The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
DLP5530PGUQ1EVM: Projection imaging size
Part Number: DLP5530PGUQ1EVM
Other Parts Discussed in Thread: DLP5530PROJQ1EVM
Hello -
In DLP5530PGUQ1EVM Evaluation Module User's Guide,I saw that the throwing distance of the optical module is 70mm.But it seems a little small for us.
Is there any way to increase the imaging size by adjusting parameters?
Or can it only be solved through the optical path?
Do you have any solutions you can share with us?
By the way, as for another process of mine, I hope to get the correct firmware as soon as possible due to the urgency of the leadership.Sincerely hope you can understand!
Here is a link to another process of mine.
DLP5530PGUQ1EVM: The role of the firmware - DLP products forum - DLP®︎ products - TI E2E support forums
Thanks again!
yang
  • Hello Yang -
    The throw distance is fixed by the design of the projection lens. There is no parameter to increase it. If you're looking for a longer throw distance, we also offer the DLP5530PROJQ1EVM.
    Note I will respond in the other thread about the firmware.
    Ross
