Compiler/TMS320F28377D: Compiler not emitting MOV32 RaH, RbH {, CNDF} or MOV32 RaH, mem32 {, CNDF} instructions
Part Number: TMS320F28377D
I am attempting to write fast code in C rather than assembler and have stumbled across the compiler not emitting MOV32 RaH, RbH {, CNDF} or MOV32 RaH, mem32 {, CNDF} instructions when I expect it to.
Given the file test.c:
#include <math.h>
double test_double(double a, double b) {
return fabs(a) > fabs(b) ? a : b;
static inline double quick_two_sum(double a, double b, double *err) {
double s = a + b;
*err = b - (s - a);
return s;
void c_dd_add_dd_d(const double *a, double b, double * restrict c) {
double s1, s2;
if (fabs(a[0]) > fabs(b)) {
s1 = a[0];
s2 = b;
} else {
s1 = b;
s2 = a[0];
s1 = quick_two_sum(s1, s2, &s2);
s2 += a[1];
c[0] = s1;
c[1] = s2;
and the command :
"C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_17.3.0.STS/bin/cl2000" -v28 -ml -mt --cla_support=cla1 --float_support=fpu32 --tmu_support=tmu0 --vcu_support=vcu2 -O4 --opt_for_speed=5 --fp_mode=strict --fp_reassoc=off --include_path="C:/ti/ccsv6/tools/compiler/ti-cgt-c2000_17.3.0.STS/include" --symdebug:none --diag_warning=225 --diag_wrap=off --display_error_number --src_interlist --preproc_with_compile --preproc_dependency="test.d"  "../test.c"
I end with the following assembly (trimmed for brevity):
_test_double:
;*** 4 ----------------------- return (ABS(a) > ABS(b)) ? a : b;
ADDB SP,#2 ; [CPU_U]
MOV32 R2H,R1H ; [CPU_] |4|
MOV32 R3H,R0H ; [CPU_] |4|
SUBB SP,#2 ; [CPU_U] |4|
ABSF32 R2H,R2H ; [CPU_] |4|
ABSF32 R3H,R3H ; [CPU_] |4|
CMPF32 R3H,R2H ; [CPU_] |4|
MOVST0 ZF, NF ; [CPU_] |4|
MOV32 R1H,R0H,GT ; [CPU_] |4|
MOV32 R0H,R1H ; [CPU_] |4|
LRETR ; [CPU_]
_c_dd_add_dd_d:
;*** 16 ----------------------- U$3 = *a;
;*** 16 ----------------------- if ( ABS(U$3) > ABS(b) ) goto g3;
MOVL ACC,*+XAR4[0] ; [CPU_] |16|
MOV32 R2H,ACC ; [CPU_] |16|
NOP ; [CPU_]
NOP ; [CPU_]
MOV32 R1H,R0H ; [CPU_] |16|
ABSF32 R1H,R1H ; [CPU_] |16|
ABSF32 R2H,R2H ; [CPU_] |16|
CMPF32 R2H,R1H ; [CPU_] |16|
MOVST0 ZF, NF ; [CPU_] |16|
B $C$L1,GT ; [CPU_] |16|
; branchcc occurs ; [] |16|
;*** 20 ----------------------- s1 = b;
;*** 21 ----------------------- s2 = U$3;
;*** 21 ----------------------- goto g4;
MOV32 R1H,R0H ; [CPU_] |20|
MOV32 R0H,ACC ; [CPU_] |21|
B $C$L2,UNC ; [CPU_] |21|
; branch occurs ; [] |21|
$C$L1:
;*** -----------------------g3:
;*** 17 ----------------------- s1 = U$3;
;*** 18 ----------------------- s2 = b;
MOV32 R1H,ACC ; [CPU_] |17|
NOP ; [CPU_]
NOP ; [CPU_]
NOP ; [CPU_]
NOP ; [CPU_]
$C$L2:
;*** -----------------------g4:
;*** 8 ----------------------- s = s1+s2; // [2]
;*** 9 ----------------------- s2 = s2-(s-s1)+a[1]; // [2]
;*** 8 ----------------------- s = s+s2; // [2]
;*** 9 ----------------------- s2 -= s-s; // [2]
;*** 28 ----------------------- *c = s;
;*** 29 ----------------------- c[1] = s2;
;*** ----------------------- return;
ADDF32 R2H,R0H,R1H ; [CPU_] |8|
NOP ; [CPU_]
SUBF32 R1H,R2H,R1H ; [CPU_] |9|
NOP ; [CPU_]
SUBF32 R0H,R0H,R1H ; [CPU_] |9|
MOV32 R3H,*+XAR4[2] ; [CPU_] |9|
ADDF32 R0H,R0H,R3H ; [CPU_] |9|
NOP ; [CPU_]
ADDF32 R1H,R0H,R2H ; [CPU_] |8|
NOP ; [CPU_]
SUBF32 R2H,R1H,R2H ; [CPU_] |9|
SUBF32 R0H,R0H,R2H ; [CPU_] |9|
MOV32 *+XAR5[0],R1H ; [CPU_] |28|
MOV32 *+XAR5[2],R0H ; [CPU_] |29|
LRETR ; [CPU_]
In _test_double a redundant move of floating-point status flags to integer status flags is performed, since the subsequent move uses the ZF and NF flags.
In _c_dd_add_dd_d a costly branch is used rather than conditional moves.
In _c_dd_add_dd_d  there is a costly use of ACC to avoid pushing and popping a floating-point register.
Am I missing something here? Is there a reason conditional moves are not being used in this situation?
Why is ACC being used as a temporary register when it results in a cycle penalty (I am at optimisation level 4 and optimise for speed 5).
  • I don't know offhand. It may not be possible to have a conditional move from ACC to RxH; the assembler rejects such instructions. I'll need to ask around for this one.
  • Reviewing the assembly output of the compiler, I'm interested in why the compiler is moving the floating-point value through the ACC in the first place rather than loading directly to a floating-point register. That way a conditional move from ACC to RxH is not required.
    Also can you clarify if the MOV32 RaH, RbH {, CNDF} and MOV32 RaH, mem32 {, CNDF} use the floating-point status bits or the integer status bits in the condition evaluation please? The assembly output of the compiler for the test_double function suggests it is the integer status bits yet the reference manual states it is the floating-point status bits.
  • Please bear with me, I'm not a C28x instruction set expert, so I had to go look up some answers here.
    Yes, conditional FPU instructions such as MOV32 use the CNDF flags, which are entirely distinct from the COND flags used in the C28x CPU. It is perhaps unfortunate that the names of some of these flags overlap, such as NEQ, EQ, etc.
    As to why the compiler generated bad code, the answer is that it's complicated. The compiler does optimization with a collection of heuristics, which don't always give an optimal answer, and in this case the compiler can't look ahead far enough to know that it should be doing this computation entirely with FPU instructions. This isn't a bug, it's just that the compiler isn't so great at taking a big-picture view of the code. There is definitely plenty of room for improvement for this function, so I'll submit an enhancement request for it (CODEGEN-2341).
  • Thanks for looking into this for me. I have been looking at the generated assembly for some other examples. I have seen the compiler generate conditional moves for floating-point registers rather than a branch, so the compiler gets it right some of the time. In these cases there is always a redundant MOVST0 instruction.
    This example function is part of a set of basic operations that are extensively used to construct more complex operations. As such they are all inlined to avoid costly function calls. I would drop down into assembly for these functions if I could but it is not possible to inline assembly functions into C/C++ or to modify C/C++ variables with inline assembly.
    Please can you provide a link for tracking the enhancement request. The SDOWP database is saying it cannot find the record.
    The enhancement request was updated.  Please try again using the SDOWP link below in my signature.
    Thanks and regards,
    -George
