Compiler: clpru 2.2.1 does not recognize "#pragma pack" ?
Paltform is BeagleBone Black under Debian, I have a ARM/PRU project.
I've a struct in shared memory, to communicate with the ARM under Debian. I must  force the struct to same byte layout under ARM and under PRU, so I used "#pragma pack"
<codesnippet>
/***** start of shared structs *****/
#pragma pack(4)
typedef struct {
    uint32_t    addr ; // register 0..7
    uint32_t    bitmask ; // change only these bits in register
    uint32_t    val ; // value set/get.
} mailbox_buslatch_t;
</codesnippet>
But clpru says
"../common/mailbox.h", line 28: warning #163-D: unrecognized #pragma
According to manual, #pragma pack(4) is supported.
Full call line:
/home/joerg/retrocmp/dec/pdp11/UniBone/91_3rd_party/pru-c-compile/ti-cgt-pru_2.2.1//bin/clpru --include_path=/home/joerg/retrocmp/dec/pdp11/UniBone/91_3rd_party/pru-c-compile/ti-cgt-pru_2.2.1//include --include_path=/home/joerg/retrocmp/dec/pdp11/UniBone/91_3rd_party/pru-c-compile/pru-software-support-package/include --include_path=/home/joerg/retrocmp/dec/pdp11/UniBone/91_3rd_party/pru-c-compile/pru-software-support-package/include/am335x --include_path=../common -v3 -O3 --auto_inline --display_error_number --endian=little --hardware_mac=on --obj_directory=../bin-bbb --pp_directory=../bin-bbb -ppd -ppa --c_src_interlist --optimizer_interlist --absolute_listing -fe ../bin-bbb/pru1_main.object pru1_main.c
Thnaks fpr caring
Joerg Hoppe
  • On PRU, all types are byte aligned.  See the section titled Data Types in the PRU compiler manual.  Therefore, all structs are packed, and there is no need for #pragma pack.
    This is an error in the manual.  To have that addressed, I filed CODEGEN-4832 in the SDOWP system.  You are welcome to follow it with the SDOWP link below in my signature.
    Thanks and regards,
    -George
  • George,
    thanks for the quick answer. Chapter 6.2.1 makes it clear.
    I understand "always byte align" this way : In
    struct {
         uint8_t   a;
         uint32_t b;
    } testvar ;
    an access to testvar.b crosses a 32bit word border. This is a legal situation, but may be an performance issue.
    Can the CPU handle "word crossing" accesses easily, or should I have all struct members as uint32_t to avoid this situation?
    best regards,
    Joerg
  • The information in this post is later found to be incorrect.  It is kept here only for continuity of the original thread.  -George
    We are not aware of any performance issues associated with non-aligned memory access.
    Thanks and regards,
    -George
  • Unfortunately, my last post is incorrect.  There is a performance penalty in some cases.
    With regard to accesses of these scalar types ...
    • char - no penalty
    • short, int, long, float, pointers - 1 cycle penalty if it crosses a 4-byte boundary
    • long long, double - 1 cycle penalty if it is not aligned on a 4-byte boundary
    At the present time, none of these data types are aligned.
    Thanks and regards,
    -George
