Other Parts Discussed in Thread: LMK04828
Dear Srs.
I'm trying to build up an acquisition system for phased array application. The system architecture is composed by 2 ADS54J60EVM boards (Dual-Channel, 16-Bit, 1.0-GSPS), each connected to a different FPGA carrier board.
I've already read that a synchronization between the 2 subsystems is possible using a common, 10MHz reference input signal (with matched cables length) fed to LMK04828 devices, as to generate synchronous and phase matched sample clocks and SYSREFs. It is correct?
Once implemented this scheme, how it's possible to merge data acquired from the 2 different subsystems? How can I synchronize JESD204B frames from the different FPGA boards?
Thanks in advance for the availability
Best Regars
