1022
468
306
542
1092
1906
2740
3402
3758
3728
3310
2576
1786
990
472
306
550
1148
1930
2770
3426
3774
3704
3288
2584
1718
960
444
308
588
1144
1980
2786
3450
3766
3702
3270
2532
1696
922
450
314
584
1184
1992
2834
3452
3774
3696
3232
2518
1650
920
432
318
602
1216
2040
2858
3480
3766
3680
3206
2472
1626
884
426
328
610
1258
2040
2892
3498
3786
3664
3190
2454
1584
854
402
330
648
1276
2108
2880
3524
3786
3666
3168
2416
1582
842
404
336
660
1304
2140
2938
3528
3798
3646
3140
2390
1522
822
378
326
694
1332
2188
2942
3552
3786
3628
3112
2364
1520
778
368
344
688
1358
2186
3000
3568
3790
3628
3102
2316
1480
762
374
340
734
1400
2226
3000
3586
3776
3610
3076
2270
1436
750
368
362
728
1418
2250
3058
3586
3796
3607
3027
2255
1379
722
350
368
764
1438
2288
3082
3622
3800
3572
3012
2202
1400
718
358
364
804
1514
2354
3138
3642
3786
3554
3016
2244
1388
732
348
366
818
1528
2416
3156
3666
3786
3530
2956
2160
1336
684
352
362
796
1524
2382
3162
3652
3796
3520
2920
2112
1286
674
342
392
838
1574
2422
3158
3670
3778
3516
2908
2090
1282
642
326
412
868
1596
2458
3204
3696
3774
3494
2884
2068
1224
614
320
430
900
1620
2490
3218
3698
3774
3478
2844
2012
1194
588
320
432
902
1670
2506
3246
3684
3764
3452
2802
1974
1168
582
310
452
960
1706
2554
3252
3702
3760
3430
2802
1956
1154
548
318
450
976
1744
2568
3296
3718
3764
3410
2740
1926
1140
550
308
474
998
1754
2612
3294
3718
3746
3396
2726
1884
1092
510
316
484
1008
1794
2638
3324
3716
3750
3388
2702
1856
1064
522
328
500
1052
1818
2682
3350
3748
3740
3362
2666
1810
1052
492
312
520
1078
1874
2704
3372
3756
3728
3338
2632
1806
1024
480
306
520
1086
1870
2734
3388
3770
3714
3318
2602
1746
1004
486
320
546
1122
1934
2742
3424
3752
3720
3298
2572
1742
960
454
306
568
1156
1960
2804
3428
3776
3706
3266
2566
1704
952
442
324
588
1188
2002
2820
3472
3778
3708
3240
2502
1694
916
436
314
596
1224
2016
2860
3468
3778
3682
3208
2498
1638
896
416
326
618
1220
2078
2872
3502
3768
3676
3200
2436
1626
852
420
322
618
1272
2078
2910
3512
3786
3668
3174
2438
1576
862
410
332
662
1290
2134
2934
3536
3798
3648
3152
2380
1540
810
380
332
684
1336
2158
2964
3534
3800
3650
3120
2366
1500
816
380
352
700
1354
2190
2972
3576
3778
3624
3086
2324
1484
778
370
352
712
1392
2219
3025
3571
3793
3606
3076
2290
1426
764
362
354
740
1406
2272
3040
3598
3782
3596
3052
2264
1432
726
346
358
746
1454
2280
3082
3610
3790
3586
3014
2230
1378
698
348
370
790
1456
2320
3078
3618
3788
3562
3012
2166
1352
682
356
380
808
1510
2348
3132
3646
3800
3546
2960
2146
1322
688
348
384
824
1526
2390
3134
3658
3794
3534
2944
2120
1320
658
328
406
848
1584
2398
3180
3662
3784
3528
2916
2120
1260
650
326
What values ​​should be loaded into this register?
Thank you in advance.
Best regards.
Matteo
  • This is the ADC data.
    Than you.
    Matteo
    410
    864
    1574
    2424
    3176
    3674
    3788
    3514
    2882
    2076
    1254
    606
    328
    432
    866
    1634
    2464
    3212
    3672
    3794
    3490
    2872
    2046
    1212
    620
    314
    418
    904
    1642
    2500
    3206
    3706
    3766
    3460
    2852
    2000
    1224
    578
    310
    436
    920
    1684
    2510
    3260
    3694
    3774
    3450
    2790
    1992
    1168
    560
    304
    464
    956
    1700
    2564
    3260
    3716
    3766
    3442
    2770
    1946
    1136
    538
    310
    482
    954
    1750
    2570
    3300
    3704
    3756
    3422
    2746
    1922
    1128
    548
    290
    476
    1008
    1768
    2608
    3312
    3734
    3754
    3410
    2728
    1884
    1098
    540
    304
    496
    1038
    1808
    2636
    3362
    3724
    3750
    3368
    2674
    1858
    1052
    504
    308
    512
    1058
    1832
    2672
    3372
    3746
    3740
    3350
    2676
    1800
    1030
    488
    314
    532
    1078
    1876
    2706
    3392
    3748
    3738
    3334
    2622
    1776
    1002
    494
    308
    526
    1106
    1894
    2748
    3406
    3758
    3732
    3310
    2596
    1728
    980
    452
    312
    554
    1132
    1940
    2768
    3438
    3766
    3712
    3278
    2574
    1736
    962
    450
    312
    574
    1162
    1950
    2802
    3432
    3770
    3712
    3262
    2536
    1688
    922
    426
    323
    589
    1177
    1995
    2826
    3470
    3758
    3690
    3256
    2508
    1654
    898
    426
    334
    606
    1218
    2032
    2856
    3476
    3770
    3674
    3216
    2488
    1640
    910
    410
    318
    620
    1240
    2088
    2874
    3506
    3790
    3676
    3198
    2436
    1614
    848
    396
    342
    634
    1290
    2086
    2922
    3524
    3794
    3672
    3146
    2424
    1576
    838
    394
    328
    670
    1296
    2142
    2924
    3534
    3778
    3650
    3156
    2378
    1542
    804
    406
    352
    662
    1316
    2154
    2974
    3534
    3790
    3644
    3120
    2350
    1492
    814
    368
    344
    698
    1364
    2198
    2978
    3578
    3796
    3622
    3106
    2312
    1478
    768
    366
    346
    716
    1392
    2222
    3024
    3584
    3804
    3600
    3058
    2278
    1440
    750
    360
    362
    744
    1420
    2266
    3052
    3598
    3782
    3598
    3052
    2276
    1416
    720
    358
    366
    750
    1468
    2284
    3076
    3592
    3798
    3592
    3004
    2210
    1378
    728
    350
    376
    784
    1488
    2328
    3088
    3628
    3784
    3560
    2986
    2176
    1362
    694
    348
    376
    804
    1512
    2358
    3124
    3628
    3784
    3548
    2952
    2166
    1318
    672
    324
    398
    828
    1532
    2392
    3142
    3670
    3782
    3540
    2934
    2118
    1300
    660
    342
    402
    824
    1564
    2420
    3186
    3656
    3796
    3522
    2900
    2096
    1244
    630
    328
    402
    876
    1586
    2454
    3190
    3684
    3788
    3494
    2858
    2046
    1244
    596
    318
    430
    890
    1648
    2476
    3230
    3688
    3778
    3466
    2838
    2026
    1206
    592
    314
    432
    920
    1684
    2528
    3252
    3704
    3764
    3470
    2806
    1982
    1176
    564
    332
    452
    950
    1708
    2526
    3276
    3690
    3776
    3442
    2796
    1956
    1138
    574
    304
    456
    966
    1722
    2584
    3288
    3716
    3754
    3418
    2774
    1916
    1148
    538
    298
    478
    996
    1770
    2614
    3330
    3722
    3762
    3388
    2714
    1898
    1084
    514
    302
    472
    1020
    1780
    2664
    3330
    3734
    3748
    3378
    2684
    1852
    1064
    508
    314
    492
    1040
    1850
    2666
    3358
    3734
    3748
    3358
    2666
    1822
    1054
    506
    314
    504
    1062
    1848
    2708
    3374
    3768
    3738
    3338
    2646
    1798
    1026
    482
    302
    526
    1094
    1898
    2722
    3394
    3760
    3720
    3318
    2604
    1780
    978
    462
    294
    544
    1126
    1928
    2786
    3410
    3778
    3728
    3286
    2595
    1717
    961
    457
    316
    582
    1150
    1970
    2786
    3434
    3762
    3712
    3284
    2544
    1704
    940
    440
    314
    584
    1190
    2004
    2822
    3450
    3772
    3696
    3254
    2538
    1672
    938
    428
    320
    598
    1198
    2022
    2828
    3492
    3786
    3676
    3204
    2480
    1662
    884
    430
    312
    612
    1242
    2040
    2878
    3494
    3788
    3676
    3200
    2450
    1606
    858
    396
    326
    632
    1268
    2076
    2902
    3528
    3788
    3680
    3174
    2418
    1570
    830
    412
    340
    664
    1288
    2122
    2940
    3516
    3794
    3652
    3158
    2410
    1540
    846
    406
    332
    672
    1330
    2154
    2946
    3562
    3786
    3652
    3118
    2370
    1532
    788
    372
    338
    702
    1364
    2160
    2996
    3564
    3802
    3622
    3110
    2338
    1466
    770
    352
    344
    710
    1390
    2226
    3010
    3588
    3786
    3612
    3090
    2290
    1468
    750
    366
    350
    738
    1408
    2252
    3044
    3580
    3798
    3596
    3050
    2240
    1408
    748
    346
    348
    768
    1430
    2298
    3064
    3616
    3800
    3584
    3036
    2200
    1406
    718
    338
    360
    772
    1482
    2318
    3082
    3612
    3792
    3568
    2974
    2202
    1348
    694
    332
    382
    796
    1496
    2360
    3128
    3632
    3804
    3558
    2986
    2162
    1334
    670
    334
    386
    810
    1538
    2374
    3140
    3650
    3792
    3540
    2922
    2132
    1292
    672
    332
    410
    848
    1558
    2418
    3150
    3682
    3790
    3526
    2896
    2094
    1282
    626
    332
    418
    856
    1596
    2420
    3180
    3666
    3782
    3502
    2882
    2090
    1220
    612
    328
    424
    900
    1630
    2484
    3216
    3680
    3788
    3478
    2856
    2022
    1222
    584
    330
    438
    910
    1670
    2506
    3246
    3692
    3788
    3458
    2828
    1990
    1180
    590
    318
    436
    936
    1688
    2556
    3260
    3712
    3770
    3450
    2798
    1966
    1156
    560
    314
    462
    962
    1746
    2570
    3296
    3710
    3776
    3430
    2764
    1932
    1130
    552
    306
    464
    996
    1748
    2602
    3300
    3722
    3756
    3404
    2736
    1920
    1110
    528
    322
    494
    1008
    1790
    2618
    3336
    3726
    3744
    3378
    2708
    1868
    1064
    518
    312
    488
    1050
    1814
    2668
    3342
    3756
    3750
    3354
    2700
    1828
    1072
    492
    304
    506
    1070
    1848
    2670
    3372
    3754
    3756
    3342
    2642
    1806
    1002
    480
    314
    526
    1100
    1884
    2722
    3387
    3763
    3729
    3321
    2622
    1768
    982
    456
    314
    546
    1132
    1918
    2722
    3420
    3756
    3720
    3286
    2588
    1756
    960
    456
    316
    558
    1170
    1948
    2792
    3428
    3760
    3710
    3272
    2566
    1696
    974
    446
    308
    576
    1172
    1980
    2802
    3464
    3766
    3704
    3250
    2528
    1700
    918
    434
    320
    596
    1208
    2008
    2844
    3462
    3774
    3686
    3220
    2500
    1644
    884
    420
    306
    616
    1206
    2044
    2848
    3496
    3764
    3670
    3218
    2458
    1606
    882
    412
    326
    622
    1266
    2062
    2898
    3506
    3796
    3670
    3178
    2438
    1584
    872
    392
    328
    654
    1276
    2124
    2910
    3530
    3776
    3656
    3154
    2384
    1554
    834
    398
    326
    662
    1312
    2132
    2952
    3528
    3792
    3638
    3138
    2394
    1524
    818
    374
    346
    704
    1344
    2170
    2960
    3564
    3798
    3628
    3110
    2340
    1500
    786
    372
    354
    704
    1384
    2190
    3002
    3574
    3798
    3624
    3084
    2312
    1442
    764
    352
    352
    728
    1398
    2238
    3028
    3582
    3780
    3618
    3062
    2284
    1430
    730
    356
    360
    764
    1448
    2276
    3068
    3594
    3796
    3592
    3022
    2232
    1388
    724
    344
    364
    786
    1468
    2308
    3086
    3618
    3770
    3580
    3006
    2200
    1376
    692
    344
    376
    800
    1498
    2338
    3120
    3626
    3770
    3550
    2970
    2180
    1328
    692
    322
    382
    822
    1540
    2388
    3130
    3652
    3792
    3546
    2932
    2120
    1320
    674
    332
    402
    824
    1558
    2392
    3164
    3656
    3788
    3514
    2914
    2116
    1282
    650
    322
    406
    866
    1570
    2452
    3174
    3666
    3778
    3514
    2890
    2072
    1256
    620
    322
    424
    858
    1628
    2464
    3208
    3676
    3784
    3502
    2858
    2046
    1224
    618
    318
    440
    920
    1640
    2484
    3216
    3702
    3768
    3466
    2846
    1996
    1216
    584
    320
    436
    926
    1680
    2528
    3258
    3700
    3776
    3454
    2808
    1990
    1164
    580
    326
    442
    962
    1724
    2582
    3266
    3710
    3760
    3424
    2770
    1938
    1150
    554
    312
    470
    958
    1758
    2584
    3304
    3724
    3766
    3412
    2744
    1910
    1100
    550
    304
    466
    1018
    1766
    2614
    3316
    3736
    3748
    3392
    2716
    1882
    1112
    520
    318
    494
    1030
    1810
    2658
    3352
    3744
    3748
    3364
    2708
    1850
    1060
    508
    320
    515
    1059
    1845
    2675
    3358
    3760
    3748
    3352
    2660
    1822
    1036
    490
    314
    512
    1086
    1862
    2702
    3392
    3746
    3744
    3334
    2622
    1780
    1000
    496
    300
    538
    1112
    1902
    2726
    3386
    3758
    3744
    3294
    2608
    1754
    978
    472
    310
    558
    1122
    1936
    2770
    3428
    3770
    3704
    3282
    2566
    1738
    958
    454
    314
    566
    1180
    1960
    2788
    3434
    3778
    3692
    3260
    2548
    1692
    930
    440
    330
    586
    1200
    2028
    2816
    3472
    3772
    3682
    3234
    2526
    1650
    886
    438
    322
    600
    1222
    2026
    2864
    3478
    3788
    3690
    3206
    2476
    1626
    892
    424
    314
    634
    1244
    2076
    2896
    3512
    3784
    3672
    3200
    2434
    1610
    860
    396
    326
    652
    1274
    2090
    2908
    3508
    3794
    3652
    3168
    2402
    1570
    834
    404
    320
    670
    1314
    2150
    2924
    3534
    3796
    3648
    3142
    2360
    1532
    818
    390
    334
    670
    1348
    2168
    2978
    3550
    3808
    3638
    3114
    2342
    1500
    800
    374
    340
    706
    1356
    2198
    2992
    3590
    3792
    3612
    3090
    2314
    1472
    754
    386
    356
    708
    1394
    2202
    3010
    3578
    3790
    3614
    3070
    2310
    1426
    736
    352
    352
    738
    1428
    2266
    3050
    3616
    3788
    3576
    3040
    2234
    1414
    724
    354
    364
    746
    1478
    2308
    3088
    3606
    3806
    3568
    3006
    2222
    1378
    700
    338
    370
    794
    1500
    2348
    3114
    3626
    3786
    3562
    2976
    2188
    1354
    678
    342
    388
    808
    1524
    2358
    3132
    3632
    3786
    3538
    2956
    2150
    1320
    660
    322
    384
    826
    1534
    2382
    3150
    3650
    3786
    3532
    2942
    2116
    1276
    638
    336
    408
    846
    1592
    2416
    3178
    3660
    3788
    3522
    2912
    2074
    1260
    642
    324
    412
    876
    1590
    2462
    3196
    3690
    3774
    3482
    2874
    2062
    1246
    600
    316
    426
    894
    1642
    2488
    3222
    3690
    3776
    3460
    2840
    2020
    1182
    594
    320
    428
    930
    1684
    2524
    3228
    3696
    3780
    3462
    2812
    1998
    1180
    570
    302
    454
    952
    1692
    2544
    3266
    3698
    3766
    3438
    2784
    1950
    1150
    552
    306
    470
    984
    1744
    2586
    3300
    3718
    3770
    3418
    2752
    1904
    1134
    536
    310
    476
    990
    1778
    2608
    3322
    3726
    3764
    3402
    2726
    1885
    1089
    539
    327
    494
    1036
    1794
    2652
    3330
    3732
    3742
    3380
    2708
    1854
    1070
    512
    310
    506
    1034
    1822
    2662
    3368
    3740
    3748
    3362
    2658
    1830
    1030
    500
    306
    518
    1076
    1852
    2708
    3366
    3756
    3748
    3332
    2644
    1794
    1022
    476
    322
    532
    1088
    1900
    2722
    3420
    3746
    3734
    3296
    2606
    1766
    974
    468
    310
    548
    1128
    1922
    2768
    3408
    3758
    3714
    3282
    2576
    1724
    974
    456
    308
    562
    1148
    1978
    2784
    3440
    3758
    3716
    3272
    2542
    1712
    938
    456
    316
    586
    1192
    1990
    2818
    3458
    3786
    3710
    3228
    2512
    1676
    928
    430
    312
    584
    1202
    2032
    2844
    3492
    3776
    3672
    3230
    2490
    1642
    888
    418
    336
    618
    1240
    2054
    2878
    3492
    3782
    3666
    3186
    2464
    1612
    868
    410
    334
    638
    1274
    2104
    2904
    3520
    3786
    3664
    3160
    2420
    1570
    842
    388
    334
    660
    1304
    2120
    2932
    3514
    3804
    3646
    3148
    2390
    1544
    836
    374
    324
    672
    1312
    2154
    2934
    3560
    3772
    3630
    3122
    2346
    1530
    802
    374
    340
    692
    1378
    2182
    2998
    3546
    3800
    3626
    3100
    2338
    1486
    774
    378
    348
    712
    1382
    2264
    3010
    3578
    3788
    3606
    3080
    2274
    1448
    756
    370
    360
    730
    1406
    2234
    3068
    3590
    3800
    3606
    3028
    2270
    1424
    748
    328
    346
    762
    1450
    2292
    3060
    3632
    3792
    3572
    3000
    2222
    1410
    706
    328
    370
    774
    1478
    2324
    3094
    3616
    3796
    3578
    2974
    2206
    1342
    690
    346
    388
    800
    1506
    2366
    3120
    3638
    3780
    3550
    2964
    2166
    1334
    666
    354
    386
    812
    1552
    2364
    3152
    3640
    3788
    3532
    2924
    2132
    1306
    658
    324
    404
    848
    1562
    2408
    3174
    3664
    3790
    3504
    2906
    2104
    1272
    660
    318
    404
    870
    1620
    2452
    3206
    3676
    3804
    3506
    2884
    2098
    1254
    608
    322
    422
    896
    1638
    2500
    3218
    3714
    3770
    3476
    2876
    2038
    1212
    598
    330
    430
    888
    1678
    2516
    3276
    3692
    3762
    3460
    2820
    2004
    1186
    588
    322
    442
    938
    1680
    2550
    3248
    3718
    3770
    3434
    2788
    1952
    1172
    564
    310
    450
    966
    1744
    2578
    3298
    3713
    3767
    3417
    2763
    1938
    1118
    556
    300
    462
    998
    1750
    2604
    3308
    3732
    3748
    3396
    2712
    1910
    1098
    508
    310
    484
    1002
    1792
    2626
    3334
    3718
    3754
    3382
    2694
    1846
    1070
    526
    306
    474
    1048
    1826
    2664
    3342
    3748
    3750
    3354
    2690
    1818
    1066
    502
    312
    516
    1062
    1856
    2678
    3384
    3752
    3742
    3336
    2640
    1818
    1012
    484
    322
    522
    1100
    1868
    2724
    3388
    3756
    3722
    3300
    2628
    1746
    976
    462
    322
    546
    1106
    1936
    2764
    3426
    3754
    3730
    3298
    2582
    1748
    974
    468
    320
    552
    1166
    1934
    2786
    3430
    3764
    3714
    3258
    2546
    1708
    952
    446
    314
    574
    1182
    1980
    2808
    3476
    3770
    3694
    3252
    2510
    1696
    912
    424
    310
    596
    1202
    2004
    2858
    3478
    3782
    3684
    3228
    2496
    1650
    902
    418
    324
    616
    1234
    2042
    2850
    3506
    3776
    3686
    3204
    2466
    1628
    860
    436
    320
    620
    1268
    2056
    2894
    3490
    3788
    3682
    3182
    2434
    1580
    852
    400
    324
    648
    1284
    2108
    2908
    3528
    3792
    3660
    3160
    2406
    1562
    828
    388
    338
    668
    1330
    2144
    2962
    3540
    3788
    3640
    3124
    2370
    1518
    798
    378
    354
    686
    1342
    2180
    2970
    3572
    3796
    3636
    3120
    2330
    1498
    776
    388
    344
    702
    1392
    2206
    3006
    3566
    3812
    3624
    3084
    2312
    1464
    768
    362
    362
    754
    1406
    2250
    3034
    3596
    3796
    3602
    3062
    2254
    1440
    742
    354
    356
    752
    1454
    2284
    3076
    3592
    3806
    3594
    3036
    2234
    1372
    728
    348
    394
    796
    1482
    2308
    3078
    3614
    3794
    3572
    3002
    2184
    1364
    688
    338
    378
    806
    1506
    2322
    3128
    3630
    3796
    3558
    2980
    2166
    1336
    686
    336
    384
    818
    1538
    2378
    3140
    3648
    3788
    3520
    2938
    2136
    1318
    660
    322
    404
    838
    1568
    2390
    3162
    3658
    3784
    3532
    2898
    2124
    1276
    638
    316
    414
    866
    1594
    2450
    3178
    3678
    3774
    3496
    2888
    2080
    1260
    614
    318
    422
    886
    1628
    2458
    3192
    3678
    3800
    3496
    2864
    2034
    1216
    612
    316
    422
    920
    1664
    2516
    3228
    3712
    3782
    3470
    2822
    2000
    1182
    578
    308
    456
    923
    1715
    2547
    3269
    3690
    3768
    3438
    2792
    1984
    1172
    574
    308
    454
    974
    1710
    2574
    3274
    3710
    3760
    3434
    2786
    1938
    1154
    540
    330
    476
    992
    1740
    2602
    3298
    3726
    3760
    3418
    2752
    1926
    1104
    538
    296
    482
    1016
    1776
    2632
    3322
    3740
    3756
    3394
    2708
    1888
    1098
    520
    310
    506
    1018
    1824
    2652
    3362
    3738
    3752
    3364
    2678
    1864
    1054
    512
    306
    506
    1056
    1834
    2694
    3364
    3742
    3746
    3342
    2678
    1806
    1024
    478
    306
    532
    1088
    1896
    2714
    3392
    3742
    3744
    3330
    2610
    1800
    1002
    484
    310
    540
    1108
    1890
    2766
    3410
    3776
    3726
    3288
    2594
    1720
    992
    466
    304
    554
    1146
    1952
    2770
    3430
    3770
    3706
    3288
    2544
    1728
    950
    448
    308
    570
    1182
    1974
    2804
    3442
    3776
    3704
    3252
    2536
    1674
    938
    440
    328
    588
    1202
    2036
    2812
    3462
    3762
    3702
    3246
    2500
    1654
    888
    428
    308
    596
    1224
    2060
    2880
    3470
    3782
    3692
    3212
    2472
    1628
    898
    422
    334
    624
    1260
    2076
    2888
    3508
    3778
    3658
    3180
    2436
    1592
    842
    422
    340
    632
    1286
    2108
    2934
    3516
    3800
    3644
    3150
    2408
    1560
    828
    370
    330
    662
    1298
    2148
    2932
    3542
    3770
    3658
    3138
    2362
    1522
    812
    402
    334
    690
    1340
    2156
    2970
    3532
    3792
    3618
    3102
    2342
    1486
    784
    374
    328
    706
    1350
    2196
    2992
    3574
    3788
    3608
    3084
    2308
    1492
    752
    366
    352
    722
    1416
    2238
    3028
    3580
    3798
    3604
    3044
    2280
    1428
    746
    360
    364
    746
    1424
    2290
    3038
    3620
    3788
    3584
    3044
    2242
    1424
    722
    350
    380
    770
    1458
    2296
    3072
    3604
    3786
    3572
    2988
    2210
    1368
    708
    356
    368
    790
    1502
    2344
    3084
    3640
    3794
    3556
    2966
    2172
    1374
    676
    336
    386
    826
    1528
    2338
    3138
    3642
    3806
    3546
    2962
    2158
    1314
    674
    348
    392
    840
    1528
    2398
    3142
    3666
    3776
    3522
    2934
    2096
    1292
    648
    328
    402
    846
    1588
    2426
    3188
    3678
    3796
    3514
    2896
    2088
    1266
    632
    336
    404
    884
    1620
    2464
    3206
    3680
    3784
    3500
    2876
    2048
    1257
    613
    323
    423
    898
    1662
    2492
    3244
    3692
    3774
    3480
    2846
    2022
    1176
    580
    322
    438
    938
    1682
    2530
    3248
    3694
    3776
    3446
    2822
    1980
    1166
    568
    312
    452
    944
    1704
    2548
    3280
    3708
    3762
    3442
    2766
    1950
    1150
    560
    322
    456
    976
    1756
    2592
    3292
    3732
    3772
    3414
    2740
    1896
    1134
    546
    312
    472
    1010
    1766
    2600
    3318
    3726
    3762
    3390
    2728
    1900
    1098
    524
    320
    496
    1024
    1782
    2660
    3328
    3732
    3748
    3368
    2686
    1850
    1074
    496
    312
    510
    1040
    1838
    2658
    3376
    3744
    3750
    3368
    2670
    1820
    1034
    492
    318
    518
    1080
    1872
    2728
    3370
    3760
    3746
    3338
    2626
    1766
    1018
    460
    312
    538
    1090
    1910
    2744
    3414
    3754
    3738
    3304
    2602
    1758
    984
    474
    308
    552
    1130
    1922
    2776
    3420
    3766
    3716
    3310
    2596
    1730
    954
    446
    312
    572
    1162
    1982
    2778
    3460
    3764
    3716
    3268
    2536
    1704
    932
    446
    322
    572
    1198
    1992
    2826
    3448
    3766
    3684
    3244
    2506
    1650
    916
    430
    314
    602
    1206
    2044
    2864
    3488
    3790
    3696
    3216
    2464
    1638
    870
    416
    326
    620
    1262
    2060
    2894
    3490
    3766
    3676
    3194
    2452
    1590
    858
    406
    344
    632
    1270
    2124
    2900
    3522
    3788
    3668
    3184
    2406
    1564
    848
    414
    330
    674
    1288
    2136
    2930
    3530
    3780
    3634
    3150
    2372
    1520
    812
    384
    342
    686
    1320
    2164
    2958
    3568
    3792
    3626
    3108
    2344
    1530
    812
    386
    338
    698
    1366
    2188
    3008
    3564
    3796
    3622
    3088
    2324
    1488
    770
    360
    358
    712
    1362
    2234
    3000
    3588
    3794
    3608
    3076
    2272
    1440
    750
    366
    362
    728
    1422
    2248
    3044
    3600
    3800
    3602
    3046
    2264
    1408
    736
    348
    356
    758
    1446
    2308
    3066
    3606
    3804
    3576
    3018
    2204
    1404
    704
    344
    370
    776
    1498
    2312
    3114
    3614
    3790
    3562
    2970
    2194
    1340
    684
    320
    394
    814
    1508
    2370
    3112
    3646
    3780
    3528
    2964
    2168
    1312
    678
    340
    398
    814
    1560
    2374
    3158
    3644
    3788
    3540
    2920
    2124
    1300
    668
    320
    400
    854
    1582
    2436
    3172
    3680
    3785
    3515
    2907
    2089
    1282
    620
    314
    408
    872
    1596
    2452
    3200
    3682
    3798
    3504
    2884
    2080
    1226
    626
    326
    408
    902
    1628
    2490
    3214
    3682
    3778
    3472
    2840
    2032
    1220
    588
    326
    438
    910
    1698
    2514
    3248
    3688
    3774
    3460
    2832
    1980
    1188
    596
    314
    438
    964
    1694
    2550
    3264
    3716
    3770
    3432
    2798
    1980
    1158
    562
    310
    458
    958
    1740
    2562
    3306
    3728
    3770
    3406
    2748
    1936
    1122
    552
    302
    470
    990
    1738
    2610
    3310
    3736
    3744
    3406
    2744
    1896
    1096
    532
    320
    492
    1010
    1804
    2634
    3342
    3732
    3750
    3384
    2682
    1848
    1062
    524
    310
    500
    1038
    1830
    2682
    3344
    3746
    3744
    3370
    2674
    1822
    1064
    482
    326
    520
    1066
    1880
    2680
    3402
    3746
    3734
    3318
    2650
    1810
    998
    482
    304
    530
    1096
    1886
    2742
    3392
    3776
    3736
    3314
    2608
    1750
    968
    460
    316
    546
    1118
    1926
    2748
    3430
    3762
    3722
    3288
    2584
    1734
    974
    466
    324
    548
    1154
    1954
    2792
    3430
    3768
    3706
    3270
    2540
    1712
    956
    452
    314
    584
    1172
    1992
    2816
    3458
    3768
    3696
    3268
    2506
    1690
    914
    432
    320
    604
    1206
    2026
    2864
    3458
    3784
    3694
    3226
    2504
    1640
    902
    420
    314
    620
    1234
    2050
    2874
    3506
    3770
    3674
    3206
    2468
    1616
    874
    414
    324
    620
    1270
    2088
    2910
    3500
    3786
    3664
    3180
    2430
    1574
    848
    404
    338
    650
    1298
    2124
    2926
    3538
    3800
    3636
    3152
    2386
    1548
    840
    386
    338
    676
    1326
    2166
    2960
    3534
    3802
    3644
    3134
    2366
    1512
    792
    380
    342
    696
    1340
    2206
    2978
    3562
    3790
    3620
    3102
    2336
    1466
    770
    364
    366
    706
    1386
    2212
    3016
    3566
    3788
    3612
    3056
    2298
    1448
    762
    360
    348
    728
    1420
    2252
    3038
    3596
    3780
    3604
    3046
    2260
    1438
    736
    356
    362
    750
    1436
    2288
    3074
    3590
    3792
    3578
    3020
    2258
    1404
    698
    346
    362
    780
    1480
    2330
    3080
    3624
    3788
    3582
    3008
    2204
    1348
    688
    350
    380
    784
    1506
    2344
    3132
    3628
    3794
    3550
    2966
    2180
    1342
    666
    336
    406
    824
    1543
    2381
    3121
    3645
    3786
    3542
    2948
    2132
    1326
    650
    330
    396
    846
    1560
    2398
    3192
    3650
    3800
    3518
    2908
    2102
    1254
    650
    312
    390
    868
    1598
    2446
    3192
    3660
    3772
    3498
    2906
    2066
    1244
    616
    322
    422
    888
    1650
    2458
    3234
    3672
    3778
    3480
    2848
    2038
    1216
    604
    334
    426
    916
    1654
    2514
    3226
    3702
    3770
    3468
    2840
    1996
    1186
    568
    312
    436
    934
    1698
    2514
    3270
    3714
    3768
    3442
    2804
    1984
    1164
    580
    308
    440
    964
    1724
    2566
    3274
    3710
    3746
    3426
    2778
    1924
    1142
    548
    314
    466
    964
    1766
    2592
    3304
    3728
    3760
    3388
    2750
    1908
    1120
    540
    296
    474
    1018
    1776
    2626
    3324
    3742
    3740
    3378
    2716
    1868
    1078
    508
    312
    490
    1040
    1820
    2648
    3360
    3730
    3756
    3364
    2678
    1850
    1038
    510
    300
    516
    1072
    1854
    2706
    3352
    3756
    3728
    3336
    2656
    1798
    1020
    474
    316
    530
    1096
    1884
    2724
    3380
    3762
    3716
    3334
    2612
    1776
    992
    482
    314
    532
    1098
    1910
    2746
    3404
    3766
    3716
    3314
    2588
    1744
    998
    458
    310
    572
    1128
    1944
    2762
    3438
    3760
    3716
    3274
    2538
    1734
    942
    432
    322
    566
    1172
    1962
    2804
    3440
    3766
    3700
    3250
    2560
    1668
    930
    436
    330
    604
    1180
    2018
    2814
    3478
    3768
    3704
    3236
    2510
    1652
    888
    424
    326
    618
    1210
    2034
    2872
    3478
    3794
    3690
    3206
    2468
    1610
    888
    418
    330
    626
    1244
    2070
    2866
    3494
    3780
    3664
    3186
    2418
    1606
    852
    404
    318
    646
    1304
    2096
    2924
    3520
    3778
    3638
    3170
    2412
    1550
    832
    402
    330
    682
    1312
    2168
    2956
    3542
    3796
    3636
    3136
    2366
    1528
    812
    400
    344
    686
    1354
    2172
    2996
    3548
    3790
    3642
    3110
    2338
    1488
    790
    366
    338
    720
    1368
    2188
    2992
    3574
    3784
    3620
    3086
    2300
    1464
    762
    362
    346
    730
    1416
    2226
    3026
    3576
    3794
    3596
    3048
    2266
    1428
    740
    354
    354
    746
    1434
    2288
    3058
    3608
    3786
    3590
    3046
    2250
    1400
    720
    346
    368
    762
    1452
    2302
    3086
    3606
    3794
    3588
    3004
    2234
    1364
    707
    363
    385
    799
    1504
    2344
    3076
    3620
    3778
    3576
    2972
    2184
    1348
    676
    344
    386
    816
    1520
    2366
    3134
    3644
    3790
    3528
    2962
    2158
    1310
    654
    324
    400
    828
    1540
    2408
    3140
    3648
    3766
    3518
    2918
    2102
    1282
    656
    334
    398
    864
    1580
    2430
    3176
    3660
    3772
    3512
    2892
    2072
    1222
    632
    324
    410
    898
    1602
    2464
    3194
    3690
    3780
    3486
    2876
    2050
    1238
    608
    326
    428
    900
    1646
    2482
    3242
    3676
    3778
    3464
    2830
    2026
    1180
    586
    312
    438
    942
    1684
    2528
    3260
    3702
    3776
    3456
    2818
    1984
    1178
    576
    316
    448
    954
    1700
    2530
    3274
    3702
    3770
    3428
    2784
    1946
    1116
    564
    314
    468
    974
    1740
    2602
    3294
    3732
    3758
    3420
    2736
    1924
    1130
    552
    318
    476
    990
    1780
    2608
    3326
    3716
    3758
    3390
    2702
    1900
    1090
    528
    294
    504
    1036
    1808
    2656
    3336
    3740
    3740
    3372
    2698
    1860
    1064
    506
    314
    498
    1040
    1842
    2670
    3362
    3746
    3740
    3342
    2662
    1824
    1032
    506
    320
    510
    1090
    1852
    2710
    3380
    3758
    3726
    3320
    2626
    1776
    1022
    468
    306
    542
    1092
    1906
    2740
    3402
    3758
    3728
    3310
    2576
    1786
    990
    472
    306
    550
    1148
    1930
    2770
    3426
    3774
    3704
    3288
    2584
    1718
    960
    444
    308
    588
    1144
    1980
    2786
    3450
    3766
    3702
    3270
    2532
    1696
    922
    450
    314
    584
    1184
    1992
    2834
    3452
    3774
    3696
    3232
    2518
    1650
    920
    432
    318
    602
    1216
    2040
    2858
    3480
    3766
    3680
    3206
    2472
    1626
    884
    426
    328
    610
    1258
    2040
    2892
    3498
    3786
    3664
    3190
    2454
    1584
    854
    402
    330
    648
    1276
    2108
    2880
    3524
    3786
    3666
    3168
    2416
    1582
    842
    404
    336
    660
    1304
    2140
    2938
    3528
    3798
    3646
    3140
    2390
    1522
    822
    378
    326
    694
    1332
    2188
    2942
    3552
    3786
    3628
    3112
    2364
    1520
    778
    368
    344
    688
    1358
    2186
    3000
    3568
    3790
    3628
    3102
    2316
    1480
    762
    374
    340
    734
    1400
    2226
    3000
    3586
    3776
    3610
    3076
    2270
    1436
    750
    368
    362
    728
    1418
    2250
    3058
    3586
    3796
    3607
    3027
    2255
    1379
    722
    350
    368
    764
    1438
    2288
    3082
    3622
    3800
    3572
    3012
    2202
    1400
    718
    358
    364
    804
    1514
    2354
    3138
    3642
    3786
    3554
    3016
    2244
    1388
    732
    348
    366
    818
    1528
    2416
    3156
    3666
    3786
    3530
    2956
    2160
    1336
    684
    352
    362
    796
    1524
    2382
    3162
    3652
    3796
    3520
    2920
    2112
    1286
    674
    342
    392
    838
    1574
    2422
    3158
    3670
    3778
    3516
    2908
    2090
    1282
    642
    326
    412
    868
    1596
    2458
    3204
    3696
    3774
    3494
    2884
    2068
    1224
    614
    320
    430
    900
    1620
    2490
    3218
    3698
    3774
    3478
    2844
    2012
    1194
    588
    320
    432
    902
    1670
    2506
    3246
    3684
    3764
    3452
    2802
    1974
    1168
    582
    310
    452
    960
    1706
    2554
    3252
    3702
    3760
    3430
    2802
    1956
    1154
    548
    318
    450
    976
    1744
    2568
    3296
    3718
    3764
    3410
    2740
    1926
    1140
    550
    308
    474
    998
    1754
    2612
    3294
    3718
    3746
    3396
    2726
    1884
    1092
    510
    316
    484
    1008
    1794
    2638
    3324
    3716
    3750
    3388
    2702
    1856
    1064
    522
    328
    500
    1052
    1818
    2682
    3350
    3748
    3740
    3362
    2666
    1810
    1052
    492
    312
    520
    1078
    1874
    2704
    3372
    3756
    3728
    3338
    2632
    1806
    1024
    480
    306
    520
    1086
    1870
    2734
    3388
    3770
    3714
    3318
    2602
    1746
    1004
    486
    320
    546
    1122
    1934
    2742
    3424
    3752
    3720
    3298
    2572
    1742
    960
    454
    306
    568
    1156
    1960
    2804
    3428
    3776
    3706
    3266
    2566
    1704
    952
    442
    324
    588
    1188
    2002
    2820
    3472
    3778
    3708
    3240
    2502
    1694
    916
    436
    314
    596
    1224
    2016
    2860
    3468
    3778
    3682
    3208
    2498
    1638
    896
    416
    326
    618
    1220
    2078
    2872
    3502
    3768
    3676
    3200
    2436
    1626
    852
    420
    322
    618
    1272
    2078
    2910
    3512
    3786
    3668
    3174
    2438
    1576
    862
    410
    332
    662
    1290
    2134
    2934
    3536
    3798
    3648
    3152
    2380
    1540
    810
    380
    332
    684
    1336
    2158
    2964
    3534
    3800
    3650
    3120
    2366
    1500
    816
    380
    352
    700
    1354
    2190
    2972
    3576
    3778
    3624
    3086
    2324
    1484
    778
    370
    352
    712
    1392
    2219
    3025
    3571
    3793
    3606
    3076
    2290
    1426
    764
    362
    354
    740
    1406
    2272
    3040
    3598
    3782
    3596
    3052
    2264
    1432
    726
    346
    358
    746
    1454
    2280
    3082
    3610
    3790
    3586
    3014
    2230
    1378
    698
    348
    370
    790
    1456
    2320
    3078
    3618
    3788
    3562
    3012
    2166
    1352
    682
    356
    380
    808
    1510
    2348
    3132
    3646
    3800
    3546
    2960
    2146
    1322
    688
    348
    384
    824
    1526
    2390
    3134
    3658
    3794
    3534
    2944
    2120
    1320
    658
    328
    406
    848
    1584
    2398
    3180
    3662
    3784
    3528
    2916
    2120
    1260
    650
    326
  • Matteo,
    Are you doing ADC core calibration? See sections 7.3.2.2 and 7.4.7 of the data sheet. What data is in your first attachment? It is not clear to me.
    Jim
  • Hi Jim,
    yes, i apply a foreground calibration before starting the data acquisition.
    In my first mail i have attached the fft plot for an input signal at 3691.406 MHz and in the second mail i have attached the data acquisition of this input signal.
    Matteo
  • Matteo,
    After analyzing your data, it appears there may be an issue with the analog timing. If you are running in foreground calibration mode and using the CHA input, try adjusting the two interleaved CHA ADC timing registers, 0x314 and 0x315. I would just start with raising and lowering from the default value of one of these by 16 bits at a time while observing the data.
    Jim
