Other Parts Discussed in Thread: IWR1642, , TSW14J57EVM, DATACONVERTERPRO-SW, ADC12DJ3200EVM
Tool/software: Linux
Is this device can be used for support Ku band? If not which one can support Ku and Ka band?
Hi Hong
I'm not aware of any K band radar solutions, but a different group at TI has several higher frequency products targeted at Automotive and Industrial radar:
http://www.ti.com/sensing-products/mmwave/awr/overview.html
http://www.ti.com/sensing-products/mmwave/iwr/overview.html
I hope this is helpful.
Jim B
Hi Jim,
Thanks for the info, is this chip IWR1642: Small, high performance single chip radar can be used for KU band 12-16GHz operation frequency using FMCW technique for range estimation?
Hong
Hi Jim,
Is there any TI product solution to support Ku band radar?
Hong
Hi Hong
I have not identified any TI high speed ADC or integrated radar products which can directly support Ku band frequencies.
At a minimum, some frequency down-conversion would be needed to allow usage of the currently available ADCs. None of the TI RF up/down-converting mixers support K band frequencies, so non-TI solution would be needed for this portion of the signal chain.
Jim B
Hi Martin
The hardware platform used for TIDA-01442 consists of the ADC12DJ3200EVM and TSW14J57EVM capture platform. The standard ADC EVM GUI was used to configure the ADC board, while the High Speed Data Converter Pro (DATACONVERTERPRO-SW) software platform was used for capture board control and data analysis.
If you want to buy a single unit for testing and evaluation purposes the boards can be obtained at the links above.
If you want to buy large quantities then you will need to engage with a third party vendor. Unfortunately I'm not aware of any publicly available products from our customers.
Jim B
