Hi team,
Customer has a issue
I only use Blue LED.
Can you provide support? The customer needs detailed guidance step by step.
Vivian
Hi team,
Vivian
Hello Vivian,
Welcome to the TI E2E forums.
Do you know if the customer has a chance to use Write Pattern Order Table Entry and Read Pattern Order Table Entry vis GUI? I would recommend them to compare the flow with GUI and API.
For generating multiple pattern sets, are they using internal or external pattern streaming mode? The maximum number of patterns can be used in internal streaming mode and limited by the external flash memory. I would also recommend them to generate the pattern sets via GUI and compare it with the API.
Please come back to this thread if the customer has question.
Lori
Hi Lori,
Thanks for your quick reply.
Hi Vivian,
Great, thank you for letting us know! I hope the API document is helpful, then I'll close this thread.
Lori
