Part Number: AM5728
are the TI ARM Code Generation Tools also available for the Cortex-A15 as a host?
I want to compile code for the M4 cores on the A15 running Linux.
Ralf
Part Number: AM5728
Ralf
The TI ARM compiler has full support for Cortex-M4 CPU cores.
For Cortex-A15 CPU cores, the support is partial. In that case, you are limited to building for a Cortex-A8 core. The generated code can execute on a Cortex-A15 CPU, but does not use any of the new features the Cortex-A15 has the Cortex-A8 lacks.
Thanks and regards,
-George
Ralf Goebel said:I actually want to run the compiler on the A15 host, generating code for the M4 cores on the same chip.
I'm sorry I misunderstood that. You stated it clearly.
The TI ARM compiler does not support being hosted on Cortex-A15 Linux systems. Use the GCC ARM compiler for that.
Thanks and regards,
-George
