DLPDLCR230NPEVM: with pi5, I2C communication problems
Part Number: DLPDLCR230NPEVM
Other Parts Discussed in Thread: DLPC3436
Hello, there
I am currently working with the DLPDLCR230NPEVM connected to a Raspberry Pi 5 (running Raspberry Pi OS Bookworm, 64-bit). The board powers on correctly, the fan is spinning, and the test pattern (rainbow bars) is projected as expected.
However, I cannot establish I²C communication with the DLPC3436 controller.
  • /dev/i2c-7 is created after adding the overlay (dtoverlay=i2c-gpio,sda=23,scl=22,bus=7,i2c_gpio_delay_us=20).
  • GPIO25 (MODE_SEL) is successfully held HIGH using gpioset, confirmed by gpioinfo.
  • Running i2cdetect -y 7 shows only -- (no device detected at 0x27).
  • I also tried increasing the I²C delay (20–100 µs), disabling DPI configuration, and verifying ribbon cable (pin1 Left right arrow pin1), but the issue persists.
  • On the TI forum, I found that Raspberry Pi 4 with Bullseye works correctly, but with Raspberry Pi 5 + Bookworm, it seems I²C is not responding.
Could you please confirm if the DLPDLCR230NPEVM has compatibility issues with Raspberry Pi 5 and Bookworm OS? Or is there an updated overlay / configuration recommended for Pi 5?
Any guidance on enabling I²C communication (address 0x27) would be greatly appreciated.
Thank you.
  • Hello User,
    The EVM has not been tested with this version of the raspberry Pi and that OS.
    There is a I2C.py script that will likely need to be modified to match the address. It is included in the python support package. The default is 7 in this script, but this may have changed on the RPi side. Go to the /dev folder and look for some i2c-xx files. You will want to try either address found here in the i2c.py script. On the older OS this is a solution to most of these issues.
    John
