CCS 6.2 - Multiple java.lang.NullPointerException
Other Parts Discussed in Thread: CCSTUDIO, STRIKE
Ubuntu 16.04 LTS
java version "1.8.0_101"
Code Composer Studio: Version: 6.2.0.00050
The worst is the 'An internal error occurred during: "Refreshing paths and symbols"'. This pops up a dialog at startup and everytime a file changes in the workspace making CCS 6.2 unusable.
!ENTRY com.ti.common.project.core 4 0 2016-10-10 15:16:28.680
!MESSAGE An internal error was logged by 'com.ti.common.project.core'.
!STACK 0
at com.ti.common.project.core.util.CTIProjectCoreUtils.getConfigurationSettings(CTIProjectCoreUtils.java:1214)
at com.ti.ccstudio.project.core.internal.legacy.ImplicitLegacyCCSProjectMigrator.onProjectBuild_Pre(ImplicitLegacyCCSProjectMigrator.java:146)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$6.visit(ProjectStateMonitor.java:359)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.notifyListeners(ProjectStateMonitor.java:644)
at com.ti.common.project.core.internal.events.ProjectStateMonitor.access$2(ProjectStateMonitor.java:633)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:357)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:299)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:289)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:152)
at org.eclipse.core.internal.resources.Workspace.broadcastBuildEvent(Workspace.java:359)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!ENTRY com.ti.common.project.core 4 0 2016-10-10 15:16:28.681
!STACK 0
at com.ti.ccstudio.project.core.internal.ProjectStateListener.onResourceRemoved(ProjectStateListener.java:251)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$1$2.visit(ProjectStateMonitor.java:242)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$1.visit(ProjectStateMonitor.java:240)
at org.eclipse.core.internal.events.ResourceDelta.accept(ResourceDelta.java:63)
at org.eclipse.core.internal.events.ResourceDelta.accept(ResourceDelta.java:74)
at org.eclipse.core.internal.events.ResourceDelta.accept(ResourceDelta.java:47)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:213)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:147)
!ENTRY com.ti.ccstudio.project.core 4 0 2016-10-10 15:16:28.682
!MESSAGE An internal error was logged by 'com.ti.ccstudio.project.core'.
!STACK 0
at com.ti.ccstudio.project.core.internal.ProjectStateListener.onProjectBuild_Post(ProjectStateListener.java:467)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener$7.visit(ProjectStateMonitor.java:373)
at com.ti.common.project.core.internal.events.ProjectStateMonitor$ResourceChangeListener.resourceChanged(ProjectStateMonitor.java:371)
!ENTRY org.eclipse.core.jobs 4 2 2016-10-10 15:16:28.683
!MESSAGE An internal error occurred during: "Refreshing paths and symbols".
!STACK 0
at org.eclipse.cdt.build.internal.core.scannerconfig2.CfgScannerConfigInfoFactory2.create(CfgScannerConfigInfoFactory2.java:366)
at org.eclipse.cdt.build.internal.core.scannerconfig2.CfgScannerConfigProfileManager.getCfgScannerConfigBuildInfo(CfgScannerConfigProfileManager.java:27)
at com.ti.ccstudio.project.core.internal.build.ProjectScannerInfoManager$UpdateJob.invokeScannerConfigBuilder(ProjectScannerInfoManager.java:128)
at com.ti.ccstudio.project.core.internal.build.ProjectScannerInfoManager$UpdateJob.runInWorkspace(ProjectScannerInfoManager.java:108)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:39)
  • Works fine on Version: 6.1.3.00034
    Can this behavior be isolated to just one or more projects, (ie) can you open a new workspace and import just one project into it and reproduce the behavior? Or does it occur in general no matter which project or which workspace?
    Please see this thread that discusses a similar issue that was fixed in an earlier version of CCSv6. Since you are experiencing this with CCS 6.2, It is possible that the problem you are seeing is a similar but different manifestation.
    Would you be able to provide us your project so we can reproduce the issue and investigate it? If not the entire project, then at least the project metadata files (.*project)?
  • Preface, I do not use CCS to build, only as an IDE / JTAG debugger. I build with the external TI compiler on command line.
    Seems to occur with every project I checkout from SVN (via subversive) which are also very large projects.
    Does not seem to occur on small project (i.e. hello world).
    I can't attach the whole project. I can attach the project files (which are not stored in SVN, they are created on checkout by CCS).
    How do I attach files?
  • Started happening on CCS 6.1.3.00034 now too. Does not happen on a different PC with the same Ubuntu version. However this PC is using OpenJDK, not the Oracle JDK.
  • Strike that idea, CCS is using the packaged JRE.
    Please see this post for information on how to attach.
    If the same projects do not exhibit this behavior on a different PC, then there must be something slowing things down on the problematic PC.
    We can take a look at your project files and I'll also check with others here to see if we have other ideas on what could be triggering this.
  • Update. It doesn't happen on CCS 6.1.3.00034 if I create the project with CCS 6.1.3.00034. It does happen on CCS 6.1.3.00034 if the project was originally created with CCS 6.2.
  • Can you share the project files for one such project that demonstrates the problem? My previous post tells how you can attach files.
  • Hi Simon,
    for your information, you are not alone with that issue. I have also that issue after updating to CCS 6.2.0.00050. Im using also a real project with a lot of sub-libraries and some C6657 programs. I am running on Windows 7 Ultimate 64bit, so the problem is not related to Ubuntu.
    Kind regards
    Sven
  • Simon, Sven,
    We would really like to get to the bottom of this issue, so if you are willing to share your project files and other details so we can reproduce this at our end, it will be very much appreciated.
  • Dear Aarti,
    sorry for the late response. My project is very large and contains a lot of private sources, which I can not share. Please take also a look to that post:
    e2e.ti.com/.../2004704
    It describes the same issue around "Refreshing paths and symbols".
    The "Refreshing paths and symbols" pops up also during setting of break points.
    Kind regards
    Sven
    Yes that post mentions the same message, however we have not been able to reproduce this locally which makes it challenging to investigate.
    Would you be willing to share the workspace log file? Perhaps that will provide some clues. This is the .log file that is in your workspace's .metadata folder.
  • Dear Aarti,
    attached is my .log file. Before I have delete all old .log files. After them I have clean all projects and then I have build the main project multiple times. On my PC the CCS needs around 3 minutes (sometimes also 5 minutes) before the builder runs the gmake.
    It looks like that the .log file does not contains logs from the building process :-(
    Kind regards
    Sven
    !SESSION 2016-11-02 18:03:55.954 -----------------------------------------------
    eclipse.buildId=4.5.1.M20150904-0015
    java.version=1.7.0_80
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
    Framework arguments:  -product com.ti.ccstudio.branding.product
    Command-line arguments:  -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    !ENTRY org.eclipse.equinox.p2.engine 4 4 2016-11-02 18:03:59.910
    !MESSAGE An error occurred while configuring the installed items
    !SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2016-11-02 18:03:59.910
    !MESSAGE session context was:(profile=epp.package.cpp, phase=org.eclipse.equinox.internal.p2.engine.phases.Configure, operand=null --> [R]com.ti.gcc.arm.win32.zipselector.notmac 1.0.0, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CopyAction).
    !SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.natives 4 0 2016-11-02 18:03:59.910
    !MESSAGE I/O Error while copying D:\ti\ccsv6\eclipse\features\com.ti.gcc.arm.win32_4.9.3.2015q3_20150921\com.ti.gcc.arm.win32.properties - see details.
    !STACK 0
    java.io.IOException: Source: D:\ti\ccsv6\eclipse\features\com.ti.gcc.arm.win32_4.9.3.2015q3_20150921\com.ti.gcc.arm.win32.propertiesdoes not exists
    	at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CopyAction.xcopy(CopyAction.java:118)
    	at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CopyAction.mergeCopy(CopyAction.java:104)
    	at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CopyAction.copy(CopyAction.java:77)
    	at org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CopyAction.execute(CopyAction.java:39)
    	at org.eclipse.equinox.internal.p2.engine.ParameterizedProvisioningAction.execute(ParameterizedProvisioningAction.java:38)
    	at org.eclipse.equinox.internal.p2.engine.Phase.mainPerform(Phase.java:183)
    	at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:95)
    	at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
    	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
    	at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
    	at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.executePlan(ProfileSynchronizer.java:805)
    	at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.performAddRemove(ProfileSynchronizer.java:202)
    	at org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSynchronizer.synchronize(ProfileSynchronizer.java:141)
    	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.synchronize(Activator.java:469)
    	at org.eclipse.equinox.internal.p2.reconciler.dropins.Activator.start(Activator.java:177)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
    	at java.security.AccessController.doPrivileged(Native Method)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
    	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
    	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)
    	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)
    	at org.eclipse.osgi.container.Module.doStart(Module.java:571)
    	at org.eclipse.osgi.container.Module.start(Module.java:439)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
    	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
    	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
    !ENTRY com.ti.common.core 4 0 2016-11-02 18:04:02.720
    !MESSAGE path=ccs_base/DebugServer
    !ENTRY com.ti.common.core 4 0 2016-11-02 18:04:02.727
    !MESSAGE debugServerDir=D:/ti/ccsv6/ccs_base/DebugServer
    !ENTRY org.eclipse.ui 2 0 2016-11-02 18:04:10.918
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.graph.visualization' does not provide a 'class' attribute.
    This usage is deprecated and a 'class' attribute should be provided.
    The release after Mars (4.5) will no longer support the deprecated usage!
    !ENTRY org.eclipse.ui 2 0 2016-11-02 18:04:10.932
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.rovsupport' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-11-02 18:04:10.954
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.dvt.ui' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-11-02 18:04:10.962
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.util.ui' does not provide a 'class' attribute.
    !ENTRY org.eclipse.ui 2 0 2016-11-02 18:04:10.985
    !MESSAGE The 'org.eclipse.ui.startup' extension from 'com.ti.uia.sessionmgr.view' does not provide a 'class' attribute.
    !ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2016-11-02 18:04:54.524
    !MESSAGE No repository found at file:/D:/ti.ccs-6.2.0/ccsv6/eclipse/configuration/org.eclipse.osgi/173/data/listener_1925729951/.
    !ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2016-11-02 18:04:54.535
    !MESSAGE No repository found at file:/D:/ti.ccs-6.2.0/ccsv6/eclipse/.eclipseextension.
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:06:05.772
    !MESSAGE Error: sig_bits is not a member of mask_uint_t
    !STACK 0
    java.lang.IllegalArgumentException: sig_bits is not a member of mask_uint_t
    	at org.eclipse.cdt.internal.core.dom.parser.cpp.ClassTypeHelper.invalidMember(ClassTypeHelper.java:1021)
    	at org.eclipse.cdt.internal.core.dom.parser.cpp.ClassTypeHelper.getVisibility(ClassTypeHelper.java:945)
    	at org.eclipse.cdt.internal.core.dom.parser.cpp.CPPClassSpecialization.getVisibility(CPPClassSpecialization.java:459)
    	at org.eclipse.cdt.internal.core.pdom.dom.cpp.PDOMCPPLinkage.getVisibility(PDOMCPPLinkage.java:608)
    	at org.eclipse.cdt.internal.core.pdom.dom.cpp.PDOMCPPLinkage.addChild(PDOMCPPLinkage.java:619)
    	at org.eclipse.cdt.internal.core.pdom.dom.cpp.PDOMCPPLinkage.createBinding(PDOMCPPLinkage.java:570)
    	at org.eclipse.cdt.internal.core.pdom.dom.cpp.PDOMCPPLinkage.addBinding(PDOMCPPLinkage.java:424)
    	at org.eclipse.cdt.internal.core.pdom.dom.cpp.PDOMCPPLinkage.addBinding(PDOMCPPLinkage.java:370)
    	at org.eclipse.cdt.internal.core.pdom.dom.PDOMFile.createPDOMName(PDOMFile.java:515)
    	at org.eclipse.cdt.internal.core.pdom.dom.PDOMFile.addNames(PDOMFile.java:482)
    	at org.eclipse.cdt.internal.core.pdom.WritablePDOM.addFileContent(WritablePDOM.java:154)
    	at org.eclipse.cdt.internal.core.index.WritableCIndex.setFileContent(WritableCIndex.java:87)
    	at org.eclipse.cdt.internal.core.pdom.PDOMWriter.storeFileInIndex(PDOMWriter.java:616)
    	at org.eclipse.cdt.internal.core.pdom.PDOMWriter.storeSymbolsInIndex(PDOMWriter.java:316)
    	at org.eclipse.cdt.internal.core.pdom.PDOMWriter.addSymbols(PDOMWriter.java:273)
    	at org.eclipse.cdt.internal.core.pdom.AbstractIndexerTask.writeToIndex(AbstractIndexerTask.java:1279)
    	at org.eclipse.cdt.internal.core.pdom.AbstractIndexerTask.parseFile(AbstractIndexerTask.java:1094)
    	at org.eclipse.cdt.internal.core.pdom.AbstractIndexerTask.parseLinkage(AbstractIndexerTask.java:898)
    	at org.eclipse.cdt.internal.core.pdom.AbstractIndexerTask.runTask(AbstractIndexerTask.java:554)
    	at org.eclipse.cdt.internal.core.pdom.indexer.PDOMIndexerTask.run(PDOMIndexerTask.java:161)
    	at org.eclipse.cdt.internal.core.pdom.indexer.PDOMUpdateTask.run(PDOMUpdateTask.java:94)
    	at org.eclipse.cdt.internal.core.pdom.PDOMIndexerJob.run(PDOMIndexerJob.java:149)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:06:05.776
    !MESSAGE Error: sig_bits_fast is not a member of mask_uint_t
    !STACK 0
    java.lang.IllegalArgumentException: sig_bits_fast is not a member of mask_uint_t
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:06:38.261
    !STACK 0
    	at org.eclipse.cdt.internal.core.pdom.indexer.PDOMRebuildTask.run(PDOMRebuildTask.java:90)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:06:38.265
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:06:40.495
    !MESSAGE Indexed 'dabrf.cmd' (37 sources, 1.782 headers) in 32,8 sec: 116.062 declarations; 709.066 references; 0 unresolved inclusions; 365 syntax errors; 791 unresolved names (0,096 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:07:08.309
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:07:08.315
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:07:24.962
    !MESSAGE Indexed 'dabrf.core' (98 sources, 1.540 headers) in 44,4 sec: 111.106 declarations; 695.559 references; 0 unresolved inclusions; 731 syntax errors; 1.924 unresolved names (0,24 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:07:27.631
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:07:27.635
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:07:51.302
    !MESSAGE Indexed 'dabrf.driver' (14 sources, 1.434 headers) in 26,3 sec: 100.516 declarations; 640.254 references; 0 unresolved inclusions; 252 syntax errors; 763 unresolved names (0,1 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:07:52.836
    !MESSAGE Indexed 'dabrf.fatfs' (15 sources, 105 headers) in 1,52 sec: 5.696 declarations; 15.418 references; 0 unresolved inclusions; 493 syntax errors; 109 unresolved names (0,51 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:10.356
    !MESSAGE Indexed 'dabrf.helper' (18 sources, 725 headers) in 17,5 sec: 35.167 declarations; 221.956 references; 1 unresolved inclusions; 32 syntax errors; 188 unresolved names (0,073 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:16.634
    !MESSAGE Indexed 'dabrf.idc' (13 sources, 303 headers) in 6,26 sec: 22.865 declarations; 46.224 references; 0 unresolved inclusions; 92 syntax errors; 16 unresolved names (0,023 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:17.387
    !MESSAGE Indexed 'dabrf.miniz' (5 sources, 18 headers) in 0,738 sec: 2.779 declarations; 13.686 references; 0 unresolved inclusions; 10 syntax errors; 26 unresolved names (0,16 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:22.466
    !MESSAGE Indexed 'dabrf.nimu' (10 sources, 204 headers) in 5,04 sec: 11.904 declarations; 22.738 references; 0 unresolved inclusions; 728 syntax errors; 270 unresolved names (0,77 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:54.687
    !MESSAGE Indexed 'dabrf.platform' (27 sources, 1.282 headers) in 32,2 sec: 79.582 declarations; 443.102 references; 0 unresolved inclusions; 1.336 syntax errors; 439 unresolved names (0,084 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:08:58.125
    !MESSAGE Indexed 'dabrf.png' (5 sources, 138 headers) in 3,41 sec: 13.779 declarations; 34.857 references; 0 unresolved inclusions; 6 syntax errors; 6 unresolved names (0,012 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:09:07.315
    !MESSAGE Indexed 'ti.ctools' (43 sources, 77 headers) in 9,12 sec: 6.610 declarations; 20.021 references; 0 unresolved inclusions; 140 syntax errors; 75 unresolved names (0,28 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:09:42.908
    !MESSAGE Indexed 'test.omp' (14 sources, 1.347 headers) in 35,5 sec: 71.250 declarations; 448.777 references; 0 unresolved inclusions; 44 syntax errors; 82 unresolved names (0,016 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:34:23.937
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:34:23.941
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:34:26.043
    !MESSAGE Indexed 'dabrf.cmd' (37 sources, 1.781 headers) in 31,8 sec: 116.062 declarations; 709.058 references; 0 unresolved inclusions; 362 syntax errors; 791 unresolved names (0,096 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:35:00.450
    !MESSAGE Indexed 'test.omp' (14 sources, 1.345 headers) in 21,3 sec: 71.250 declarations; 448.761 references; 0 unresolved inclusions; 38 syntax errors; 82 unresolved names (0,016 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:35:28.303
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:35:28.309
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:35:30.091
    !MESSAGE Indexed 'dabrf.tbr.app' (4 sources, 1.749 headers) in 29,6 sec: 112.448 declarations; 698.606 references; 0 unresolved inclusions; 256 syntax errors; 821 unresolved names (0,1 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:04.701
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:04.705
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:36:16.874
    !MESSAGE Indexed 'dabrf.dxp.app' (29 sources, 2.100 headers) in 46,8 sec: 134.024 declarations; 736.810 references; 0 unresolved inclusions; 1.408 syntax errors; 1.145 unresolved names (0,13 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:46.183
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:46.188
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:36:48.270
    !MESSAGE Indexed 'dabrf.cmd' (37 sources, 1.780 headers) in 31,4 sec: 116.044 declarations; 709.018 references; 0 unresolved inclusions; 359 syntax errors; 791 unresolved names (0,096 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:50.901
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:36:50.905
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:14.651
    !MESSAGE Indexed 'dabrf.driver' (14 sources, 1.432 headers) in 26,4 sec: 100.516 declarations; 640.238 references; 0 unresolved inclusions; 246 syntax errors; 763 unresolved names (0,1 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:15.671
    !MESSAGE Indexed 'dabrf.fatfs' (15 sources, 104 headers) in 1 sec: 5.678 declarations; 15.378 references; 0 unresolved inclusions; 490 syntax errors; 109 unresolved names (0,52 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:25.886
    !MESSAGE Indexed 'dabrf.helper' (18 sources, 723 headers) in 10,2 sec: 35.167 declarations; 221.940 references; 1 unresolved inclusions; 26 syntax errors; 188 unresolved names (0,073 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:29.587
    !MESSAGE Indexed 'dabrf.idc' (13 sources, 301 headers) in 3,69 sec: 22.865 declarations; 46.208 references; 0 unresolved inclusions; 86 syntax errors; 16 unresolved names (0,023 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:29.987
    !MESSAGE Indexed 'dabrf.miniz' (5 sources, 17 headers) in 0,39 sec: 2.779 declarations; 13.678 references; 0 unresolved inclusions; 7 syntax errors; 26 unresolved names (0,16 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:31.603
    !MESSAGE Indexed 'dabrf.nimu' (10 sources, 201 headers) in 1,6 sec: 11.865 declarations; 22.639 references; 0 unresolved inclusions; 725 syntax errors; 270 unresolved names (0,78 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:51.939
    !MESSAGE Indexed 'dabrf.platform' (29 sources, 1.280 headers) in 20,3 sec: 79.549 declarations; 443.029 references; 0 unresolved inclusions; 1.331 syntax errors; 439 unresolved names (0,084 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:53.982
    !MESSAGE Indexed 'dabrf.png' (5 sources, 137 headers) in 2,03 sec: 13.779 declarations; 34.849 references; 0 unresolved inclusions; 3 syntax errors; 6 unresolved names (0,012 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:37:55.646
    !MESSAGE Indexed 'ti.ctools' (43 sources, 76 headers) in 1,64 sec: 6.610 declarations; 20.013 references; 0 unresolved inclusions; 137 syntax errors; 75 unresolved names (0,28 %)
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:38:20.773
    !STACK 0
    !ENTRY org.eclipse.cdt.core 4 0 2016-11-02 18:38:20.777
    !STACK 0
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:38:35.117
    !MESSAGE Indexed 'dabrf.core' (98 sources, 1.538 headers) in 39,4 sec: 111.088 declarations; 695.517 references; 0 unresolved inclusions; 725 syntax errors; 1.924 unresolved names (0,24 %)
    !ENTRY org.eclipse.cdt.core 1 0 2016-11-02 18:40:10.680
    !MESSAGE Indexed 'test.omp' (14 sources, 1.345 headers) in 20,9 sec: 71.250 declarations; 448.761 references; 0 unresolved inclusions; 38 syntax errors; 82 unresolved names (0,016 %)
    !ENTRY com.ti.ccstudio.system.setup.ui 1 0 2016-11-02 18:59:47.616
    !MESSAGE targetCfgPath1=C:/Users/ADMIN~1.MUL/user/CCSTargetConfigurations
    !ENTRY com.ti.ccstudio.system.setup.ui 1 0 2016-11-02 18:59:47.620
    !MESSAGE targetCfgPath2=C:/Users/ADMIN~1.MUL/ti/CCSTargetConfigurations
  • Sven,
    Thank you for providing the workspace log file. A CCS developer looked at it and didn't see anything suspicious in that file.
    As a next step, could you please try to capture several Eclipse stack dumps during those 3-5 mins that CCS does not respond? We think that information would be helpful. Please see this page for details on how to capture stack dumps. You can paste the contents of the stack trace into a file and then attach the file here.
    Thank you again for your efforts and patience while we work through this.
  • Hi Aarti,
    I have try to use the latest version of JVisualVM but I can not see the process of ccstudio or eclipse.
    Please would you give me an hint to connect the ccstudio session.
    Kind regards
    Sven
    For me, it shows up as a Local Application (see screenshot below).
    After connecting to the process, you can go to the Threads tab and click on Thread dump at various points during the CCS lock-up.
  • Hi Aarti,
    your screenshots is what I expect, but I can only see the VisualVM entry.
    On my system I have installed some different development systems (CCS 6.1.2, CCS 6.2.0, Xilinx ISE, Cypress IDE, ...).
    Each of them has an own JRE.
    Is here any command line switch to enable the debugging?
    Kind regards
    Sven
    I haven't tried it myself, but the Eclipse Wiki entry for How to report a deadlock describes how to use jstack to get a tread dump.
  • Hi Aarti,
    I have resolved the issue around the missing CCS entry. The temporary directory hsperfdata_username was not accessable, I have to recreate the directory and the Java VisualVM works now.
    Attached you can find an archive with some thread dumps during the time of "waiting". I can also provide some heap dumps, but the size is very large (250 MByte).
    Kind regards
    Sven
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/81/threaddumps.7z
  • Hi Sven,
    Thank you for providing the thread-dumps.  They do show one problem.  I am attaching a patch that would hopefully fix it.  Could you please try this patch and let us know if it fixes the issue?
    To install the patch:
    1. Download the attached file to your machine, and copy it into your <ccs>/ccsv6/eclipse/plugins/ directory.
    2. Rename the already existing file in that directory, with the same name, to have extension ".jar_orig".
    3. Rename the downloaded file to have extension ".jar".
    4. Start (or restart) CCS.
    NOTE: this patch would only work on CCS v6.2.0.00050.
    - Baltasar.
    com.ti.ccstudio.project.core_6.2.0.201609121600.jar.txt
  • Dear Baltasar,
    thanks for your quick patch. I have try it out but it looks not better. The first time of building one of the executable projects It waits 1 minute, the second build waits two minutes until any gmake is called (with print outs on the console).
    If I look to the "Refreshing paths and symbols" work item then I can see that it runs multiple times over all executable projects instead only the selected project. Should I send again some new thread-dumps?
    Kind regards
    Sven
  • Hi Sven,
    I'm attaching an updated patch.  Could you please give it a try and let me know how it goes?
    - Baltasar0676.com.ti.ccstudio.project.core_6.2.0.201609121600.jar.txt
  • Hi Baltasar,
    thank you for the new patch. I am out of the office until Friday. I will try out the new patch later.
    Kind regards
    Sven
  • Hi Sven,
    Please ignore the patch in my previous post, and try this one instead.  This patch has a potential fix for the performance problem.
    Please let me know if it resolves the 3-5 minute delays you see.
    - Baltasar
    2526.com.ti.ccstudio.project.core_6.2.0.201609121600.jar.txt
  • Dear Baltasar,
    thanks for the new patch and your support. It looks like that the new patch works, the gmake starts now immediately after pressing the "Build" button.
    Kind regards
    Sven
  • Hi Sven,
    Thank you for verifying the patch.  I have submitted the fix for the upcoming CCS v7.0, which is planned for December of this year.  Until then, please continue to use the patch.
    - Baltasar
