I want to know how this product communicate with arduino and dragonboard.
Is it compatible with arduino or not.
I'm unable to find any forums where these details are given, please guide me with this.
- Thanks in advance.
Hi Pooja,
Welcome to DLP forum and hank you for your interest in DLP technology.
You can communicate with the EVM using I2C commands. The programmer's guide describing these commands is located at http://www.ti.com/lit/pdf/dlpu013
Akhil
Hi Akhil,
Thanks for you reply.
Actually I'm looking for using dlpdlcr200 evm boards projector as a primary display using dragonboard 410e.
But unable to find any solution to work.
If there any suggestions please let me know.
Thanks in advance.
HI Pooja
Currently there are software drivers supported for the BeagleBone. Will get back to you if there are any other generic drivers available after discussing internally. Most probably you would need to develop a custom HDMI-Parallel I/F video data (via RGB888) driver and the I2C driver for the dragonboard.
Since this is a holiday season and most of the team will not be available. So please expect some delay for you query.
Akhil
Hi Pooja,
Please review the user's guide for information on the external interface for this EVM here: https://www.ti.com/lit/ug/dlpu049c/dlpu049c.pdf (section 3.5, pg.10). You will need to route connections based on this pinout from the EVM. Any external hardware may require you to develop something to interface properly.
Thank you,
Chris
