Are there any updates on the AWG chip with NVM? I would like to see if it will fit our design still, there is a good chance we can include it if I could access some design files or spec sheet. Thanks!
Ashwati
Hi Krishnan,
We do not have a device that does truly arbitrary waveform generation, but we do have some that have a subset of functions that can be supported. Take a look at the DAC53701.
If you need higher resolution, then you can look at some of our high precision devices that can be used for AWG, but you would need to stream the data to DAC. See the DAC8811 or the DAC11001A.
Paul
Thank you Paul. I had asked because in an earlier thread there was a mention of such a chip (link here: https://e2e.ti.com/support/data-converters/f/73/t/950228
