Problems building with CCS 4.1 in command line. Appears after I upgraded from CCS 4.0 to CCS. 4.1.
Other Parts Discussed in Thread: CCSTUDIO, CODECOMPOSER
I got it to work again by  reinstalling CCS 4.0, but I need the features in CCS 4.1.
The command is run on Windows XP PC in a DOS prompt:
java -jar "C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar" -data "C:\Workspace\VALHAL_MC_DSP" -application com.ti.ccstudio.apps.projectBuild -ccs.workspace
The compilation succeed when a run it within the CCS 4.1 GUI with the same workspace. I have close the CCS 4.1 program before I run the command line.
The error list:
org.eclipse.core.internal.resources.ResourceException: Errors during build.
at org.eclipse.core.internal.resources.Project.build(Project.java:91)
at com.ti.ccstudio.apps.project.Build.buildProjects(Build.java:246)
at com.ti.ccstudio.apps.project.Build.doRun(Build.java:104)
at com.ti.ccstudio.apps.project.BaseHeadlessApp$1.run(BaseHeadlessApp.java:168)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1737)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1719)
at com.ti.ccstudio.apps.project.BaseHeadlessApp.internalRun(BaseHeadlessApp.java:166)
at com.ti.ccstudio.apps.project.BaseHeadlessApp.run(BaseHeadlessApp.java:136)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:996)
at org.eclipse.core.launcher.Main.main(Main.java:971)
CCS configuration:
*** Date: Thu Apr 22 13:28:08 CEST 2010
*** Platform Details:
*** System properties:
DEFAULT_CCS_TARGET_CONFIGURATION=
XPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
awt.toolkit=sun.awt.windows.WToolkit
deployment.browser.args=-raise -remote openURL(%u,new-window)
deployment.browser.path=C:\Program Files\Internet Explorer\IEXPLORE.EXE
deployment.cache.jarcompression=0
deployment.cache.max.size=-1
deployment.capture.mime.types=false
deployment.console.startup.mode=HIDE
deployment.control.panel.log=false
deployment.home.j2se.url=http://java.sun.com/j2se/
deployment.javapi.cache.enabled=true
deployment.javapi.cache.update=true
deployment.javapi.lifecycle.exception=false
deployment.javapi.log.filename=
deployment.javapi.runtime.type=0
deployment.javapi.trace.filename=
deployment.javaws.associations=ASK_USER
deployment.javaws.autodownload=ALWAYS
deployment.javaws.home.jnlp.url=http://java.sun.com/products/javawebstart
deployment.javaws.installURL=http://java.sun.com/products/autodl/j2se
deployment.javaws.logFileName=
deployment.javaws.muffin.max=256
deployment.javaws.shortcut=ASK_IF_HINTED
deployment.javaws.ssv.enabled=true
deployment.javaws.traceFileName=
deployment.javaws.uninstall.shortcut=false
deployment.javaws.update.timeout=1500
deployment.log=false
deployment.mime.types.use.default=true
deployment.proxy.bypass.local=false
deployment.proxy.override.hosts=
deployment.proxy.same=false
deployment.proxy.type=3
deployment.repository.askdownloaddialog.show=true
deployment.repository.enabled=true
deployment.security.SSLv2Hello=true
deployment.security.SSLv3=true
deployment.security.TLSv1=false
deployment.security.askgrantdialog.notinca=true
deployment.security.askgrantdialog.show=true
deployment.security.authenticator=true
deployment.security.browser.keystore.use=true
deployment.security.clientauth.keystore.auto=true
deployment.security.jsse.hostmismatch.warning=true
deployment.security.sandbox.awtwarningwindow=true
deployment.security.sandbox.jnlp.enhanced=true
deployment.security.trusted.policy=
deployment.system.security.cacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\cacerts
deployment.system.security.jssecacerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\jssecacerts
deployment.system.security.trusted.certs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.certs
deployment.system.security.trusted.clientauthcerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.clientcerts
deployment.system.security.trusted.jssecerts=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\security\trusted.jssecerts
deployment.trace=false
deployment.update.mime.types=true
deployment.user.cachedir=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\cache
deployment.user.extdir=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\ext
deployment.user.logdir=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\log
deployment.user.security.policy=file://C:/Documents%20and%20Settings/pphilips/Application%20Data/Sun/Java/Deployment/security/java.policy
deployment.user.security.trusted.cacerts=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\security\trusted.cacerts
deployment.user.security.trusted.certs=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\security\trusted.certs
deployment.user.security.trusted.clientauthcerts=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\security\trusted.clientcerts
deployment.user.security.trusted.jssecacerts=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\security\trusted.jssecacerts
deployment.user.security.trusted.jssecerts=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\security\trusted.jssecerts
deployment.user.tmp=C:\Documents and Settings\pphilips\Application Data\Sun\Java\Deployment\tmp
deployment.version=6.0
eclipse.buildId=4.1.1.00014
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
f70_173c
-clean
-data
/C:/Workspace/Projects/
-vm
C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=com.ti.ccstudio.branding.product
eclipse.startTime=1271935201369
eclipse.vm=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=yes
-Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=file:///emeafpthorkol/users/pphilips/workspace/
-jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\endorsed
java.ext.dirs=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\ext
java.home=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre
java.io.tmpdir=C:\DOCUME~1\pphilips\LOCALS~1\Temp\1\
java.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:/Program Files/Texas Instruments/xdctools_3_15_02_62;C:\Xilinx\11.1\ChipScope\bin\nt;C:\Xilinx\11.1\common\bin\nt;C:\Xilinx\11.1\common\lib\nt;C:\Xilinx\11.1\EDK\bin\nt;C:\Xilinx\11.1\EDK\lib\nt;C:\Xilinx\11.1\PlanAhead\bin;C:\Xilinx\11.1\ISE\bin\nt;C:\Xilinx\11.1\ISE\lib\nt;C:\Program Files\PHP\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Subversion\bin;C:\Program Files\Java\jdk1.6.0_12\bin;C:\Program Files\GrammaTech\CodeSonar\codesonar\bin;C:\jdk1.6.0_03\bin;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\;c:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\WINDOWS\system32\WindowsPowerShell\v1.0;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Dev-Cpp\bin\;C:\Program Files\TortoiseSVN\bin;C:/Program Files/Texas Instruments/xdctools_3_15_02_62;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\emulation\analysis\bin\
java.net.useSystemProxies=true
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_14-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_14
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_14-b03
javaplugin.proxy.config.type=direct
line.separator=
org.eclipse.ui.workbench.activePerspective=org.eclipse.cdt.ui.CPerspective
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=da
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=com.ti.ccstudio.osgi,org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles
osgi.clean=true
osgi.configuration.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/
osgi.framework=file:/c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201002091800.jar
osgi.framework.beginningstartlevel=1
osgi.framework.extensions=com.ti.ccstudio.osgi
osgi.framework.shape=jar
osgi.framework.version=3.2.0.vTI-201002091800
osgi.frameworkClassPath=., file:c:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201002091800.jar
osgi.install.area=file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/
osgi.instance.area=file:/C:/Workspace/Projects/
osgi.instance.area.default=file://emeafpthorkol/users/pphilips/workspace/
osgi.logfile=C:\Workspace\Projects\.metadata\.log
osgi.manifest.cache=C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\manifests
osgi.nl=da_DK
osgi.os=win32
osgi.splashLocation=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins\com.ti.ccstudio.branding_4.1.0.201002091800\splash.bmp
osgi.splashPath=platform:/base/plugins/com.ti.ccstudio.branding
osgi.syspath=c:\Program Files\Texas Instruments\ccsv4\eclipse\plugins
osgi.user.area=file:/C:/Documents and Settings/pphilips/user/
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\rt.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\i18n.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\sunrsasign.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jsse.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\jce.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\lib\charsets.jar;C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\classes
sun.boot.library.path=C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.java.launcher=SUN_STANDARD
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=60000
sun.net.client.defaultReadTimeout=60000
sun.os.patch.level=Service Pack 2
user.country=DK
user.dir=C:\Program Files\Texas Instruments\ccsv4\eclipse
user.home=C:\Documents and Settings\pphilips
user.language=da
user.name=pphilips
user.timezone=Europe/Paris
user.variant=
*** Features:
com.ti.ccstudio (4.0.0.201002091800) "CCE Product Branding"
com.ti.dvt.graph.visualization (1.0.0.200911121836) "Visualization Plug-in"
com.ti.dvt.profileanalysismanager (1.0.0.200911121836) "Profiler Analysis Manager"
com.ti.dvt.rta (1.0.0.200911121836) "DSP/BIOS RTA"
com.ti.dvt.scripting.ui (4.0.0.200911121836) "DVT Scripting Plugin"
com.xdais_6_23 (6.23.0) "XDAIS 6.23 Help"
org.eclipse.cdt (3.1.0.vTI-201002091800) "Eclipse C/C++ Development Tools"
org.eclipse.platform (3.2.0.vTI-201002091800) "Eclipse Platform"
org.eclipse.rcp (3.2.0.vTI-201002091800) "Eclipse RCP"
org.eclipse.rtsc.xdctools (3.15.2.62) "RTSC/XDCtools"
org.eclipse.tm.terminal (1.0.0.vTI-201002091800) "Target Management Terminal Widget"
*** Plug-in Registry:
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.ti.bios.rta (5.40.2.22) "BIOS 5 RTA Plug-in" [Resolved]
com.ti.bios.rtscRegistry_5.40.2.22 (5.40.2.22) "BIOS 5.40.02.22 Help" [Resolved]
com.ti.ccstudio.apps (4.0.0.200907161600) "CCS Headless Applications" [Installed]
com.ti.ccstudio.apps (4.1.1.201002091800) "CCS Headless Applications" [Resolved]
com.ti.ccstudio.binaryparser (4.0.0.200907161600) "CCE Binary Parser" [Installed]
com.ti.ccstudio.binaryparser (4.0.0.201002091800) "CCE Binary Parser" [Resolved]
com.ti.ccstudio.branding (4.0.0.200907161600) "CCE Product Branding" [Installed]
com.ti.ccstudio.branding (4.1.0.201002091800) "CCE Product Branding" [Active]
com.ti.ccstudio.breakpoint (4.0.0.200907161600) "Property Breakpoint Interfaces" [Installed]
com.ti.ccstudio.breakpoint (4.0.0.201002091800) "Property Breakpoint Interfaces" [Resolved]
com.ti.ccstudio.breakpoint.core (4.0.0.200907161600) "Property Breakpoint Core" [Installed]
com.ti.ccstudio.breakpoint.core (4.0.0.201002091800) "Property Breakpoint Core" [Resolved]
com.ti.ccstudio.breakpoint.ui (4.0.0.200907161600) "Property Breakpoint User Interface" [Installed]
com.ti.ccstudio.breakpoint.ui (4.0.0.201002091800) "Property Breakpoint User Interface" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000 (4.0.0.200907161600) "CCE C2000 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000 (4.1.0.201002091800) "CCS C2000 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C2000_4.1 (4.0.0.200907161600) "CCE C2000 v4.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_4.1 (4.1.0.201002091800) "CCE C2000 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.0 (4.0.0.200907161600) "CCE C2000 v5.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.0 (4.1.0.201002091800) "CCE C2000 v5.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.1 (4.0.0.200907161600) "CCE C2000 v5.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.1 (4.1.0.201002091800) "CCE C2000 v5.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_5.2 (4.0.0.200907161600) "CCE C2000 v5.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_5.2 (4.1.0.201002091800) "CCE C2000 v5.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C2000_legacy (4.0.0.200907161600) "CCS C2000 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C2000_legacy (4.1.0.201002091800) "CCS C2000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400 (4.0.0.200907161600) "CCE C5400 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5400 (4.1.0.201002091800) "CCS C5400 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C5400_4.1 (4.0.0.200907161600) "CCE C5400 v4.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5400_4.1 (4.1.0.201002091800) "CCE C5400 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400_4.2 (4.0.0.200907161600) "CCE C5400 v4.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5400_4.2 (4.1.0.201002091800) "CCE C5400 v4.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5400_legacy (4.0.0.200907161600) "CCS C5400 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5400_legacy (4.1.0.201002091800) "CCS C5400 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500 (4.0.0.200907161600) "CCE C5500 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500 (4.1.0.201002091800) "CCS C5500 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C5500_4.0 (4.0.0.200907161600) "CCE C5500 v4.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500_4.0 (4.1.0.201002091800) "CCE C5500 v4.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.1 (4.0.0.200907161600) "CCE C5500 v4.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500_4.1 (4.1.0.201002091800) "CCE C5500 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.2 (4.0.0.200907161600) "CCE C5500 v4.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500_4.2 (4.1.0.201002091800) "CCE C5500 v4.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_4.3 (4.0.0.200907161600) "CCE C5500 v4.3 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500_4.3 (4.1.0.201002091800) "CCE C5500 v4.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C5500_legacy (4.0.0.200907161600) "CCE C5500 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C5500_legacy (4.1.0.201002091800) "CCE C5500 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000 (4.0.0.200907161600) "CCE C6000 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000 (4.1.0.201002091800) "CCS C6000 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.C6000_5.3 (4.0.0.200907161600) "C6000 v5.3 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000_5.3 (4.1.0.201002091800) "C6000 v5.3 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.0 (4.0.0.200907161600) "C6000 v6.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000_6.0 (4.1.0.201002091800) "C6000 v6.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_6.1 (4.0.0.200907161600) "C6000 v6.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000_6.1 (4.1.0.201002091800) "C6000 v6.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_7.0 (4.0.0.200907161600) "C6000 v7.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000_7.0 (4.1.1.201002091800) "C6000 v7.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.C6000_legacy (4.0.0.200907161600) "C6000 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.C6000_legacy (4.1.0.201002091800) "C6000 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.core (4.0.0.200907161600) "Managed Build Definitions Core" [Installed]
com.ti.ccstudio.buildDefinitions.core (4.1.0.201002091800) "Managed Build Definitions Core" [Active]
com.ti.ccstudio.buildDefinitions.GNU (4.1.0.201002091800) "CCE GNU Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430 (4.0.0.200907161600) "CCE MSP430 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430 (4.1.0.201002091800) "CCS MSP430 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430_2.0 (4.0.0.200907161600) "MSP430 v2.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_2.0 (4.1.0.201002091800) "MSP430 v2.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.0 (4.0.0.200907161600) "MSP430 v3.0 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.0 (4.1.0.201002091800) "MSP430 v3.0 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.1 (4.0.0.200907161600) "MSP430 v3.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.1 (4.1.0.201002091800) "MSP430 v3.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_3.2 (4.0.0.200907161600) "MSP430 v3.2 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_3.2 (4.1.0.201002091800) "MSP430 v3.2 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (4.0.0.200907161600) "CCE MSP430 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (4.1.0.201002091800) "CCE MSP430 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470 (4.0.0.200907161600) "CCE TMS470 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470 (4.1.0.201002091800) "CCS TMS470 Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.TMS470_2.54 (4.0.0.200907161600) "CCE TMS470 v2.54 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_2.54 (4.1.0.201002091800) "CCE TMS470 v2.54 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_2.71 (4.0.0.200907161600) "CCS TMS470 v2.71 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_2.71 (4.1.0.201002091800) "CCS TMS470 v2.71 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.1 (4.0.0.200907161600) "CCS TMS470 v4.1 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_4.1 (4.1.0.201002091800) "CCS TMS470 v4.1 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.4 (4.0.0.200907161600) "CCE TMS470 v4.4 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_4.4 (4.1.0.201002091800) "CCE TMS470 v4.4 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.5 (4.0.0.200907161600) "CCS TMS470 v4.5 Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_4.5 (4.1.0.201002091800) "CCS TMS470 v4.5 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_4.6 (4.1.0.201002091800) "CCS TMS470 v4.6 Managed Build Definitions" [Resolved]
com.ti.ccstudio.buildDefinitions.TMS470_legacy (4.0.0.200907161600) "CCE TMS470 Legacy Managed Build Definitions" [Installed]
com.ti.ccstudio.buildDefinitions.TMS470_legacy (4.1.0.201002091800) "CCE TMS470 Legacy Managed Build Definitions" [Resolved]
com.ti.ccstudio.c2000help.doc (4.0.0) "com.ti.ccstudio.c2000help.doc" [Resolved]
com.ti.ccstudio.c5000help.doc (4.0.0) "com.ti.ccstudio.c5000help.doc" [Resolved]
com.ti.ccstudio.c6000help.doc (4.0.0) "com.ti.ccstudio.c6000help.doc" [Resolved]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.200907161600) "TI Debugger Breakpoint User Interface" [Installed]
com.ti.ccstudio.debug.breakpoint.ui (4.0.0.201002091800) "TI Debugger Breakpoint User Interface" [Resolved]
com.ti.ccstudio.debug.cacheview (1.0.0) "Cache View Plug-in" [Resolved]
com.ti.ccstudio.debug.core (4.0.0.200907161600) "CCE Debug Core" [Installed]
com.ti.ccstudio.debug.core (4.0.0.201002091800) "CCE Debug Core" [Active]
com.ti.ccstudio.debug.memoryserver (4.0.0.200907161600) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.memoryserver (4.0.0.201002091800) "Memory Server Plugin" [Resolved]
com.ti.ccstudio.debug.mptv (4.0.0.200907161600) "MptvName" [Installed]
com.ti.ccstudio.debug.mptv (4.0.0.201002091800) "MptvName" [Resolved]
com.ti.ccstudio.debug.registers.ui (4.0.0.200907161600) "Registers UI Plug-in" [Installed]
com.ti.ccstudio.debug.registers.ui (4.1.0.201002091800) "Registers UI Plug-in" [Resolved]
com.ti.ccstudio.debug.server.extensions (4.0.0.200907161600) "CCE Debug Server Extensions" [Installed]
com.ti.ccstudio.debug.server.extensions (4.0.0.201002091800) "CCE Debug Server Extensions" [Active]
com.ti.ccstudio.debug.server.factory (4.0.0.200907161600) "CCE Debug Server Factory" [Resolved]
com.ti.ccstudio.debug.server.factory (4.0.0.201002091800) "CCE Debug Server Factory" [Active]
com.ti.ccstudio.debug.trace.core (4.0.0.200907161600) "Trace Core" [Installed]
com.ti.ccstudio.debug.trace.core (4.0.0.201002091800) "Trace Core" [Resolved]
com.ti.ccstudio.debug.trace.msp430 (4.0.0.200907161600) "MSP430 State Storage" [Installed]
com.ti.ccstudio.debug.trace.msp430 (4.0.0.201002091800) "MSP430 State Storage" [Resolved]
com.ti.ccstudio.debug.trace.ui (4.0.0.200907161600) "Trace UI" [Installed]
com.ti.ccstudio.debug.trace.ui (4.0.0.201002091800) "Trace UI" [Resolved]
com.ti.ccstudio.debug.ui (4.0.0.200907161600) "CCE Debug User Interface" [Installed]
com.ti.ccstudio.debug.ui (4.1.0.201002091800) "CCE Debug User Interface" [Active]
com.ti.ccstudio.debug.ui.msp430 (4.0.0.200907161600) "CCE Debug User Interface for MSP430" [Installed]
com.ti.ccstudio.debug.ui.msp430 (4.0.0.201002091800) "CCE Debug User Interface for MSP430" [Active]
com.ti.ccstudio.device.setup (4.0.0.200907161600) "CCE Device Setup" [Installed]
com.ti.ccstudio.device.setup (4.1.0.201002091800) "CCS Device Setup" [Active]
com.ti.ccstudio.disassembly.core (4.0.0.200907161600) "CCS Disassembly Core Plug-in" [Resolved]
com.ti.ccstudio.disassembly.core (4.1.0.201002091800) "CCS Disassembly Core Plug-in" [Resolved]
com.ti.ccstudio.disassembly.ui (4.0.0.200907161600) "CCS Disassembly UI Plug-in" [Installed]
com.ti.ccstudio.disassembly.ui (4.1.0.201002091800) "CCS Disassembly UI Plug-in" [Resolved]
com.ti.ccstudio.errorparser (4.0.0.200907161600) "CCE Error Parser" [Installed]
com.ti.ccstudio.errorparser (4.0.0.201002091800) "CCE Error Parser" [Resolved]
com.ti.ccstudio.gelhelp.doc (4.0.0.200907161600) "GEL Help Document Plug-in" [Installed]
com.ti.ccstudio.gelhelp.doc (4.0.0.201002091800) "GEL Help Document Plug-in" [Resolved]
com.ti.ccstudio.jline (4.0.0.200907161600) "Jline" [Installed]
com.ti.ccstudio.jline (4.0.0.201002091800) "Jline" [Resolved]
com.ti.ccstudio.mainhelp.doc (4.0.0) "CCS Help 4.0 Plugin" [Resolved]
com.ti.ccstudio.managedbuild.core (4.0.1.200907161600) "CCE Managed Build Core" [Installed]
com.ti.ccstudio.managedbuild.core (4.1.1.201002091800) "CCS Managed Build Core" [Active]
com.ti.ccstudio.managedbuild.ui (4.0.0.200907161600) "CCE Managed Build User Interface" [Installed]
com.ti.ccstudio.managedbuild.ui (4.1.0.201002091800) "CCE Managed Build User Interface" [Active]
com.ti.ccstudio.marker (4.0.0.200907161600) "Marker Plug-in" [Installed]
com.ti.ccstudio.marker (4.0.0.201002091800) "Marker Plug-in" [Resolved]
com.ti.ccstudio.memory.ui (4.0.0.200907161600) "CCS Memory UI Plug-in" [Installed]
com.ti.ccstudio.memory.ui (4.0.0.201002091800) "CCS Memory UI Plug-in" [Active]
com.ti.ccstudio.multi.purpose.view (4.0.0) "Control Panel View" [Installed]
com.ti.ccstudio.multi.purpose.view (4.1.0.201002091800) "Control Panel View" [Active]
com.ti.ccstudio.multi.purpose.view.contributors (4.0.0) "Control Panel View Contributors" [Installed]
com.ti.ccstudio.multi.purpose.view.contributors (4.1.0.201002091800) "Control Panel View Contributors" [Active]
com.ti.ccstudio.osgi (4.0.0.201002091800) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.osgi (4.0.0.200907161600) "CCE OSGi Hooks" [Resolved]
com.ti.ccstudio.pinconnect (4.0.0.200907161600) "PinConnect Tool Plug-in" [Installed]
com.ti.ccstudio.pinconnect (4.0.0.201002091800) "PinConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.pinport.common (4.0.0.200907161600) "Common Plug-in For Pin and Port Connect Tools" [Installed]
com.ti.ccstudio.pinport.common (4.0.0.201002091800) "Common Plug-in For Pin and Port Connect Tools" [Resolved]
com.ti.ccstudio.portconnect (4.0.0.200907161600) "PortConnect Tool Plug-in" [Installed]
com.ti.ccstudio.portconnect (4.0.0.201002091800) "PortConnect Tool Plug-in" [Resolved]
com.ti.ccstudio.product.paths (4.0.0.200907161600) "CCE Product Paths" [Installed]
com.ti.ccstudio.product.paths (4.1.0.201002091800) "CCS Product Paths" [Active]
com.ti.ccstudio.profile.setup (4.0.0.200907161600) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup (4.0.0.201002091800) "Profile Setup Plug-in" [Resolved]
com.ti.ccstudio.profile.setup.ui (4.0.0.200907161600) "Profile SetupUI Plug-in" [Installed]
com.ti.ccstudio.profile.setup.ui (4.0.0.201002091800) "Profile SetupUI Plug-in" [Active]
com.ti.ccstudio.project.ui (4.0.0.200907161600) "CCE Project User Interface" [Installed]
com.ti.ccstudio.project.ui (4.0.0.201002091800) "CCE Project User Interface" [Active]
com.ti.ccstudio.rhino (4.0.0.200907161600) "CCE Rhino JavaScript Engine" [Installed]
com.ti.ccstudio.rhino (4.0.0.201002091800) "CCE Rhino JavaScript Engine" [Resolved]
com.ti.ccstudio.scripting.console (4.0.0.200907161600) "Scripting Console" [Installed]
com.ti.ccstudio.scripting.console (4.0.0.201002091800) "Scripting Console" [Active]
com.ti.ccstudio.scripting.dss (4.0.0.200907161600) "Debug Server Scripting" [Installed]
com.ti.ccstudio.scripting.dss (4.0.0.201002091800) "Debug Server Scripting" [Resolved]
com.ti.ccstudio.scripting.environment (4.0.0.200907161600) "CCE Scripting Environment" [Installed]
com.ti.ccstudio.scripting.environment (4.0.0.201002091800) "CCE Scripting Environment" [Resolved]
com.ti.ccstudio.scripting.gss (4.0.0.200907161600) "CodeComposer Studio Scripting" [Installed]
com.ti.ccstudio.scripting.gss (4.0.0.201002091800) "CodeComposer Studio Scripting" [Resolved]
com.ti.ccstudio.scripting.ui (4.0.0.200907161600) "User Interface Scripting" [Installed]
com.ti.ccstudio.scripting.ui (4.0.0.201002091800) "User Interface Scripting" [Resolved]
com.ti.ccstudio.system.hotmenu (4.0.0.200907161600) "CCS System Hotmenu Plug-in" [Installed]
com.ti.ccstudio.system.hotmenu (4.0.0.201002091800) "CCS System Hotmenu Plug-in" [Active]
com.ti.ccstudio.system.setup (4.0.0.200907161600) "CCE System Setup" [Installed]
com.ti.ccstudio.system.setup (4.0.0.201002091800) "CCE System Setup" [Active]
com.ti.ccstudio.system.setup.ui (4.0.0.200907161600) "CCS System Setup Editor Plug-in" [Installed]
com.ti.ccstudio.system.setup.ui (4.0.0.201002091800) "CCS System Setup Editor Plug-in" [Active]
com.ti.ccstudio.tms470help.doc (4.0.0) "com.ti.ccstudio.tms470help.doc" [Resolved]
com.ti.ccstudio.trace.control (4.0.0.200907161600) "Trace Control Plug-in" [Installed]
com.ti.ccstudio.trace.control (4.1.0.201002091800) "Trace Control Plug-in" [Active]
com.ti.ccstudio.ui (4.0.0.200907161600) "CCE Platform User Interface" [Installed]
com.ti.ccstudio.ui (4.1.0.201002091800) "CCS Platform User Interface" [Active]
com.ti.ccstudio.ui.cheatsheets (4.0.0.200907161600) "Cheatsheets Plug-in" [Installed]
com.ti.ccstudio.ui.cheatsheets (4.0.0.201002091800) "Cheatsheets Plug-in" [Resolved]
com.ti.ccstudio.ui.forms (4.0.0.200907161600) "Forms Plug-in" [Installed]
com.ti.ccstudio.ui.forms (4.0.0.201002091800) "Forms Plug-in" [Resolved]
com.ti.ccstudio.update (4.0.0.200907161600) "CCS Update Plug-in" [Installed]
com.ti.ccstudio.update (4.0.0.201002091800) "CCS Update Plug-in" [Active]
com.ti.ccstudio.useaccess (4.0.0.200907161600) "Use Access Plug-in" [Installed]
com.ti.ccstudio.useaccess (4.0.0.201002091800) "Use Access Plug-in" [Resolved]
com.ti.common.core (4.0.0.200907161600) "Common TI Platform Core" [Installed]
com.ti.common.core (4.1.0.201002091800) "Common TI Platform Core" [Active]
com.ti.common.managedbuild.core (4.0.0.200907161600) "TI Common Managed-Build Core" [Installed]
com.ti.common.managedbuild.core (4.1.1.201002091800) "TI Common Managed-Build Core" [Active]
com.ti.common.managedbuild.ui (4.0.0.200907161600) "TI Common Managed-Build UI" [Installed]
com.ti.common.managedbuild.ui (4.1.0.201002091800) "TI Common Managed-Build UI" [Active]
com.ti.common.ui (4.0.0.200907161600) "Common TI User Interface" [Installed]
com.ti.common.ui (4.1.0.201002091800) "Common TI User Interface" [Active]
com.ti.common.update.discovery (4.0.0.200907161600) "Extension Site Discovery" [Installed]
com.ti.common.update.discovery (4.1.1.201002091800) "Extension Site Discovery" [Active]
com.ti.dvt.cceideadapter (1.0.0.200911121836) "CCStudio v4 IDE Adapter" [Resolved]
com.ti.dvt.cceideadapter (1.0.0) "CCStudio v4 IDE Adapter" [Installed]
com.ti.dvt.ccesymbolmanager (1.0.0.200911121836) "CCStudio 4.0 Symbol Manager" [Resolved]
com.ti.dvt.ccesymbolmanager (1.0.0) "CCStudio 4.0 Symbol Manager" [Installed]
com.ti.dvt.coverageplugin (1.0.0.200911121836) "Coverageplugin Plug-in" [Active]
com.ti.dvt.coverageplugin (1.0.0) "Coverageplugin Plug-in" [Installed]
com.ti.dvt.datamodel (1.0.0) "DVT Model" [Installed]
com.ti.dvt.datamodel (1.0.0.200911121836) "DVT Model" [Active]
com.ti.dvt.graph.visualization (1.0.0.200911121836) "Visualization Plug-in" [Active]
com.ti.dvt.graph.visualization (1.0.0) "Visualization Plug-in" [Installed]
com.ti.dvt.graph.visualization.doc (1.0.0.200911121836) "Graph Visualization Help  Plug-in" [Resolved]
com.ti.dvt.graph.visualization.doc (1.0.0) "Graph Visualization Help  Plug-in" [Installed]
com.ti.dvt.gridview (1.0.0.200911121836) "Gridview Plug-in" [Resolved]
com.ti.dvt.gridview (1.0.0) "Gridview Plug-in" [Installed]
com.ti.dvt.ideadapter (1.0.0.200911121836) "IDEAdapter" [Active]
com.ti.dvt.ideadapter (1.0.0) "IDEAdapter" [Installed]
com.ti.dvt.ideadapterplugin (1.0.0.200911121836) "IDEAdapter Plug-in" [Active]
com.ti.dvt.ideadapterplugin (1.0.0) "IDEAdapter Plug-in" [Installed]
com.ti.dvt.ofssymbolmanager (1.0.0) "OFSSymbolManager Plug-in" [Installed]
com.ti.dvt.ofssymbolmanager (1.0.0.200911121836) "OFSSymbolManager Plug-in" [Resolved]
com.ti.dvt.profileanalysis (1.0.0.200911121836) "DVT Profile Analysis Providers" [Resolved]
com.ti.dvt.profileanalysis (1.0.0) "DVT Profile Analysis Providers" [Installed]
com.ti.dvt.profileanalysis.doc (1.0.0.200911121836) "DVT Profile Analysis Providers Help" [Resolved]
com.ti.dvt.profileanalysis.doc (1.0.0) "DVT Profile Analysis Providers Help" [Installed]
com.ti.dvt.profileanalysismanager (1.0.0.200911121836) "Profiler Analysis Manager" [Resolved]
com.ti.dvt.profileanalysismanager (1.0.0) "Profiler Analysis Manager" [Installed]
com.ti.dvt.profileanalysismanagerplugin (1.0.0.200911121836) "Profile Server Plug-in" [Active]
com.ti.dvt.profileanalysismanagerplugin (1.0.0) "Profile Server Plug-in" [Installed]
com.ti.dvt.profiledata (1.0.0.200911121836) "Profile Data Source" [Resolved]
com.ti.dvt.profiledata (1.0.0) "Profile Data Source" [Resolved]
com.ti.dvt.rovsupport (1.0.0.200911121836) "Rovsupport Plug-in" [Active]
com.ti.dvt.rovsupport (1.0.0) "Rovsupport Plug-in" [Installed]
com.ti.dvt.rovsupport.doc (1.0.0.200911121836) "ROV Support Doc Plug-in" [Resolved]
com.ti.dvt.rovsupport.doc (1.0.0) "ROV Support Doc Plug-in" [Installed]
com.ti.dvt.rta (1.0.0.200911121836) "DSP/BIOS RTA" [Active]
com.ti.dvt.rta (1.0.0) "DSP/BIOS RTA" [Installed]
com.ti.dvt.rta.doc (1.0.0) "RTA Help" [Installed]
com.ti.dvt.rta.doc (1.0.0.200911121836) "RTA Help" [Resolved]
com.ti.dvt.rta.interfaces (1.0.0.200911121836) "RTA interfaces" [Resolved]
com.ti.dvt.rta.interfaces (1.0.0) "RTA interfaces" [Installed]
com.ti.dvt.scripting.ui (1.0.0.200911121836) "DVT Scripting Plugin" [Resolved]
com.ti.dvt.scripting.ui (1.0.0) "DVT Scripting Plugin" [Installed]
com.ti.dvt.server (3.15.2.62) "ROV Controller" [Resolved]
com.ti.dvt.sourceref (1.0.0.200911121836) "Source Reference Plug-in" [Resolved]
com.ti.dvt.sourceref (1.0.0) "Source Reference Plug-in" [Installed]
com.ti.dvt.sourcerefplugin (1.0.0) "Source Reference Preference Plug-in" [Installed]
com.ti.dvt.sourcerefplugin (1.0.0.200911121836) "Source Reference Preference Plug-in" [Resolved]
com.ti.dvt.symbolmanager (1.0.0.200911121836) "SymbolManager" [Resolved]
com.ti.dvt.symbolmanager (1.0.0) "SymbolManager" [Installed]
com.ti.dvt.symbolmanagerplugin (1.0.0.200911121836) "SymbolManager Plug-in" [Active]
com.ti.dvt.symbolmanagerplugin (1.0.0) "SymbolManager Plug-in" [Installed]
com.ti.dvt.tidisassembly (1.0.0) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.tidisassembly (1.0.0.200911121836) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.trace (1.0.0.200911121836) "DVT Trace Analyzer" [Active]
com.ti.dvt.trace (1.0.0) "DVT Trace Analyzer" [Installed]
com.ti.dvt.trace.doc (1.1.0) "Trace_Analyzer_User_Guide" [Installed]
com.ti.dvt.trace.doc (1.1.0.200911121836) "Trace_Analyzer_User_Guide" [Resolved]
com.ti.dvt.ui (1.0.0.200911121836) "DvtUI Plug-in" [Active]
com.ti.dvt.ui (1.0.0) "DvtUI Plug-in" [Installed]
com.ti.dvt.ui.doc (1.0.0) "com.ti.dvt.ui.doc" [Installed]
com.ti.dvt.ui.doc (1.0.0.200911121836) "com.ti.dvt.ui.doc" [Resolved]
com.ti.dvt.via.doc (1.1.0) "Image Analyzer" [Installed]
com.ti.dvt.via.doc (1.1.0.200911121836) "Image Analyzer" [Resolved]
com.ti.dvt.via.imvr (1.0.0.200911121836) "Image Viewer Plug-in" [Resolved]
com.ti.dvt.via.imvr (1.0.0) "Image Viewer Plug-in" [Installed]
com.ti.dvt.via.plugin (1.0.0.200911121836) "Image Analyzer" [Active]
com.ti.dvt.via.plugin (1.0.0) "Image Analyzer" [Installed]
com.ti.dvt.via.plugin.ccs (1.0.0.200911121836) "Image Analyzer (CCS)" [Active]
com.ti.dvt.via.plugin.ccs (1.0.0) "Image Analyzer (CCS)" [Installed]
com.ti.fnc (4.0.0.200907161600) "FlexNet Connect Plug-in" [Resolved]
com.ti.fnc (4.0.0.201002091800) "FlexNet Connect Plug-in" [Active]
com.ti.ipc.rtscRegistry_1.0.1.48 (1.0.1.48) "IPC 1.00.01.48 Help" [Resolved]
com.ti.rta (3.15.2.62) "XDC RTA Plug-in" [Resolved]
com.ti.util (1.0.0.200911121836) "Util Plug-in" [Resolved]
com.ti.util (1.0.0) "Util Plug-in" [Resolved]
com.ti.util.ui (1.0.0.200911121836) "Util Plug-in" [Active]
com.ti.util.ui (1.0.0) "Util Plug-in" [Installed]
com.xdais_6_23 (6.23) "XDAIS 6.23 Help" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.cdt (3.1.0.200606261600) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.1.0.vTI-200907161600) "C/C++ Development Tools Core" [Installed]
org.eclipse.cdt.core (3.1.0.vTI-201002091800) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.win32 (3.1.0.200606261600) "C/C++ Development Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.0.vTI-200907161600) "C/C++ Development Tools Debug Model" [Installed]
org.eclipse.cdt.debug.core (3.1.0.vTI-201002091800) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.mi.core (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.0.200606261600) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.0.vTI-200907161600) "C/C++ Development Tools Debugger UI" [Installed]
org.eclipse.cdt.debug.ui (3.1.0.vTI-201002091800) "C/C++ Development Tools Debugger UI" [Resolved]
org.eclipse.cdt.launch (3.1.0.vTI-200907161600) "C/C++ Development Tools Launching Support" [Installed]
org.eclipse.cdt.launch (3.1.0.vTI-201002091800) "C/C++ Development Tools Launching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.0.vTI-200907161600) "C/C++ Standard make Build Core" [Installed]
org.eclipse.cdt.make.core (3.1.0.vTI-201002091800) "C/C++ Standard make Build Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.0.vTI-200907161600) "C/C++ Standard make Build UI" [Installed]
org.eclipse.cdt.make.ui (3.1.0.vTI-201002091800) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-200907161600) "C/C++ Managed Builder Core" [Installed]
org.eclipse.cdt.managedbuilder.core (3.1.0.vTI-201002091800) "C/C++ Managed Builder Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-200907161600) "GNU Managed Build Definitions" [Installed]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.0.vTI-201002091800) "GNU Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-200907161600) "C/C++ Managed Builder UI" [Installed]
org.eclipse.cdt.managedbuilder.ui (3.1.0.vTI-201002091800) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.refactoring (3.1.0.vTI-200907161600) "C/C++ Refactoring" [Installed]
org.eclipse.cdt.refactoring (3.1.0.vTI-201002091800) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.ui (3.1.0.vTI-200907161600) "C/C++ Development Tools UI" [Installed]
org.eclipse.cdt.ui (3.1.0.vTI-201002091800) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.2.0.vTI-200907161600) "Compare Support" [Installed]
org.eclipse.compare (3.2.0.vTI-201002091800) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.vTI-200907161600) "Eclipse Jobs Mechanism" [Installed]
org.eclipse.core.jobs (3.2.0.vTI-201002091800) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.vTI-200907161600) "Core Resource Management" [Installed]
org.eclipse.core.resources (3.2.0.vTI-201002091800) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.vTI-201002091800) "Core Runtime" [Active]
org.eclipse.core.runtime (3.2.0.vTI-200907161600) "Core Runtime" [Installed]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-200907161600) "Traditional Memory Rendering" [Installed]
org.eclipse.dd.debug.memory.renderings.traditional (1.0.0.vTI-201002091800) "Traditional Memory Rendering" [Resolved]
org.eclipse.debug.core (3.2.0.vTI-200907161600) "Debug Core" [Installed]
org.eclipse.debug.core (3.2.0.vTI-201002091800) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.vTI-200907161600) "Debug UI" [Installed]
org.eclipse.debug.ui (3.2.0.vTI-201002091800) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.equinox.common (3.2.0.vTI-201002091800) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.common (3.2.0.vTI-200907161600) "Common Eclipse Runtime" [Installed]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Support" [Active]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]
org.eclipse.jface (3.2.0.vTI-200907161600) "JFace" [Resolved]
org.eclipse.jface (3.2.0.vTI-201002091800) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-200907161600) "JFace Text" [Resolved]
org.eclipse.jface.text (3.2.0.vTI-201002091800) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) "Refactoring UI" [Resolved]
org.eclipse.osgi (3.2.0.vTI-200907161600) "OSGi System Bundle" [Installed]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment Runtime" [Resolved]
org.eclipse.platform (3.2.0.vTI-200907161600) "Eclipse Platform" [Installed]
org.eclipse.platform (3.2.0.vTI-201002091800) "Eclipse Platform" [Resolved]
org.eclipse.rcp (3.2.0.vTI-200907161600) "Eclipse RCP" [Installed]
org.eclipse.rcp (3.2.0.vTI-201002091800) "Eclipse RCP" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.0.0.200907161600) "DSP/BIOS Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (1.1.0.201002091800) "DSP/BIOS Managed Build Definitions" [Resolved]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31 (1.0.0.200907161600) "DSP/BIOS v5.31 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31 (1.1.0.201002091800) "DSP/BIOS v5.31 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (1.0.0.200907161600) "DSP/BIOS v5.40 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (1.1.0.201002091800) "DSP/BIOS v5.40 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00 (1.0.0.200907161600) "DSP/BIOS v6.00 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00 (1.1.0.201002091800) "DSP/BIOS v6.00 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.0.0.200907161600) "XDC Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (1.1.0.201002091800) "XDC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.0.0.200907161600) "XDC v3.00 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (1.0.0.201002091800) "XDC v3.00 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.0.0.200907161600) "XDC v3.10 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (1.0.0.201002091800) "XDC v3.10 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.0.0.200907161600) "XDC v3.15 Managed Build Definitions" [Installed]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (1.0.0.201002091800) "XDC v3.15 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (1.1.0.201002091800) "XDC v3.16 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.core (3.15.2.62) "XDCtools core" [Resolved]
org.eclipse.rtsc.xdctools.managedbuild.core (1.0.0.200907161600) "RTSC Managed Build Core" [Installed]
org.eclipse.rtsc.xdctools.managedbuild.core (1.1.1.201002091800) "RTSC Managed Build Core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.0.0.200907161600) "RTSC Managed Build UI" [Installed]
org.eclipse.rtsc.xdctools.managedbuild.ui (1.1.0.201002091800) "RTSC Managed Build UI" [Active]
org.eclipse.rtsc.xdctools.model (3.15.2.62) "Model Plug-in" [Resolved]
org.eclipse.rtsc.xdctools.model.lang (3.15.2.62) "Lang Fragment" [Resolved]
org.eclipse.rtsc.xdctools.product (3.15.2.62) "RTSC/XDCtools" [Resolved]
org.eclipse.rtsc.xdctools.server (3.15.2.62) "XDCscript command server" [Resolved]
org.eclipse.rtsc.xdctools.ui (3.15.2.62) "Eclipse Plug-in" [Resolved]
org.eclipse.search (3.2.0.vTI-200907161600) "Search Support" [Installed]
org.eclipse.search (3.2.0.vTI-201002091800) "Search Support" [Active]
org.eclipse.swt (3.2.0.vTI-200907161600) "Standard Widget Toolkit" [Installed]
org.eclipse.swt (3.2.0.vTI-201002091800) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.vTI-200907161600) "Standard Widget Toolkit for Windows" [Installed]
org.eclipse.swt.win32.win32.x86 (3.2.0.vTI-201002091800) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tm.terminal (1.0.0.vTI-200907161600) "Target Management Terminal Widget" [Installed]
org.eclipse.tm.terminal (1.0.0.vTI-201002091800) "Target Management Terminal Widget" [Resolved]
org.eclipse.tm.terminal.serial (1.0.0.v20070605) "Target Management Terminal Serial Connector" [Resolved]
org.eclipse.tm.terminal.view (1.0.0.v20070620) "Target Management Terminal View" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.vTI-200907161600) "Eclipse UI" [Installed]
org.eclipse.ui (3.2.0.vTI-201002091800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.2.0.vTI-200907161600) "Cheat Sheets" [Installed]
org.eclipse.ui.cheatsheets (3.2.0.vTI-201002091800) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.vTI-200907161600) "Console" [Installed]
org.eclipse.ui.console (3.1.100.vTI-201002091800) "Console" [Active]
org.eclipse.ui.editors (3.2.0.vTI-200907161600) "Default Text Editor" [Installed]
org.eclipse.ui.editors (3.2.0.vTI-201002091800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.vTI-200907161600) "External Tools" [Installed]
org.eclipse.ui.externaltools (3.1.100.vTI-201002091800) "External Tools" [Resolved]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.0.vTI-200907161600) "Eclipse IDE UI" [Installed]
org.eclipse.ui.ide (3.2.0.vTI-201002091800) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) "Universal Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) "Navigator Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.vTI-200907161600) "Views" [Installed]
org.eclipse.ui.views (3.2.0.vTI-201002091800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) "Tabbed Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.2.0.vTI-200907161600) "Workbench" [Installed]
org.eclipse.ui.workbench (3.2.0.vTI-201002091800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-200907161600) "Text Editor Framework" [Installed]
org.eclipse.ui.workbench.texteditor (3.2.0.vTI-201002091800) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.2.0.vTI-201002091800) "Install/Update Configurator" [Active]
org.eclipse.update.configurator (3.2.0.v20060605) "Install/Update Configurator" [Installed]
org.eclipse.update.core (3.2.0.vTI-200907161600) "Install/Update Core" [Installed]
org.eclipse.update.core (3.2.0.vTI-201002091800) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.0.vTI-200907161600) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.core.win32 (3.2.0.vTI-201002091800) "Install/Update Core for Windows" [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.0.vTI-200907161600) "Install/Update UI" [Installed]
org.eclipse.update.ui (3.2.0.vTI-201002091800) "Install/Update UI" [Active]
system.bundle (3.2.0.vTI-201002091800) "OSGi System Bundle" [Active]
xdc.tools.xgconf.modeldata (3.15.2.62) "Modeldata Plug-in" [Resolved]
*** User Preferences:
#Thu Apr 22 13:28:08 CEST 2010
@com.ti.ccstudio.debug.ui=4.1.0.201002091800
/instance/com.ti.ccstudio.debug.ui/com.ti.ccstudio.debug.ui.legacy.LaunchConfigurationMigrator.ran=true
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.ui=3.2.0.vTI-201002091800
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.ide/platformState=1271935202661
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external location\="C\:\\Program Files\\Mozilla Firefox\\firefox.exe" name\="Firefox"/>\r\n<external location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe" name\="Internet Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.core.resources/pathvariable.CCS_C5500_4_3_2_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c5500
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.core.resources/pathvariable.CCS_MSP430_3_2_1_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/msp430
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.core.resources/pathvariable.CCS_C6000_6_1_9_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c6000
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.core.resources/pathvariable.CCS_C2000_5_2_1_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c2000
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.common_source_containers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<sourceLookupDirector>\r\n<sourceContainers duplicates\="false"/>\r\n</sourceLookupDirector>\r\n
@org.eclipse.core.resources=3.2.0.vTI-201002091800
@com.ti.ccstudio.ui=4.1.0.201002091800
/instance/org.eclipse.core.resources/pathvariable.CCS_TMS470_4_5_1_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/tms470
@org.eclipse.ui.ide=3.2.0.vTI-201002091800
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
@org.eclipse.cdt.ui=3.1.0.vTI-201002091800
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Workspace\\Projects,C\:\\Workspace\\VALHAL_MC_DSP_Codesonar_eStatic
@org.eclipse.cdt.debug.core=3.1.0.vTI-201002091800
file_export_version=3.0
/instance/com.ti.ccstudio.ui/CCStudioUIPreferences.IS_NOT_FIRST_CCE_LAUNCH=true
/instance/org.eclipse.core.resources/pathvariable.CCS_C5400_4_2_0_CG_ROOT=C\:/Program Files/Texas Instruments/ccsv4/tools/compiler/c5400
*** Current Install Configuration:
Install configuration:
 Last changed on 22/04/2010
 Location: file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/configuration/org.eclipse.update/platform.xml
 Configured sites:
  platform:/base/
  file:/C:/Program Files/Texas Instruments/bios_5_40_02_22/eclipse/
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/
  file:/C:/Program Files/Texas Instruments/ipc_1_00_01_48/eclipse/
  file:/C:/Program Files/Texas Instruments/xdais_6_23/eclipse/
 Configured features:
  ID: com.ti.ccstudio.msp430, Version: 4.0.0.201002091800
  ID: org.eclipse.cdt, Version: 3.1.0.vTI-201002091800
  ID: com.ti.dvt.rov, Version: 1.0.0.200911121836
  ID: com.ti.ccstudio.c5400, Version: 4.0.0.201002091800
  ID: com.ti.ccstudio.product, Version: 4.1.1.00014
  ID: com.ti.cgt.c5400.4.2, Version: 4.2.0
  ID: com.ti.ccstudio.tms470, Version: 4.0.0.201002091800
  ID: com.ti.dvt.ccstudio, Version: 1.0.0.200911121836
  ID: com.ti.ccstudio.c2000, Version: 4.0.0.201002091800
  ID: com.ti.ccstudio.c6000, Version: 4.0.0.201002091800
  ID: org.eclipse.tm.terminal, Version: 1.0.0.vTI-201002091800
  ID: com.ti.ccstudio.c5500, Version: 4.0.0.201002091800
  ID: org.eclipse.platform, Version: 3.2.0.vTI-201002091800
  ID: com.ti.cgt.c6000.6.1, Version: 6.1.12
  ID: com.ti.dvt.profileanalysismanager, Version: 1.0.0.200911121836
  ID: com.ti.dvt.via.ccs, Version: 1.0.0.200911121836
  ID: com.ti.dvt.trace.ccs, Version: 2.1.0.200911121836
  ID: com.ti.ccstudio.branding, Version: 4.0.0.201002091800
  ID: com.ti.cgt.tms470.4.6, Version: 4.6.1
  ID: org.eclipse.rcp, Version: 3.2.0.vTI-201002091800
  ID: com.ti.ccstudio.rtsc, Version: 4.0.0.201002091800
  ID: com.ti.dvt.rta, Version: 1.0.0.200911121836
  ID: com.ti.dvt.graph.visualization, Version: 1.0.0.200911121836
  ID: com.ti.dvt.scripting.ui, Version: 4.0.0.200911121836
  ID: com.ti.dvt.core.ccstudio, Version: 1.0.0.200911121836
  ID: com.ti.cgt.c2000.5.2, Version: 5.2.3
  ID: com.ti.ccstudio.base.win32, Version: 4.0.0.200907161600
  ID: com.ti.cgt.c5500.4.3, Version: 4.3.5
  ID: com.ti.bios_5.40.2.22, Version: 5.40.2.22
  ID: org.eclipse.rtsc.xdctools.product, Version: 3.15.2.62
  ID: com.ti.ipc_1.0.1.48, Version: 1.0.1.48
  ID: com.xdais_6_23, Version: 6.23.0
 Configured plug-ins:
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ibm.icu_3.4.4.1.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.apps_4.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.binaryparser_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.0.0.200907161600/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.branding_4.1.0.201002091800/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.core_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.breakpoint_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_4.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.0_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.2_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_5.2_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.2_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_4.2_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5400_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.0_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.2_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.2_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.3_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_4.3_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C5500_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_5.3_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_5.3_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.0_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_6.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_7.0_4.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.C6000_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.core_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.GNU_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_2.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_2.0_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.0_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.0_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.2_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_3.2_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.54_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.54_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.71_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_2.71_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.1_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.1_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.4_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.4_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.5_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.5_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_4.6_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_legacy_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.buildDefinitions.TMS470_legacy_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c2000help.doc_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c5000help.doc_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.c6000help.doc_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.breakpoint.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.cacheview_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.core_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.200907161600/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.memoryserver_4.0.0.201002091800/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.mptv_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.registers.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.extensions_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.server.factory_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.core_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.msp430_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.msp430_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.trace.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui.msp430_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui.msp430_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.debug.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.device.setup_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.core_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.disassembly.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.errorparser_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.gelhelp.doc_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.jline_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.mainhelp.doc_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.0.1.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.core_4.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.managedbuild.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.marker_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.memory.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view.contributors_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.multi.purpose.view_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.osgi_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinconnect_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.pinport.common_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.portconnect_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.product.paths_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.profile.setup_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.project.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.rhino_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.console_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.dss_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.environment_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.gss_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.scripting.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.hotmenu_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup.ui_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.system.setup_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.tms470help.doc_4.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.trace.control_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.cheatsheets_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui.forms_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.update_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.ccstudio.useaccess_4.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.core_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.core_4.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.managedbuild.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.ui_4.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.common.update.discovery_4.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.cceideadapter_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ccesymbolmanager_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.coverageplugin_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.datamodel_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization.doc_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.graph.visualization_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.gridview_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapterplugin_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ideadapter_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ofssymbolmanager_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis.doc_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanagerplugin_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysismanager_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profileanalysis_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.profiledata_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport.doc_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rovsupport_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.doc_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta.interfaces_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.rta_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.scripting.ui_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourcerefplugin_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.sourceref_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanagerplugin_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.symbolmanager_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.tidisassembly_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_1.1.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace.doc_1.1.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.trace_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_1.0.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui.doc_1.0.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.ui_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_1.1.0/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.doc_1.1.0.200911121836/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.imvr_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin.ccs_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.dvt.via.plugin_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.200907161600/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.fnc_4.0.0.201002091800/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util.ui_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_1.0.0.200911121836.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/com.ti.util_1.0.0.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.ant_1.6.5/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core.win32_3.1.0.200606261600/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.core_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.0.200606261600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.0.200606261600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.launch_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.core_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt.ui_3.1.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.cdt_3.1.0.200606261600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.compare_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.jobs_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.resources_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.0.v20060603/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.runtime_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.dd.debug.memory.renderings.traditional_1.0.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.core_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.debug.ui_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.common_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help.webapp_3.2.0.v20060602/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface.text_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.jface_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.osgi_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-200907161600/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.platform_3.2.0.vTI-201002091800/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rcp_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_6.00_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_1.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_1.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_1.0.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.core_1.1.1.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.0.0.200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_1.1.0.201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.search_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.swt_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.core_3.2.0.I200606051140.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M20060628.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051140.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.serial_1.0.0.v20070605.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal.view_1.0.0.v20070620.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tm.terminal_1.0.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.console_3.1.100.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.editors_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.ide_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.0.v20060602/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.views_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-1400.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.ui_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.v20060605.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.configurator_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.core_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v20060605.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-200907161600.jar
  file:/C:/Program Files/Texas Instruments/ccsv4/eclipse/plugins/org.eclipse.update.ui_3.2.0.vTI-201002091800.jar
  file:/C:/Program Files/Texas Instruments/bios_5_40_02_22/eclipse/plugins/com.ti.bios.rta_5.40.2.22.jar
  file:/C:/Program Files/Texas Instruments/bios_5_40_02_22/eclipse/plugins/com.ti.bios.rtscRegistry_5.40.2.22/
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/com.ti.dvt.server_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/com.ti.rta_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.core_3.15.2.62/
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.model.lang_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.model_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.product_3.15.2.62/
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.server_3.15.2.62/
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/org.eclipse.rtsc.xdctools.ui_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/xdctools_3_15_02_62/eclipse/plugins/xdc.tools.xgconf.modeldata_3.15.2.62.jar
  file:/C:/Program Files/Texas Instruments/ipc_1_00_01_48/eclipse/plugins/com.ti.ipc.rtscRegistry_1.0.1.48/
  file:/C:/Program Files/Texas Instruments/xdais_6_23/eclipse/plugins/com.xdais_6_23/
  • There were a few bugs with the headless project build functionality that was fixed in v4.1.2. Could you retry on v4.1.2?
    http://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/42466.aspx
    ki
  • Hi
    I installed Version 4.1.2007 and are using the latest Code Generation Tools (v6.1.14) for our project.
    But I still having the problem. Could it have something to do with the Java version I have installed? I'm using Java v. 1.6.0_18_b07.
    Per
  • Hi Per,
    I cannot place build "4.1.2007" to any known CCS version.  Could you please double-check the exact version of CCS you are using (as shown in the Help > About dialog in CCS IDE)?
    Also, I doubt the problem you're seeing is related to the JVM.  But, it is still not advisable to be using the system-default Java installation.  Instead, you must explicitly use the JVM that is installed with CCS (see http://processors.wiki.ti.com/index.php/Projects_-_Command_Line_Build/Create for details).
    - Baltasar
  • Hi
    Sorry I misspleded the build#. The correct one is:  Version: 4.1.2.00027
    I ran the command build of my project as descripted here: http://processors.wiki.ti.com/index.php/Projects_-_Command_Line_Build/Create
    With the correct JVM.
    The build scratched as before.
    But I noticed that when I afterwards started CCSv4 GUI I get an notification the the previous session has cratched. Please find the log attached.
     !SESSION 2010-04-29 09:22:55.930 -----------------------------------------------
    eclipse.buildId=4.1.2.00027
    java.version=1.5.0_14
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=da_DK
    Framework arguments:  -application com.ti.ccstudio.apps.projectBuild -ccs.workspace
    Command-line arguments:  -data C:\Workspace\VALHAL_MC_DSP -application com.ti.ccstudio.apps.projectBuild -ccs.workspace
    This is a continuation of log file C:\workspace\VALHAL_MC_DSP\.metadata\.bak_0.log
    Created Time: 2010-04-29 09:23:00.948
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:23:00.948
    !MESSAGE Error logged from Debug UI:
    !STACK 1
    org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.debug.ui" was unable to instantiate class "org.eclipse.debug.internal.ui.views.breakpoints.WorkingSetBreakpointOrganizer".
     at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:165)
     at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:159)
     at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:759)
     at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
     at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerExtension.getOrganizer(BreakpointOrganizerExtension.java:96)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerExtension.addPropertyChangeListener(BreakpointOrganizerExtension.java:116)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerManager.start(BreakpointOrganizerManager.java:80)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerManager.<init>(BreakpointOrganizerManager.java:65)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerManager.getDefault(BreakpointOrganizerManager.java:54)
     at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:407)
     at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:995)
     at java.security.AccessController.doPrivileged(Native Method)
     at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:989)
     at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:970)
     at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:317)
     at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:256)
     at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.preFindLocalClass(EclipseLazyStarter.java:86)
     at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:409)
     at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:188)
     at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:339)
     at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:391)
     at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:352)
     at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:83)
     at java.lang.ClassLoader.loadClass(Unknown Source)
     at org.eclipse.osgi.framework.internal.core.BundleLoader.loadClass(BundleLoader.java:276)
     at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:227)
     at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1245)
     at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:147)
     at org.eclipse.core.internal.variables.DynamicVariable.getValue(DynamicVariable.java:47)
     at org.eclipse.cdt.managedbuilder.internal.macros.EclipseVariablesMacroSupplier$EclipseVarMacro.loadValue(EclipseVariablesMacroSupplier.java:85)
     at org.eclipse.cdt.managedbuilder.internal.macros.EclipseVariablesMacroSupplier$EclipseVarMacro.getStringValue(EclipseVariablesMacroSupplier.java:74)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.resolveMacro(DefaultMacroSubstitutor.java:377)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.resolveMacro(DefaultMacroSubstitutor.java:308)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.resolveMacro(DefaultMacroSubstitutor.java:296)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.getResolvedMacro(DefaultMacroSubstitutor.java:281)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.resolveToString(DefaultMacroSubstitutor.java:233)
     at org.eclipse.cdt.managedbuilder.internal.macros.DefaultMacroSubstitutor.resolveToString(DefaultMacroSubstitutor.java:251)
     at org.eclipse.cdt.managedbuilder.internal.macros.MacroResolver.resolve(MacroResolver.java:149)
     at org.eclipse.cdt.managedbuilder.internal.macros.MacroResolver.resolveToStringList(MacroResolver.java:226)
     at org.eclipse.cdt.managedbuilder.internal.macros.BuildMacroProvider.resolveStringListValue(BuildMacroProvider.java:199)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.processPath(ManagedBuildInfo.java:1143)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.addPaths(ManagedBuildInfo.java:1358)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.addIncludes(ManagedBuildInfo.java:1351)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.readToolsOptions(ManagedBuildInfo.java:1325)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.getOptionValues(ManagedBuildInfo.java:1250)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.getManagedBuildValues(ManagedBuildInfo.java:1220)
     at org.eclipse.cdt.managedbuilder.internal.core.ManagedBuildInfo.getManagedBuildValues(ManagedBuildInfo.java:1188)
     at org.eclipse.cdt.managedbuilder.internal.scannerconfig.ManagedBuildCPathEntryContainer.getPathEntries(ManagedBuildCPathEntryContainer.java:198)
     at org.eclipse.cdt.internal.core.model.PathEntryManager.getResolvedPathEntries(PathEntryManager.java:457)
     at org.eclipse.cdt.internal.core.model.PathEntryManager.getResolvedPathEntries(PathEntryManager.java:429)
     at org.eclipse.cdt.core.model.CoreModel.getResolvedPathEntries(CoreModel.java:941)
     at org.eclipse.cdt.internal.core.model.CProject.getResolvedPathEntries(CProject.java:400)
     at org.eclipse.cdt.internal.core.model.CProject.computeSourceRoots(CProject.java:595)
     at org.eclipse.cdt.internal.core.model.CProject.getAllSourceRoots(CProject.java:502)
     at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:287)
     at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:227)
     at org.eclipse.cdt.internal.core.model.DeltaProcessor.createElement(DeltaProcessor.java:92)
     at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:458)
     at org.eclipse.cdt.internal.core.model.DeltaProcessor.traverseDelta(DeltaProcessor.java:477)
     at org.eclipse.cdt.internal.core.model.DeltaProcessor.processResourceDelta(DeltaProcessor.java:439)
     at org.eclipse.cdt.internal.core.model.CModelManager.resourceChanged(CModelManager.java:747)
     at org.eclipse.core.internal.events.NotificationManager$2.run(NotificationManager.java:284)
     at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
     at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:278)
     at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
     at org.eclipse.core.internal.resources.Workspace.broadcastPostChange(Workspace.java:256)
     at org.eclipse.core.internal.resources.Workspace.aboutToBuild(Workspace.java:187)
     at org.eclipse.core.internal.resources.Project.build(Project.java:87)
     at com.ti.ccstudio.apps.project.Build.buildProjects(Build.java:246)
     at com.ti.ccstudio.apps.project.Build.doRun(Build.java:104)
     at com.ti.ccstudio.apps.project.BaseHeadlessApp$1.run(BaseHeadlessApp.java:168)
     at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1737)
     at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1719)
     at com.ti.ccstudio.apps.project.BaseHeadlessApp.internalRun(BaseHeadlessApp.java:166)
     at com.ti.ccstudio.apps.project.BaseHeadlessApp.run(BaseHeadlessApp.java:136)
     at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
     at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
     at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
     at java.lang.reflect.Method.invoke(Unknown Source)
     at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
     at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
     at org.eclipse.core.launcher.Main.run(Main.java:996)
     at org.eclipse.core.launcher.Main.main(Main.java:971)
    org.eclipse.core.runtime.CoreException[1]: java.lang.IllegalStateException: Workbench has not been created yet.
     at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
     at org.eclipse.debug.internal.ui.views.breakpoints.WorkingSetBreakpointOrganizer.<init>(WorkingSetBreakpointOrganizer.java:34)
     at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
     at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
     at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
     at java.lang.reflect.Constructor.newInstance(Unknown Source)
     at java.lang.Class.newInstance0(Unknown Source)
     at java.lang.Class.newInstance(Unknown Source)
     at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:157)
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:23:00.948
    !MESSAGE Plug-in "org.eclipse.debug.ui" was unable to instantiate class "org.eclipse.debug.internal.ui.views.breakpoints.WorkingSetBreakpointOrganizer".
    !STACK 0
    !STACK 1
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerExtension.removePropertyChangeListener(BreakpointOrganizerExtension.java:127)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerManager.start(BreakpointOrganizerManager.java:81)
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:23:00.964
    !STACK 1
    org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.debug.ui" was unable to instantiate class "org.eclipse.debug.internal.ui.views.breakpoints.BreakpointSetOrganizer".
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointOrganizerManager.<init>(BreakpointOrganizerManager.java:66)
     at org.eclipse.debug.internal.ui.views.breakpoints.BreakpointSetOrganizer.<init>(BreakpointSetOrganizer.java:42)
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:23:00.964
    !MESSAGE Plug-in "org.eclipse.debug.ui" was unable to instantiate class "org.eclipse.debug.internal.ui.views.breakpoints.BreakpointSetOrganizer".
    !STACK 0
    !STACK 1
    !STACK 0
    !SESSION 2010-04-29 09:27:28.724 -----------------------------------------------
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:27:32.756
    !STACK 1
     at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:254)
     at org.eclipse.cdt.internal.core.model.CModelManager.create(CModelManager.java:229)
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:27:32.756
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:27:32.771
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:27:32.771
    !STACK 0
    !STACK 1
    !STACK 0
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:27:32.787
    !STACK 0
    !SESSION 2010-04-29 09:34:20.453 -----------------------------------------------
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:34:24.318
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:34:24.318
    !STACK 0
    !STACK 1
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 09:34:24.333
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 09:34:24.333
    !STACK 0
    !STACK 1
    !STACK 0
    !SESSION 2010-04-29 10:19:06.840 -----------------------------------------------
    !ENTRY org.eclipse.osgi 4 0 2010-04-29 10:19:18.236
    !MESSAGE While loading class "com.ti.ccstudio.managedbuild.core.options.OutputFileOptionValueHandler", thread "Worker-1" timed out waiting (5000ms) for thread "main" to finish starting bundle "com.ti.ccstudio.managedbuild.core". To avoid deadlock, thread "Worker-1" is proceeding but "com.ti.ccstudio.managedbuild.core.options.OutputFileOptionValueHandler" may not be fully initialized.
    !STACK 0
    java.lang.Exception: Generated exception.
     at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.preFindLocalClass(EclipseLazyStarter.java:75)
     at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackage.java:37)
     at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:388)
     at org.eclipse.cdt.managedbuilder.internal.core.Option.getValueHandler(Option.java:1669)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:2898)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:2850)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.loadBuildInfo(ManagedBuildManager.java:1808)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.findBuildInfoSynchronized(ManagedBuildManager.java:2478)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.findBuildInfo(ManagedBuildManager.java:2376)
     at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.getBuildInfo(ManagedBuildManager.java:2552)
     at com.ti.common.managedbuild.core.util.CTIManagedBuildCoreUtils.getBuildInfo(CTIManagedBuildCoreUtils.java:112)
     at com.ti.common.managedbuild.core.util.CTIManagedBuildCoreUtils.getBuildInfo(CTIManagedBuildCoreUtils.java:99)
     at com.ti.common.managedbuild.core.util.CTIManagedBuildCoreUtils.getActiveBuildConfiguration(CTIManagedBuildCoreUtils.java:280)
     at org.eclipse.rtsc.xdctools.buildDefinitions.XDC.XDCRootPathEntryContainer.getPathEntries(XDCRootPathEntryContainer.java:66)
     at org.eclipse.core.internal.resources.Workspace.endOperation(Workspace.java:958)
     at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:45)
     at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
    !ENTRY org.eclipse.osgi 4 0 2010-04-29 10:19:23.380
    !MESSAGE While loading class "com.ti.ccstudio.managedbuild.core.options.OutputFileOptionValueHandler$ConfigurationChangeListener", thread "Worker-1" timed out waiting (5000ms) for thread "main" to finish starting bundle "com.ti.ccstudio.managedbuild.core". To avoid deadlock, thread "Worker-1" is proceeding but "com.ti.ccstudio.managedbuild.core.options.OutputFileOptionValueHandler$ConfigurationChangeListener" may not be fully initialized.
    !STACK 0
     at java.lang.ClassLoader.loadClassInternal(Unknown Source)
     at com.ti.ccstudio.managedbuild.core.options.OutputFileOptionValueHandler.<clinit>(OutputFileOptionValueHandler.java:34)
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 10:19:24.630
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 10:19:24.646
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 10:19:24.646
    !STACK 1
    !STACK 0
    !STACK 1
    !STACK 0
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 10:19:24.661
    !STACK 0
    !ENTRY org.eclipse.core.resources 4 2 2010-04-29 10:19:28.538
    !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
    !STACK 0
    java.lang.ExceptionInInitializerError
     at org.eclipse.cdt.ui.PreferenceConstants.initializeDefaultValues(PreferenceConstants.java:392)
     at org.eclipse.cdt.ui.CUIPreferenceInitializer.initializeDefaultPreferences(CUIPreferenceInitializer.java:37)
     at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:276)
     at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:130)
     at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:337)
     at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:162)
     at org.eclipse.core.internal.preferences.DefaultPreferences.loadDefaults(DefaultPreferences.java:231)
     at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:227)
     at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:307)
     at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:543)
     at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:662)
     at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:38)
     at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:67)
     at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:248)
     at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:282)
     at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPreferenceStore.java:472)
     at org.eclipse.ui.preferences.ScopedPreferenceStore.getInt(ScopedPreferenceStore.java:498)
     at org.eclipse.cdt.internal.ui.preferences.BuildConsolePreferencePage.buildConsoleLines(BuildConsolePreferencePage.java:118)
     at org.eclipse.cdt.internal.ui.buildconsole.BuildConsolePartitioner.<init>(BuildConsolePartitioner.java:113)
     at org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleManager.getConsolePartioner(BuildConsoleManager.java:296)
     at org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleManager.getConsole(BuildConsoleManager.java:281)
     at org.eclipse.cdt.internal.ui.buildconsole.CBuildConsole.start(CBuildConsole.java:33)
     at org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefileBuilder.invokeMake(GeneratedMakefileBuilder.java:1014)
     at org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefileBuilder.fullBuild(GeneratedMakefileBuilder.java:811)
     at org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefileBuilder.build(GeneratedMakefileBuilder.java:512)
     at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:603)
     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:167)
     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
     at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:230)
     at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:233)
     at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:307)
     at org.eclipse.core.internal.resources.Project.build(Project.java:88)
    Caused by: org.eclipse.swt.SWTException: Invalid thread access
     at org.eclipse.swt.SWT.error(SWT.java:3374)
     at org.eclipse.swt.SWT.error(SWT.java:3297)
     at org.eclipse.swt.SWT.error(SWT.java:3268)
     at org.eclipse.swt.widgets.Display.error(Display.java:978)
     at org.eclipse.swt.widgets.Display.checkDevice(Display.java:638)
     at org.eclipse.swt.widgets.Display.getSystemFont(Display.java:2038)
     at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:83)
     ... 54 more
    !SESSION 2010-04-29 11:06:06.667 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2010-04-29 11:06:07.606
    !MESSAGE A workspace crash was detected. The previous session did not exit normally.
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 11:06:10.861
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 11:06:10.876
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 11:06:10.876
    !STACK 1
    !STACK 0
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 11:06:10.892
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 11:06:10.892
    !STACK 1
    !STACK 0
    !ENTRY org.eclipse.core.resources 4 2 2010-04-29 11:06:15.728
    !STACK 0
     ... 54 more
    !SESSION 2010-04-29 11:08:14.488 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2010-04-29 11:08:16.350
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 11:08:19.791
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 11:08:19.791
    !STACK 0
    !STACK 1
    !STACK 0
    !ENTRY org.eclipse.debug.ui 4 120 2010-04-29 11:08:19.807
    !STACK 1
    !SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-04-29 11:08:19.807
    !STACK 0
    !STACK 1
    !STACK 0
    !ENTRY org.eclipse.core.resources 4 2 2010-04-29 11:08:24.703
    !STACK 0
     ... 54 more
    !SESSION 2010-04-29 11:08:47.698 -----------------------------------------------
    Command-line arguments:  -os win32 -ws win32 -arch x86
    !ENTRY org.eclipse.core.resources 2 10035 2010-04-29 11:08:50.248
  • Hi Per,
    Could you try to isolate the project that causes these exceptions (by using the -ccs.projects flag in your headless build command), and e-mail that project to me?  I would need to step through the code to find out more about this issue.
    - Baltasar
  • HI Baltasar
    I would like to send you the source code in our project, but that would require that I get a None Disclosure Agreement (NDA) through our and your legal department. My experience is that that would take months.
    Therefore I tried to get a deper understanding of the problem.
    I have a theory, but I'm not an expert in Java.
    Here are some additional information:
    1. I actually can suceed to build the project one in a while. But my problem is that I need a stable build.
    2. First I through that something in the CCSv4 changed in between the good and bad build, so I created the project from scratch in a new workspace. But the result was again unstable.
    3.. The I tried to run it on different PC's with different system resources and RAM size. I seems to fail more times on a Windows XP PC with 2GB than on a Windows XP PC with 3.5 GB.
    4. Then I tried to build with different project sizes. The result was that small projects (max. 2000 code lines) succeed every time and the big (40000 code line) project I have trouble with fails.
    My conclusion is that either the Java startup.jar in CCSv4 has a problem with big projects or that it need to have more RAM allocated for the build.
    Per
  • Per,
    There were some fixes we made to the command line build functionality in v4.1.2. If you are not using that version, could you try updating to it?
    ki
  • Hi
    I'm have made all my last tests with CCS v. 4.1.2.00027.
    Per
  • Per,
    I have filed a defect to track this problem: SDSCM00036221 Headless Build: Exceptions when building.
    I will try to figure out what's happening based on the exception-log that you've provided.  But, if you could create a project to reproduce this defect, it would improve the chances.
    - Baltasar
  • Baltasar,
    I cannot give you our source code without an NDA, but I can offer you to connect to our build computer through a support line.
    Thanks for you help!
    Per
  • Per,
    I managed to reproduce the problems based on the stack-trace you've provided.  A fix has been implemented and will be available in the next CCS service-release (CCSv4.1.3).
    - Baltasar
  • Hi Baltasar
    That is really good news!
    I'm looking forward to try out the new version. Is it possible to get the new (or a beta version) already now?
    Per
  • I´m experiencing a very similar problem when I try to build my project (which was imported from CCS 3.3). Isn´t there a workaround (a patch or update) to solve this while CCSv4.1.3 isn´t released?
    P.S.: odd enough, I can manage to build my project right after importing, but only once. After that, this error repeats every time I try to build.
  • Vitor,
    CCSv4.1.3 is already available for download - http://processors.wiki.ti.com/index.php/Download_CCS.
    Let me know if you're experiencing the same problem with building your projects in CCSv4.1.3.
    - Baltasar
