I'm installing code composer studio 4 and it appears this error " bad end of central directory record".
How can I solve this?
And after it appears this:
Error in action ExecuteAction
Error in action UnzipFile
error copying "/installjammervfs1/jre/lib/deploy/ffjcext.zip" to "C:/Program Files/Texas Instruments/ccsv4/eclipse/jre/lib/deploy/ffjcext.zip": permission denied
while executing
"file copy -force $file $new"
(procedure "::InstallJammer::actions::UnzipFile" line 75)
invoked from within
"::InstallJammer::actions::$component $this"
while executing
"$obj execute"
(procedure "::InstallJammer::ExecuteActions" line 62)
invoked from within
"::InstallJammer::ExecuteActions $action -parent $id -conditions $eval"
(procedure "::InstallJammer::actions::ExecuteAction" line 35)
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
invoked from within
while executing
"$obj execute"
invoked from within
"::InstallJammer::ExecuteActions $id -when $when"
(procedure "::InstallJammer::RaiseEventHandler" line 79)
invoked from within
"::InstallJammer::RaiseEventHandler .wizard"
(command bound to event)
Pedro,
This is an installer issue, and it is usually caused by a corrupt download. Can you send the the exact version you downloaded and the .zip file size? Also, if you can get the MD5 sum of the file you can verify its integrity (I can run it here as well and we compare both values).
Rafael
Pedro,
By the size of the file I see you downloaded CCSv4.2.3.00004. Can you compare the MD5 sum with the one I obtained below using the Microsoft utility? Maybe the file has the same size but it became corrupt somehow.
Cheers,
Rafael
5773.setup_CCS_4.2.3.00004.zip.md5
