CCS/EK-TM4C1294XL: How to see dumped code in CCS tool
Part Number: EK-TM4C1294XL
1) how to  check source code from this board using CCS tool (it's already dumped I want to see)
2) how create new source code for this, give some example source codes like blink led
3) how to transfer dumped code in to another Tiva tm4c1294xl through CCS tool
    You said "it is already dumped", does this mean you extracted a binary file from the target? That binary file would not have any debug symbols so there is no source correlation. It is just raw executable code (and data)
    I am not sure I understand what you are asking. You wish to generate source code from the extracted binary?
    In the Memory view, there is an a option to load a binary file to memory. You can also use tools like UniFlash to program a binary file to a target.
    ki
    I haven’t heard back from you, hence this issue is being closed. If you wish to continue the discussion, please post a reply with an update below (or create a new thread).
    ki
