error on build of any project ...
Other Parts Discussed in Thread: MSP430G2553
I just downloaded the latest CCS 6, running on Windows 8.1  64 bit
I always get these errors:
**** Build of configuration MSP430G2553 for project SMB_Master00_AllProtocols ****
"C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
process_begin: CreateProcess(C:\Users\EHISK_~1\AppData\Local\Temp\make199940-1.bat, C:\Users\EHISK_~1\AppData\Local\Temp\make199940-1.bat, ...) failed.
make (e=2): The system cannot find the file specified.
gmake: *** [Master_HAL.obj] Error 2
gmake: *** [main.obj] Error 2
gmake: *** [smbuslib/smbus.obj] Error 2
gmake: *** [smbuslib/smbus_nwk.obj] Error 2
gmake: *** [smbuslib/MSP430G2xx3/smbus_phy.obj] Error 2
gmake: Target `all' not remade because of errors.
**** Build Finished ****
Any suggestions?  Thanks for whatever you can tell me
  • Hi Edward,
    your issue looks similar to the one reported in below thread:
    e2e.ti.com/.../444240
    Can you try Aarti's suggestions and see if they help at all?
    ki
  • I tried Aarti's suggestions, but no change. Here you can see the same problem happens with the TMP and TEMP changed to a custom c:\temp directory... also cleaned out the system PATH, and no help there either. Is there a way I can run gmake in a command line? Is there any documentation for it? Can you tell me where the build script for CSS is located? Thanks.
    Edward
  • ...here is the latest error listing --
    **** Build of configuration MSP430G2553 for project SMB_Slave01_ReadByteEcho ****
    process_begin: CreateProcess(c:\temp\make180376-1.bat, c:\temp\make180376-1.bat, ...) failed.
    gmake: *** [Slave_HAL.obj] Error 2
  • I just did additional installs on Windows 10, and then on Windows 7.
    It crashes with the same problem on WIndows 10. Windows 7 works OK.
    My guess is that TI is just not keeping up with Microsoft. Who can blame them?
    This seems to indicate that an incorrect make utility is being invoked (make instead of gmake).
    Can you double-check what your Windows PATH variable is set to? If you have other toolchains in your PATH that also contain make utilities in their directories, then that could cause a conflict, and the incorrect make may be picked up. Many things such as Cygwin, OpenCL, WINAVR in the system PATH may cause this issue. Try to set your PATH to a bare minimum, restart CCS and see if the error persists.
