Hi all,
I've a blackhawk XDS200 USB debugger which work well on Windows. However when we try to use it with an Ubuntu installation of CCS 6.1.0.00104 we have an host connection error. I know there are several threads about this debugger, but none of them helped us in fixing our problem.
The TI wiki page suggests to check lsusb and udev rules.
The device is listed when I run the lsusb command. This is the output:
Bus 001 Device 006: ID 0451:bef0 Texas Instruments, Inc.
If I try to test the udev rule I get the following error. I'm not expert on this, so I hope the command I used is the correct one.
luca@lucapc:~/Projects/Verity/vs_root/ws_pc_build/bin$ udevadm test /dev/bus/usb/001/006 calling: test version 204 This program is for debugging only, it does not run any program specified by a RUN key. It may show incorrect results, because some values may be different, or not available at a simulation run. === trie on-disk === tool version: 204 file size: 5773073 bytes header size 80 bytes strings 1271633 bytes nodes 4501360 bytes load module index read rules file: /etc/udev/rules.d/10-kvaser.rules read rules file: /lib/udev/rules.d/40-crda.rules read rules file: /lib/udev/rules.d/40-gnupg.rules read rules file: /lib/udev/rules.d/40-hyperv-hotadd.rules read rules file: /lib/udev/rules.d/40-inputattach.rules read rules file: /lib/udev/rules.d/40-libgphoto2-6.rules GOTO 'libgphoto2_usb_end' has no matching label in: '/lib/udev/rules.d/40-libgphoto2-6.rules' read rules file: /lib/udev/rules.d/40-libsane.rules read rules file: /lib/udev/rules.d/40-open-vm-tools.rules read rules file: /lib/udev/rules.d/40-openocd.rules read rules file: /lib/udev/rules.d/40-usb-media-players.rules read rules file: /lib/udev/rules.d/40-usb_modeswitch.rules read rules file: /lib/udev/rules.d/40-xdiagnose.rules read rules file: /lib/udev/rules.d/42-usb-hid-pm.rules read rules file: /etc/udev/rules.d/49-stlinkv1.rules read rules file: /etc/udev/rules.d/49-stlinkv2-1.rules read rules file: /etc/udev/rules.d/49-stlinkv2.rules read rules file: /lib/udev/rules.d/50-firmware.rules read rules file: /lib/udev/rules.d/50-udev-default.rules read rules file: /lib/udev/rules.d/55-dm.rules read rules file: /lib/udev/rules.d/56-hpmud.rules read rules file: /lib/udev/rules.d/60-cdrom_id.rules read rules file: /lib/udev/rules.d/60-keyboard.rules read rules file: /lib/udev/rules.d/60-pcmcia.rules read rules file: /lib/udev/rules.d/60-persistent-alsa.rules read rules file: /lib/udev/rules.d/60-persistent-input.rules read rules file: /lib/udev/rules.d/60-persistent-serial.rules read rules file: /lib/udev/rules.d/60-persistent-storage-dm.rules read rules file: /lib/udev/rules.d/60-persistent-storage-tape.rules read rules file: /lib/udev/rules.d/60-persistent-storage.rules read rules file: /lib/udev/rules.d/60-persistent-v4l.rules read rules file: /lib/udev/rules.d/61-accelerometer.rules read rules file: /lib/udev/rules.d/61-gnome-bluetooth-rfkill.rules read rules file: /lib/udev/rules.d/62-google-cloudimg.rules read rules file: /lib/udev/rules.d/64-btrfs.rules read rules file: /lib/udev/rules.d/64-xorg-xkb.rules read rules file: /lib/udev/rules.d/66-xorg-synaptics-quirks.rules read rules file: /lib/udev/rules.d/69-cd-sensors.rules IMPORT found builtin 'usb_id --export %p', replacing /lib/udev/rules.d/69-cd-sensors.rules:89 read rules file: /lib/udev/rules.d/69-libmtp.rules read rules file: /lib/udev/rules.d/69-xorg-vmmouse.rules read rules file: /lib/udev/rules.d/69-xserver-xorg-input-wacom.rules read rules file: /etc/udev/rules.d/70-persistent-cd.rules read rules file: /etc/udev/rules.d/70-persistent-net.rules read rules file: /lib/udev/rules.d/70-power-switch.rules read rules file: /lib/udev/rules.d/70-printers.rules read rules file: /lib/udev/rules.d/70-uaccess.rules read rules file: /etc/udev/rules.d/71-bh-permissions.rules read rules file: /etc/udev/rules.d/71-sd-permissions.rules read rules file: /lib/udev/rules.d/71-seat.rules read rules file: /etc/udev/rules.d/71-ti-permissions.rules read rules file: /lib/udev/rules.d/73-idrac.rules read rules file: /lib/udev/rules.d/73-seat-late.rules read rules file: /lib/udev/rules.d/75-net-description.rules read rules file: /lib/udev/rules.d/75-persistent-net-generator.rules read rules file: /lib/udev/rules.d/75-probe_mtd.rules read rules file: /lib/udev/rules.d/75-tty-description.rules read rules file: /lib/udev/rules.d/77-nm-olpc-mesh.rules read rules file: /lib/udev/rules.d/78-graphics-card.rules read rules file: /lib/udev/rules.d/78-sound-card.rules read rules file: /lib/udev/rules.d/80-drivers.rules read rules file: /lib/udev/rules.d/80-udisks.rules read rules file: /lib/udev/rules.d/80-udisks2.rules read rules file: /lib/udev/rules.d/85-brltty.rules read rules file: /lib/udev/rules.d/85-hdparm.rules read rules file: /lib/udev/rules.d/85-hplj10xx.rules read rules file: /lib/udev/rules.d/85-keyboard-configuration.rules read rules file: /lib/udev/rules.d/85-regulatory.rules read rules file: /lib/udev/rules.d/85-usbmuxd.rules read rules file: /lib/udev/rules.d/90-alsa-restore.rules read rules file: /lib/udev/rules.d/90-alsa-ucm.rules read rules file: /lib/udev/rules.d/90-libgpod.rules read rules file: /lib/udev/rules.d/90-pulseaudio.rules read rules file: /lib/udev/rules.d/95-cd-devices.rules read rules file: /lib/udev/rules.d/95-udev-late.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-dell.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-fujitsu.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-gateway.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-ibm.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-lenovo.rules read rules file: /lib/udev/rules.d/95-upower-battery-recall-toshiba.rules read rules file: /lib/udev/rules.d/95-upower-csr.rules read rules file: /lib/udev/rules.d/95-upower-hid.rules read rules file: /lib/udev/rules.d/95-upower-wup.rules read rules file: /lib/udev/rules.d/97-bluetooth-hid2hci.rules read rules file: /lib/udev/rules.d/97-ofono-speedup.rules read rules file: /lib/udev/rules.d/97-ofono.rules read rules file: /etc/udev/rules.d/99-icdi.rules rules contain 196608 bytes tokens (16384 * 12 bytes), 34402 bytes strings 16673 strings (147497 bytes), 13604 de-duplicated (116165 bytes), 3070 trie nodes used unable to open device '/sys/dev/bus/usb/001/006' unload module index
Once again, I'm not expert of this, but this is the content of the file /etc/udev/rules.d/71-ti-permissions.rules. Isn't the debugger we are trying to use ignored?
SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="a6d0",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="a6d1",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="6010",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="bcd9",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0403",ATTRS{idProduct}=="bcda",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="1cbe",ATTRS{idProduct}=="00fd",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="1cbe",ATTRS{idProduct}=="00ff",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0451",ATTRS{idProduct}=="bef1",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0451",ATTRS{idProduct}=="bef2",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0451",ATTRS{idProduct}=="bef3",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0451",ATTRS{idProduct}=="bef4",MODE:="0666" SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="0451",ATTRS{idProduct}=="c32a",MODE:="0666" ATTRS{idVendor}=="0451",ATTRS{idProduct}=="bef0",ENV{ID_MM_DEVICE_IGNORE}="1" ATTRS{idVendor}=="0c55",ATTRS{idProduct}=="0220",ENV{ID_MM_DEVICE_IGNORE}="1" KERNEL=="ttyACM[0-9]*",MODE:="0666"
Please let me know if you need further information.
Thanks in advance for any help.
