I just did the update option to get my installation of CCS to 5.2.1.00018. Everything thing appears to work fine, until a hit the "Project -> Build All" button. Then I get the following error message:
Errors occurred during the build.
Errors running builder 'CDT Builder' on project 'ccm_sysbios'.
Generated resource conflict:
two resources of the same name: /ccm_sysbios/Debug/.metadata/.plugins/org.eclipse.cdt.make.core/specs.obj
generated by different tools
tool1: C2000 Compiler
tool2: C2000 Compiler
...I can build successfully if I do a "Project -> Clean...", or wipe my "Debug" build directory. But then it comes back again when trying the "Build All". Everything was working correctly under CCS 5.1.1. I find it interesting that it appears to be complaing about a specs.obj file that doesn't exist. The issue might also be related to the one described here:
http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/p/203656/726567.aspx
...the "fixes" described in that thread don't seem to work, especially since I don't have a .gconf directory anywhere. Also of interest is that those files have nothing to do with what I want to build, and the specs.c and specs.cpp that are in my workspace are empty (1-byte) files. I have a work-around, in the form of building clean each time, but I wonder if anyone else is having a similar problem, or know the proper fix.
Greg
