Blow is the picture of the problem.The output noise is vevy big.
HI,
It seems you are using the headphone output of the 'AIC3204. When these outputs are used, we recommend to use a low-pass RC filter when using test equipment, like oscilloscopes, to make audio noise measurements. Is it possible to add a similar filter to make the noise analysis?, we use the following filter in our EVM:
-Diego Meléndez López
Audio Applications Engineer
