We are using CCS 6.1.0.00104 and compiler TI v6.4.3 for TMS320F28x DSPs.
We have noticed a strange repeatable behavior of this compiler. Consider the following code:
typedef unsigned int uint16_t ; typedef unsigned long uint32_t; uint16_t parA = 94U; uint16_t parB16 = 6U; uint32_t parB32 = 6U; void foo(uint16_t a, uint32_t b){ /* do something */ }
Looking inside the generated assembler, it seems that the compiler performs a wrong behavior if foo() is called using not casted values because it puts on the stack the shortest word and within the procedure gets from the stack a word with proper size.
For example:
foo(94U, 6U); /*>>> error <<<<*/ foo(94U, 66000U); /*OK*/ foo((uint16_t)94U, (uint32_t) 6U); /* OK */ foo(parA, parB16); /*OK*/ foo(parA, parB32); /*OK*/
Is this kind of wrong behavior described somewhere in Texas Instruments documentation?
Where can we find the list of similar issues in Texas Instruments documentation?
Can this compiler considered safe?
Nicola
