error processing changed links in project description file
  Hello @All
Does anyone know what this message means?
I am using the (QUICKSTART - CODE
COMPOSER STUDIOTM)
When I import the library grlib and click finish, the message above appears.
My CCS4 version: 4.1.3.00034
Please tell me what to do.
best regards
 Bassel
  • Bassel,
    Is there any additional information in the error log view?
    Window->Show View->Error Log
    John
  • thank you,
     yes there is a message which says:
    Error
    Fri Dec 03 08:10:32 CET 2010
    The project description file (.project) for grlib is missing.  This file contains important information about the project.  The project will not function properly until this file is restored."
    best regards
    bassel
  • Bassel,
    I have tried on a few different installations and I cannot reproduce the problem.  It seems like your StellarisWare installation is corrupted.  I have attached the .project file form my grlib project.  However you may need to re-install Stellarisware.  Note that when you import the StellarisWare projects you need to uncheck the box to copy them into your workspace.
    7318..project archive.zip
    John
