CCSv6 An error has occurred. See the log file null.
I am running CCSv6.1.3.0034 on a Win7 SP1 32 bit machine, and I get the following when running in normal user mode,
However, when I right click on the shortcut, and select "Run as administrator, it seems to work fine.
I suspect this a permissions issue somewhere. Perhaps in the registry?
Can someone please help me with this?
Thanks, Mark.
  • Please take a look at this related thread. Can you check if a reboot of the computer helps?
  • Hi AartiG:
    I did find that related thread when searching before, but the suggestions there did not fix the problem.
    I will post my install log file.
    Thanks, Mark.
    Log started 07/24/2016 at 17:04:19
    Preferred installation mode : unattended
    Trying to init installer in mode unattended
    Mode unattended successfully initialized
    Cannot delete file C:/Users/Mark/AppData/Local/Temp/bitrock_installer_5460.log
    [17:04:21] installer_command_line_arguments :
    [17:04:24] Product Name Code Composer Studio 6.1.3
    [17:04:24] Product Version 6.1.3.00034
    [17:04:24]
    Preparing to Install
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin
    Unpacking files
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\appLaunch.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tcl86.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tclsh.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tclsh86.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tclvfse.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tk86.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tkcon.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\wish.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\wish86.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\zlib1.dll
    Directory already exists: C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\dict8.5.3
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8\8.5
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8\8.6
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\dde1.4
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\http1.0
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\opt0.4
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\reg1.3
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tbcload1.7
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\thread2.6.7
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tdom0.8.3
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5
    Unpacking files
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl86.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tclstub86.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk86.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tkstub86.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\arrow.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\bitmap.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\button.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\buttonbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\calendar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\ChangeLog
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\choosedir.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\choosefile.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\color.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\combobox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\configure.in
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\dialog.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\dragsite.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\drawerpanel.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\dropsite.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\dynhelp.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\entry.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\font.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\icons.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\init.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\label.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\labelentry.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\labelframe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\license.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\listbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\mainframe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\Makefile.in
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\messagedlg.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\notebook.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\optiontree.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\pagesmgr.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\panedw.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\panelframe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\passwddlg.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\preferences.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\progressbar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\progressdlg.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\properties.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\readme.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\scrollframe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\scrollview.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\scrollw.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\separator.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\spinbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\splitlist.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\statusbar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\stddialog.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\tablelist.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\text.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\titleframe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\todo.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\tree.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\ttkbutton.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\utils.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\widget.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\wizard.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\xpm2image.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\bold.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\BWidget.gif.tkico
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\BWidget.png.tkico
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\copy.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\cut.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\downarrow.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\dragfile.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\dragicon.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\error.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\file.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\folder.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\hourglass.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\info.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\italic.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\minus.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\new.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\opcopy.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\open.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\openfold.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\oplink.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\opmove.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\overstrike.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\palette.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\passwd.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\paste.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\plus.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\print.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\question.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\redo.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\save.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\target.xbm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\underline.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\undo.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\uparrow.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\images\warning.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\de.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\en.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\es.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\fr.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\hu.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\pl.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\BWidget\lang\pt_br.rc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\dict8.5.3\dict853.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\dict8.5.3\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itcl.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itcl4.0.1.tap
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itcl401.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itcl401.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itclConfig.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itclHullCmds.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itclstub401.lib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\itclWidget.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\itcl4.0.1\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8\8.5\msgcat-1.5.2.tm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8\8.5\tcltest-2.3.8.tm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8\8.6\http-2.8.8.tm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\auto.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\clock.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\history.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\init.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\package.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\parray.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\safe.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tclConfig-shared.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tclConfig.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tclIndex
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\teapot-link.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tm.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\word.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\dde1.4\dde.tap
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\dde1.4\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\dde1.4\tcldde14.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\ascii.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\big5.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1250.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1251.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1252.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1253.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1254.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1255.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1256.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1257.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp1258.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp437.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp737.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp775.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp850.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp852.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp855.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp857.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp860.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp861.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp862.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp863.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp864.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp865.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp866.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp869.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp874.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp932.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp936.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp949.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\cp950.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\dingbats.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\ebcdic.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\euc-cn.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\euc-jp.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\euc-kr.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\gb12345.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\gb1988.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\gb2312-raw.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\gb2312.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso2022-jp.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso2022-kr.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso2022.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-1.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-10.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-13.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-14.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-15.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-16.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-2.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-3.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-4.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-5.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-6.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-7.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-8.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\iso8859-9.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\jis0201.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\jis0208.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\jis0212.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\koi8-r.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\koi8-u.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\ksc5601.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macCentEuro.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macCroatian.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macCyrillic.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macDingbats.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macGreek.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macIceland.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macJapan.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macRoman.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macRomania.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macThai.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macTurkish.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\macUkraine.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\shiftjis.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\symbol.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\encoding\tis-620.enc
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\http1.0\http.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\http1.0\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\af.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\af_za.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ar.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ar_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ar_jo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ar_lb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ar_sy.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\be.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\bg.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\bn.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\bn_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ca.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\cs.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\da.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\de.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\de_at.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\de_be.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\el.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_au.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_be.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_bw.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_ca.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_gb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_hk.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_ie.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_nz.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_ph.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_sg.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_za.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\en_zw.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\eo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_ar.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_bo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_cl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_co.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_cr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_do.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_ec.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_gt.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_hn.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_mx.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_ni.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_pa.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_pe.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_pr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_py.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_sv.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_uy.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\es_ve.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\et.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\eu.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\eu_es.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fa.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fa_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fa_ir.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fi.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fo_fo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fr_be.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fr_ca.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\fr_ch.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ga.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ga_ie.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\gl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\gl_es.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\gv.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\gv_gb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\he.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\hi.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\hi_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\hr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\hu.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\id.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\id_id.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\is.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\it.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\it_ch.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ja.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kl_gl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ko.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kok.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kok_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ko_kr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kw.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\kw_gb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\lt.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\lv.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\mk.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\mr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\mr_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ms.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ms_my.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\mt.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\nb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\nl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\nl_be.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\nn.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\pl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\pt.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\pt_br.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ro.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ru.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ru_ua.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sh.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sk.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sq.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sv.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\sw.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ta.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\ta_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\te.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\te_in.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\th.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\tr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\uk.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\vi.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\zh.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\zh_cn.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\zh_hk.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\zh_sg.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\msgs\zh_tw.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\opt0.4\optparse.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\opt0.4\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\reg1.3\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\reg1.3\registry.tap
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\reg1.3\tclreg13.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tbcload1.7\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tbcload1.7\tbcload.tap
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\tbcload1.7\tbcload17.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\thread2.6.7\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\thread2.6.7\thread267.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tcl8.6\thread2.6.7\ttrace.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tdom0.8.3\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tdom0.8.3\tdom.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tdom0.8.3\tdom083.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\altTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\aquaTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\button.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\clamTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\classicTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\combobox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\cursors.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\defaults.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\dialog.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\entry.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\fonts.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\icons.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\keynav.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\menubutton.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\notebook.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\paned.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\progress.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\scale.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\scrollbar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\stepTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\tile.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\tile0.7.5.tap
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\tile075.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\treeview.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\utils.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\winTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tile0.7.5\xpTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\bgerror.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\button.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\choosedir.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\clrpick.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\comdlg.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\console.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\dialog.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\entry.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\focus.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\fontchooser.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\iconlist.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\icons.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\listbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\megawidget.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\menu.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\mkpsenc.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\obsolete.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\optMenu.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\palette.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\panedwindow.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\safetk.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\scale.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\scrlbar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\spinbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tclIndex
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tearoff.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\text.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tk.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tkAppInit.c
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tkConfig-shared.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tkConfig.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\tkfbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\unsupported.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\xmfbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\lamp.png
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\lamp.svg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\logo.eps
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\logo100.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\logo64.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\logoLarge.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\logoMed.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo.eps
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo100.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo150.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo175.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo200.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\pwrdLogo75.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\README
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\images\tai-ku.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\cs.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\da.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\de.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\el.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\en.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\en_gb.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\eo.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\es.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\fr.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\hu.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\it.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\nl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\pl.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\pt.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\ru.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\msgs\sv.msg
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\altTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\aquaTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\button.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\clamTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\classicTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\combobox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\cursors.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\defaults.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\entry.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\fonts.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\menubutton.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\notebook.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\panedwindow.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\progress.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\scale.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\scrollbar.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\sizegrip.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\spinbox.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\treeview.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\ttk.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\utils.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\vistaTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\winTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tk8.6\ttk\xpTheme.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\pkgIndex.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\README.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\README.win32
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\tls.htm
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\tls.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\lib\tls1.5\tls15.dll
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util
    Unpacking files
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\CCScube.png
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\CCSCubeSmall.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ccs_installini_linux-x64.xml
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ccs_installini_linux.xml
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ccs_installini_osx.xml
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ccs_installini_windows.xml
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ccs_manifest_windows.xml
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\libeay32.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\libiconv2.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\libintl3.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\libpacparser.1.dylib
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\libssl32.dll
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\lsproxy.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ofview-x64.zip
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\ofview.zip
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\pactester
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\proxyfinder.sh
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\unzip.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\wget.exe
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\zip.exe
    Extracting compressed file C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\OpenedFilesView.chm
    Extracting compressed file C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\OpenedFilesView.exe
    Extracting compressed file C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\util\readme.txt
    Directory already exists: C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates
    Unpacking files
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ewa1.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ewa2.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ewa3.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ewa4.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\install-certs.bat
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\sd1.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ti1.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ti2.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ti3.p7b
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\certificates\ti4.p7b
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\images
    Unpacking files
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\error_report
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\install
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\launch
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources
    Creating directory C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\update_frontend
    Unpacking files
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\6.1.3.201606291323.txt
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\csv.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\Externs.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\Images.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\InstallDir.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\json-1.2.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\Logger.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\ProgramArgs.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\PropertiesFile.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\PropertiesFileWriter.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\Util.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\Validation.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\BasePane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\FinishPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\ProgressPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\ProgressUpdate.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\SilentProgressPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\panes\ThreadedProgressUpdate.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\AppsJson.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\AppsProduct.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\Component.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\ComponentDetail.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\ConfigFileFeature.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\ConfigFileReader.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\ConfigFileWriter.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\Edition.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\editManifest.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\InstallComponent.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\InstallIni.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\JsonReader.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\Manifest.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\PaneTreeItem.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\ProductFamily.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\UpdateManifest.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\common\xml\XmlReader.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\error_report\error_report.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\error_report\main.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\install\.buildpath
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\install\.project
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\install\InstallComponents.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\launch\main.launch
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\launch\udpate.launch
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\main.tcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\ResponseFile.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\AppsPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\BaseListPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\BaseTextPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\BaseTreePane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\ComponentsPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\EmulatorsPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\InstallDirPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\ISAPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\LaunchersPane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\panes\LicensePane.itcl
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\appIcon.xcf
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\appsIcon.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\appsIcon_osx.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\CCScube.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\CCScube.png
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\main_frontend\resources\CCSCubeSmall.gif
    Unpacking C:\Users\Mark\AppData\Local\Temp\ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\installer_tcl\update_frontend\main.tcl
    [17:04:53] admin = 1
    [17:04:53] installertype = setup
    [17:04:53]
    [17:04:53] running C:\Users\Mark\AppData\Local\Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tclsh "C:/Users/Mark/AppData/Local/Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28/installer_tcl/main_frontend/main.tcl" --installersrc "D:/Downloads/_ComputerRelated/_Development_Hardware/ti/CCS/V6" --installertmp "C:/Users/Mark/AppData/Local/Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28" --buildid 6.1.3.00034 --installer "D:/Downloads/_ComputerRelated/_Development_Hardware/ti/CCS/V6/ccs_setup_win32.exe" --bitness 32-bit --os windows --osname "Windows 7" --spversion "1"
    Executing C:\Users\Mark\AppData\Local\Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28\tcl\bin\tclsh "C:/Users/Mark/AppData/Local/Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28/installer_tcl/main_frontend/main.tcl" --installersrc "D:/Downloads/_ComputerRelated/_Development_Hardware/ti/CCS/V6" --installertmp "C:/Users/Mark/AppData/Local/Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28" --buildid 6.1.3.00034 --installer "D:/Downloads/_ComputerRelated/_Development_Hardware/ti/CCS/V6/ccs_setup_win32.exe" --bitness 32-bit --os windows --osname "Windows 7" --spversion "1"
    Script exit code: 0
    Script output:
    Script stderr:
    [18:03:49]
    [18:03:49]
    [18:03:49]
    launchCCS:0
    createDesktopShortcut:0
    createStartMenuShortcut:0
    eclipsedir:c:/ti/ccsv6/eclipse
    [18:03:49] ccsdir = c:/ti/ccsv6
    [18:03:49] Found C:\Users\Mark\AppData\Local\Temp/ccs_915912e7-c6b5-461f-5a9a-c753f0489e28/finish.txt
    [18:03:49] deleting Code Composer Studio 6.1.1 6.1.1.00022
    [18:03:50] deleting temp directory
    Creating Uninstaller
    Creating uninstaller 25%
    Creating uninstaller 50%
    Creating uninstaller 75%
    Creating uninstaller 100%
    Installation completed
    [18:04:25] ccsdir = c:/ti/ccsv6
    [18:04:26] testing unity: c:/ti/Code Composer Studio 6.1.3.desktop
    1
    false
    Log finished 07/24/2016 at 18:04:26
  • Could you please also attach your Eclipse log file? It is the .log file inside the .metadata directory in your workspace folder.
    The file can be quite large so please attach it using the "Insert File" icon that will appear when you click on "Use rich formatting" when replying to the post.
  • AartiG:
    Thanks for taking the time for this.
    I tried to use the file attach as you requested, but it kept complaining about only allowing certain URL's or file extensions, so I inserted the old fashioned way. Sorry 'bout that.
    Note, the last entries in the log are dated the 9th. I ran CCS then by right clicking the icon and selecting "Run as administrator".
    Today, the 10th, I tried to run as normal user and got the usual error above.
    It doesn't get to the point of asking me for the workspace, so I suspect the log I am attaching is not what you are looking for.
    There is a second log dated today inserted below this one.
    !SESSION 2016-08-08 12:06:47.270 -----------------------------------------------
    eclipse.buildId=4.5.1.M20150904-0015
    java.version=1.7.0_80
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    This is a continuation of log file N:\Standalone_EQ\Piccolo-28022\.metadata\.bak_0.log
    Created Time: 2016-08-08 17:08:20.448
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:20.471
    !MESSAGE Error
    !STACK 0
    java.nio.channels.ClosedByInterruptException
    	at java.nio.channels.spi.AbstractInterruptibleChannel.end(AbstractInterruptibleChannel.java:202)
    	at sun.nio.ch.FileChannelImpl.size(FileChannelImpl.java:312)
    	at org.eclipse.cdt.internal.core.parser.scanner.FileCharArray.create(FileCharArray.java:44)
    	at org.eclipse.cdt.internal.core.parser.InternalParserUtil.createFileContent(InternalParserUtil.java:240)
    	at org.eclipse.cdt.internal.core.parser.InternalParserUtil.createExternalFileContent(InternalParserUtil.java:223)
    	at org.eclipse.cdt.core.parser.FileContent.createForExternalFileLocation(FileContent.java:129)
    	at org.eclipse.cdt.core.parser.FileContent.createForExternalFileLocation(FileContent.java:121)
    	at org.eclipse.cdt.internal.core.parser.SavedFilesProvider.getContentForInclusion(SavedFilesProvider.java:37)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor$1.checkFile(CPreprocessor.java:164)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor$1.checkFile(CPreprocessor.java:1)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.findInclusion(CPreprocessor.java:1231)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.executeInclude(CPreprocessor.java:1578)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.executeDirective(CPreprocessor.java:1354)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.internalFetchToken(CPreprocessor.java:942)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.fetchToken(CPreprocessor.java:641)
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.nextToken(CPreprocessor.java:738)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.fetchToken(AbstractGNUSourceCodeParser.java:278)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.nextToken(AbstractGNUSourceCodeParser.java:302)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.acceptInactiveCodeBoundary(AbstractGNUSourceCodeParser.java:363)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.declarationList(AbstractGNUSourceCodeParser.java:1333)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.parseTranslationUnit(AbstractGNUSourceCodeParser.java:1306)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.translationUnit(AbstractGNUSourceCodeParser.java:1301)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.parse(AbstractGNUSourceCodeParser.java:658)
    	at org.eclipse.cdt.core.dom.parser.AbstractCLikeLanguage.getASTTranslationUnit(AbstractCLikeLanguage.java:167)
    	at org.eclipse.cdt.internal.core.model.TranslationUnit.getAST(TranslationUnit.java:876)
    	at org.eclipse.cdt.internal.core.model.TranslationUnit.getAST(TranslationUnit.java:826)
    	at sun.reflect.GeneratedMethodAccessor257.invoke(Unknown Source)
    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    	at java.lang.reflect.Method.invoke(Method.java:606)
    	at org.eclipse.rtsc.xdctools.ui.contentassist.RTSCHelpProvider.getFunctionSummaries(Unknown Source)
    	at org.eclipse.rtsc.xdctools.ui.contentassist.RTSCHelpProvider.getFunctionInfo(Unknown Source)
    	at org.eclipse.cdt.internal.ui.text.CHelpSettings.getFunctionInfo(CHelpSettings.java:121)
    	at org.eclipse.cdt.internal.ui.CHelpProviderManager.getFunctionInfo(CHelpProviderManager.java:163)
    	at org.eclipse.cdt.internal.ui.text.c.hover.CDocHover.getHoverInfo(CDocHover.java:86)
    	at org.eclipse.cdt.internal.ui.text.c.hover.AbstractCEditorTextHover.getHoverInfo2(AbstractCEditorTextHover.java:84)
    	at org.eclipse.cdt.internal.ui.text.c.hover.BestMatchHover.getHoverInfo2(BestMatchHover.java:144)
    	at org.eclipse.cdt.internal.ui.text.c.hover.CEditorTextHoverProxy.getHoverInfo2(CEditorTextHoverProxy.java:84)
    	at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextViewerHoverManager.java:166)
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:20.521
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:20.586
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:20.641
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:20.756
    !MESSAGE Error
    !STACK 0
    	at org.eclipse.cdt.internal.core.parser.scanner.CPreprocessor.findInclusion(CPreprocessor.java:1191)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.lookaheadToken(AbstractGNUSourceCodeParser.java:312)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.LA(AbstractGNUSourceCodeParser.java:335)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.LT(AbstractGNUSourceCodeParser.java:461)
    	at org.eclipse.cdt.internal.core.dom.parser.c.GNUCSourceParser.initClause(GNUCSourceParser.java:163)
    	at org.eclipse.cdt.internal.core.dom.parser.c.GNUCSourceParser.optionalInitializer(GNUCSourceParser.java:146)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.addInitializer(AbstractGNUSourceCodeParser.java:1803)
    	at org.eclipse.cdt.internal.core.dom.parser.c.GNUCSourceParser.simpleDeclaration(GNUCSourceParser.java:325)
    	at org.eclipse.cdt.internal.core.dom.parser.c.GNUCSourceParser.declaration(GNUCSourceParser.java:298)
    	at org.eclipse.cdt.internal.core.dom.parser.AbstractGNUSourceCodeParser.declarationList(AbstractGNUSourceCodeParser.java:1365)
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:34.886
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:34.970
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.017
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.069
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.129
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.199
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.263
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.312
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.363
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.413
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.466
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.524
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.582
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.676
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.749
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.846
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:35.892
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.014
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.067
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.195
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.763
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.818
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.920
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:36.975
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.086
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.155
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.227
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.277
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.325
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.379
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.435
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.499
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.565
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.620
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.756
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.821
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.883
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:37.930
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:38.101
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:38.166
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:38.282
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.102
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.146
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.202
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.280
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.373
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.461
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.512
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.554
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.599
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.655
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.742
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.800
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.873
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.920
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:39.996
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:40.067
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:40.120
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:08:40.316
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:36.785
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:36.849
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:36.912
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:36.961
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:37.012
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:37.079
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:37.132
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:37.253
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:39.416
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:39.528
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:39.634
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:44.907
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:44.966
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.052
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.106
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.153
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.206
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.262
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.326
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.426
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.489
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.544
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.648
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.734
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.783
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.840
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:45.930
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:46.054
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.337
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.392
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.448
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.509
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.581
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.643
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.693
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.744
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.831
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.923
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:55.981
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.027
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.091
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.145
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.201
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.244
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.294
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.349
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:09:56.476
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:41.736
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:41.796
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:41.843
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:41.898
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:41.943
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.002
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.078
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.131
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.187
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.242
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.292
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.339
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.390
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.503
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:10:42.632
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:29.689
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:29.751
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:29.796
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:29.874
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:29.933
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.035
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.085
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.132
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.185
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.232
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.280
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.338
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.406
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.488
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.552
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.786
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.873
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.936
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:30.990
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:11:31.126
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.ui 4 0 2016-08-08 17:52:07.090
    !MESSAGE Error in CDT UI during reconcile
    !STACK 1
    C Model Exception: C Model Status [Element file:/N:/Standalone_EQ/Piccolo-28022/Include/ReadWrite8530.h does not exist.]
    	at org.eclipse.cdt.internal.core.model.CElement.newNotPresentException(CElement.java:484)
    	at org.eclipse.cdt.internal.core.model.TranslationUnit.makeConsistent(TranslationUnit.java:573)
    	at org.eclipse.cdt.internal.core.model.ReconcileWorkingCopyOperation.executeOperation(ReconcileWorkingCopyOperation.java:62)
    	at org.eclipse.cdt.internal.core.model.CModelOperation.execute(CModelOperation.java:341)
    	at org.eclipse.cdt.internal.core.model.CModelOperation.run(CModelOperation.java:607)
    	at org.eclipse.cdt.internal.core.model.CModelOperation.runOperation(CModelOperation.java:635)
    	at org.eclipse.cdt.internal.core.model.WorkingCopy.reconcile(WorkingCopy.java:362)
    	at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:78)
    	at org.eclipse.cdt.internal.ui.text.CReconcilingStrategy.reconcile(CReconcilingStrategy.java:63)
    	at org.eclipse.cdt.internal.ui.text.CompositeReconcilingStrategy.reconcile(CompositeReconcilingStrategy.java:87)
    	at org.eclipse.cdt.internal.ui.text.CCompositeReconcilingStrategy.reconcile(CCompositeReconcilingStrategy.java:95)
    	at org.eclipse.jface.text.reconciler.MonoReconciler.process(MonoReconciler.java:77)
    	at org.eclipse.cdt.internal.ui.text.CReconciler.process(CReconciler.java:349)
    	at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:206)
    !SUBENTRY 1 org.eclipse.cdt.core 4 969 2016-08-08 17:52:07.093
    !MESSAGE Element file:/N:/Standalone_EQ/Piccolo-28022/Include/ReadWrite8530.h does not exist.
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:50.619
    !MESSAGE Error
    !STACK 0
    	at sun.reflect.GeneratedMethodAccessor277.invoke(Unknown Source)
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:51.608
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:51.889
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:52.334
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:52.987
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:53.360
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:53.615
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:54.095
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:55.384
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:52:55.821
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:48.792
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:49.084
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:49.145
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:49.203
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:50.316
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:51.083
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:53.172
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:54.260
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:54.579
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:54.813
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:54.892
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:54.946
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.041
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.177
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.231
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.286
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.333
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.378
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.435
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.489
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:53:55.604
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:57:50.571
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:57:50.685
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 17:57:50.828
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.362
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.421
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.464
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.605
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.651
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.709
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.773
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.838
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:33.885
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.169
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.215
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.258
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.313
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.370
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:01:34.529
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:01.108
    !MESSAGE Error
    !STACK 0
    	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:01.398
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:01.491
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:01.668
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:01.823
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:31:02.553
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:05.249
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:05.449
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:05.595
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:05.696
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.041
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.305
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.410
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.541
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.653
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.842
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:06.987
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.337
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.458
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.544
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.628
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.710
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:07.792
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:33:08.055
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:02.615
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:02.740
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:02.833
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:02.935
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:03.035
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:03.330
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:03.596
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.031
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.182
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.277
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.504
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.729
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.833
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:04.958
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-08 18:35:05.493
    !MESSAGE Error
    !STACK 0
    !SESSION 2016-08-09 11:38:02.941 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-08-09 11:39:11.005
    !MESSAGE path=ccs_base/DebugServer
    !ENTRY com.ti.common.core 4 0 2016-08-09 11:39:11.183
    !MESSAGE debugServerDir=C:/ti/ccsv6/ccs_base/DebugServer
    !ENTRY org.eclipse.ui 2 0 2016-08-09 11:41:52.896
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.graph.visualization' does not provide a 'class' attribute.
    This usage is deprecated and a 'class' attribute should be provided.
    The release after Mars (4.5) will no longer support the deprecated usage!
    !ENTRY org.eclipse.ui 2 0 2016-08-09 11:41:53.193
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.rovsupport' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-08-09 11:41:53.894
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.ui' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-08-09 11:41:54.843
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.uia.sessionmgr.view' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-08-09 11:41:55.281
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.util.ui' does not provide a 'class' attribute.
    !ENTRY org.eclipse.cdt.core 1 0 2016-08-09 11:47:18.418
    !MESSAGE Indexed 'Standalone_Wireless_Programmer' (5 sources, 23 headers) in 4.08 sec: 1,973 declarations; 2,492 references; 0 unresolved inclusions; 4 syntax errors; 151 unresolved names (3.3%)
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.088
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.162
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.217
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.262
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.304
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.366
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.421
    !MESSAGE Error
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-08-09 11:48:03.653
    !MESSAGE Error
    !STACK 0
    I found a much shorter log file dated today in the CCS install folder (C:\ti\ccsv6\eclipse\configuration) that may be of more help (also attached.)
    !SESSION 2016-08-10 11:38:07.705 -----------------------------------------------
    !ENTRY org.eclipse.osgi 4 0 2016-08-10 11:38:08.888
    !MESSAGE Error reading configuration: C:\ti\ccsv6\eclipse\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
    !STACK 0
    java.io.FileNotFoundException: C:\ti\ccsv6\eclipse\configuration\org.eclipse.osgi\.manager\.fileTableLock (Access is denied)
    	at java.io.RandomAccessFile.open(Native Method)
    	at java.io.RandomAccessFile.<init>(RandomAccessFile.java:241)
    	at org.eclipse.osgi.internal.location.Locker_JavaNio.lock(Locker_JavaNio.java:36)
    	at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:388)
    	at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:701)
    	at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1760)
    	at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1777)
    	at org.eclipse.osgi.storage.Storage.<init>(Storage.java:128)
    	at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:87)
    	at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:75)
    	at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:295)
    	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:231)
    	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
    	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
    	at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
    Mark.
  • They appear to be Java exceptions but I'm not sure what is triggering them. I know it is an inconvenience but would you mind trying an uninstall and reinstall of CCS?
    If you do so, be sure to wipe out the old install directory completely before reinstalling to the same location.
    You can also review this troubleshooting section in case any of the suggestions there help:
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCSv6#Startup
  • Thanks again AartiG:
    OK, I found the problem.
    I did look over the link you sent and, while thinking upon those tips, I discarded them because it works if I run as administrator so there must be nothing wrong with the installation.
    As a test, I stopped and restarted CCS today and ran with elevated privileges, and noted no new short log file was created in C:\ti\ccsv6\eclipse\configuration. So a log file is created only when there is a problem.
    This got me thinking again about permissions. So I added the column "owner" to the explorer listing noted all the files and sub folders were created with user administrator. This makes sense as when I ran the install, Windows popped up the "Run ad administrator" query.
    Sure enough, I went in and found that users had only read and execute permissions, where administrator had full permissions.
    I changed the permissions of all files (and sub folders and files) to full control, and, wallah, all is golden.
    I will marked this as solved and go to the other poses and recommend they also try the permissions solution.
    Thanks again AartiG.
    Mark.
  • Thank you for the update and glad you were able to resolve the issue.
