Hi!
Is there a possibility in Code Composter 5.2 in the debug view to change the default number format?
The standard value in the Variables View is ASCII and so far I always have to manually change every new variable to HEX.
Hi!
Check the attached screen; you can click on the small triangle at the top right of the Expressions view and set the preferred default format.
Hope this helps,
Rafael
