PCM1794 (1792) MONO - CONNECTION?
Hi All.
There are two option of the MONO connection:
1) To use separate I/U for each output (L+.L-, R+,R-), then 2 diff.amps (O1=L+ - L- and O2=R+ - R-), and then O=O1-O2.  Like in datasheet
2) To connect L+ with R+,  L- with R-, thento  use 2 I/V and then one diff.amp.
What is better?  I thnk: less stages=less distorions, less noise.
  • Hi, Alto,
    We have optimized performance with the recommendations in the data sheet. I suggest that you follow our recommendations.
    -d2
  • Hi Don,
    Did you try the second method, or this is only the supposition ?
    According to my (and not only my) experience, for the regular (not mono) appliction, there are a lot of output schematics, that works 10 times better then schematic from datsheet. For example - using much better OP then old and cheap 5534, also using FDA in I/V and other solutions. Datasheet is only example, "at least is works"...
    But for mono mode - I don't know.
    Theoretically, It should be no difference, but who knows?
    Alto.
  • So, did anybody tried to connect DAC's output together in mono mode?
