Linux/TDA3XEVM: INTERNAL ERROR
Part Number: TDA3XEVM
Other Parts Discussed in Thread: LP8733, LP3907, SYSCONFIG, TVP5158, TLC59108
Tool/software: Linux
Hi there,
I am trying to build the application for TDA3x evm (building it for the first time) using "PROCESSOR_SDK_VISION_03_03_00_00_setuplinux" , after made changes in ../vision_sdk/build/Rules.make to set MAKEAPPNAME=apps and MAKECONFIG=tda3xx_evm_bios_all.(using ubuntu 14.04, os-type=64 bit)
In terminal ../vision_sdk/build$ make -s -j depend (compiled successfully)
and doing "make -s -j" i am experiencing an error with is mentioned below:
INTERNAL ERROR: (native_path)/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/cg_tools/linux/arp32_1.0.7/bin/acpia-arp32 experienced a segmentation fault while
                processing
This is a serious problem.  Please contact Customer
Support with this message and a copy of the input file
and help us to continue to make the tools more robust.
>> Compilation failure
Why does this happen? How can I solve these  issue?
Thanks in advance
With Regards
Balaji
    Can you build using "make -s" and see if you are getting the same error.
    If yes kindly share the full log
    Rishabh
  • Hi Rishabh,
    Here is the log, that you have asked for build using "make -s". But this time the error is slightly different.
    Log:-(to be mentioned "make -s -j depend"  compiled successfully)
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build$ make -s
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_algorithm
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_dup
    # Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_dup
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_dup
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_dup
    # Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_dup
    # Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_gate
    # Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_gate
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_gate
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_gate
    # Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_gate
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_ipcIn
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_ipcOut
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_merge
    # Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_merge
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_merge
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_merge
    # Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_merge
    # Compiling tda3xx-evm:ipu1_0:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_null
    # Compiling tda3xx-evm:ipu1_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_null
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_null
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_null
    # Compiling tda3xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_null
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_network_tx
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_network_tx
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_network_tx
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_network_tx
    # Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_network_tx
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_network_rx
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_network_rx
    # Compiling tda3xx-evm:ipu1_0:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_nullSrc
    # Compiling tda3xx-evm:ipu1_1:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_nullSrc
    # Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_select
    # Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_select
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_select
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_select
    # Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_select
    # Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_sync
    # Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_sync
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_sync
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_sync
    # Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_sync
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_display
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_apply_config.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_create_delete.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_process_frame.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_subframe_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_l3_emif_bw.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_boot_slaves.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_esm.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_ipu_ecc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_dcc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_execp_trace_local_m4.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_uart.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cbuf_ocmc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_qspi.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_idle_m4.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_temperature.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_stat_collector.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prcm_stats.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_emif_ecc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mcspi.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_taskTimer.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci_config_tda3x.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_iss.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: network_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api_dma.c
    # Archiving tda3xx-evm:ipu1_0:release:utils_common
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_iss.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_execp_trace_remote_m4.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_1.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_idle_m4.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_stat_collector.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_qspi.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api_dma.c
    # Archiving tda3xx-evm:ipu1_1:release:utils_common
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
    # Archiving tda3xx-evm:c66xdsp_1:release:utils_common
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_api.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
    # Archiving tda3xx-evm:c66xdsp_2:release:utils_common
    # Compiling tda3xx-evm:arp32_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_l3fw.c
    # Archiving tda3xx-evm:arp32_1:release:utils_common
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_system
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_system
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_dsp_system
    # Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_dsp_system
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: system_eve.c
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_eve_system
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_bsp_init.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_system
    # Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: system_ipu1_1.c
    # Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda3xx-evm:ipu1_1:release:links_ipu_system
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: crc/crcLink_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: crc/crc_algSystemDma.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: deWarp/deWarp_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: objectdetection/fpcompute2/imgPyramid_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: objectdetection/fpcompute2/iss_resizer.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: objectdetection/objectDrawLink_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: objectdetection/objectDrawLink_trafficSigns.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: objectdetection/objectDrawLink_trafficLights.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: sceneobstruction/sceneObstructionDetectLink_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: openvx/openvx_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: openvx/openvx.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: tidl/tidlpreprocLink_algPlugin.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font01.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font03.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font04.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font05.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font06.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font07.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font08.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font09.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font14.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_1.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ti_logo_white_small.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font02.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font00.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_frontcam_logo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/lut16x16x0_25_129x129_0.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/lut16x16x0_25_129x129_1.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_sv_logo_small.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_3d_perception_sfm_logo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_220x330.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_228x432.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_jeep_Image_288x432.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_suv_topView_348x480.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_tda2x.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_tda3x.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_left.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_rearview_right.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_left.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_ford_sf_lines_topdown_rearview_right.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_colorbar_20x720.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_colorbar_35x450.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_green.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2c_tl_red.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_echo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_calib_image_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_dynamic_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_iss_raw_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_object_detect_set_dynamic_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/network_cons/network_cons_ipc.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: common/sample.cpp
    # Archiving tda3xx-evm:ipu1_0:release:app_alg_plugins
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignLUT_tda3xx.oe66' given more than once in the same rule.
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignExt_tda3xx.oe66' given more than once in the same rule.
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/acDetectLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/pEstimateLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: autocalibration/calMatGen_If.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: autoremap/autoRemapLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: clr/clrLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImgLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImgLink_dma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImageLUT_65x65_0.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImageLUT_65x65_1.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImageLUT_129x129_0.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: denseopticalflow/vectorToImageLUT_129x129_1.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: dmaSwMs/dmaSwMsLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: drawRearview/drawRearviewAlgoLocalDma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: drawRearview/drawRearviewLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: drawRearview/drawRearviewLink_DynamicLines.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: framecopy/frameCopyAlgoLocalDma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: lanedetection/laneDetectLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDetectionLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectClassificationLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_trafficSigns.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_trafficLights.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: safe_framecopy/safeFrameCopyLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: safe_framecopy/safeFrameCopyAlgoLocalDma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: sceneobstruction/sceneObstructionDetectLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: sfm/sfmLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: sfm/fcwLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: stereo_postprocessing/stereoPostProcessLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/synthesisLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignLUT_tda3xx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/GAlignExt_tda3xx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/pAlignLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/uFusionLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusionExt.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/UFusion_bufferZonesLUT.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlignLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/gAlign3DLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svLutGen_If.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/svBlendTableGen_If.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: surroundview/adaptiveBowlLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: stereo_app/stereoAppLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: tidl/tidlLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4CompDecomp_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: commonutils/calmat.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda3xx-evm:c66xdsp_1:release:app_alg_plugins
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample_vcop_array_add_uns_short_kernel.k
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font10_yuv.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font11_yuv.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font12_yuv.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font13_yuv.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/alg_ivision.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: census/censusLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: denseopticalflow/denseOpticalFlowLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: disparityhamdist/disparityHamDistLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: edgedetection/edgeDetectionLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: framecopy/frameCopyAlgoEve.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute1/featurePlaneCompLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute1/alg_imagePyramid.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute1/alg_featureCompute.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute2/imagePreProcess_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute2/fpComputeLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/fpcompute2/alg_fpCompute2.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/alg_filter2d.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: objectdetection/alg_clahe.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: remapmerge/remapMergeLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: remapmerge/rectMapLeft_int_converted.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: remapmerge/rectMapRight_int_converted.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: safe_framecopy/safeFrameCopyLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: safe_framecopy/safeFrameCopyAlgoLocalDma.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: sparseopticalflow/sparseOpticalFlowLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: subframecopy/subframeCopyLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: subframecopy/subframeCopyLink_edma.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: tidl/tidlLink_algPlugin.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: common/sample.cpp
    # Archiving tda3xx-evm:arp32_1:release:app_alg_plugins
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_settings_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_stereo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_avb.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_multi_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_single_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_iss.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_opencl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_misc.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_vision.c
    INTERNAL ERROR: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armacpia experienced a segmentation fault
    while processing function (unknown or file scope) file /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/src/ip/uart/V1/cslr_uart.h line 509
    This is caused by a defect in the compiler itself. TI Customer
    Support may be able to suggest a workaround to avoid this.
    Upgrading to the newest version of the compiler may fix this problem.
    Contact TI in the E2E support forums at http://e2e.ti.com under
    "Development Tools", "TI C/C++ Compiler". See the link titled
    "Submitting an issue". Include this ENTIRE error message and a
    copy of the .pp file created when option --preproc_with_comment
    (-ppc) is used.
    >> Compilation failure
    make[5]: *** [/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_libs/tda3xx-evm/ipu1_0/release/chains_main_bios_vision.oem4] Error 1
    make[4]: *** [ipu1_0] Error 2
    make[3]: *** [app_libs] Error 2
    make[2]: *** [apps_libs] Error 2
    make[1]: *** [apps] Error 2
    gmake: *** [vision_sdk] Error 2
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build$
    regards,
    balaji
  • Hi there,
    Any update..?
  • Hi Balaji,
    PDK is compiled first when you do make -s depend. It seems that somehow dependencies were not build correctly due to which you are seeing this. Can you try a clean build.
    First build dependencies using "make -s depend" and then VSDK using "make -s".
    Rishabh
    Is there an update on this.
    Rishabh
  • Hi Rishabh,
    The above mentioned commands i.e., Building dependencies using "make -s depend" and then VSDK using "make -s" are working fine, but i am compiling many times to make sure that its working completely fine.
    Thank you for helping me about this error, get back to you shortly.,
    Balaji
  • Hi Rishabh,
    i am facing the same error again, here is the reference log.
    balaji@FSETBLR2D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build$ gmake -s depend
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/links_fw/include/config’: File exists
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/links_fw/include/config/apps’: File exists
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_all’: File exists
    # makeconfig: Config is [ tda3xx_evm_bios_all ]
    # makeconfig: Output file is @ /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_04_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_all/system_cfg.h
    # makeconfig: Input file is @ /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/configs/tda3xx_evm_bios_all/cfg.mk
    # makeconfig: Generating header ...
    # makeconfig: Generating alg plugin config ...
    # makeconfig: Generating usecase config ...
    # makeconfig: Generating footer ...
    # makeconfig: Done !!!
    # CPUs that are NOT required but included in config [ tda3xx_evm_bios_all ],
    # WARNING: IPU1_1 can be excluded from application
    # CPUs that are required but not included in config [ tda3xx_evm_bios_all ],
    # Edit /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/configs/tda3xx_evm_bios_all/cfg.mk to include or exclude CPUs in an application
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda3xx-evm:ipu1_0:release:edma3lld_drv
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda3xx-evm:ipu1_0:release:edma3lld_rm: src/configs/edma3_tda3xx_cfg.c
    # Archiving tda3xx-evm:ipu1_0:release:edma3lld_rm
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda3xx-evm:c66xdsp_1:release:edma3lld_drv
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda3xx-evm:c66xdsp_1:release:edma3lld_rm: src/configs/edma3_tda3xx_cfg.c
    # Archiving tda3xx-evm:c66xdsp_1:release:edma3lld_rm
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_init.c
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_basic.c
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_adv.c
    # Archiving tda3xx-evm:arp32_1:release:edma3lld_drv
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_rm: src/edma3resmgr.c
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
    # Compiling tda3xx-evm:arp32_1:release:edma3lld_rm: src/configs/edma3_tda3xx_cfg.c
    # Archiving tda3xx-evm:arp32_1:release:edma3lld_rm
    Nothing to be done for tda3xx csl_init
    Nothing to be done for tda3xx csl_intc
    # Compiling tda3xx:ipu1_0:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda3xx:ipu1_0:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda3xx:ipu1_0:release:csl: ./arch/m4/src/interrupt.c
    # Compiling tda3xx:ipu1_0:release:csl: ./arch/m4/src/ipu_wugen.c
    # Compiling tda3xx:ipu1_0:release:csl: ./arch/m4/src/ammu.c
    # Compiling tda3xx:ipu1_0:release:csl: ./arch/m4/src/unicache.c
    # Compiling tda3xx:ipu1_0:release:csl: ./arch/m4/src/ipu_ecc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/adc/V0/priv/adc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/crc/V0/priv/crc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/dcc/V0/priv/dcc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/esm/V0/priv/esm.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mcan/V0/priv/mcan.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/rti/V0/priv/rti.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/tesoc/V0/priv/tesoc.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda3xx:ipu1_0:release:csl: src/ip/uart/V1/priv/uart.c
    # Archiving tda3xx:ipu1_0:release:csl into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/lib/tda3xx/m4/release/ti.csl.aem4 ...
    # Compiling tda3xx:ipu1_0:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda3xx:ipu1_0:release:csl_utils_common into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/common/lib/tda3xx/m4/release/csl_utils_common.aem4 ...
    # Compiling tda3xx:ipu1_0:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda3xx:ipu1_0:release:csl_uart_console into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/uart_console/lib/tda3xx/m4/release/csl_uart_console.aem4 ...
    # Compiling tda3xx:ipu1_0:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda3xx:ipu1_0:release:csl_utils_i2c into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/i2c/lib/tda3xx/m4/release/csl_utils_i2c.aem4 ...
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pm_utils.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_lp8731.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_lp8733.c
    # Compiling tda3xx:ipu1_0:release:pm_hal: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:ipu1_0:release:pm_hal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/m4/release/pm_hal.aem4 ...
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    while processing function (unknown or file scope) file (unknown) line 0
    (-ppc) is used.
    >> Compilation failure
    make[4]: *** [/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/ti/drv/pm/src/pmhal/optimized/obj/tda3xx/m4/release/pmhal_prcm_stats.oem4] Error 1
    make[3]: *** [pm_hal_optimized] Error 2
    make[2]: *** [pdk] Error 2
    make[1]: *** [pdk] Error 2
    gmake: *** [depend] Error 2
    regards
    balaji
    In one of the posts you have mentioned that the build worked for you. Can you describe the scenarios where the build works and where it doesn't.
    Also can you try building a fresh release package without -j.
    Rishabh
  • Hi Rishabh,
    I am very thankful for extending your help to solve this issue.
    After you suggested to build dependencies using "make -s depend" and then VSDK using "make -s" its worked fine for two times. Then i tried next morning i am getting the same error, even now i tried and i got error mentioned below in "make -s" step.
    Log building a fresh release package without -j
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build$ make -s depend
    # makeconfig: Output file is @ /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_all/system_cfg.h
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_lp8731.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_lp8733.c
    # Compiling tda3xx:ipu1_0:release:pm_hal_optimized: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:ipu1_0:release:pm_hal_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/m4/release/pm_hal_optimized.aem4 ...
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_m4.c
    # Archiving tda3xx:ipu1_0:release:pm_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/m4/release/pm_lib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_m4.asm
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_m4.c
    # Archiving tda3xx:ipu1_0:release:pm_lib_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/m4/release/pm_lib_optimized.aem4 ...
    Nothing to be done for tda3xx pm_rtos
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib: src/sbl_lib_common.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib: src/sbl_lib_board.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib: src/sbl_lib_weak.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib: src/tda3xx/sbl_lib_tda3xx_platform.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib: src/tda3xx/sbl_lib_tda3xx_prcm_dpll.c
    # Archiving tda3xx-evm:tda3xx:ipu1_0:release:sbl_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/boot/sbl_auto/lib/tda3xx-evm/m4/release/sbl_lib.aem4 ...
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_utils: src/sbl_utils_common.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_utils: src/tda3xx/sbl_utils_tda3xx.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_utils: src/tda3xx/sbl_utils_tda3xx_i2c.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:sbl_utils: src/tda3xx/sbl_utils_tda3xx_ddr_config.c
    # Archiving tda3xx-evm:tda3xx:ipu1_0:release:sbl_utils into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/boot/sbl_auto/lib/tda3xx-evm/m4/release/sbl_utils.aem4 ...
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_utils.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_ecc.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_eccEmif.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_eccOcmc.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_mcspi.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_can.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_adc.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_crc.c
    # Compiling tda3xx:ipu1_0:release:diag: src/diagLib_eccIpu.c
    # Archiving tda3xx:ipu1_0:release:diag into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/diag/lib/tda3xx/m4/release/diag.aem4 ...
    # Compiling tda3xx:ipu1_0:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda3xx:ipu1_0:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda3xx:ipu1_0:release:firewall_l3l4 into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/fw_l3l4/lib/tda3xx/m4/release/firewall_l3l4.aem4 ...
    # Compiling tda3xx:ipu1_0:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xx.c
    # Compiling tda3xx:ipu1_0:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxMailboxCfg.c
    # Compiling tda3xx:ipu1_0:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxProcCfg.c
    # Compiling tda3xx:ipu1_0:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxXbarCfg.c
    # Compiling tda3xx:ipu1_0:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda3xx:ipu1_0:release:ipc_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/ipc_lite/lib/tda3xx/ipu1_0/release/ipc_lib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:norflash_lib: src/nor_flash.c
    # Compiling tda3xx:ipu1_0:release:norflash_lib: src/debug.c
    # Archiving tda3xx:ipu1_0:release:norflash_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/boot/sbl_auto/norflash/lib/tda3xx/m4/release/norflash_lib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:qspiflash_lib: src/qspi_cmd_init.c
    # Compiling tda3xx:ipu1_0:release:qspiflash_lib: src/qspi_flash.c
    # Archiving tda3xx:ipu1_0:release:qspiflash_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/boot/sbl_auto/qspiflash/lib/tda3xx/m4/release/qspiflash_lib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda3xx:ipu1_0:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda3xx:ipu1_0:release:i2c_lld into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/i2clld/lib/tda3xx/m4/release/i2c_lld.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/platform.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/stw_platform.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/irq_xbar.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/dma_xbar.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/chip_config.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/platform_tda3xx.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/platform_tda3xx_pad_config.c
    # Compiling tda3xx:ipu1_0:release:stw_platform: src/tda3xx/stw_platformTda3xx.c
    # Archiving tda3xx:ipu1_0:release:stw_platform into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/platform/lib/tda3xx/m4/release/stw_platform.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda3xx:ipu1_0:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda3xx:ipu1_0:release:stw_uartconsole into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/uartconsole/lib/tda3xx/m4/release/stw_uartconsole.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_fatlib: src/fat_mmcsd.c
    # Compiling tda3xx:ipu1_0:release:stw_fatlib: fatfs/ff.c
    # Compiling tda3xx:ipu1_0:release:stw_fatlib: src/hs_mmcsdlib.c
    # Compiling tda3xx:ipu1_0:release:stw_fatlib: src/mmcsd_proto.c
    # Compiling tda3xx:ipu1_0:release:stw_fatlib: src/hsmmcsd_API.c
    # Archiving tda3xx:ipu1_0:release:stw_fatlib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/fatlib/lib/tda3xx/m4/release/stw_fatlib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_fatlib_edma: fatlib_edma/hsmmcsd_edma.c
    # Archiving tda3xx:ipu1_0:release:stw_fatlib_edma into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/fatlib/lib/tda3xx/m4/release/stw_fatlib_edma.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_boards: src/stw_board.c
    # Compiling tda3xx:ipu1_0:release:stw_boards: src/stw_boardTda3xx.c
    # Compiling tda3xx:ipu1_0:release:stw_boards: src/stw_boardTda3xxPinmuxData.c
    # Archiving tda3xx:ipu1_0:release:stw_boards into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/boards/lib/tda3xx/m4/release/stw_boards.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_devices: src/stw_device.c
    # Compiling tda3xx:ipu1_0:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda3xx:ipu1_0:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda3xx:ipu1_0:release:stw_devices into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/devices/lib/tda3xx/m4/release/stw_devices.aem4 ...
    # Compiling tda3xx:ipu1_0:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda3xx:ipu1_0:release:stw_examples_utility into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/examples/utility/lib/tda3xx/m4/release/stw_examples_utility.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vps_osal_baremetal: osal.c
    # Compiling tda3xx:ipu1_0:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda3xx:ipu1_0:release:vps_osal_baremetal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/ipu1_0/release/vps_osal_baremetal.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vps_common: src/bsp_common.c
    # Compiling tda3xx:ipu1_0:release:vps_common: src/bsp_utils.c
    # Compiling tda3xx:ipu1_0:release:vps_common: src/bsp_utilsQue.c
    # Compiling tda3xx:ipu1_0:release:vps_common: src/trace.c
    # Archiving tda3xx:ipu1_0:release:vps_common into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vps_common.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_csc.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_sc.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_vpdma.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_vipPort.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_vipTop.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcPipeTda3xx.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcOvlyTda3xx.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_dssSdVenc.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_iss.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issvtnf.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_isssimcop.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/wdrldc/vpshal_issldc.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_isscal.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_calCsi2Tda3x.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issnsf3.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_isslvdsrx.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issipipe.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issisif.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issrsz.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issipipeif.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/vpshal_issh3a.c
    # Compiling tda3xx:ipu1_0:release:vpslib: hal/src/wdrldc/vpshal_issglbce.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/vps_evtMgr.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/vps_resrcMgr.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/vps_graph.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/vpslib_initTda3xx.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/iem_evtmgr.c
    # Compiling tda3xx:ipu1_0:release:vpslib: common/src/irm_resrcMgr.c
    # Compiling tda3xx:ipu1_0:release:vpslib: captcore/src/vpscore_vip.c
    # Compiling tda3xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipDefaults.c
    # Compiling tda3xx:ipu1_0:release:vpslib: captcore/src/vpscore_vipVipControl.c
    # Compiling tda3xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dss.c
    # Compiling tda3xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrl.c
    # Compiling tda3xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlDefaults.c
    # Compiling tda3xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlGraph.c
    # Compiling tda3xx:ipu1_0:release:vpslib: dispcore/src/vpscore_dssWb.c
    # Compiling tda3xx:ipu1_0:release:vpslib: isscore/src/vpscore_isscommon.c
    # Compiling tda3xx:ipu1_0:release:vpslib: isscore/src/vpscore_captureapi.c
    # Compiling tda3xx:ipu1_0:release:vpslib: isscore/src/vpscore_simcop.c
    # Compiling tda3xx:ipu1_0:release:vpslib: isscore/src/vpscore_ispapi.c
    # Compiling tda3xx:ipu1_0:release:vpslib: isscore/src/vpscore_isp.c
    # Archiving tda3xx:ipu1_0:release:vpslib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vpslib.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vpsdrv_baremetal: src/vps_initDrv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv_baremetal: src/vps_vipDrv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dctrlDrv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv_baremetal: src/vps_dssDrv.c
    # Archiving tda3xx:ipu1_0:release:vpsdrv_baremetal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vpsdrv_baremetal.aem4 ...
    # Compiling tda3xx:ipu1_0:release:fvid2: src/fvid2_drvMgr.c
    # Archiving tda3xx:ipu1_0:release:fvid2 into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/fvid2.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda3xx:ipu1_0:release:vps_osal_tirtos into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vps_osal_tirtos.aem4 ...
    Nothing to be done for tda3xx vps_osal_tirtos_smp
    # Compiling tda3xx:ipu1_0:release:vpsdrv: src/vpsdrv_init.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: src/vpsdrv_control.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureApi.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureProc.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureCore.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_capturePriv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayApi.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayProc.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayCore.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayPriv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_dctrl.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssApi.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssCore.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssProc.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssPriv.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv/src/vpsdrv_m2mIntfApi.c
    # Compiling tda3xx:ipu1_0:release:vpsdrv: m2mdrv/src/vpsdrv_m2mIssCore.c
    # Archiving tda3xx:ipu1_0:release:vpsdrv into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vpsdrv.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vps_platforms: src/bsp_platform.c
    # Compiling tda3xx:ipu1_0:release:vps_platforms: src/bsp_platformTda3xx.c
    # Archiving tda3xx:ipu1_0:release:vps_platforms into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vps_platforms.aem4 ...
    # Compiling tda3xx:ipu1_0:release:vps_devices: src/bsp_device.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: src/bsp_deviceI2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Reg.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xApi.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xI2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov10x3xReg.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_lcdCtrlApi.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_tc358778Ctrl.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: tlc59108/src/bsp_tlc59108.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Reg.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccApi.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccI2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccReg.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: sii9022a/src/bspdrv_sii9022a.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ioexp/src/bspdrv_ioexpTca64xx.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: pga450/src/bspdrv_pga450.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_DOL_MIPI_4Lane.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_Linear.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: imx290/src/bspdrv_imx290Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Reg.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Api.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490I2c.c
    # Compiling tda3xx:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Reg.c
    # Archiving tda3xx:ipu1_0:release:vps_devices into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/m4/release/vps_devices.aem4 ...
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_boards: src/bsp_board.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_boards: src/bsp_boardTda2xx.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_boards: src/bsp_boardTda2ex.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_boards: src/bsp_boardTda3xx.c
    # Archiving tda3xx-evm:tda3xx:ipu1_0:release:vps_boards into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx-evm/m4/release/vps_boards.aem4 ...
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_app.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_buf.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_mbx.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_tsk.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_prf.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_mem_default.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_tiler.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub960.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_ub95x.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_lvds.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_fileio.c
    # Compiling tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility: src/bsputils_uart.c
    # Archiving tda3xx-evm:tda3xx:ipu1_0:release:vps_examples_utility into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx-evm/m4/release/vps_examples_utility.aem4 ...
    # Compiling tda3xx:ipu1_0:release:bsp_i2c: src/bsp_i2cdrv.c
    # Archiving tda3xx:ipu1_0:release:bsp_i2c into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/bsp_lld/i2c/lib/tda3xx/m4/release/bsp_i2c.aem4 ...
    # Compiling tda3xx:ipu1_0:release:bsp_uart: src/bspdrv_uart.c
    # Compiling tda3xx:ipu1_0:release:bsp_uart: src/bspdrv_uartEdma.c
    # Archiving tda3xx:ipu1_0:release:bsp_uart into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/bsp_lld/uart/lib/tda3xx/m4/release/bsp_uart.aem4 ...
    # Compiling tda3xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspi.c
    # Compiling tda3xx:ipu1_0:release:bsp_mcspi: src/bsp_mcspiEdma.c
    # Archiving tda3xx:ipu1_0:release:bsp_mcspi into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/bsp_lld/mcspi/lib/tda3xx/m4/release/bsp_mcspi.aem4 ...
    Nothing to be done for tda3xx ipu1_1 csl
    Nothing to be done for tda3xx ipu1_1 csl_utils_common
    Nothing to be done for tda3xx ipu1_1 csl_uart_console
    Nothing to be done for tda3xx ipu1_1 csl_utils_i2c
    Nothing to be done for tda3xx ipu1_1 pm_hal
    Nothing to be done for tda3xx ipu1_1 pm_hal_optimized
    Nothing to be done for tda3xx ipu1_1 pm_lib
    Nothing to be done for tda3xx ipu1_1 pm_lib_optimized
    Nothing to be done for tda3xx ipu1_1 sbl_lib
    Nothing to be done for tda3xx ipu1_1 sbl_utils
    Nothing to be done for tda3xx ipu1_1 diag
    Nothing to be done for tda3xx ipu1_1 firewall_l3l4
    # Compiling tda3xx:ipu1_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xx.c
    # Compiling tda3xx:ipu1_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxMailboxCfg.c
    # Compiling tda3xx:ipu1_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxProcCfg.c
    # Compiling tda3xx:ipu1_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxXbarCfg.c
    # Compiling tda3xx:ipu1_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda3xx:ipu1_1:release:ipc_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/ipc_lite/lib/tda3xx/ipu1_1/release/ipc_lib.aem4 ...
    Nothing to be done for tda3xx ipu1_1 norflash_lib
    Nothing to be done for tda3xx ipu1_1 qspiflash_lib
    Nothing to be done for tda3xx ipu1_1 i2c_lld
    Nothing to be done for tda3xx ipu1_1 stw_platform
    Nothing to be done for tda3xx ipu1_1 stw_uartconsole
    Nothing to be done for tda3xx ipu1_1 stw_fatlib
    Nothing to be done for tda3xx ipu1_1 stw_fatlib_edma
    Nothing to be done for tda3xx ipu1_1 stw_boards
    Nothing to be done for tda3xx ipu1_1 stw_devices
    Nothing to be done for tda3xx ipu1_1 stw_examples_utility
    # Compiling tda3xx:ipu1_1:release:vps_osal_baremetal: osal.c
    # Compiling tda3xx:ipu1_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda3xx:ipu1_1:release:vps_osal_baremetal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/ipu1_1/release/vps_osal_baremetal.aem4 ...
    Nothing to be done for tda3xx ipu1_1 vps_common
    Nothing to be done for tda3xx ipu1_1 vpslib
    Nothing to be done for tda3xx ipu1_1 vpsdrv_baremetal
    Nothing to be done for tda3xx ipu1_1 fvid2
    Nothing to be done for tda3xx ipu1_1 vps_osal_tirtos
    Nothing to be done for tda3xx ipu1_1 vps_platforms
    Nothing to be done for tda3xx ipu1_1 vps_devices
    Nothing to be done for tda3xx ipu1_1 vps_boards
    Nothing to be done for tda3xx ipu1_1 vps_examples_utility
    Nothing to be done for tda3xx ipu1_1 bsp_i2c
    Nothing to be done for tda3xx ipu1_1 bsp_uart
    Nothing to be done for tda3xx ipu1_1 bsp_mcspi
    Nothing to be done for tda3xx ipu2_0 csl
    Nothing to be done for tda3xx ipu2_0 csl_utils_common
    Nothing to be done for tda3xx ipu2_0 csl_uart_console
    Nothing to be done for tda3xx ipu2_0 csl_utils_i2c
    Nothing to be done for tda3xx ipu2_0 pm_hal
    Nothing to be done for tda3xx ipu2_0 pm_hal_optimized
    Nothing to be done for tda3xx ipu2_0 pm_lib
    Nothing to be done for tda3xx ipu2_0 pm_lib_optimized
    Nothing to be done for tda3xx ipu2_0 sbl_lib
    Nothing to be done for tda3xx ipu2_0 sbl_utils
    Nothing to be done for tda3xx ipu2_0 diag
    Nothing to be done for tda3xx ipu2_0 firewall_l3l4
    Nothing to be done for tda3xx ipu2_0 ipc_lib
    Nothing to be done for tda3xx ipu2_0 norflash_lib
    Nothing to be done for tda3xx ipu2_0 qspiflash_lib
    Nothing to be done for tda3xx ipu2_0 i2c_lld
    Nothing to be done for tda3xx ipu2_0 stw_platform
    Nothing to be done for tda3xx ipu2_0 stw_uartconsole
    Nothing to be done for tda3xx ipu2_0 stw_fatlib
    Nothing to be done for tda3xx ipu2_0 stw_fatlib_edma
    Nothing to be done for tda3xx ipu2_0 stw_boards
    Nothing to be done for tda3xx ipu2_0 stw_devices
    Nothing to be done for tda3xx ipu2_0 stw_examples_utility
    Nothing to be done for tda3xx ipu2_0 vps_osal_baremetal
    Nothing to be done for tda3xx ipu2_0 vps_common
    Nothing to be done for tda3xx ipu2_0 vpslib
    Nothing to be done for tda3xx ipu2_0 vpsdrv_baremetal
    Nothing to be done for tda3xx ipu2_0 fvid2
    Nothing to be done for tda3xx ipu2_0 vps_osal_tirtos
    Nothing to be done for tda3xx ipu2_0 vps_platforms
    Nothing to be done for tda3xx ipu2_0 vps_devices
    Nothing to be done for tda3xx ipu2_0 vps_boards
    Nothing to be done for tda3xx ipu2_0 vps_examples_utility
    Nothing to be done for tda3xx ipu2_0 bsp_i2c
    Nothing to be done for tda3xx ipu2_0 bsp_uart
    Nothing to be done for tda3xx ipu2_0 bsp_mcspi
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/intvecs.asm
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/swenr.asm
    # Compiling tda3xx:c66x:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda3xx:c66x:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/interrupt.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_wugen.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_config.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_ecc.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_icfg.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_usrSpvSupport.c
    # Compiling tda3xx:c66x:release:csl: ./arch/c66x/src/dsp_xmc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/adc/V0/priv/adc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/crc/V0/priv/crc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda3xx:c66x:release:csl: src/ip/dcc/V0/priv/dcc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda3xx:c66x:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda3xx:c66x:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda3xx:c66x:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda3xx:c66x:release:csl: src/ip/esm/V0/priv/esm.c
    # Compiling tda3xx:c66x:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda3xx:c66x:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda3xx:c66x:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda3xx:c66x:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mcan/V0/priv/mcan.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda3xx:c66x:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda3xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda3xx:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda3xx:c66x:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda3xx:c66x:release:csl: src/ip/rti/V0/priv/rti.c
    # Compiling tda3xx:c66x:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda3xx:c66x:release:csl: src/ip/tesoc/V0/priv/tesoc.c
    # Compiling tda3xx:c66x:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda3xx:c66x:release:csl: src/ip/uart/V1/priv/uart.c
    # Archiving tda3xx:c66x:release:csl into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/lib/tda3xx/c66/release/ti.csl.ae66 ...
    # Compiling tda3xx:c66x:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda3xx:c66x:release:csl_utils_common into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/common/lib/tda3xx/c66/release/csl_utils_common.ae66 ...
    # Compiling tda3xx:c66x:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda3xx:c66x:release:csl_uart_console into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/uart_console/lib/tda3xx/c66/release/csl_uart_console.ae66 ...
    # Compiling tda3xx:c66x:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda3xx:c66x:release:csl_utils_i2c into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/i2c/lib/tda3xx/c66/release/csl_utils_i2c.ae66 ...
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pm_utils.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_lp8731.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_lp8733.c
    # Compiling tda3xx:c66x:release:pm_hal: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:c66x:release:pm_hal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/c66/release/pm_hal.ae66 ...
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_lp8731.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_lp8733.c
    # Compiling tda3xx:c66x:release:pm_hal_optimized: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:c66x:release:pm_hal_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/c66/release/pm_hal_optimized.ae66 ...
    # Compiling tda3xx:c66x:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:c66x:release:pm_lib: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda3xx:c66x:release:pm_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/c66/release/pm_lib.ae66 ...
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:c66x:release:pm_lib_optimized: prcm/pmlib_cpuidle_c66x.c
    # Archiving tda3xx:c66x:release:pm_lib_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/c66/release/pm_lib_optimized.ae66 ...
    Nothing to be done for tda3xx c66x sbl_lib
    Nothing to be done for tda3xx c66x sbl_utils
    Nothing to be done for tda3xx c66x diag
    # Compiling tda3xx:c66x:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda3xx:c66x:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda3xx:c66x:release:firewall_l3l4 into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/fw_l3l4/lib/tda3xx/c66/release/firewall_l3l4.ae66 ...
    Nothing to be done for tda3xx c66x ipc_lib
    Nothing to be done for tda3xx c66x norflash_lib
    Nothing to be done for tda3xx c66x qspiflash_lib
    # Compiling tda3xx:c66x:release:i2c_lld: src/lld_hsi2c.c
    # Compiling tda3xx:c66x:release:i2c_lld: src/lld_hsi2c_edma.c
    # Archiving tda3xx:c66x:release:i2c_lld into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/i2clld/lib/tda3xx/c66/release/i2c_lld.ae66 ...
    # Compiling tda3xx:c66x:release:stw_platform: src/platform.c
    # Compiling tda3xx:c66x:release:stw_platform: src/stw_platform.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/irq_xbar.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/dma_xbar.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/chip_config.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/platform_tda3xx.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/platform_tda3xx_pad_config.c
    # Compiling tda3xx:c66x:release:stw_platform: src/tda3xx/stw_platformTda3xx.c
    # Archiving tda3xx:c66x:release:stw_platform into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/platform/lib/tda3xx/c66/release/stw_platform.ae66 ...
    # Compiling tda3xx:c66x:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda3xx:c66x:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda3xx:c66x:release:stw_uartconsole into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/uartconsole/lib/tda3xx/c66/release/stw_uartconsole.ae66 ...
    Nothing to be done for tda3xx c66x stw_fatlib
    Nothing to be done for tda3xx c66x stw_fatlib_edma
    # Compiling tda3xx:c66x:release:stw_boards: src/stw_board.c
    # Compiling tda3xx:c66x:release:stw_boards: src/stw_boardTda3xx.c
    # Compiling tda3xx:c66x:release:stw_boards: src/stw_boardTda3xxPinmuxData.c
    # Archiving tda3xx:c66x:release:stw_boards into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/boards/lib/tda3xx/c66/release/stw_boards.ae66 ...
    # Compiling tda3xx:c66x:release:stw_devices: src/stw_device.c
    # Compiling tda3xx:c66x:release:stw_devices: src/stw_deviceI2c.c
    # Compiling tda3xx:c66x:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
    # Archiving tda3xx:c66x:release:stw_devices into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/devices/lib/tda3xx/c66/release/stw_devices.ae66 ...
    # Compiling tda3xx:c66x:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda3xx:c66x:release:stw_examples_utility into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/examples/utility/lib/tda3xx/c66/release/stw_examples_utility.ae66 ...
    Nothing to be done for tda3xx c66x vps_osal_baremetal
    Nothing to be done for tda3xx c66x vps_common
    Nothing to be done for tda3xx c66x vpslib
    Nothing to be done for tda3xx c66x vpsdrv_baremetal
    Nothing to be done for tda3xx c66x fvid2
    # Compiling tda3xx:c66x:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda3xx:c66x:release:vps_osal_tirtos into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/c66/release/vps_osal_tirtos.ae66 ...
    Nothing to be done for tda3xx c66x vps_platforms
    Nothing to be done for tda3xx c66x vps_devices
    Nothing to be done for tda3xx c66x vps_boards
    Nothing to be done for tda3xx c66x vps_examples_utility
    Nothing to be done for tda3xx c66x bsp_i2c
    Nothing to be done for tda3xx c66x bsp_uart
    Nothing to be done for tda3xx c66x bsp_mcspi
    Nothing to be done for tda3xx c66xdsp_1 csl
    Nothing to be done for tda3xx c66xdsp_1 csl_utils_common
    Nothing to be done for tda3xx c66xdsp_1 csl_uart_console
    Nothing to be done for tda3xx c66xdsp_1 csl_utils_i2c
    Nothing to be done for tda3xx c66xdsp_1 pm_hal
    Nothing to be done for tda3xx c66xdsp_1 pm_hal_optimized
    Nothing to be done for tda3xx c66xdsp_1 pm_lib
    Nothing to be done for tda3xx c66xdsp_1 pm_lib_optimized
    Nothing to be done for tda3xx c66xdsp_1 sbl_lib
    Nothing to be done for tda3xx c66xdsp_1 sbl_utils
    Nothing to be done for tda3xx c66xdsp_1 diag
    Nothing to be done for tda3xx c66xdsp_1 firewall_l3l4
    # Compiling tda3xx:c66xdsp_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xx.c
    # Compiling tda3xx:c66xdsp_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxMailboxCfg.c
    # Compiling tda3xx:c66xdsp_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxProcCfg.c
    # Compiling tda3xx:c66xdsp_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxXbarCfg.c
    # Compiling tda3xx:c66xdsp_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda3xx:c66xdsp_1:release:ipc_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/ipc_lite/lib/tda3xx/c66xdsp_1/release/ipc_lib.ae66 ...
    Nothing to be done for tda3xx c66xdsp_1 norflash_lib
    Nothing to be done for tda3xx c66xdsp_1 qspiflash_lib
    Nothing to be done for tda3xx c66xdsp_1 i2c_lld
    Nothing to be done for tda3xx c66xdsp_1 stw_platform
    Nothing to be done for tda3xx c66xdsp_1 stw_uartconsole
    Nothing to be done for tda3xx c66xdsp_1 stw_fatlib
    Nothing to be done for tda3xx c66xdsp_1 stw_fatlib_edma
    Nothing to be done for tda3xx c66xdsp_1 stw_boards
    Nothing to be done for tda3xx c66xdsp_1 stw_devices
    Nothing to be done for tda3xx c66xdsp_1 stw_examples_utility
    # Compiling tda3xx:c66xdsp_1:release:vps_osal_baremetal: osal.c
    # Compiling tda3xx:c66xdsp_1:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda3xx:c66xdsp_1:release:vps_osal_baremetal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/c66xdsp_1/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda3xx c66xdsp_1 vps_common
    Nothing to be done for tda3xx c66xdsp_1 vpslib
    Nothing to be done for tda3xx c66xdsp_1 vpsdrv_baremetal
    Nothing to be done for tda3xx c66xdsp_1 fvid2
    Nothing to be done for tda3xx c66xdsp_1 vps_osal_tirtos
    Nothing to be done for tda3xx c66xdsp_1 vps_platforms
    Nothing to be done for tda3xx c66xdsp_1 vps_devices
    Nothing to be done for tda3xx c66xdsp_1 vps_boards
    Nothing to be done for tda3xx c66xdsp_1 vps_examples_utility
    Nothing to be done for tda3xx c66xdsp_1 bsp_i2c
    Nothing to be done for tda3xx c66xdsp_1 bsp_uart
    Nothing to be done for tda3xx c66xdsp_1 bsp_mcspi
    Nothing to be done for tda3xx c66xdsp_2 csl
    Nothing to be done for tda3xx c66xdsp_2 csl_utils_common
    Nothing to be done for tda3xx c66xdsp_2 csl_uart_console
    Nothing to be done for tda3xx c66xdsp_2 csl_utils_i2c
    Nothing to be done for tda3xx c66xdsp_2 pm_hal
    Nothing to be done for tda3xx c66xdsp_2 pm_hal_optimized
    Nothing to be done for tda3xx c66xdsp_2 pm_lib
    Nothing to be done for tda3xx c66xdsp_2 pm_lib_optimized
    Nothing to be done for tda3xx c66xdsp_2 sbl_lib
    Nothing to be done for tda3xx c66xdsp_2 sbl_utils
    Nothing to be done for tda3xx c66xdsp_2 diag
    Nothing to be done for tda3xx c66xdsp_2 firewall_l3l4
    # Compiling tda3xx:c66xdsp_2:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xx.c
    # Compiling tda3xx:c66xdsp_2:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxMailboxCfg.c
    # Compiling tda3xx:c66xdsp_2:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxProcCfg.c
    # Compiling tda3xx:c66xdsp_2:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxXbarCfg.c
    # Compiling tda3xx:c66xdsp_2:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda3xx:c66xdsp_2:release:ipc_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/ipc_lite/lib/tda3xx/c66xdsp_2/release/ipc_lib.ae66 ...
    Nothing to be done for tda3xx c66xdsp_2 norflash_lib
    Nothing to be done for tda3xx c66xdsp_2 qspiflash_lib
    Nothing to be done for tda3xx c66xdsp_2 i2c_lld
    Nothing to be done for tda3xx c66xdsp_2 stw_platform
    Nothing to be done for tda3xx c66xdsp_2 stw_uartconsole
    Nothing to be done for tda3xx c66xdsp_2 stw_fatlib
    Nothing to be done for tda3xx c66xdsp_2 stw_fatlib_edma
    Nothing to be done for tda3xx c66xdsp_2 stw_boards
    Nothing to be done for tda3xx c66xdsp_2 stw_devices
    Nothing to be done for tda3xx c66xdsp_2 stw_examples_utility
    # Compiling tda3xx:c66xdsp_2:release:vps_osal_baremetal: osal.c
    # Compiling tda3xx:c66xdsp_2:release:vps_osal_baremetal: osal_cache.c
    # Archiving tda3xx:c66xdsp_2:release:vps_osal_baremetal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/c66xdsp_2/release/vps_osal_baremetal.ae66 ...
    Nothing to be done for tda3xx c66xdsp_2 vps_common
    Nothing to be done for tda3xx c66xdsp_2 vpslib
    Nothing to be done for tda3xx c66xdsp_2 vpsdrv_baremetal
    Nothing to be done for tda3xx c66xdsp_2 fvid2
    Nothing to be done for tda3xx c66xdsp_2 vps_osal_tirtos
    Nothing to be done for tda3xx c66xdsp_2 vps_platforms
    Nothing to be done for tda3xx c66xdsp_2 vps_devices
    Nothing to be done for tda3xx c66xdsp_2 vps_boards
    Nothing to be done for tda3xx c66xdsp_2 vps_examples_utility
    Nothing to be done for tda3xx c66xdsp_2 bsp_i2c
    Nothing to be done for tda3xx c66xdsp_2 bsp_uart
    Nothing to be done for tda3xx c66xdsp_2 bsp_mcspi
    # Compiling tda3xx:arp32_1:release:csl: ./arch/arp32/src/boot_arp32.asm
    # Compiling tda3xx:arp32_1:release:csl: ./soc/common/csl_device_xbar.c
    # Compiling tda3xx:arp32_1:release:csl: ./soc/common/csl_device_common.c
    # Compiling tda3xx:arp32_1:release:csl: ./arch/arp32/src/arp32_wugen.c
    # Compiling tda3xx:arp32_1:release:csl: ./arch/arp32/src/intctl.c
    # Compiling tda3xx:arp32_1:release:csl: ./arch/arp32/src/interrupt.c
    # Compiling tda3xx:arp32_1:release:csl: ./arch/arp32/src/inth.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/adc/V0/priv/adc.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/crc/V0/priv/crc.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/dcan/V0/priv/dcan.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/dcc/V0/priv/dcc.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/edma/V1/priv/edma.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/elm/V0/priv/elm.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/emif/V0/priv/emif.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/esm/V0/priv/esm.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/gpmc/V1/priv/gpmc.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/i2c/V2/priv/i2c.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/l3fw/V0/priv/l3fw.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/l4fw/V0/priv/l4fw.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mailbox/V0/priv/mailbox.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mcan/V0/priv/mcan.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mcasp/V0/priv/mcasp.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mcspi/V0/priv/mcspi.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mmc/V0/priv/mmcsd.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/qspi/V1/priv/qspi.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/rti/V0/priv/rti.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/spinlock/V0/priv/spinlock.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/tesoc/V0/priv/tesoc.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/timer/V1/priv/timer.c
    # Compiling tda3xx:arp32_1:release:csl: src/ip/uart/V1/priv/uart.c
    # Archiving tda3xx:arp32_1:release:csl into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/lib/tda3xx/arp32/release/ti.csl.aearp32F ...
    # Compiling tda3xx:arp32_1:release:csl_utils_common: ./src/app_utils.c
    # Archiving tda3xx:arp32_1:release:csl_utils_common into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/common/lib/tda3xx/arp32/release/csl_utils_common.aearp32F ...
    # Compiling tda3xx:arp32_1:release:csl_uart_console: ./src/uartConfig.c
    # Archiving tda3xx:arp32_1:release:csl_uart_console into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/uart_console/lib/tda3xx/arp32/release/csl_uart_console.aearp32F ...
    # Compiling tda3xx:arp32_1:release:csl_utils_i2c: ./src/i2c.c
    # Archiving tda3xx:arp32_1:release:csl_utils_i2c into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/example/utils/i2c/lib/tda3xx/arp32/release/csl_utils_i2c.aearp32F ...
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_vm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_pmic.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_mm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_prm_int.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_bgap.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_pdm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_rm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_sd.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_cm.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pm_utils.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_prcm_stats.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_clocktree.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_tps65917.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_lp8731.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_lp8733.c
    # Compiling tda3xx:arp32_1:release:pm_hal: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:arp32_1:release:pm_hal into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/arp32/release/pm_hal.aearp32F ...
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_vm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_vmdata.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_data_names.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmic.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_mm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prm_int.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_bgap.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_bgap_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_pdm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_rm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_sd.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_cm.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_prmdata.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pm_utils.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/V2/hw_pmhal_clocktree_data.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_clocktree.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps65917.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_lp8731.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_lp8733.c
    # Compiling tda3xx:arp32_1:release:pm_hal_optimized: prcm/pmhal_lp8731_lp3907.c
    # Archiving tda3xx:arp32_1:release:pm_hal_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/arp32/release/pm_hal_optimized.aearp32F ...
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/pmlib_clkrate.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/pmlib_videopll.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:arp32_1:release:pm_lib: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda3xx:arp32_1:release:pm_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/arp32/release/pm_lib.aearp32F ...
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_clkrate.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/V2/pmlib_boardconfig.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/V2/pmlib_videopll_data.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_videopll.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/V2/pmlib_clk_rate_data_tda3xx.c
    # Compiling tda3xx:arp32_1:release:pm_lib_optimized: prcm/pmlib_cpuidle_arp32.c
    # Archiving tda3xx:arp32_1:release:pm_lib_optimized into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/pm/lib/tda3xx/arp32/release/pm_lib_optimized.aearp32F ...
    Nothing to be done for tda3xx arp32_1 sbl_lib
    Nothing to be done for tda3xx arp32_1 sbl_utils
    Nothing to be done for tda3xx arp32_1 diag
    # Compiling tda3xx:arp32_1:release:firewall_l3l4: src/fwlibl3.c
    # Compiling tda3xx:arp32_1:release:firewall_l3l4: src/fwlibl4.c
    # Archiving tda3xx:arp32_1:release:firewall_l3l4 into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/fw_l3l4/lib/tda3xx/arp32/release/firewall_l3l4.aearp32F ...
    # Compiling tda3xx:arp32_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xx.c
    # Compiling tda3xx:arp32_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxMailboxCfg.c
    # Compiling tda3xx:arp32_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxProcCfg.c
    # Compiling tda3xx:arp32_1:release:ipc_lib: src/tda3xx/ipclib_interruptTda3xxXbarCfg.c
    # Compiling tda3xx:arp32_1:release:ipc_lib: src/ipclib_interrupt.c
    # Archiving tda3xx:arp32_1:release:ipc_lib into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/ipc_lite/lib/tda3xx/arp32_1/release/ipc_lib.aearp32F ...
    Nothing to be done for tda3xx arp32_1 norflash_lib
    Nothing to be done for tda3xx arp32_1 qspiflash_lib
    Nothing to be done for tda3xx arp32_1 i2c_lld
    # Compiling tda3xx:arp32_1:release:stw_platform: src/platform.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/stw_platform.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/irq_xbar.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/dma_xbar.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/chip_config.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/platform_tda3xx.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/platform_tda3xx_pad_config.c
    # Compiling tda3xx:arp32_1:release:stw_platform: src/tda3xx/stw_platformTda3xx.c
    # Archiving tda3xx:arp32_1:release:stw_platform into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/platform/lib/tda3xx/arp32/release/stw_platform.aearp32F ...
    # Compiling tda3xx:arp32_1:release:stw_uartconsole: src/uartConsole.c
    # Compiling tda3xx:arp32_1:release:stw_uartconsole: src/uartStdio.c
    # Archiving tda3xx:arp32_1:release:stw_uartconsole into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/uartconsole/lib/tda3xx/arp32/release/stw_uartconsole.aearp32F ...
    Nothing to be done for tda3xx arp32_1 stw_fatlib
    Nothing to be done for tda3xx arp32_1 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_1 stw_boards
    Nothing to be done for tda3xx arp32_1 stw_devices
    # Compiling tda3xx:arp32_1:release:stw_examples_utility: src/stwutils_app.c
    # Archiving tda3xx:arp32_1:release:stw_examples_utility into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/stw_lld/examples/utility/lib/tda3xx/arp32/release/stw_examples_utility.aearp32F ...
    Nothing to be done for tda3xx arp32_1 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_1 vps_common
    Nothing to be done for tda3xx arp32_1 vpslib
    Nothing to be done for tda3xx arp32_1 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_1 fvid2
    # Compiling tda3xx:arp32_1:release:vps_osal_tirtos: bsp_osal.c
    # Archiving tda3xx:arp32_1:release:vps_osal_tirtos into /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/drivers/pdk_01_09_00_17/packages/ti/drv/vps/lib/tda3xx/arp32/release/vps_osal_tirtos.aearp32F ...
    Nothing to be done for tda3xx arp32_1 vps_platforms
    Nothing to be done for tda3xx arp32_1 vps_devices
    Nothing to be done for tda3xx arp32_1 vps_boards
    Nothing to be done for tda3xx arp32_1 vps_examples_utility
    Nothing to be done for tda3xx arp32_1 bsp_i2c
    Nothing to be done for tda3xx arp32_1 bsp_uart
    Nothing to be done for tda3xx arp32_1 bsp_mcspi
    Nothing to be done for tda3xx csl_init
    Nothing to be done for tda3xx csl_intc
    Nothing to be done for tda3xx arp32_2 csl
    Nothing to be done for tda3xx arp32_2 csl_utils_common
    Nothing to be done for tda3xx arp32_2 csl_uart_console
    Nothing to be done for tda3xx arp32_2 csl_utils_i2c
    Nothing to be done for tda3xx arp32_2 pm_hal
    Nothing to be done for tda3xx arp32_2 pm_hal_optimized
    Nothing to be done for tda3xx arp32_2 pm_lib
    Nothing to be done for tda3xx arp32_2 pm_lib_optimized
    Nothing to be done for tda3xx pm_rtos
    Nothing to be done for tda3xx arp32_2 sbl_lib
    Nothing to be done for tda3xx arp32_2 sbl_utils
    Nothing to be done for tda3xx arp32_2 diag
    Nothing to be done for tda3xx arp32_2 firewall_l3l4
    Nothing to be done for tda3xx arp32_2 ipc_lib
    Nothing to be done for tda3xx arp32_2 norflash_lib
    Nothing to be done for tda3xx arp32_2 qspiflash_lib
    Nothing to be done for tda3xx arp32_2 i2c_lld
    Nothing to be done for tda3xx arp32_2 stw_platform
    Nothing to be done for tda3xx arp32_2 stw_uartconsole
    Nothing to be done for tda3xx arp32_2 stw_fatlib
    Nothing to be done for tda3xx arp32_2 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_2 stw_boards
    Nothing to be done for tda3xx arp32_2 stw_devices
    Nothing to be done for tda3xx arp32_2 stw_examples_utility
    Nothing to be done for tda3xx arp32_2 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_2 vps_common
    Nothing to be done for tda3xx arp32_2 vpslib
    Nothing to be done for tda3xx arp32_2 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_2 fvid2
    Nothing to be done for tda3xx arp32_2 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_2 vps_platforms
    Nothing to be done for tda3xx arp32_2 vps_devices
    Nothing to be done for tda3xx arp32_2 vps_boards
    Nothing to be done for tda3xx arp32_2 vps_examples_utility
    Nothing to be done for tda3xx arp32_2 bsp_i2c
    Nothing to be done for tda3xx arp32_2 bsp_uart
    Nothing to be done for tda3xx arp32_2 bsp_mcspi
    Nothing to be done for tda3xx arp32_3 csl
    Nothing to be done for tda3xx arp32_3 csl_utils_common
    Nothing to be done for tda3xx arp32_3 csl_uart_console
    Nothing to be done for tda3xx arp32_3 csl_utils_i2c
    Nothing to be done for tda3xx arp32_3 pm_hal
    Nothing to be done for tda3xx arp32_3 pm_hal_optimized
    Nothing to be done for tda3xx arp32_3 pm_lib
    Nothing to be done for tda3xx arp32_3 pm_lib_optimized
    Nothing to be done for tda3xx arp32_3 sbl_lib
    Nothing to be done for tda3xx arp32_3 sbl_utils
    Nothing to be done for tda3xx arp32_3 diag
    Nothing to be done for tda3xx arp32_3 firewall_l3l4
    Nothing to be done for tda3xx arp32_3 ipc_lib
    Nothing to be done for tda3xx arp32_3 norflash_lib
    Nothing to be done for tda3xx arp32_3 qspiflash_lib
    Nothing to be done for tda3xx arp32_3 i2c_lld
    Nothing to be done for tda3xx arp32_3 stw_platform
    Nothing to be done for tda3xx arp32_3 stw_uartconsole
    Nothing to be done for tda3xx arp32_3 stw_fatlib
    Nothing to be done for tda3xx arp32_3 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_3 stw_boards
    Nothing to be done for tda3xx arp32_3 stw_devices
    Nothing to be done for tda3xx arp32_3 stw_examples_utility
    Nothing to be done for tda3xx arp32_3 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_3 vps_common
    Nothing to be done for tda3xx arp32_3 vpslib
    Nothing to be done for tda3xx arp32_3 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_3 fvid2
    Nothing to be done for tda3xx arp32_3 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_3 vps_platforms
    Nothing to be done for tda3xx arp32_3 vps_devices
    Nothing to be done for tda3xx arp32_3 vps_boards
    Nothing to be done for tda3xx arp32_3 vps_examples_utility
    Nothing to be done for tda3xx arp32_3 bsp_i2c
    Nothing to be done for tda3xx arp32_3 bsp_uart
    Nothing to be done for tda3xx arp32_3 bsp_mcspi
    Nothing to be done for tda3xx arp32_4 csl
    Nothing to be done for tda3xx arp32_4 csl_utils_common
    Nothing to be done for tda3xx arp32_4 csl_uart_console
    Nothing to be done for tda3xx arp32_4 csl_utils_i2c
    Nothing to be done for tda3xx arp32_4 pm_hal
    Nothing to be done for tda3xx arp32_4 pm_hal_optimized
    Nothing to be done for tda3xx arp32_4 pm_lib
    Nothing to be done for tda3xx arp32_4 pm_lib_optimized
    Nothing to be done for tda3xx arp32_4 sbl_lib
    Nothing to be done for tda3xx arp32_4 sbl_utils
    Nothing to be done for tda3xx arp32_4 diag
    Nothing to be done for tda3xx arp32_4 firewall_l3l4
    Nothing to be done for tda3xx arp32_4 ipc_lib
    Nothing to be done for tda3xx arp32_4 norflash_lib
    Nothing to be done for tda3xx arp32_4 qspiflash_lib
    Nothing to be done for tda3xx arp32_4 i2c_lld
    Nothing to be done for tda3xx arp32_4 stw_platform
    Nothing to be done for tda3xx arp32_4 stw_uartconsole
    Nothing to be done for tda3xx arp32_4 stw_fatlib
    Nothing to be done for tda3xx arp32_4 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_4 stw_boards
    Nothing to be done for tda3xx arp32_4 stw_devices
    Nothing to be done for tda3xx arp32_4 stw_examples_utility
    Nothing to be done for tda3xx arp32_4 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_4 vps_common
    Nothing to be done for tda3xx arp32_4 vpslib
    Nothing to be done for tda3xx arp32_4 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_4 fvid2
    Nothing to be done for tda3xx arp32_4 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_4 vps_platforms
    Nothing to be done for tda3xx arp32_4 vps_devices
    Nothing to be done for tda3xx arp32_4 vps_boards
    Nothing to be done for tda3xx arp32_4 vps_examples_utility
    Nothing to be done for tda3xx arp32_4 bsp_i2c
    Nothing to be done for tda3xx arp32_4 bsp_uart
    Nothing to be done for tda3xx arp32_4 bsp_mcspi
    # Depend tda3xx-evm:ipu1_0:release:links_common_algorithm
    # Depend tda3xx-evm:ipu1_1:release:links_common_algorithm
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_algorithm
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_algorithm
    # Depend tda3xx-evm:arp32_1:release:links_common_algorithm
    # Depend tda3xx-evm:ipu1_0:release:links_common_dup
    # Depend tda3xx-evm:ipu1_1:release:links_common_dup
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_dup
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_dup
    # Depend tda3xx-evm:arp32_1:release:links_common_dup
    # Depend tda3xx-evm:ipu1_0:release:links_common_gate
    # Depend tda3xx-evm:ipu1_1:release:links_common_gate
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_gate
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_gate
    # Depend tda3xx-evm:arp32_1:release:links_common_gate
    # Depend tda3xx-evm:ipu1_0:release:links_common_ipcIn
    # Depend tda3xx-evm:ipu1_1:release:links_common_ipcIn
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Depend tda3xx-evm:arp32_1:release:links_common_ipcIn
    # Depend tda3xx-evm:ipu1_0:release:links_common_ipcOut
    # Depend tda3xx-evm:ipu1_1:release:links_common_ipcOut
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Depend tda3xx-evm:arp32_1:release:links_common_ipcOut
    # Depend tda3xx-evm:ipu1_0:release:links_common_merge
    # Depend tda3xx-evm:ipu1_1:release:links_common_merge
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_merge
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_merge
    # Depend tda3xx-evm:arp32_1:release:links_common_merge
    # Depend tda3xx-evm:ipu1_0:release:links_common_null
    # Depend tda3xx-evm:ipu1_1:release:links_common_null
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_null
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_null
    # Depend tda3xx-evm:arp32_1:release:links_common_null
    # Depend tda3xx-evm:ipu1_0:release:links_common_network_tx
    # Depend tda3xx-evm:ipu1_1:release:links_common_network_tx
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_network_tx
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_network_tx
    # Depend tda3xx-evm:arp32_1:release:links_common_network_tx
    # Depend tda3xx-evm:ipu1_0:release:links_common_network_rx
    # Depend tda3xx-evm:ipu1_1:release:links_common_network_rx
    # Depend tda3xx-evm:ipu1_0:release:links_common_nullSrc
    # Depend tda3xx-evm:ipu1_1:release:links_common_nullSrc
    # Depend tda3xx-evm:ipu1_0:release:links_common_select
    # Depend tda3xx-evm:ipu1_1:release:links_common_select
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_select
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_select
    # Depend tda3xx-evm:arp32_1:release:links_common_select
    # Depend tda3xx-evm:ipu1_0:release:links_common_sync
    # Depend tda3xx-evm:ipu1_1:release:links_common_sync
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_sync
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_sync
    # Depend tda3xx-evm:arp32_1:release:links_common_sync
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_display
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
    # Depend tda3xx-evm:ipu1_0:release:utils_common
    # Depend tda3xx-evm:ipu1_1:release:utils_common
    # Depend tda3xx-evm:c66xdsp_1:release:utils_common
    # Depend tda3xx-evm:c66xdsp_2:release:utils_common
    # Depend tda3xx-evm:arp32_1:release:utils_common
    # Depend tda3xx-evm:ipu1_0:release:links_common_system
    # Depend tda3xx-evm:ipu1_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_system
    # Depend tda3xx-evm:arp32_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_1:release:links_dsp_system
    # Depend tda3xx-evm:c66xdsp_2:release:links_dsp_system
    # Depend tda3xx-evm:arp32_1:release:links_eve_system
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_system
    # Depend tda3xx-evm:ipu1_1:release:links_ipu_system
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build$ make -s
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_algorithm
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_dup
    # Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_dup: dupLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_dup
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_dup
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_dup
    # Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_dup
    # Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_gate
    # Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_gate: gateLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_gate
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_gate
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_gate
    # Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_gate
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_ipcIn
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_ipcIn
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_ipcOut
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_ipcOut
    # Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_merge
    # Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_merge
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_merge
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_merge
    # Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_merge
    # Compiling tda3xx-evm:ipu1_0:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_null
    # Compiling tda3xx-evm:ipu1_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_null
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_null
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_null
    # Compiling tda3xx-evm:arp32_1:release:links_common_null: nullLink_tsk.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_null
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_network_tx
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_network_tx
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_network_tx
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_network_tx
    # Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_network_tx: networkTxLink_drv.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_network_tx
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_network_rx
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_network_rx: networkRxLink_drv.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_network_rx
    # Compiling tda3xx-evm:ipu1_0:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_nullSrc
    # Compiling tda3xx-evm:ipu1_1:release:links_common_nullSrc: nullSrcLink_tsk.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_nullSrc
    # Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_select
    # Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_select: selectLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_select
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_select
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_select
    # Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_select
    # Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_sync
    # Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_sync: syncLink_tsk_create_single_mbx.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_sync
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_sync
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_sync
    # Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_sync
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display: displayLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_display
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_apply_config.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_create_delete.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_process_frame.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_subframe_drv.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_l3_emif_bw.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_boot_slaves.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_esm.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_ipu_ecc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: tda3xx/utils_dcc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_execp_trace_local_m4.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_uart.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_cbuf_ocmc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_qspi.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_idle_m4.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_temperature.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_stat_collector.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_prcm_stats.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_emif_ecc.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mcspi.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_mem_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_taskTimer.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: stat_collector_utils/sci_config_tda3x.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: utils_iss.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: network_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api.c
    # Compiling tda3xx-evm:ipu1_0:release:utils_common: file_api_dma.c
    # Archiving tda3xx-evm:ipu1_0:release:utils_common
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_iss.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_execp_trace_remote_m4.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_1.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_idle_m4.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_stat_collector.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/sci.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: stat_collector_utils/cToolsHelper.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: utils_qspi.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: ndk/ndk_nsp_hooks.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api.c
    # Compiling tda3xx-evm:ipu1_1:release:utils_common: file_api_dma.c
    # Archiving tda3xx-evm:ipu1_1:release:utils_common
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
    # Compiling tda3xx-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
    # Archiving tda3xx-evm:c66xdsp_1:release:utils_common
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_api.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
    # Compiling tda3xx-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
    # Archiving tda3xx-evm:c66xdsp_2:release:utils_common
    # Compiling tda3xx-evm:arp32_1:release:utils_common: tda3xx/utils_clk.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_server.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_mem.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_prf.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_que.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_ipc_que.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_remote_log_client.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_global_time.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_buf_ext.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_pm.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_spinlock.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: safety_osal.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_cio.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_dma.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: network_api.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: network_tfdtp_api.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_idle_arp32.c
    # Compiling tda3xx-evm:arp32_1:release:utils_common: utils_l3fw.c
    # Archiving tda3xx-evm:arp32_1:release:utils_common
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:ipu1_0:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_system
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:ipu1_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_system
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_linkApi_local.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_common.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_openvxipc.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_if.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
    # Compiling tda3xx-evm:arp32_1:release:links_common_system: system_ipc_bios_ipc.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_system
    # Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_dsp_system
    # Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
    # Compiling tda3xx-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_dsp_system
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: system_eve.c
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
    # Compiling tda3xx-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
    # Archiving tda3xx-evm:arp32_1:release:links_eve_system
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_bsp_init.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: system_ipu1_0.c
    # Compiling tda3xx-evm:ipu1_0:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda3xx-evm:ipu1_0:release:links_ipu_system
    # Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: system_ipu1_1.c
    # Compiling tda3xx-evm:ipu1_1:release:links_ipu_system: systemLink_tsk_ipu1.c
    # Archiving tda3xx-evm:ipu1_1:release:links_ipu_system
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Archiving tda3xx-evm:ipu1_0:release:app_alg_plugins
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignLUT_tda3xx.oe66' given more than once in the same rule.
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignExt_tda3xx.oe66' given more than once in the same rule.
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Archiving tda3xx-evm:c66xdsp_1:release:app_alg_plugins
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Archiving tda3xx-evm:arp32_1:release:app_alg_plugins
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_settings_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_stereo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_avb.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_multi_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_single_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_iss.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_opencl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_misc.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_rsvp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_tidl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/common/chains_main_bios_openvx.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_srv_calib_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sved_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sv_sof_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_OF_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_multiFCalg_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_stereo_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout2.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_fcAnalytics2_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sfm.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x3DSv_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x2D3DSv_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3xRearView3DSv_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_metadata_draw.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_rvp_layout.c
    INTERNAL ERROR: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armacpia experienced a segmentation fault
    while processing function (unknown or file scope) file (unknown) line 0
    This is caused by a defect in the compiler itself. TI Customer
    Support may be able to suggest a workaround to avoid this.
    Upgrading to the newest version of the compiler may fix this problem.
    Contact TI in the E2E support forums at http://e2e.ti.com under
    "Development Tools", "TI C/C++ Compiler". See the link titled
    "Submitting an issue". Include this ENTIRE error message and a
    copy of the .pp file created when option --preproc_with_comment
    (-ppc) is used.
    >> Compilation failure
    make[5]: *** [/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_VISION_03_03_00_00_setuplinux/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_libs/tda3xx-evm/ipu1_0/release/grpxSrcLink_rvp_layout.oem4] Error 1
    make[4]: *** [ipu1_0] Error 2
    make[3]: *** [app_libs] Error 2
    make[2]: *** [apps_libs] Error 2
    make[1]: *** [apps] Error 2
    make: *** [vision_sdk] Error 2
  • Hi Balaji,
    It seems strange that build works for you sometimes and sometimes it doesn't.
    Can you double check that you are not making any changes in case the build doesn't work.
    We will try this at our end and get back to you.
    Rishabh
  • Hi Balaji,
    We are not facing any issues while building.
    Can you please share a screenshot of the “ti_components\cg_tools\linux” folder in your installation.
    Thanks.
    Rishabh
  • Hi Rishabh,
    I just deleted the previously installed VSDK and reinstalled again, with reference to instructions provided in "VisionSDK_UserGuide_TDA3xx.pdf", i compiled it again but getting the same error. I request you to fix this error soon.
    INTERNAL ERROR: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armacpia experienced a segmentation fault
    (-ppc) is used.
    sir, in the above error it is mentioned to create .pp file, pls help me to create that .pp file so that you can also try to produce the same error.
    i am currently using ubuntu-14.04(64-bit).
    regards
    Balaji
    Can you please share a screenshot of the “ti_components\cg_tools\linux” folder in your installation as mentioned above.
    Rishabh
  • Hi Rishabh,
    Here is the screenshot of "ti_components\cg_tools\linux" in my installation.
    NOTE : I just installed  GCC ARM tools from the below mentioned site.
    regards
    Balaji
  • Hi Balaji,
    Can you run PROCESSOR_SDK_VISION_03_03_00_00\vision_sdk\build\hlos\scripts\linux\setup-linux-build-env.sh and then try the build.
    Also share the log when you run this script.
    Rishabh
  • Hi Rishabh,
    I am very sorry for the late reply, below you can find the log for both script and build.,
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/hlos/scripts/linux$ sh setup-linux-build-env.sh
    This step will make sure you have the proper host support packages installed
    using the following command: sudo apt-get install ssh corkscrew gawk lib32z1 lib32ncurses5 lib32bz2-1.0 libc6:i386 libc6-i386 libstdc++6:i386 libncurses5:i386 libz1:i386 libc6-dev-i386 device-tree-compiler mono-complete
    Note! This command requires you to have administrator priviliges (sudo access)
    on your host.
    Press Enter to continue
    [sudo] password for balaji:
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Note, selecting 'zlib1g:i386' instead of 'libz1:i386'
    device-tree-compiler is already the newest version.
    gawk is already the newest version.
    lib32bz2-1.0 is already the newest version.
    lib32ncurses5 is already the newest version.
    lib32z1 is already the newest version.
    corkscrew is already the newest version.
    libncurses5:i386 is already the newest version.
    zlib1g:i386 is already the newest version.
    libc6-dev-i386 is already the newest version.
    libc6-i386 is already the newest version.
    ssh is already the newest version.
    mono-complete is already the newest version.
    libc6:i386 is already the newest version.
    libstdc++6:i386 is already the newest version.
    The following packages were automatically installed and are no longer required:
    libntdb1 libtar0 linux-headers-4.2.0-27 linux-headers-4.2.0-27-generic
    linux-image-4.2.0-27-generic linux-image-extra-4.2.0-27-generic python-ntdb
    vlc-plugin-pulse
    Use 'apt-get autoremove' to remove them.
    0 upgraded, 0 newly installed, 0 to remove and 183 not upgraded.
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/hlos/scripts/linux$ make -s depend
    make: *** No rule to make target `depend'. Stop.
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/hlos/scripts/linux$ cd ../..
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/hlos$ cd ..
    balaji@FSETBLR1D036:~/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build$ make -s depend
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/links_fw/include/config’: File exists
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/links_fw/include/config/apps’: File exists
    mkdir: cannot create directory ‘/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_all’: File exists
    # makeconfig: Config is [ tda3xx_evm_bios_all ]
    # makeconfig: Output file is @ /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/links_fw/include/config/apps/tda3xx_evm_bios_all/system_cfg.h
    # makeconfig: Input file is @ /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/configs/tda3xx_evm_bios_all/cfg.mk
    # makeconfig: Generating header ...
    # makeconfig: Generating alg plugin config ...
    # makeconfig: Generating usecase config ...
    # makeconfig: Generating footer ...
    # makeconfig: Done !!!
    # CPUs that are NOT required but included in config [ tda3xx_evm_bios_all ],
    # WARNING: IPU1_1 can be excluded from application
    # CPUs that are required but not included in config [ tda3xx_evm_bios_all ],
    # Edit /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/configs/tda3xx_evm_bios_all/cfg.mk to include or exclude CPUs in an application
    Nothing to be done for tda3xx csl_init
    Nothing to be done for tda3xx csl_intc
    Nothing to be done for tda3xx pm_rtos
    Nothing to be done for tda3xx vps_osal_tirtos_smp
    Nothing to be done for tda3xx ipu1_1 csl
    Nothing to be done for tda3xx ipu1_1 csl_utils_common
    Nothing to be done for tda3xx ipu1_1 csl_uart_console
    Nothing to be done for tda3xx ipu1_1 csl_utils_i2c
    Nothing to be done for tda3xx ipu1_1 pm_hal
    Nothing to be done for tda3xx ipu1_1 pm_hal_optimized
    Nothing to be done for tda3xx ipu1_1 pm_lib
    Nothing to be done for tda3xx ipu1_1 pm_lib_optimized
    Nothing to be done for tda3xx ipu1_1 sbl_lib
    Nothing to be done for tda3xx ipu1_1 sbl_utils
    Nothing to be done for tda3xx ipu1_1 diag
    Nothing to be done for tda3xx ipu1_1 firewall_l3l4
    Nothing to be done for tda3xx ipu1_1 norflash_lib
    Nothing to be done for tda3xx ipu1_1 qspiflash_lib
    Nothing to be done for tda3xx ipu1_1 i2c_lld
    Nothing to be done for tda3xx ipu1_1 stw_platform
    Nothing to be done for tda3xx ipu1_1 stw_uartconsole
    Nothing to be done for tda3xx ipu1_1 stw_fatlib
    Nothing to be done for tda3xx ipu1_1 stw_fatlib_edma
    Nothing to be done for tda3xx ipu1_1 stw_boards
    Nothing to be done for tda3xx ipu1_1 stw_devices
    Nothing to be done for tda3xx ipu1_1 stw_examples_utility
    Nothing to be done for tda3xx ipu1_1 vps_common
    Nothing to be done for tda3xx ipu1_1 vpslib
    Nothing to be done for tda3xx ipu1_1 vpsdrv_baremetal
    Nothing to be done for tda3xx ipu1_1 fvid2
    Nothing to be done for tda3xx ipu1_1 vps_osal_tirtos
    Nothing to be done for tda3xx ipu1_1 vps_platforms
    Nothing to be done for tda3xx ipu1_1 vps_devices
    Nothing to be done for tda3xx ipu1_1 vps_boards
    Nothing to be done for tda3xx ipu1_1 vps_examples_utility
    Nothing to be done for tda3xx ipu1_1 bsp_i2c
    Nothing to be done for tda3xx ipu1_1 bsp_uart
    Nothing to be done for tda3xx ipu1_1 bsp_mcspi
    Nothing to be done for tda3xx ipu2_0 csl
    Nothing to be done for tda3xx ipu2_0 csl_utils_common
    Nothing to be done for tda3xx ipu2_0 csl_uart_console
    Nothing to be done for tda3xx ipu2_0 csl_utils_i2c
    Nothing to be done for tda3xx ipu2_0 pm_hal
    Nothing to be done for tda3xx ipu2_0 pm_hal_optimized
    Nothing to be done for tda3xx ipu2_0 pm_lib
    Nothing to be done for tda3xx ipu2_0 pm_lib_optimized
    Nothing to be done for tda3xx ipu2_0 sbl_lib
    Nothing to be done for tda3xx ipu2_0 sbl_utils
    Nothing to be done for tda3xx ipu2_0 diag
    Nothing to be done for tda3xx ipu2_0 firewall_l3l4
    Nothing to be done for tda3xx ipu2_0 ipc_lib
    Nothing to be done for tda3xx ipu2_0 norflash_lib
    Nothing to be done for tda3xx ipu2_0 qspiflash_lib
    Nothing to be done for tda3xx ipu2_0 i2c_lld
    Nothing to be done for tda3xx ipu2_0 stw_platform
    Nothing to be done for tda3xx ipu2_0 stw_uartconsole
    Nothing to be done for tda3xx ipu2_0 stw_fatlib
    Nothing to be done for tda3xx ipu2_0 stw_fatlib_edma
    Nothing to be done for tda3xx ipu2_0 stw_boards
    Nothing to be done for tda3xx ipu2_0 stw_devices
    Nothing to be done for tda3xx ipu2_0 stw_examples_utility
    Nothing to be done for tda3xx ipu2_0 vps_osal_baremetal
    Nothing to be done for tda3xx ipu2_0 vps_common
    Nothing to be done for tda3xx ipu2_0 vpslib
    Nothing to be done for tda3xx ipu2_0 vpsdrv_baremetal
    Nothing to be done for tda3xx ipu2_0 fvid2
    Nothing to be done for tda3xx ipu2_0 vps_osal_tirtos
    Nothing to be done for tda3xx ipu2_0 vps_platforms
    Nothing to be done for tda3xx ipu2_0 vps_devices
    Nothing to be done for tda3xx ipu2_0 vps_boards
    Nothing to be done for tda3xx ipu2_0 vps_examples_utility
    Nothing to be done for tda3xx ipu2_0 bsp_i2c
    Nothing to be done for tda3xx ipu2_0 bsp_uart
    Nothing to be done for tda3xx ipu2_0 bsp_mcspi
    Nothing to be done for tda3xx c66x sbl_lib
    Nothing to be done for tda3xx c66x sbl_utils
    Nothing to be done for tda3xx c66x diag
    Nothing to be done for tda3xx c66x ipc_lib
    Nothing to be done for tda3xx c66x norflash_lib
    Nothing to be done for tda3xx c66x qspiflash_lib
    Nothing to be done for tda3xx c66x stw_fatlib
    Nothing to be done for tda3xx c66x stw_fatlib_edma
    Nothing to be done for tda3xx c66x vps_osal_baremetal
    Nothing to be done for tda3xx c66x vps_common
    Nothing to be done for tda3xx c66x vpslib
    Nothing to be done for tda3xx c66x vpsdrv_baremetal
    Nothing to be done for tda3xx c66x fvid2
    Nothing to be done for tda3xx c66x vps_platforms
    Nothing to be done for tda3xx c66x vps_devices
    Nothing to be done for tda3xx c66x vps_boards
    Nothing to be done for tda3xx c66x vps_examples_utility
    Nothing to be done for tda3xx c66x bsp_i2c
    Nothing to be done for tda3xx c66x bsp_uart
    Nothing to be done for tda3xx c66x bsp_mcspi
    Nothing to be done for tda3xx c66xdsp_1 csl
    Nothing to be done for tda3xx c66xdsp_1 csl_utils_common
    Nothing to be done for tda3xx c66xdsp_1 csl_uart_console
    Nothing to be done for tda3xx c66xdsp_1 csl_utils_i2c
    Nothing to be done for tda3xx c66xdsp_1 pm_hal
    Nothing to be done for tda3xx c66xdsp_1 pm_hal_optimized
    Nothing to be done for tda3xx c66xdsp_1 pm_lib
    Nothing to be done for tda3xx c66xdsp_1 pm_lib_optimized
    Nothing to be done for tda3xx c66xdsp_1 sbl_lib
    Nothing to be done for tda3xx c66xdsp_1 sbl_utils
    Nothing to be done for tda3xx c66xdsp_1 diag
    Nothing to be done for tda3xx c66xdsp_1 firewall_l3l4
    Nothing to be done for tda3xx c66xdsp_1 norflash_lib
    Nothing to be done for tda3xx c66xdsp_1 qspiflash_lib
    Nothing to be done for tda3xx c66xdsp_1 i2c_lld
    Nothing to be done for tda3xx c66xdsp_1 stw_platform
    Nothing to be done for tda3xx c66xdsp_1 stw_uartconsole
    Nothing to be done for tda3xx c66xdsp_1 stw_fatlib
    Nothing to be done for tda3xx c66xdsp_1 stw_fatlib_edma
    Nothing to be done for tda3xx c66xdsp_1 stw_boards
    Nothing to be done for tda3xx c66xdsp_1 stw_devices
    Nothing to be done for tda3xx c66xdsp_1 stw_examples_utility
    Nothing to be done for tda3xx c66xdsp_1 vps_common
    Nothing to be done for tda3xx c66xdsp_1 vpslib
    Nothing to be done for tda3xx c66xdsp_1 vpsdrv_baremetal
    Nothing to be done for tda3xx c66xdsp_1 fvid2
    Nothing to be done for tda3xx c66xdsp_1 vps_osal_tirtos
    Nothing to be done for tda3xx c66xdsp_1 vps_platforms
    Nothing to be done for tda3xx c66xdsp_1 vps_devices
    Nothing to be done for tda3xx c66xdsp_1 vps_boards
    Nothing to be done for tda3xx c66xdsp_1 vps_examples_utility
    Nothing to be done for tda3xx c66xdsp_1 bsp_i2c
    Nothing to be done for tda3xx c66xdsp_1 bsp_uart
    Nothing to be done for tda3xx c66xdsp_1 bsp_mcspi
    Nothing to be done for tda3xx c66xdsp_2 csl
    Nothing to be done for tda3xx c66xdsp_2 csl_utils_common
    Nothing to be done for tda3xx c66xdsp_2 csl_uart_console
    Nothing to be done for tda3xx c66xdsp_2 csl_utils_i2c
    Nothing to be done for tda3xx c66xdsp_2 pm_hal
    Nothing to be done for tda3xx c66xdsp_2 pm_hal_optimized
    Nothing to be done for tda3xx c66xdsp_2 pm_lib
    Nothing to be done for tda3xx c66xdsp_2 pm_lib_optimized
    Nothing to be done for tda3xx c66xdsp_2 sbl_lib
    Nothing to be done for tda3xx c66xdsp_2 sbl_utils
    Nothing to be done for tda3xx c66xdsp_2 diag
    Nothing to be done for tda3xx c66xdsp_2 firewall_l3l4
    Nothing to be done for tda3xx c66xdsp_2 norflash_lib
    Nothing to be done for tda3xx c66xdsp_2 qspiflash_lib
    Nothing to be done for tda3xx c66xdsp_2 i2c_lld
    Nothing to be done for tda3xx c66xdsp_2 stw_platform
    Nothing to be done for tda3xx c66xdsp_2 stw_uartconsole
    Nothing to be done for tda3xx c66xdsp_2 stw_fatlib
    Nothing to be done for tda3xx c66xdsp_2 stw_fatlib_edma
    Nothing to be done for tda3xx c66xdsp_2 stw_boards
    Nothing to be done for tda3xx c66xdsp_2 stw_devices
    Nothing to be done for tda3xx c66xdsp_2 stw_examples_utility
    Nothing to be done for tda3xx c66xdsp_2 vps_common
    Nothing to be done for tda3xx c66xdsp_2 vpslib
    Nothing to be done for tda3xx c66xdsp_2 vpsdrv_baremetal
    Nothing to be done for tda3xx c66xdsp_2 fvid2
    Nothing to be done for tda3xx c66xdsp_2 vps_osal_tirtos
    Nothing to be done for tda3xx c66xdsp_2 vps_platforms
    Nothing to be done for tda3xx c66xdsp_2 vps_devices
    Nothing to be done for tda3xx c66xdsp_2 vps_boards
    Nothing to be done for tda3xx c66xdsp_2 vps_examples_utility
    Nothing to be done for tda3xx c66xdsp_2 bsp_i2c
    Nothing to be done for tda3xx c66xdsp_2 bsp_uart
    Nothing to be done for tda3xx c66xdsp_2 bsp_mcspi
    Nothing to be done for tda3xx arp32_1 sbl_lib
    Nothing to be done for tda3xx arp32_1 sbl_utils
    Nothing to be done for tda3xx arp32_1 diag
    Nothing to be done for tda3xx arp32_1 norflash_lib
    Nothing to be done for tda3xx arp32_1 qspiflash_lib
    Nothing to be done for tda3xx arp32_1 i2c_lld
    Nothing to be done for tda3xx arp32_1 stw_fatlib
    Nothing to be done for tda3xx arp32_1 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_1 stw_boards
    Nothing to be done for tda3xx arp32_1 stw_devices
    Nothing to be done for tda3xx arp32_1 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_1 vps_common
    Nothing to be done for tda3xx arp32_1 vpslib
    Nothing to be done for tda3xx arp32_1 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_1 fvid2
    Nothing to be done for tda3xx arp32_1 vps_platforms
    Nothing to be done for tda3xx arp32_1 vps_devices
    Nothing to be done for tda3xx arp32_1 vps_boards
    Nothing to be done for tda3xx arp32_1 vps_examples_utility
    Nothing to be done for tda3xx arp32_1 bsp_i2c
    Nothing to be done for tda3xx arp32_1 bsp_uart
    Nothing to be done for tda3xx arp32_1 bsp_mcspi
    Nothing to be done for tda3xx arp32_2 csl
    Nothing to be done for tda3xx arp32_2 csl_utils_common
    Nothing to be done for tda3xx arp32_2 csl_uart_console
    Nothing to be done for tda3xx arp32_2 csl_utils_i2c
    Nothing to be done for tda3xx arp32_2 pm_hal
    Nothing to be done for tda3xx arp32_2 pm_hal_optimized
    Nothing to be done for tda3xx arp32_2 pm_lib
    Nothing to be done for tda3xx arp32_2 pm_lib_optimized
    Nothing to be done for tda3xx arp32_2 sbl_lib
    Nothing to be done for tda3xx arp32_2 sbl_utils
    Nothing to be done for tda3xx arp32_2 diag
    Nothing to be done for tda3xx arp32_2 firewall_l3l4
    Nothing to be done for tda3xx arp32_2 ipc_lib
    Nothing to be done for tda3xx arp32_2 norflash_lib
    Nothing to be done for tda3xx arp32_2 qspiflash_lib
    Nothing to be done for tda3xx arp32_2 i2c_lld
    Nothing to be done for tda3xx arp32_2 stw_platform
    Nothing to be done for tda3xx arp32_2 stw_uartconsole
    Nothing to be done for tda3xx arp32_2 stw_fatlib
    Nothing to be done for tda3xx arp32_2 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_2 stw_boards
    Nothing to be done for tda3xx arp32_2 stw_devices
    Nothing to be done for tda3xx arp32_2 stw_examples_utility
    Nothing to be done for tda3xx arp32_2 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_2 vps_common
    Nothing to be done for tda3xx arp32_2 vpslib
    Nothing to be done for tda3xx arp32_2 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_2 fvid2
    Nothing to be done for tda3xx arp32_2 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_2 vps_platforms
    Nothing to be done for tda3xx arp32_2 vps_devices
    Nothing to be done for tda3xx arp32_2 vps_boards
    Nothing to be done for tda3xx arp32_2 vps_examples_utility
    Nothing to be done for tda3xx arp32_2 bsp_i2c
    Nothing to be done for tda3xx arp32_2 bsp_uart
    Nothing to be done for tda3xx arp32_2 bsp_mcspi
    Nothing to be done for tda3xx arp32_3 csl
    Nothing to be done for tda3xx arp32_3 csl_utils_common
    Nothing to be done for tda3xx arp32_3 csl_uart_console
    Nothing to be done for tda3xx arp32_3 csl_utils_i2c
    Nothing to be done for tda3xx arp32_3 pm_hal
    Nothing to be done for tda3xx arp32_3 pm_hal_optimized
    Nothing to be done for tda3xx arp32_3 pm_lib
    Nothing to be done for tda3xx arp32_3 pm_lib_optimized
    Nothing to be done for tda3xx arp32_3 sbl_lib
    Nothing to be done for tda3xx arp32_3 sbl_utils
    Nothing to be done for tda3xx arp32_3 diag
    Nothing to be done for tda3xx arp32_3 firewall_l3l4
    Nothing to be done for tda3xx arp32_3 ipc_lib
    Nothing to be done for tda3xx arp32_3 norflash_lib
    Nothing to be done for tda3xx arp32_3 qspiflash_lib
    Nothing to be done for tda3xx arp32_3 i2c_lld
    Nothing to be done for tda3xx arp32_3 stw_platform
    Nothing to be done for tda3xx arp32_3 stw_uartconsole
    Nothing to be done for tda3xx arp32_3 stw_fatlib
    Nothing to be done for tda3xx arp32_3 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_3 stw_boards
    Nothing to be done for tda3xx arp32_3 stw_devices
    Nothing to be done for tda3xx arp32_3 stw_examples_utility
    Nothing to be done for tda3xx arp32_3 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_3 vps_common
    Nothing to be done for tda3xx arp32_3 vpslib
    Nothing to be done for tda3xx arp32_3 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_3 fvid2
    Nothing to be done for tda3xx arp32_3 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_3 vps_platforms
    Nothing to be done for tda3xx arp32_3 vps_devices
    Nothing to be done for tda3xx arp32_3 vps_boards
    Nothing to be done for tda3xx arp32_3 vps_examples_utility
    Nothing to be done for tda3xx arp32_3 bsp_i2c
    Nothing to be done for tda3xx arp32_3 bsp_uart
    Nothing to be done for tda3xx arp32_3 bsp_mcspi
    Nothing to be done for tda3xx arp32_4 csl
    Nothing to be done for tda3xx arp32_4 csl_utils_common
    Nothing to be done for tda3xx arp32_4 csl_uart_console
    Nothing to be done for tda3xx arp32_4 csl_utils_i2c
    Nothing to be done for tda3xx arp32_4 pm_hal
    Nothing to be done for tda3xx arp32_4 pm_hal_optimized
    Nothing to be done for tda3xx arp32_4 pm_lib
    Nothing to be done for tda3xx arp32_4 pm_lib_optimized
    Nothing to be done for tda3xx arp32_4 sbl_lib
    Nothing to be done for tda3xx arp32_4 sbl_utils
    Nothing to be done for tda3xx arp32_4 diag
    Nothing to be done for tda3xx arp32_4 firewall_l3l4
    Nothing to be done for tda3xx arp32_4 ipc_lib
    Nothing to be done for tda3xx arp32_4 norflash_lib
    Nothing to be done for tda3xx arp32_4 qspiflash_lib
    Nothing to be done for tda3xx arp32_4 i2c_lld
    Nothing to be done for tda3xx arp32_4 stw_platform
    Nothing to be done for tda3xx arp32_4 stw_uartconsole
    Nothing to be done for tda3xx arp32_4 stw_fatlib
    Nothing to be done for tda3xx arp32_4 stw_fatlib_edma
    Nothing to be done for tda3xx arp32_4 stw_boards
    Nothing to be done for tda3xx arp32_4 stw_devices
    Nothing to be done for tda3xx arp32_4 stw_examples_utility
    Nothing to be done for tda3xx arp32_4 vps_osal_baremetal
    Nothing to be done for tda3xx arp32_4 vps_common
    Nothing to be done for tda3xx arp32_4 vpslib
    Nothing to be done for tda3xx arp32_4 vpsdrv_baremetal
    Nothing to be done for tda3xx arp32_4 fvid2
    Nothing to be done for tda3xx arp32_4 vps_osal_tirtos
    Nothing to be done for tda3xx arp32_4 vps_platforms
    Nothing to be done for tda3xx arp32_4 vps_devices
    Nothing to be done for tda3xx arp32_4 vps_boards
    Nothing to be done for tda3xx arp32_4 vps_examples_utility
    Nothing to be done for tda3xx arp32_4 bsp_i2c
    Nothing to be done for tda3xx arp32_4 bsp_uart
    Nothing to be done for tda3xx arp32_4 bsp_mcspi
    # Depend tda3xx-evm:ipu1_0:release:links_common_algorithm
    # Depend tda3xx-evm:ipu1_1:release:links_common_algorithm
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_algorithm
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_algorithm
    # Depend tda3xx-evm:arp32_1:release:links_common_algorithm
    # Depend tda3xx-evm:ipu1_0:release:links_common_dup
    # Depend tda3xx-evm:ipu1_1:release:links_common_dup
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_dup
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_dup
    # Depend tda3xx-evm:arp32_1:release:links_common_dup
    # Depend tda3xx-evm:ipu1_0:release:links_common_gate
    # Depend tda3xx-evm:ipu1_1:release:links_common_gate
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_gate
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_gate
    # Depend tda3xx-evm:arp32_1:release:links_common_gate
    # Depend tda3xx-evm:ipu1_0:release:links_common_ipcIn
    # Depend tda3xx-evm:ipu1_1:release:links_common_ipcIn
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_ipcIn
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_ipcIn
    # Depend tda3xx-evm:arp32_1:release:links_common_ipcIn
    # Depend tda3xx-evm:ipu1_0:release:links_common_ipcOut
    # Depend tda3xx-evm:ipu1_1:release:links_common_ipcOut
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_ipcOut
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_ipcOut
    # Depend tda3xx-evm:arp32_1:release:links_common_ipcOut
    # Depend tda3xx-evm:ipu1_0:release:links_common_merge
    # Depend tda3xx-evm:ipu1_1:release:links_common_merge
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_merge
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_merge
    # Depend tda3xx-evm:arp32_1:release:links_common_merge
    # Depend tda3xx-evm:ipu1_0:release:links_common_null
    # Depend tda3xx-evm:ipu1_1:release:links_common_null
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_null
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_null
    # Depend tda3xx-evm:arp32_1:release:links_common_null
    # Depend tda3xx-evm:ipu1_0:release:links_common_network_tx
    # Depend tda3xx-evm:ipu1_1:release:links_common_network_tx
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_network_tx
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_network_tx
    # Depend tda3xx-evm:arp32_1:release:links_common_network_tx
    # Depend tda3xx-evm:ipu1_0:release:links_common_network_rx
    # Depend tda3xx-evm:ipu1_1:release:links_common_network_rx
    # Depend tda3xx-evm:ipu1_0:release:links_common_nullSrc
    # Depend tda3xx-evm:ipu1_1:release:links_common_nullSrc
    # Depend tda3xx-evm:ipu1_0:release:links_common_select
    # Depend tda3xx-evm:ipu1_1:release:links_common_select
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_select
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_select
    # Depend tda3xx-evm:arp32_1:release:links_common_select
    # Depend tda3xx-evm:ipu1_0:release:links_common_sync
    # Depend tda3xx-evm:ipu1_1:release:links_common_sync
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_sync
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_sync
    # Depend tda3xx-evm:arp32_1:release:links_common_sync
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_display
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_display_ctrl
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_capture
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2misp
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2msimcop
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_iss_m2mresizer
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_vip_capture
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_dssM2mWb
    # Depend tda3xx-evm:ipu1_0:release:utils_common
    # Depend tda3xx-evm:ipu1_1:release:utils_common
    # Depend tda3xx-evm:c66xdsp_1:release:utils_common
    # Depend tda3xx-evm:c66xdsp_2:release:utils_common
    # Depend tda3xx-evm:arp32_1:release:utils_common
    # Depend tda3xx-evm:ipu1_0:release:links_common_system
    # Depend tda3xx-evm:ipu1_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_2:release:links_common_system
    # Depend tda3xx-evm:arp32_1:release:links_common_system
    # Depend tda3xx-evm:c66xdsp_1:release:links_dsp_system
    # Depend tda3xx-evm:c66xdsp_2:release:links_dsp_system
    # Depend tda3xx-evm:arp32_1:release:links_eve_system
    # Depend tda3xx-evm:ipu1_0:release:links_ipu_system
    # Depend tda3xx-evm:ipu1_1:release:links_ipu_system
    # Compiling tda3xx-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
    # Archiving tda3xx-evm:ipu1_0:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Archiving tda3xx-evm:ipu1_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Archiving tda3xx-evm:c66xdsp_1:release:links_common_algorithm
    # Compiling tda3xx-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
    # Archiving tda3xx-evm:c66xdsp_2:release:links_common_algorithm
    # Compiling tda3xx-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
    # Archiving tda3xx-evm:arp32_1:release:links_common_algorithm
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_rd.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_qspi_wr.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mmc_wr_proxy.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_sys_reset.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_mem_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_calib_image_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_stereo_set_dynamic_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_iss_raw_save.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/network_ctrl/network_ctrl_handle_object_detect_set_dynamic_params.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/osal/chains_common_osal.c
    # Compiling tda3xx-evm:ipu1_0:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignLUT_tda3xx.oe66' given more than once in the same rule.
    /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/build/rtos/makerules/rules_66.mk:181: target `/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_alg_plugins/tda3xx-evm/66/release/GAlignExt_tda3xx.oe66' given more than once in the same rule.
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_algPlugin.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_trafficSigns.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: objectdetection/objectDrawLink_trafficLights.c
    # Compiling tda3xx-evm:c66xdsp_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/lz4CompDecomp/lz4.c
    # Compiling tda3xx-evm:arp32_1:release:app_alg_plugins: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_settings_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_stereo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_avb.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_multi_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_single_cam.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_iss.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_opencl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_misc.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_rsvp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_tidl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/common/chains_main_bios_openvx.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x2D3DSv_layout.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_vision.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_stereo.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_sfm.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_fc_analytics2.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_rear_view_panorama.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_dewarp.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/common/chains_common_tidl.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/fast_boot_iss_capture_isp_simcop_pd_display/chains_fastBoot_issIspSimcop_pd_Display.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/fast_boot_iss_capture_isp_simcop_pd_display/chains_fastBoot_issIspSimcop_pd_Display_priv.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/fast_boot_iss_capture_isp_simcop_pd_display/chains_fastBoot_dspEvePowerDown.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/iss_capture_isp_simcop_display/chains_issIspSimcop_Display.c
    # Compiling tda3xx-evm:ipu1_0:release:app_libs: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/apps/src/rtos/usecases/iss_mult_capture_isp_2d_3d_sv_tda3x/chains_issMultCaptIsp2d3dSv_Display.c
    INTERNAL ERROR: /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armasm experienced a segmentation fault
    while processing section .text:Chains_issMultCaptIsp2d3d3dSv_Display file /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_libs/tda3xx-evm/ipu1_0/release/chains_issMultCaptIsp2d3dSv_Display.sem4 line 79451
    (-ppc) is used.
    >> Compilation failure
    make[5]: *** [/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_libs/tda3xx-evm/ipu1_0/release/chains_issMultCaptIsp2d3dSv_Display.oem4] Error 1
    regards,
    balaji t
  • Hi Balaji,
    Can you try the clean build i.e. run "make allclean" and "rm -rf binary" commands.
    In this thread itself you have mentioned that the build worked for you in between. Can you see what has changed after that?
    Rishabh
  • Hi Rishabh,
    It worked for only one time, so i took time to check multiple times to make sure its working completely fine.
  • Hi Rishabh,
    Again i can see the same error, build after "make allclean". for reference error noted below,
    while processing function (unknown or file scope) file /home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/ti_components/drivers/pdk_01_09_00_17/packages/ti/csl/src/ip/iss/V0/hw_iss_simcop_dma.h line 257
    (-ppc) is used.
    >> Compilation failure
    make[5]: *** [/home/balaji/workdir/projects/PROCESSOR_SDK_VISION_03_03_00_00/PROCESSOR_SDK_03_03/vision_sdk/binaries/apps/tda3xx_evm_bios_all/obj/app_libs/tda3xx-evm/ipu1_0/release/chains_common_vision.oem4] Error 1
    Please let me know is there any faults in my PC, so that i will check my side.
    regards
    balaji t
  • Hi Balaji,
    What is the configuration of your PC. For us build works on 64 bit Windows as well as linux.
    Rishabh
  • Hi Rishabh,
    Here is the conf of my pc,
    balaji@FSETBLR1D036:~$ uname -a
    Linux FSETBLR1D036 4.2.0-42-generic #49~14.04.1-Ubuntu SMP Wed Jun 29 20:22:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
    Balaji T
  • Hi Balaji,
    I tried the build on Ubuntu 14.04.5 and it worked fine for me.
    Can you please check if the build works for you on another machine or using a fresh installation on same machine.
    Rishabh
  • Hi Rishabh,
    I am using another PC with "Linux FSETBLR1LX046 4.4.0-57-generic #78~14.04.1-Ubuntu SMP Sat Dec 10 00:14:47 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux" configuration, in that i made build many time without any error.
    But my PC is with "Linux FSETBLR1D036 4.2.0-42-generic #49~14.04.1-Ubuntu SMP Wed Jun 29 20:22:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux", gives the error every time.
    Does kernel versions 4.4 and 4.2 makes any sense? can i do upgrade my kernel to  Linux 4.4.0-57 and try build again?
    I want to find the reasons for this error, because i have another project using TDA2Echo board, In that also while building "make -s" i am getting the same error. so please look into this issue very seriously.
    regards
    balaji t
  • Hi Balaji,
    we are not able to come up with any reason why it works on one machine and there is segmentation on another one, so I will move the thread to Compilers forum. Hopefully the experts there can give some help.
    Yordan
  • Hi Yordan,
    I would really like to appreciate this help from you,
    Balaji T
  • Hi there,
    Is there any update..?
    regards
    Balaji T
  • I suspect you are experiencing compiler bug CODEGEN-2098.  In some circumstances, multiple compilations in parallel may use the same temporary file name, with unpredictable results.  See the Target Release part of the bug entry for the list of compiler versions which implement the fix.  Be sure all the compilers you use are of one of those versions, or later.
    Thanks and regards,
    -George
  • Hi George,
    Upgrading compilers may resolve my issue..??
    regards
    Balaji T
  • Hi Balaji,
    Yes. Can you use the compilers mentioned under "Target Release" in the Incident report mentioned above.
    Rishabh
  • Hi Balaji,
    Is this issue resolved?
    Rishabh
  • Hi Rishabh,
    i am using Ubuntu_14.04(64-bit), and gcc compiler version "gcc (Ubuntu 4.8.4-2ubuntu1~14.04.4) 4.8.4". Now i am just struggling to match my compiler version with the compiler versions mentioned in CODEGEN-2098, target release.
    will you guys please help me to find the correct version.
    Thank you,
    balaji.
  • Hi Balaji,
    You don't need to update gcc. You should update the other compilers mentioned in list.
    Rishabh
  • Hi Rishabh,
    i found some dependencies in updating the list of compilers, please, give me some time and i ill get back to you.
    regards
    Balaji T
  • Hi Balaji,
    Thanks for the confirmation.
    Kindly start a new thread if you face any further issues.
    Rishabh
