Other Parts Discussed in Thread: TMS320F2812
I’m having a problem setting breakpoints using the CCS 5 debugger where, despite not having any other breakpoints being set (including ‘Halt at program termination’ and ‘Enable CIO function use’) as not to exceed the JTAG debugger’s 2 breakpoint limit, attempting to set a breakpoint results in failure with the display of a dialog bearing the message:
Error programming AET Job: This task cannot be accomplished with the existing AET resources.
Further, on start, the message "C28xx: AutoRun: Target not run as breakpoint could not be set: Error programming AET Job: ANA_ENABLE Register write failed” appears in the console.
Target device is a TMS320F2812.
Thoughts on what can correct this? I'll verify if there's power to the target or needs resetting. This error message sounds like this could be the case reading other threads.
Thanks in advance.
