We are running SYS/BIOS with NDK on our production board using the CPSW interface. Our current software versions:
Processor AM3352
Code Composer Version: 6.0.1.00040
Compiler TI v5.1.6
SYS/BIOS 6.40.3.39
XDCTools 3.30.3.47_core
NDK 2.24.0.11
System Analyzer (UIA Target) 1.3.1.08
We are currently having issues with the NDK and have rebuilt a copied version for testing. After getting the test version of the NDK into the project properties by loading it trough Window-->Preferences--> Code Composer Stdio-->RTSC-->Products, we began to get compile failures because the xdcpath was not set to the current directory specified in the Project properties-->CCS Build-->XDCtools. When we look in the .cproject file at the top level of the project directory tree I can see the incorrect path being shown under the "fileInfo id". When I look under the project properties CCS Build-->XDCTools, the xdcpath looks correct. Why doesn't the .cproject file get updated correctly?
John C.
Compiler error showing incorrect path to ndk------------------------------------------------------------------------------------------------
**** Build of configuration Debug for project AIRtrac_sysbios ****
"C:\\ti\\ccsv6\\ccsv6\\utils\\bin\\gmake" -k all
'Building file: ../airtrac.cfg'
'Invoking: XDCtools'
"C:/ti/ccsv6/xdctools_3_30_03_47_core/xs" --xdcpath="C:/ti/uia_1_03_01_08/packages;C:/ti/am335x_sysbios_ind_sdk_1.1.0.5/sdk/platform;C:/ti/ccsv6/ccsv6/ccs_base;C:/ti/bios_6_40_03_39/packages;C:/ti/nsp_1_10_02_09/packages;C:/ti/ndk_2_24_00_11_copy/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.A8Fnv -p AIRtrac_1 -r debug -c "C:/ti/ccsv6/ccsv6/tools/compiler/arm_5.1.6" --compileOptions "-g --optimize_with_debug" "../airtrac.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring airtrac.xea8fnv from package/cfg/airtrac_pea8fnv.cfg ...
js: "C:/Users/jconover/workspace_v6_1/AIRtrac_sysbios/airtrac.cfg", line 25: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'ti.ndk.config' along the path: 'C:/ti/uia_1_03_01_08/packages;C:/ti/am335x_sysbios_ind_sdk_1.1.0.5/sdk/platform;C:/ti/ccsv6/ccsv6/ccs_base;C:/ti/bios_6_40_03_39/packages;C:/ti/nsp_1_10_02_09/packages;C:/ti/ndk_2_24_00_11_copy/packages;C:/ti/ccsv6/xdctools_3_30_03_47_core/packages;..;'. Ensure that the package path is set correctly.
"./package/cfg/airtrac_pea8fnv.cfg", line 195
gmake.exe: *** [package/cfg/airtrac_pea8fnv.xdl] Error 1
Warning: directory "C:/ti/ndk_2_24_00_11_copy/packages" on package path does not exist
js: "C:/ti/ccsv6/xdctools_3_30_03_47_core/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
making ../src/sysbios/sysbios.aea8fnv ...
gmake[1]: Entering directory `C:/Users/.../workspace_v6_1/AIRtrac_sysbios/src/sysbios'
clea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/BIOS.c ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/TaskSupport_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/exc/Exception_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/a8/TimestampProvider_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/a8/Mmu_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/a8/Cache_asm.asm ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm.s470 ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/family/arm/a8/intcps/Hwi_asm_switch.s470 ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/timers/gptimer/Timer_asm.s470 ...
asmea8fnv C:/ti/bios_6_40_03_39/packages/ti/sysbios/timers/dmtimer/Timer_asm.s470 ...
area8fnv BIOS.obj arm_IntrinsicsSupport_asm.obj arm_TaskSupport_asm.obj exc_Exception_asm.obj a8_TimestampProvider_asm.obj a8_Mmu_asm.obj a8_Cache_asm.obj intcps_Hwi_asm.obj intcps_Hwi_asm_switch.obj gptimer_Timer_asm.obj dmtimer_Timer_asm.obj ...
gmake[1]: Leaving directory `C:/Users/.../workspace_v6_1/AIRtrac_sysbios/src/sysbios'
gmake: Target `all' not remade because of errors.
From the .cproject file, the NDK directory is incorrect ---------------------------------------------------------------------------
<fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.367402827.582417462" name="airtrac.cfg" rcbsApplicability="disable" resourcePath="airtrac.cfg" toolsToInvoke="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.686796931.1289797647">
<tool id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.686796931.1289797647" name="XDCtools" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.686796931">
<option id="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH.945835473" name="Package repositories (--xdcpath)" superClass="com.ti.rtsc.buildDefinitions.XDC_3.16.tool.XDC_PATH" valueType="stringList">
<listOptionValue builtIn="false" value=""${COM_TI_UIA_INSTALL_DIR}/packages""/>
<listOptionValue builtIn="false" value=""C:\ti\am335x_sysbios_ind_sdk_1.1.0.5\sdk\platform""/>
<listOptionValue builtIn="false" value=""${TARGET_CONTENT_BASE}""/>
<listOptionValue builtIn="false" value=""${BIOS_CG_ROOT}/packages""/>
<listOptionValue builtIn="false" value=""${NSP_INSTALL_DIR}/packages""/>
<listOptionValue builtIn="false" value=""C:\ti\ndk_2_24_00_11_copy\packages""/>
</option>
</tool>
<tool customBuildStep="true" id="org.eclipse.cdt.managedbuilder.ui.rcbs.1706620786" name="Resource Custom Build Step">
<inputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.inputtype.991487736" name="Resource Custom Build Step Input Type">
<additionalInput kind="additionalinputdependency" paths=""/>
</inputType>
<outputType id="org.eclipse.cdt.managedbuilder.ui.rcbs.outputtype.1105796459" name="Resource Custom Build Step Output Type"/>
</tool>
</fileInfo>
Current Project settings showing the correct xdcpath:
