XDS troubleshooting on Linux
I'm trying to debug using a Delfino controlCARD (F28377D) with expansion backplane and a Spectrum Digital XDS200 JTAG debugger. Here is what I've done so far.
1) Gotten this all working on my Windows 7 desktop to verify that I had switch settings working, XDS200 is functional and familiarize myself with the setup. (During this process I also upgraded CCS from 6.1 to 6.2.)
2) Plugged the board/debugger intro our Linux build server and repeated the process. When it came to configuring the "Target configuration" I configured as before "Texas Instruments XDS2xx USB Debug Probe":
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
    <configuration XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
        <instance XML_version="1.2" desc="Texas Instruments XDS2xx USB Debug Probe_0" href="connections/TIXDS2XXUSB_Connection.xml" id="Texas Instruments XDS2xx USB Debug Probe_0" xml="TIXDS2XXUSB_Connection.xml" xmlpath="connections"/>
        <connection XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
            <instance XML_version="1.2" href="drivers/tixds560icepick_c.xml" id="drivers" xml="tixds560icepick_c.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560c28x.xml" id="drivers" xml="tixds560c28x.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cla1.xml" id="drivers" xml="tixds560cla1.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cs_child.xml" id="drivers" xml="tixds560cs_child.xml" xmlpath="drivers"/>
            <platform XML_version="1.2" id="platform_0">
                <instance XML_version="1.2" desc="TMS320F28377D_0" href="devices/tms320f28377d.xml" id="TMS320F28377D_0" xml="tms320f28377d.xml" xmlpath="devices"/>
                <device HW_revision="1" XML_version="1.2" description="" id="TMS320F28377D_0" partnum="TMS320F28377D">
                    <router HW_revision="1.0" XML_version="1.2" description="ICEPick_C router" id="IcePick_C_0" isa="ICEPICK_C">
                        <subpath id="Subpath_1">
                            <property Type="numericfield" Value="0x11" desc="Port Number_0" id="Port Number"/>
                        </subpath>
                    </router>
                </device>
            </platform>
        </connection>
    </configuration>
</configurations>
I clicked the "Test Connection" button. The test ran for a long time with the last line displayed :
This utility has selected a 560/2xx-class product.
This utility will load the program 'xds2xxu.out'.
And after some minutes (a timeout?) completed and reported
E_RPCENV_IO_ERROR(-6) No connection: DTC_IO_Open::dtc_io
Failed to open i/o connection (xds2xxu:0)
An error occurred while soft opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-250' (0xffffff06).
The title is 'SC_ERR_ECOM_EMUNAME'.
The explanation is:
An attempt to access the debug probe via USCIF ECOM has failed.
[End: Texas Instruments XDS2xx USB Debug Probe_0]
This seems to be the generic 'can't communicate' with the USB debugger message. Following is what I find in dmesg output when
[1444128.176067] usb 4-1.2: new high-speed USB device number 12 using ehci-pci
[1444128.268904] usb 4-1.2: New USB device found, idVendor=0451, idProduct=bef0
[1444128.268909] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[1444128.268913] usb 4-1.2: Product: XDS2xx USB Emulator - Composit
[1444128.268916] usb 4-1.2: Manufacturer: Spectrum Digital
[1444128.268918] usb 4-1.2: SerialNumber: S200-000E99039000
[1444128.269425] cdc_acm 4-1.2:1.0: ttyACM1: USB ACM device
[1444128.269903] cdc_acm 4-1.2:1.2: ttyACM2: USB ACM device
Perms on the TTY devices look OK (and I am a member of the dialout group.)
hbarta@itws007:/opt/ti/ccsv6/install_scripts$ ls -l /dev/ttyACM?
crw-rw-rw- 1 root dialout 166, 0 Oct 27 15:17 /dev/ttyACM0
crw-rw-rw- 1 root dialout 166, 1 Oct 27 15:17 /dev/ttyACM1
crw-rw-rw- 1 root dialout 166, 2 Oct 27 15:17 /dev/ttyACM2
Device: ID 0451:bef0 Texas Instruments, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2 ?
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x0451 Texas Instruments, Inc.
  idProduct          0xbef0
  bcdDevice            1.00
  iManufacturer           1 Spectrum Digital
  iProduct                2 XDS2xx USB Emulator - Composit
  iSerial                 3 S200-000E99039000
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength          141
    bNumInterfaces          4
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              250mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         2
      bFunctionClass          2 Communications
      bFunctionSubClass       2 Abstract (modem)
      bFunctionProtocol       1 AT-commands (v.25ter)
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         2 Communications
      bInterfaceSubClass      2 Abstract (modem)
      bInterfaceProtocol      1 AT-commands (v.25ter)
      iInterface              0
      CDC Header:
        bcdCDC               1.10
      CDC ACM:
        bmCapabilities       0x06
          sends break
          line coding and serial state
      CDC Union:
        bMasterInterface        0
        bSlaveInterface         1
      CDC Call Management:
        bmCapabilities       0x01
          call management
        bDataInterface          1
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass        10 CDC Data
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 8
      bDescriptorType        11
      bFirstInterface         2
      bInterfaceCount         2
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
      CDC Header:
        bcdCDC               1.10
      CDC ACM:
        bmCapabilities       0x06
          sends break
      CDC Union:
        bMasterInterface        2
        bSlaveInterface         3
        bmCapabilities       0x01
          call management
        bDataInterface          3
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Status:     0x0000
  (Bus Powered)
I think I have just attached the relevant entry for this device from 'lsusb -v'.
I ran the XDS200 firmware update procedure on Windows and found that the firmware version is 1.0.0.8 and there does not seem to be anything more recent. (The XDS200 was just purchased.)
I don't see any obvious problems with anything I have looked at. Versions of what I'm running are:
Ubuntu Linux 14.04 LTS
CCS 6.2.0.00050 (Linux and Windows 7)
Debugger probe lists the following information on the sticker (I have obfuscated the serial number):
Spectrum Digital Inc.
P/N 616410-0001A
S/N X2B_1601nnn (obfuscated)
Product: XDS200
Output following instructions on
C:\ti\ccsv6\ccs_base\emulation\specdig\xds2xx>xds2xx_conf get xds2xxu 0
boardRev=1
ipAddress=0.0.0.0
ipConfig=dhcp
ipGateway=0.0.0.0
ipNetmask=0.0.0.0
productClass=XDS2XX
productName=XDS200
serialNum=00:0E:99:04:nn:nn   (obfuscated)
swRev=1.0.0.8
hostCPU=AM1802
emuCtrlType=Bit bang
extMemType=SDRAM
portUSB=true
portENET=false
portWIFI=false
portRS232=false
EnableUSBSerial=false
CurrentMeasure=false
C:\ti\ccsv6\ccs_base\emulation\specdig\xds2xx>update_xds2xx xds200
C:\ti\ccsv6\ccs_base\emulation\specdig\xds2xx>echo off
Updating CPLD
Updating Firmware
Rebooting
Reading Configuration
Check swRev is 1.0.0.8 or higher
boardRev=1
ipAddress=0.0.0.0
ipConfig=dhcp
ipGateway=0.0.0.0
ipNetmask=0.0.0.0
productClass=XDS2XX
productName=XDS200
swRev=1.0.0.8
hostCPU=AM1802
extMemType=SDRAM
portUSB=true
portENET=false
portWIFI=false
portRS232=false
Press any key to continue . . .
I have previously used the XDS100 USB debugger built into the controlCARD on Linux mostly successfully. (Couldn't get it working inside a Docker container.)
Any help resolving this is very appreciated. If further information is needed, please let me know.
Thanks!
  • I have just installed available updates for CCS6.2 including a debugger update but it does not seem to improve the situation.
    I also tried running CCS as root (via sudo) to see if it was a permissions problem and it seems not to be.
  • To check out my procedure for creating the Target Configuration on Linux (and the S/W behind it) I created a target configuration for the built in XDS100 debugger and tested it. The test was successful.
  • Any chance I can get someone to look into this?
    Am I asking in the right place?
    Thanks!
  • I found this at Spectrum Digital: support.spectrumdigital.com/.../ but do not know how to apply it.
    Thanks!
  • Hank,
    Please apologize for the delay and thanks for a very thorough post. It contains pretty much all details that would have been asked. A first detail: this Linux machine is native and not a VM or docker, right?
    I compared the output of both lsusb -v commands (I also have a Ubuntu 14.04/64) and could only find a small difference on the first line that describes where the XDS200 is mapped in the USB subsystem.
    My system said:
    Bus 001 Device 019: ID 0451:bef0 Texas Instruments, Inc.
    Therefore I ask: can you make sure the udev rules are correctly installed under the directory below?
    rules.d said:
    user@host:~$ ls -l /etc/udev/rules.d/
    total 36
    -rw-r--r-- 1 root root  381 Nov  1 10:42 61-msp430uif.rules
    -rwxr-xr-x 1 root root  711 Nov  1 10:42 70-mm-no-ti-emulators.rules
    -rw-r--r-- 1 root root  439 Mar  6  2015 70-persistent-net.rules
    -rw-r--r-- 1 root root  691 Sep 12 09:41 71-bh-permissions.rules
    -rw-r--r-- 1 root root  559 Sep 12 09:41 71-sd-permissions.rules
    -rw-r--r-- 1 root root 1814 Nov  1 10:42 71-ti-permissions.rules
    -rw-r--r-- 1 root root  544 Aug  2 09:43 99-icdi.rules
    -rw-r--r-- 1 root root 2998 Feb 25  2015 99-jlink.rules
    -rw-r--r-- 1 root root 1157 Apr 14  2014 README
    If you don't see the highlighted file above (others may be missing depending on the installed components) then this may be getting on the way of a successful connection. Check the second important remark in the link below for details:
    http://processors.wiki.ti.com/index.php/Linux_Host_Support_CCSv6#Installation_Instructions
    At last, it may well be an issue with incompatible HUB or USB port on the Linux machine that is unknown. In this case, switching the port should help workaround this.
    I will think about additional scenarios and reply back.
    Hope this helps,
    Rafael
  • Hi Rafael,
    Thank you for your reply.
    This is native Linux, not a VM or Docker container.
    Rules in udev are
    hbarta@itws007:~$ ls -l /etc/udev/rules.d/
    total 24
    -rw-r--r-- 1 root root  626 Apr 11  2016 70-persistent-net.rules
    -rw-r--r-- 1 root root  691 Oct 27 15:16 71-bh-permissions.rules
    -rw-r--r-- 1 root root  559 Oct 27 15:16 71-sd-permissions.rules
    -rw-r--r-- 1 root root 1814 Oct 28 09:06 71-ti-permissions.rules
    -rw-r--r-- 1 root root  343 Nov 20  2015 80-docker.rules
    hbarta@itws007:~$
    I cannot see anything highlighted in your post but I presume you meant to point out the '71-*' files. If there is something missing, please let me know.
    I have the device plugged into what I believe to be a USB 2.0 port on the front of a Dell PC. (It is not easy to tell because the markings are subtle.) I will try other ports to see if it helps.
    Can you share what brand PC you are using and/or the USB HUB ID in case that matters? I have attached complete 'lsusb -v' output for the Linux PC I am working on.
    I have another thought about this. I am logging into the PC via 'ssh -Y' and not using a console X session. Do you think that matters? I ask because I think some actions (such as when inserting a USB thumb drive) depend on the user logged into the console so e.g. a thumb drive is made accessible to the console user. We have multiple users on this machine.
    Bus 004 Device 006: ID 413c:2107 Dell Computer Corp.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            0 (Defined at Interface level)
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idVendor           0x413c Dell Computer Corp.
      idProduct          0x2107
      bcdDevice            1.15
      iManufacturer           1 Dell
      iProduct                2 Dell USB Entry Keyboard
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           34
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xa0
          (Bus Powered)
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         3 Human Interface Device
          bInterfaceSubClass      1 Boot Interface Subclass
          bInterfaceProtocol      1 Keyboard
          iInterface              0
            HID Device Descriptor:
              bLength                 9
              bDescriptorType        33
              bcdHID               1.10
              bCountryCode            0 Not supported
              bNumDescriptors         1
              bDescriptorType        34 Report
              wDescriptorLength      65
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0008  1x 8 bytes
            bInterval              10
      (Bus Powered)
    Bus 004 Device 005: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idVendor           0x046d Logitech, Inc.
      idProduct          0xc077 M105 Optical Mouse
      bcdDevice           72.00
      iManufacturer           1 Logitech
      iProduct                2 USB Optical Mouse
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           34
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xa0
          (Bus Powered)
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceProtocol      2 Mouse
          iInterface              0
              bLength                 9
              bDescriptorType        33
              bcdHID               1.11
              bNumDescriptors         1
              wDescriptorLength      46
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0004  1x 4 bytes
            bInterval              10
      (Bus Powered)
    Bus 004 Device 011: ID 0d28:0204 NXP LPC1768
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            2 Communications
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idVendor           0x0d28 NXP
      idProduct          0x0204 LPC1768
      bcdDevice            1.00
      iManufacturer           1 MBED
      iProduct                2 MBED CMSIS-DAP
      iSerial                 3 20010203192ADA9BE4D60562
        bLength                 9
        bDescriptorType         2
        wTotalLength          122
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              500mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass         8 Mass Storage
          bInterfaceSubClass      6 SCSI
          bInterfaceProtocol     80 Bulk-Only
          iInterface              7 USB_MSC
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              4 USB_CDC
          CDC Header:
            bcdCDC               1.10
            bmCapabilities       0x03
              call management
              use DataInterface
            bDataInterface          2
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        1
            bSlaveInterface         2
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              32
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              5 USB_CDC1
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x04  EP 4 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceSubClass      0 No Subclass
          bInterfaceProtocol      0 None
          iInterface              6 MBED CMSIS-DAP
              bLength                 9
              bDescriptorType        33
              bcdHID               1.00
              bNumDescriptors         1
              wDescriptorLength      33
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               1
      (Bus Powered)
    Bus 004 Device 015: ID 0403:a6d0 Future Technology Devices International, Ltd Texas Instruments XDS100v2 JTAG / BeagleBone A3
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x0403 Future Technology Devices International, Ltd
      idProduct          0xa6d0 Texas Instruments XDS100v2 JTAG / BeagleBone A3
      bcdDevice            7.00
      iManufacturer           1 TI
      iProduct                2 Texas Instruments Inc.XDS100 Ver 2.0
      iSerial                 3 F28M36X
        bLength                 9
        bDescriptorType         2
        wTotalLength           55
        bNumInterfaces          2
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              400mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass       255 Vendor Specific Class
          bInterfaceSubClass    255 Vendor Specific Subclass
          bInterfaceProtocol    255 Vendor Specific Protocol
          iInterface              2 Texas Instruments Inc.XDS100 Ver 2.0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Device Qualifier (for other device speed):
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      (Bus Powered)
    Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0 Unused
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idVendor           0x8087 Intel Corp.
      idProduct          0x0024 Integrated Rate Matching Hub
      bcdDevice            0.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceProtocol      0 Full speed (or root) hub
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0002  1x 2 bytes
            bInterval              12
    Hub Descriptor:
      bLength              11
      bDescriptorType      41
      nNbrPorts             8
      wHubCharacteristic 0x0009
        Per-port power switching
        Per-port overcurrent protection
        TT think time 8 FS bits
      bPwrOn2PwrGood       50 * 2 milli seconds
      bHubContrCurrent      0 milli Ampere
      DeviceRemovable    0x00 0x00
      PortPwrCtrlMask    0xff 0xff
     Hub Port Status:
       Port 1: 0000.0503 highspeed power enable connect
       Port 2: 0000.0100 power
       Port 3: 0000.0103 power enable connect
       Port 4: 0000.0100 power
       Port 5: 0000.0303 lowspeed power enable connect
       Port 6: 0000.0303 lowspeed power enable connect
       Port 7: 0000.0100 power
       Port 8: 0000.0100 power
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceProtocol         0 Full speed (or root) hub
      bMaxPacketSize0        64
    Device Status:     0x0001
      Self Powered
    Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      idVendor           0x1d6b Linux Foundation
      idProduct          0x0002 2.0 root hub
      bcdDevice            4.02
      iManufacturer           3 Linux 4.2.0-42-generic ehci_hcd
      iProduct                2 EHCI Host Controller
      iSerial                 1 0000:00:1d.0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             3
      wHubCharacteristic 0x000a
        No power switching (usb 1.0)
      bPwrOn2PwrGood       10 * 2 milli seconds
     Hub Port Status:
       Port 3: 0000.0100 power
      Self Powered
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            9 Hub
      bDeviceProtocol         3
      bMaxPacketSize0         9
      idProduct          0x0003 3.0 root hub
      bcdDevice            4.02
      iManufacturer           3 Linux 4.2.0-42-generic xhci-hcd
      iProduct                2 xHCI Host Controller
      iSerial                 1 0000:06:00.0
        bLength                 9
        bDescriptorType         2
        wTotalLength           31
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
            bMaxBurst               0
    Hub Descriptor:
      bLength              12
      bDescriptorType      42
      nNbrPorts             4
      bHubDecLat          0.0 micro seconds
      wHubDelay             0 nano seconds
     Hub Port Status:
       Port 1: 0000.02a0 5Gbps power Rx.Detect
       Port 2: 0000.02a0 5Gbps power Rx.Detect
       Port 3: 0000.02a0 5Gbps power Rx.Detect
       Port 4: 0000.02a0 5Gbps power Rx.Detect
    Binary Object Store Descriptor:
      bLength                 5
      bDescriptorType        15
      wTotalLength           15
      bNumDeviceCaps          1
      SuperSpeed USB Device Capability:
        bLength                10
        bDescriptorType        16
        bDevCapabilityType      3
        bmAttributes         0x02
          Latency Tolerance Messages (LTM) Supported
        wSpeedsSupported   0x0008
          Device can operate at SuperSpeed (5Gbps)
        bFunctionalitySupport   3
          Lowest fully-functional device speed is SuperSpeed (5Gbps)
        bU1DevExitLat           0 micro seconds
        bU2DevExitLat           0 micro seconds
      Self Powered
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            4.02
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             4
     Hub Port Status:
       Port 1: 0000.0100 power
      Self Powered
    Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            0.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0001  1x 1 bytes
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             6
     Hub Port Status:
       Port 5: 0000.0100 power
       Port 6: 0000.0100 power
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      Self Powered
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            4.02
      iSerial                 1 0000:00:1a.0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             3
     Hub Port Status:
       Port 1: 0000.0507 highspeed power suspend enable connect
      Self Powered
    thanks,
    hank
  • Hank,
    Yes, sorry. I meant to highlight the <71-ti-permissions.rules> file. Nothing missing from your setup.
    It is a Dell Precision T3500 (2.6GHz Xeon with 4GB RAM and only USB1.1/2.0 ports). The output of the lsusb-v is attached below and the XDS200 is connected to the USB2.0 Hub (a port at the front of the PC).
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
      iManufacturer           3 Linux 3.16.0-70-generic ehci_hcd
      iSerial                 1 0000:00:1d.7
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             6
     Hub Port Status:
      Self Powered
    Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      idProduct          0x0001 1.1 root hub
      bcdDevice            3.16
      iManufacturer           3 Linux 3.16.0-70-generic uhci_hcd
      iProduct                2 UHCI Host Controller
      iSerial                 1 0000:00:1d.2
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
      bPwrOn2PwrGood        1 * 2 milli seconds
     Hub Port Status:
      Self Powered
    Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
      iSerial                 1 0000:00:1d.1
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
     Hub Port Status:
      Self Powered
    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
     Hub Port Status:
      Self Powered
    Bus 001 Device 020: ID 0451:bef0 Texas Instruments, Inc.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceSubClass         2 ?
      bMaxPacketSize0        64
      idProduct          0xbef0
      bcdDevice            1.00
        bLength                 9
        bDescriptorType         2
        wTotalLength          141
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              250mA
          bLength                 8
          bDescriptorType        11
          bFirstInterface         0
          bInterfaceCount         2
          iFunction               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
            bmCapabilities       0x01
              call management
            bDataInterface          1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 8
          bDescriptorType        11
          bFirstInterface         2
          bInterfaceCount         2
          iFunction               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        2
            bSlaveInterface         3
            bmCapabilities       0x01
              call management
            bDataInterface          3
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
      (Bus Powered)
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
      iSerial                 1 0000:00:1a.7
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             6
     Hub Port Status:
       Port 3: 0000.0503 highspeed power enable connect
      Self Powered
    Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
      iSerial                 1 0000:00:1a.2
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
     Hub Port Status:
      Self Powered
    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
      iSerial                 1 0000:00:1a.1
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
     Hub Port Status:
      Self Powered
    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            3.16
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval             255
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             2
     Hub Port Status:
      Self Powered
    The file you sent only seems to have the XDS100 that is built into the F28M36 kit. In any case, it seems you have at least one USB3.0 Hub at Bus 002. When you connect your XDS200 and issue a lsusb you can find which port type is being used.
    Hmm, maybe or maybe not. However, in your original post you seem to indicate you are running the GUI by using the target configuration editor, running the "Test Connection" button, etc.
    In any case, try to run any of the utilities from the command line: either the xds2xx_conf -e or the dbgjtag -X emulator,driver=xds2xxu,ioport=0 -rv (to see if the JTAG debugger is recognized from Linux) or ultimately loadti (to see if you can connect and load code to the device via the command line)
    Unless your system differentiates between a remote and a local user regarding privileges, I can't imagine the low-level utilities failing in a pure command line remote session.
    Hope this helps,
    Rafael
  • Bus 004 Device 006: ID 413c:2107 Dell Computer Corp.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idProduct          0x2107
      bcdDevice            1.15
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           34
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xa0
          (Bus Powered)
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
              bLength                 9
              bDescriptorType        33
              bcdHID               1.10
              bNumDescriptors         1
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
      (Bus Powered)
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      bcdDevice           72.00
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           34
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xa0
          (Bus Powered)
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
              bLength                 9
              bDescriptorType        33
              bcdHID               1.11
              bNumDescriptors         1
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
      (Bus Powered)
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         8
      idVendor           0x0d28 NXP
      bcdDevice            1.00
        bLength                 9
        bDescriptorType         2
        wTotalLength          122
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              500mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           1
          CDC Header:
            bcdCDC               1.10
            bmCapabilities       0x03
              call management
              use DataInterface
            bDataInterface          2
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        1
            bSlaveInterface         2
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              32
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           2
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
              bLength                 9
              bDescriptorType        33
              bcdHID               1.00
              bNumDescriptors         1
             Report Descriptors:
               ** UNAVAILABLE **
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval               1
      (Bus Powered)
    Bus 004 Device 019: ID 0451:bef0 Texas Instruments, Inc.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceSubClass         2 ?
      bMaxPacketSize0        64
      idProduct          0xbef0
      bcdDevice            1.00
        bLength                 9
        bDescriptorType         2
        wTotalLength          141
        bNumInterfaces          4
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              250mA
          bLength                 8
          bDescriptorType        11
          bFirstInterface         0
          bInterfaceCount         2
          iFunction               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
            bmCapabilities       0x01
              call management
            bDataInterface          1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
          bLength                 8
          bDescriptorType        11
          bFirstInterface         2
          bInterfaceCount         2
          iFunction               0
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        2
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        2
            bSlaveInterface         3
            bmCapabilities       0x01
              call management
            bDataInterface          3
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              10
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        3
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
      (Bus Powered)
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            0.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength              11
      bDescriptorType      41
      nNbrPorts             8
     Hub Port Status:
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            4.02
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             3
     Hub Port Status:
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            9 Hub
      bDeviceProtocol         3
      bMaxPacketSize0         9
      bcdDevice            4.02
        bLength                 9
        bDescriptorType         2
        wTotalLength           31
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
            bMaxBurst               0
    Hub Descriptor:
      bLength              12
      bDescriptorType      42
      nNbrPorts             4
     Hub Port Status:
      bLength                 5
      bDescriptorType        15
      wTotalLength           15
      bNumDeviceCaps          1
        bLength                10
        bDescriptorType        16
        bmAttributes         0x02
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            4.02
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             4
     Hub Port Status:
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            0.00
      iManufacturer           0
      iProduct                0
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             6
     Hub Port Status:
      bLength                10
      bDescriptorType         6
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      Self Powered
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bMaxPacketSize0        64
      bcdDevice            4.02
        bLength                 9
        bDescriptorType         2
        wTotalLength           25
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
    Hub Descriptor:
      bLength               9
      bDescriptorType      41
      nNbrPorts             3
     Hub Port Status:
      Self Powered
    Oops! Captured lsusb when working with the other emulator. I've reconnected the XDS200 and captured new list. (attached)
    This PC is also a Dell, a Precision T7610 and I'm also using one of the ports on the front of the case. It has a dual processor motherboard and /proc/cpuinfo lists 48 "Intel(R) Xeon(R) CPU E5-2697 v2" cores.
    I'm using the CCS GUI through a Windows X server (Cygwin) and 'ssh -y user@host' type of connection.
    thanks,
    hank
  • Hi Rafael,
    I did log in on the console to see if that mattered. It did not.
    thanks,
    hank
  • More things I've tried...
    Uninstall and reinstall of CCS 6.2 and drivers. (Previous install may have been over 6.1) No change.
    Move XDS200 to another USB connector. I noticed that the XDS200 was sharing the 'hub' with some other devices:
    hbarta@itws007:~/Downloads$ tree /dev/bus/usb
    /dev/bus/usb
    ├── 001
    │   └── 001
    ├── 002
    │   └── 001
    ├── 003
    │   ├── 001
    │   └── 002
    └── 004
        ├── 001
        ├── 002
        ├── 005
        ├── 006
        ├── 011
        └── 027
    4 directories, 10 files
    hbarta@itws007:~/Downloads$ lsusb
    Bus 004 Device 027: ID 0451:bef0 Texas Instruments, Inc.
    Moving to another connector on the front panel gets it on another USB hub by itself.
    Bus 001 Device 004: ID 0451:bef0 Texas Instruments, Inc.
    /dev/bus/usb
    ├── 001
    │   ├── 001
    │   └── 004
    ├── 002
    │   └── 001
    ├── 003
    │   ├── 001
    │   └── 002
    └── 004
        ├── 001
        ├── 002
        ├── 005
        ├── 006
        └── 011
    No change. :(
  • Debug Server Log of a 'test connection' operation.
    0x7FAAF5FCF740 51568 3  XPCOM R: ( (dsILogger*)0x7fa9781bca00 )->redirect( /home/hbarta/USB/debugServerLog.log ) = 0x00000000
    0x7FAAF5FCF740 51568 3  XPCOM C: ( (dsILogger*)0x7fa9781bca00 )->getLogFile( 0x7ffd680321f0 )
    0x7FAAF5FCF740 51568 3  XPCOM R: ( (dsILogger*)0x7fa9781bca00 )->getLogFile( *0x7ffd680321f0 = /home/hbarta/USB/debugServerLog.log ) = 0x00000000
    0x7FAAE1F26700 55092 3  XPCOM C: ( (dsIDebugger*)0x7fa9781b82d0 )->generateBoardDataFile( /root/ti/CCSTargetConfigurations/NewTargetConfiguration.ccxml, 0x00000000, 0x7faae1f238f0, 0x7faae1f23908 )
    0x7FAAE1F26700 55092 3  COM_DBG_IF C: 10dsDebugger::OnTaskStart()
    0x7FAAE1F26700 55092 3  COM_DBG_IF R: 10dsDebugger::OnTaskStart()
    0x7FAAE1F26700 55092 5  COM_DBG_IF I: Final Release for 14CoProgressTask (this = 0x7fa9b40009a8)
    0x7FAAE1F26700 55092 5  COM_DBG_IF I: Final Release for N14XPCOMFramework5EventINS_17EventTemplateArgsI14dsIStringEventPKc22dsIStringEventCallbackEEEE (this = 0x7fa9b4002b88)
    0x7FAAE1F26700 55092 5  COM_DBG_IF I: Final Release for N14XPCOMFramework5EventINS_17EventTemplateArgsI14dsIObjectEventP11nsISupports22dsIObjectEventCallbackEEEE (this = 0x7fa9b4002ae8)
    0x7FAAE1F26700 55102 3  SETUP I: SELECT sql FROM sqlite_master ORDER BY tbl_name, name
    0x7FAAE1F26700 55103 3  SETUP I: Loading repository "/opt/ti/ccsv6/ccs_base/common/targetdb/"
    0x7FAAE1F26700 55103 3  SETUP I: SELECT * FROM TargetDB_Repositories
    0x7FAAE1F26700 55103 3  SETUP I: SELECT * FROM TargetDB_Repositories WHERE dbid=1
    0x7FAAE1F26700 55103 3  SETUP I: PRAGMA journal_mode = MEMORY
    0x7FAAE1F26700 55103 3  SETUP I: PRAGMA synchronous = OFF
    0x7FAAE1F26700 55103 3  SETUP I: BEGIN IMMEDIATE TRANSACTION
    0x7FAAE1F26700 55103 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2006_regids.xml"
    0x7FAAE1F26700 55104 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=1
    0x7FAAE1F26700 55104 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RXX_regids.xml"
    0x7FAAE1F26700 55104 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=2
    0x7FAAE1F26700 55104 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C41XX_regids.xml"
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=3
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C66XX_regids.xml"
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=4
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2001_regids.xml"
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=5
    0x7FAAE1F26700 55105 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R9X_regids.xml"
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=6
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2003_regids.xml"
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=7
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R25X_regids.xml"
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=8
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C6XXX_regids.xml"
    0x7FAAE1F26700 55106 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=9
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2004_regids.xml"
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=10
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C40XX_regids.xml"
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=11
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS225C100_regids.xml"
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=12
    0x7FAAE1F26700 55107 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_0_regids.xml"
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=13
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2030_regids.xml"
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=14
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2000_regids.xml"
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=15
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470REX_regids.xml"
    0x7FAAE1F26700 55108 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=16
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2028_regids.xml"
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=17
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R2X_regids.xml"
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=18
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R15X_regids.xml"
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=19
    0x7FAAE1F26700 55109 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RDX_regids.xml"
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=20
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2008_regids.xml"
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=21
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RCX_regids.xml"
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=22
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2007_regids.xml"
    0x7FAAE1F26700 55110 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=23
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2027_regids.xml"
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=24
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C674X_regids.xml"
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=25
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R7X_regids.xml"
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=26
    0x7FAAE1F26700 55111 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2002_regids.xml"
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=27
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2026_regids.xml"
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=28
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_C_regids.xml"
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=29
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C28XX_regids.xml"
    0x7FAAE1F26700 55112 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=30
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="ICEPick_D_regids.xml"
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=31
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C64XX_regids.xml"
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=32
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2029_regids.xml"
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=33
    0x7FAAE1F26700 55113 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS700C4X_regids.xml"
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=34
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS320C55XX_regids.xml"
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=35
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2031_regids.xml"
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=36
    0x7FAAE1F26700 55114 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470R4X_regids.xml"
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=37
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS470RAX_regids.xml"
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=38
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2032_regids.xml"
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=39
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="CS_DAP_PC_0_regids.xml"
    0x7FAAE1F26700 55115 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=40
    0x7FAAE1F26700 55116 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="TMS192C2005_regids.xml"
    0x7FAAE1F26700 55116 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=41
    0x7FAAE1F26700 55116 3  SETUP I: END TRANSACTION
    0x7FAAE1F26700 55116 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
    0x7FAAE1F26700 55116 3  SETUP I: Scrubbing database
    0x7FAAE1F26700 55126 3  SETUP I: Loading file "/root/.ti/ti/0/0/18160090570487971461.cache"
    0x7FAAE1F26700 55126 3  SETUP I: SELECT * FROM TargetDB_Files WHERE Filename="18160090570487971461.cache"
    0x7FAAE1F26700 55126 3  SETUP I: SELECT * FROM TargetDB_Files WHERE dbid=42
    0x7FAAE1F26700 55126 3  SETUP I: SELECT count(*) FROM TargetDB_Files WHERE State=0
    0x7FAAE1F26700 55127 3  SETUP I: SELECT Systems.dbid FROM Systems, TargetDB_Files WHERE Systems.Source_File = TargetDB_Files.dbid AND TargetDB_Files.dbid = 42
    0x7FAAE1F26700 55127 3  SETUP I: SELECT * FROM Systems WHERE dbid=1
    0x7FAAE1F26700 55127 3  GTI C: JTAGData_CreateJtagDeviceList()
    0x7FAAE1F26700 55132 3  GTI R: JTAGData_CreateJtagDeviceList() = 0x7fa9b40eae00
    0x7FAAE1F26700 55132 3  GTI C: JTAGData_AddVariable( 0x7fa9b40eae00, BOARD_DATAFILE_VERSION, *0x7faae1f233ac = 2 )
    0x7FAAE1F26700 55132 3  GTI R: JTAGData_AddVariable( 0x7fa9b40eae00, BOARD_DATAFILE_VERSION, *0x7faae1f233ac = 2 ) = 1
    0x7FAAE1F26700 55132 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.ECOM_DRVR, xds2xxu.out )
    0x7FAAE1F26700 55132 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.ECOM_DRVR, xds2xxu.out ) = 1
    0x7FAAE1F26700 55132 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.ECOM_PORT, 0 )
    0x7FAAE1F26700 55132 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.ECOM_PORT, 0 ) = 1
    0x7FAAE1F26700 55132 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_0, BIO_0,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_0, BIO_0,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_1, BIO_1,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_1, BIO_1,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_2, BIO_2,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_2, BIO_2,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_3, BIO_3,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.BIO_3, BIO_3,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.TXD1, TXD1,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.TXD1, TXD1,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.RXD1, RXD1,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.RXD1, RXD1,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_4, EXPIO_4,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_4, EXPIO_4,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_5, EXPIO_5,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_5, EXPIO_5,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_6, EXPIO_6,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_6, EXPIO_6,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_7, EXPIO_7,Active_High )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, XDS2XX.EXPIO_7, EXPIO_7,Active_High ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAGBOOT_MODE, disable )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAGBOOT_MODE, disable ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAGBOOT_VALUE, hiz )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAGBOOT_VALUE, hiz ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.POWERBOOT_MODE, disable )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.POWERBOOT_MODE, disable ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.POWERBOOT_VALUE, hiz )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.POWERBOOT_VALUE, hiz ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.TCLK_PROGRAM, SPECIFIC )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.TCLK_PROGRAM, SPECIFIC ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.TCLK_FREQUENCY, 10.0MHz )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.TCLK_FREQUENCY, 10.0MHz ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.LOOPBACK_MODE, disable )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.LOOPBACK_MODE, disable ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.LOOPBACK_VALUE, disable )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.LOOPBACK_VALUE, disable ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAG_ISOLATE, enable )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.JTAG_ISOLATE, enable ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.EXTRARESET_SYSTEM, false )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, USCIF.EXTRARESET_SYSTEM, false ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, DOT7.DTS_USAGE, nothing )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, DOT7.DTS_USAGE, nothing ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, SWD.SWD_DEBUG, disabled )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, SWD.SWD_DEBUG, disabled ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, SWD.SWO_DATA, aux_uart )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, SWD.SWO_DATA, aux_uart ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddDeviceEx( 0x7fa9b40eae00, IcePick_C_0, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddDeviceEx( 0x7fa9b40eae00, IcePick_C_0, 240, 2, 0, 5, ROUTER, 4294967295, 0, 2 ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddSubpath( 0x7fa9b40eae00, Subpath_1, IcePick_C_0, 3 )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddSubpath( 0x7fa9b40eae00, Subpath_1, IcePick_C_0, 3 ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.address, 0x11 )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.address, 0x11 ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.initial, 0 )
    0x7FAAE1F26700 55133 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.initial, 0 ) = 1
    0x7FAAE1F26700 55133 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.custom, 0 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.custom, 0 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.force, 1 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.force, 1 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, cs_child_1, 224, 0, 0, 6, DSP_CPU, -1 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, cs_child_1, 224, 0, 0, 6, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.address, 0xE0042000 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.address, 0xE0042000 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.identify, 0x4bc44c09 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.identify, 0x4bc44c09 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, C28xx_CPU2, 320, 40, 127, 0, DSP_CPU, -1 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, C28xx_CPU2, 320, 40, 127, 0, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, CPU2_CLA1, 192, 32, 7, 0, DSP_CPU, -1 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, CPU2_CLA1, 192, 32, 7, 0, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddSubpath( 0x7fa9b40eae00, Subpath_0, IcePick_C_0, 3 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddSubpath( 0x7fa9b40eae00, Subpath_0, IcePick_C_0, 3 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.address, 0x10 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.address, 0x10 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.initial, 0 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.initial, 0 ) = 1
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, subpath.custom, 0 )
    0x7FAAE1F26700 55134 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, cs_child_0, 224, 0, 0, 6, DSP_CPU, -1 )
    0x7FAAE1F26700 55134 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, cs_child_0, 224, 0, 0, 6, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.address, 0xE0042000 )
    0x7FAAE1F26700 55135 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.address, 0xE0042000 ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.identify, 0x4bc44c09 )
    0x7FAAE1F26700 55135 3  GTI R: JTAGData_AddVariableEx( 0x7fa9b40eae00, device.identify, 0x4bc44c09 ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, C28xx_CPU1, 320, 40, 127, 0, DSP_CPU, -1 )
    0x7FAAE1F26700 55135 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, C28xx_CPU1, 320, 40, 127, 0, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_AddDevice( 0x7fa9b40eae00, CPU1_CLA1, 192, 32, 7, 0, DSP_CPU, -1 )
    0x7FAAE1F26700 55135 3  GTI R: JTAGData_AddDevice( 0x7fa9b40eae00, CPU1_CLA1, 192, 32, 7, 0, DSP_CPU, -1 ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_Output( 0x7fa9b40eae00, /root/.ti/ti/0/0/BrdDat/testBoard.dat )
    0x7FAAE1F26700 55135 3  GTI R: JTAGData_Output( 0x7fa9b40eae00, /root/.ti/ti/0/0/BrdDat/testBoard.dat ) = 1
    0x7FAAE1F26700 55135 3  GTI C: JTAGData_DestroyJtagDeviceList( 0x7fa9b40eae00 )
    0x7FAAE1F26700 55136 3  GTI R: JTAGData_DestroyJtagDeviceList( 0x7fa9b40eae00 ) = (nil)
    0x7FAAE1F26700 55136 3  XPCOM R: ( (dsIDebugger*)0x7fa9781b82d0 )->generateBoardDataFile( /root/ti/CCSTargetConfigurations/NewTargetConfiguration.ccxml, 0x00000000, *0x7faae1f238f0 = (null), *0x7faae1f23908 = /root/.ti/ti/0/0/BrdDat/testBoard.dat ) = 0x00000000
    I can't see any obvious problem from the debug server log file, or from the other information you have posted.
    Some suggestions based upon troubleshooting other debug probe problems under Linux:
    1) Can you look at the dmesg output and /var/log/syslog before and after the test connection and see if the failed test connection reports any messages in dmesg or /var/log/syslog ?
    2) Can you try downloading a program using loadti and post the output from loadti?
    This is because sometimes loadti gives a more informative error message than trying a test connection or starting a debug session in the CCS GUI.
  • (I'll try again. The first post never completed.)
    Hi Chester,
    Here is the information you requested. I have included some information for both XDS100 (controlCARD) and XDS200 since the XDS100 works and the XDS200 so far does not.
    First XDS200 messages from dmesg and /var/log/syslog when I unplug and plug in the debugger.
    dmesg XDS200 disconnect followed by reconnect
    [2369245.007449] usb 1-2: USB disconnect, device number 4
    [2369256.280082] usb 1-2: new high-speed USB device number 5 using xhci_hcd
    [2369256.410916] usb 1-2: New USB device found, idVendor=0451, idProduct=bef0
    [2369256.410921] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [2369256.410925] usb 1-2: Product: XDS2xx USB Emulator - Composit
    [2369256.410928] usb 1-2: Manufacturer: Spectrum Digital
    [2369256.410930] usb 1-2: SerialNumber: S200-000E99039000
    [2369256.414652] cdc_acm 1-2:1.0: ttyACM1: USB ACM device
    [2369256.415312] cdc_acm 1-2:1.2: ttyACM2: USB ACM device
    from var/log/syslog
    Nov  7 07:16:20 itws007 kernel: [2369245.007449] usb 1-2: USB disconnect, device number 4
    Nov  7 07:16:31 itws007 kernel: [2369256.280082] usb 1-2: new high-speed USB device number 5 using xhci_hcd
    Nov  7 07:16:31 itws007 kernel: [2369256.410916] usb 1-2: New USB device found, idVendor=0451, idProduct=bef0
    Nov  7 07:16:31 itws007 kernel: [2369256.410921] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Nov  7 07:16:31 itws007 kernel: [2369256.410925] usb 1-2: Product: XDS2xx USB Emulator - Composit
    Nov  7 07:16:31 itws007 kernel: [2369256.410928] usb 1-2: Manufacturer: Spectrum Digital
    Nov  7 07:16:31 itws007 kernel: [2369256.410930] usb 1-2: SerialNumber: S200-000E99039000
    Nov  7 07:16:31 itws007 kernel: [2369256.414652] cdc_acm 1-2:1.0: ttyACM1: USB ACM device
    Nov  7 07:16:31 itws007 kernel: [2369256.415312] cdc_acm 1-2:1.2: ttyACM2: USB ACM device
    Nov  7 07:16:31 itws007 mtp-probe: checking bus 1, device 5: "/sys/devices/pci0000:00/0000:00:1c.0/0000:06:00.0/usb1/1-2"
    Nov  7 07:16:31 itws007 mtp-probe: bus: 1, device: 5 was not an MTP device
    Next connect XDS100
    From 'dmesg'
    [2370053.156085] usb 1-2: new high-speed USB device number 6 using xhci_hcd
    [2370053.291405] usb 1-2: New USB device found, idVendor=0403, idProduct=a6d0
    [2370053.291420] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [2370053.291424] usb 1-2: Product: Texas Instruments Inc.XDS100 Ver 2.0
    [2370053.291426] usb 1-2: Manufacturer: TI
    [2370053.291429] usb 1-2: SerialNumber: F28M36X
    [2370053.298145] usb 1-2: Ignoring serial port reserved for JTAG
    [2370053.302262] ftdi_sio 1-2:1.1: FTDI USB Serial Device converter detected
    [2370053.302337] usb 1-2: Detected FT2232H
    [2370053.303037] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
    [2370053.314019] usb 1-2: Ignoring serial port reserved for JTAG
    [2370053.323330] usb 1-2: Ignoring serial port reserved for JTAG
    [2370053.335605] usb 1-2: Ignoring serial port reserved for JTAG
    from /var/log/syslog
    Nov  7 07:29:48 itws007 kernel: [2370053.156085] usb 1-2: new high-speed USB device number 6 using xhci_hcd
    Nov  7 07:29:48 itws007 kernel: [2370053.291405] usb 1-2: New USB device found, idVendor=0403, idProduct=a6d0
    Nov  7 07:29:48 itws007 kernel: [2370053.291420] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    Nov  7 07:29:48 itws007 kernel: [2370053.291424] usb 1-2: Product: Texas Instruments Inc.XDS100 Ver 2.0
    Nov  7 07:29:48 itws007 kernel: [2370053.291426] usb 1-2: Manufacturer: TI
    Nov  7 07:29:48 itws007 kernel: [2370053.291429] usb 1-2: SerialNumber: F28M36X
    Nov  7 07:29:48 itws007 kernel: [2370053.298145] usb 1-2: Ignoring serial port reserved for JTAG
    Nov  7 07:29:48 itws007 kernel: [2370053.302262] ftdi_sio 1-2:1.1: FTDI USB Serial Device converter detected
    Nov  7 07:29:48 itws007 kernel: [2370053.302337] usb 1-2: Detected FT2232H
    Nov  7 07:29:48 itws007 kernel: [2370053.303037] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
    Nov  7 07:29:48 itws007 mtp-probe: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:1c.0/0000:06:00.0/usb1/1-2"
    Nov  7 07:29:48 itws007 mtp-probe: bus: 1, device: 6 was not an MTP device
    Nov  7 07:29:48 itws007 kernel: [2370053.314019] usb 1-2: Ignoring serial port reserved for JTAG
    Nov  7 07:29:48 itws007 kernel: [2370053.323330] usb 1-2: Ignoring serial port reserved for JTAG
    Nov  7 07:29:48 itws007 kernel: [2370053.335605] usb 1-2: Ignoring serial port reserved for JTAG
    Output from 'loadti.sh'
    hbarta@itws007:~/sample/blinky_cpu01/CPU1_RAM$ /opt/ti/ccsv6/ccs_base/scripting/examples/loadti/loadti.sh -c /home/hbarta/ti/CCSTargetConfigurations/XDS200.ccxml -x XDS200-log.xml /opt/ti/ccsv6/ccs_base/scripting/examples/loadti
    ***** DSS Generic Loader *****
    START: 08:07:25 GMT-0600 (CST)
    Configuring Debug Server for specified target...
    Done
    E_RPCENV_IO_ERROR(-6) No connection: DTC_IO_Open::dtc_io
    Failed to open i/o connection (xds2xxu:0)
    SEVERE: IcePick_C_0: Error initializing emulator: (Error -2083 @ 0x0)
    Unable to communicate with the debug probe. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation.
    (Emulation package 6.0.407.6)
    SEVERE: Could not start server: DebugServer.1: IcePick_C_0: Error initializing emulator: (Error -2083 @ 0x0)
    org.mozilla.javascript.WrappedException: Wrapped com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1: IcePick_C_0: Error initializing emulator: (Error -2083 @ 0x0)
     (/opt/ti/ccsv6/ccs_base/scripting/examples/loadti/main.js#159)
            at org.mozilla.javascript.Context.throwAsScriptRuntimeEx(Context.java:1693)
            at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:160)
            at org.mozilla.javascript.NativeJavaMethod.call(NativeJavaMethod.java:204)
            at org.mozilla.javascript.optimizer.OptRuntime.call2(OptRuntime.java:76)
            at org.mozilla.javascript.gen.c1._c4(/opt/ti/ccsv6/ccs_base/scripting/examples/loadti/main.js:159)
            at org.mozilla.javascript.gen.c1.call(/opt/ti/ccsv6/ccs_base/scripting/examples/loadti/main.js)
            at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
            at org.mozilla.javascript.gen.c1._c0(/opt/ti/ccsv6/ccs_base/scripting/examples/loadti/main.js:9)
            at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:340)
            at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2758)
            at org.mozilla.javascript.gen.c1.exec(/opt/ti/ccsv6/ccs_base/scripting/examples/loadti/main.js)
            at org.mozilla.javascript.tools.shell.Main.evaluateScript(Main.java:503)
            at org.mozilla.javascript.tools.shell.Main.processFileSecure(Main.java:425)
            at org.mozilla.javascript.tools.shell.Main.processFile(Main.java:391)
            at org.mozilla.javascript.tools.shell.Main.processSource(Main.java:382)
            at org.mozilla.javascript.tools.shell.Main.processFiles(Main.java:179)
            at org.mozilla.javascript.tools.shell.Main$IProxy.run(Main.java:100)
            at org.mozilla.javascript.Context.call(Context.java:528)
            at org.mozilla.javascript.ContextFactory.call(ContextFactory.java:450)
            at org.mozilla.javascript.tools.shell.Main.exec(Main.java:162)
            at com.ti.ccstudio.apps.internal.scripting.RunScript$1.run(RunScript.java:88)
    Caused by: com.ti.ccstudio.scripting.environment.ScriptingException: Could not start server: DebugServer.1: IcePick_C_0: Error initializing emulator: (Error -2083 @ 0x0)
            at com.ti.debug.engine.scripting.DebugServer$SessionFactory.<init>(DebugServer.java:164)
            at com.ti.debug.engine.scripting.DebugServer.openSession(DebugServer.java:1327)
            at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
            at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:95)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
            at java.lang.reflect.Method.invoke(Method.java:620)
            at org.mozilla.javascript.MemberBox.invoke(MemberBox.java:145)
            ... 21 more
    I have tried to attach the log produced by loadti.sh as well as the .ccxml file used. The forum server/software seems to hang if I try to attach the XML log file. After canceling the upload (stuck in progress for over an hour while I went to a meeting) I cannot go back to the file upload dialog as it still says 'loading'
    The forum S/W rejected the .CCXML file so I have removed that. There are no attachments to this post. I will follow up with another post and attempt to get the attachments uploaded.
    (Note: Due to an unfortunate edit the command for 'loadti.sh' does not include the path to the .OUT file but retrying with that fixed did not change the result.)
    I also loaded the program using 'loadti.sh' and the XDS100 debugger and that worked without difficulty.
    thanks,
    hank
  • TMS320F28377D.ccxml.gz
    target configuration for the testing two posts previous.
    (It baffles me that ccxml is not a valid file extension for uploads.)
  • At I see the statement
    C:\>cd C:\ti\ccsv6\ccs_base\emulation\specdig\xds2xx - this only exists if Spectrum Digital support is installed. It is mandatory if you have a XDS220
    Looking at the Linux equivalent directory I find:
    hbarta@itws007:/opt/ti/ccsv6/ccs_base/emulation/specdig$ tree
    ├── docs
    │   └── pdf
    │       ├── TechNote_10.pdf
    │       ├── TechNote_11.pdf
    │       ├── xds560v2_quickstart_guide.pdf
    │       └── xds560v2_techref.pdf
    ├── ReleaseNotes.txt
    └── sd1.ico
    Is our installation deficient? I've isntalled CCS 6.2 twice (once an upgrade to 6.1 and the second a clean install) and installed the device drivers both times. I also installed the most recent drivers I found at  because I was not able to determine if the the installed drivers were current.
    thanks,
    hank
    OK, from the loadti.sh output and log I can't see any more information about the cause of the failure.
    Some other options are:
    1) Run loadti.sh as sudo to eliminate any permissions problem.
    2) If running loadti.sh as sudo doesn't fix the problem, try running loadti.sh under strace and post a zip file of the strace output, as strace may recording where the failure is occurring.
  • Hi Chester,
    Thanks for the suggestions. I had tried CCS as root and that did not help. I will try loadti.sh to see if that is different. (I thought the actual connection was via a 'debug server' so that's what really would need to run as root. Perhaps it inherits permissions from CCS/loadti.sh.)
    I did try running CCS under strace and that was a bit of a fools errand. We only have a 500GB drive. ;) Running loadti.sh under strace sounds like a better idea.
    I did have our admin reboot the Linux box. Good news: I have not been wasting TI's time chasing a problem that could be fixed by a reboot. :D Bad news: Reboot did not fix the problem. :(
    The 'debug server' is a collection of shared object files which get loaded by the CCS / loadti.sh processes. I.e. there isn't an actual separate 'server' process.
    loadti.sh might spawn some child processes, so best to use the strace -f option to trace child processes.
    [E.g. when I last used strace to debug a USB2000 connection problem under Linux found the the problem was that a child process was getting a SIGSEGV - https://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/541444]
  • Hi Chester,
    Running loadti.sh as root made no difference. I ran as a normal user and collected output from 'strace -f' (attached.) The output to the console was
    hbarta@itws007:~/sample/blinky_cpu01/CPU1_RAM$ strace -f 2>strace.txt /opt/ti/ccsv6/ccs_base/scripting/examples/loadti/loadti.sh -c /home/hbart/ti/CCSTargetConfigurations/XDS200.ccxml -x XDS200-log.xml blinky_cpu01.out
    START: 08:33:30 GMT-0600 (CST)
    Done
    strace.txt.gz
    thanks,
    hank
  • Hank,
    Thanks for sending the log. I can spot some errors accessing directories starting at line 1244977 but I have no idea why CCS is trying to access these invalid locations.
    That brings me a suspicion that either a CCS component or the entire install are corrupt.
    I just noticed I have CCSv6.2.0.00048. I will install CCSv6.2.00050 and collect some strace logs as well to see if I can reproduce this.
    I will get back with my findings.
    Rafael
  • Hi Rafael,
    That line does look a bit odd.
    [pid 33754] access("/opt/ti/ccsv6/emulation/drivers/NONE", F_OK) = -1 ENOENT (No such file or directory)
    The directory /opt/ti/ccsv6/emulation does not exist in my installation. It seems this stuff has been moved to /opt/ti/ccsv6/ccs_base/emulation/drivers which is accessed two lines further. Perhaps the code is checking first for older versions of the drivers. (And I do not find the file NONE under  /opt/ti/ccsv6/.)
    BTW I have already reinstalled once using a fresh download from TI.
    thanks,
    hank
    I had the same in a strace log for when was able to connect to a XDS200 under Ubuntu 16.04, so that isn't the cause of the problem.
  • Hank Barta said:
    This seems to be the generic 'can't communicate' with the USB debugger message. Following is what I find in dmesg output when
    [1444128.176067] usb 4-1.2: new high-speed USB device number 12 using ehci-pci
    [1444128.268904] usb 4-1.2: New USB device found, idVendor=0451, idProduct=bef0
    [1444128.268909] usb 4-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [1444128.268913] usb 4-1.2: Product: XDS2xx USB Emulator - Composit
    [1444128.268916] usb 4-1.2: Manufacturer: Spectrum Digital
    [1444128.268918] usb 4-1.2: SerialNumber: S200-000E99039000
    [1444128.269425] cdc_acm 4-1.2:1.0: ttyACM1: USB ACM device
    [1444128.269903] cdc_acm 4-1.2:1.2: ttyACM2: USB ACM device
    Perms on the TTY devices look OK (and I am a member of the dialout group.)
    hbarta@itws007:/opt/ti/ccsv6/install_scripts$ ls -l /dev/ttyACM?
    crw-rw-rw- 1 root dialout 166, 0 Oct 27 15:17 /dev/ttyACM0
    crw-rw-rw- 1 root dialout 166, 1 Oct 27 15:17 /dev/ttyACM1
    crw-rw-rw- 1 root dialout 166, 2 Oct 27 15:17 /dev/ttyACM2
    That output shows that the XDS200 has enumerated as the USB ACM devices ttyACM1 and ttyACM2, and that there is already an existing USB ACM device ttyACM0.
    When I looked through the strace.txt log from your loadsti.sh failure I can see the sequence of:
    1) Device ttyACM0 is opened:
    [pid 33754] open("//dev//ttyACM0", O_RDWR) = 129
    2) Some ioctl() calls are made on file descriptor for the ttyACM0 device, followed by a write of 18 bytes:
    [pid 33754] write(129, "\1f\231\0\0\22\0\0\0\r\0\177\360\0\0\0\0004", 18) = 18
    3) An attempt is made to read 8 bytes from the ttyACM0 device, but after multiply attempts no bytes are read and the file descriptor for the ttyACM0 device is closed:
    [pid 33754] read(129,  <unfinished ...>
    [pid 33754] <... read resumed> "", 8)   = 0
    <snip>
    [pid 33754] ioctl(129, FIONREAD, [0])   = 0
    [pid 33754] ioctl(129, TCFLSH, 0x2)     = 0
    [pid 33754] ioctl(129, SNDCTL_TMR_TIMEBASE or SNDRV_TIMER_IOCTL_NEXT_DEVICE or TCGETS, {B115200 -opost -isig -icanon -
    echo ...}) = 0
    [pid 33754] ioctl(129, SNDCTL_TMR_START or SNDRV_TIMER_IOCTL_TREAD or TCSETS, {B115200 -opost -isig -icanon -echo ...}
    ) = 0
    echo ...}) = 0
    [pid 33754] close(129)                  = 0
    Followed by the E_RPCENV_IO_ERROR error being reported:
    [pid 33754] munmap(0x7fdf0d3b6000, 2157672) = 0
    [pid 33754] stat("/etc/localtime", {st_mode=S_IFREG|0644, st_size=3559, ...}) = 0
    [pid 33754] write(128, "    E 10/09/16 08:36:32:870 | rp"..., 104) = 104
    [pid 33754] fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 23), ...}) = 0
    [pid 33754] mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fdf21cc9000
    [pid 33754] write(1, "E_RPCENV_IO_ERROR(-6) No connect"..., 57) = 57
    [pid 33754] write(1, "Failed to open i/o connection (x"..., 42) = 42
    Therefore, the problem appears to be that why theXDS200 has been enumerated as ttyACM1 and ttyACM2, the XDS200 driver attempts to communicate using the wrong ttyACM0 device and thus fails to establish communication with the XDS200.
    As a work-around can you determine what the ttyACM0 device is and try and remove it, to see if you can then make the XDS200 enumerate as ttyACM0 and ttyACM1 and then establish communication with the XDS200?
    On a Ubuntu system in which the XDS200 enumerated as ttyACM0 and ttyACM1, with no other USB ACM devices, a strace of a successful loadti.sh showed communication with ttyACM0.
  • Yes, that was it. It never occurred to me that /dev/ttyACM0 was not the XDS200 debugger.
    Yes, with the other device removed, the system works as expected. I was able to test the connection and download and run code.
    How do we configure CCS to use a different TTY? This is also likely to come up when other developers need to debug on Linux as our system is shared between several of us. I expect the next XDS200 will land at /dev/ttyACM3 and /dev/ttyACM4.
    thanks,
    hank
    I can repeat the failure of failure to connect to a XDS200 when enumerates as something other than /dev/ttyACM0.
    As an example:
    1) Connect a XDS200 Onboard Debug Probe, which enumerates as ttyACM0 and ttyACM01.
    Then connect a XDS100 which enumerates as ttyACM2 and ttyACM3.
    A test connection of the XDS110 and XDS200 can connect to the respective emulators.
    2) Swap the order of connecting the debug probes. i.e. connect the XDS110 first which enumerates as ttyACM0 and ttyACM1. Connect the XDS200 second which enumerates as ttyACM2 and ttyACM3.
    The test connection of the XDS110 is successful.
    However, the test connection of the XDS200 fails. It pauses after reporting:
    This utility will load the program 'xds2xxu.out'.
    And after a timeout reports:
    In this state when the XDS200 has enumerated as ttyACM2 and ttyACM3, running strace on a failed attempt to connect to the XDS200 using loadti.sh also shows that an incorrect attempt to communicate using ttyACM0 rather than ttyACM2.
    When repeated the problem was using:
    - CCS 6.1.3.00033
    - CentOS 6.8 64-bit
    - TI Emulators 6.0.407.3
    On the "Connection Properties" in the target configuration file for a XDS200 there is a "Debug Probe I/O Port Number". When a new target configuration is created the "Debug Probe I/O Port Number" defaults to zero.
    Once the XDS200 had enumerated as ttyACM2 and ttyACM3, the "Debug Probe I/O Port Number" was set to 2 in the target configuration and then the test connection could communicate with the XDS200.
    i.e. the "Debug Probe I/O Port Number" can be used to specify which XDS200 to use. However, because the USB ACM port numbers change according to the order the USB ACM devices are connected you will need to always connect multiple XDS200 probes in the same order to get repeatable results.
    The target configuration files for other debug probes, such as the XDS110, allow the debug probe instance to be specified using the USB serial number which is better since the USB serial number will always be the same for a given debug probe. It would be better if CCS allowed a consistent approach to identify multiple instances of the same debug probe.
