Other Parts Discussed in Thread: DLPC900
Tool/software: Linux
HI
HI
Hi Byron,
I don't have linux. But below is example
static hid_device *DevicePathList_G[10]; int DevCount_G = 0; int USB_Open() { if(FakeConnection == FALSE) { struct hid_device_info *hid_info; hid_info = hid_enumerate(MY_VID, MY_PID); if(hid_info == NULL) { USBConnected = FALSE; return -1; } DeviceHandle = NULL; while (hid_info != null) { if (0 == hid_info->interface_number) { DevicePathList_G[DevCount_G++] = hid_info->path; } hid_info = hid_info->next; } // Connect to device 0 DeviceHandle = hid_open_path(DevicePathList_G[0]); if(DeviceHandle == NULL) { USBConnected = FALSE; return -1; } } USBConnected = TRUE; return 0; }
Also you need to keep track of device attach/detach. For e.g initially 3 dlpc900 are connected (0-First, 1- Second, 2-Third). First one is removed. Now list will have 2 entries (0- Second 1-Third). See the "1 pos" entry in this list is third device not second device now.
So you need to track attach/detach and maintain list properly so that you don't refer to wrong device due to attach/detach of USB.
Also don't connect to wrong interface. That might hang the device.
If you use libusb, it has a unique busnumber and port number for each device connected that you can match on attach/detach events to see which device got removed/attached.
-ykc
ykc
full path? I don't understand very well. Can you give key functions and variables?
The position of -1 is actually I call LCR_GetFrmwVersion but only returns -1 in the internal hid_write failure.
Give you some USB connection details:
osrc@stretch-armhf:~/libusbtest$ lsusb -v
Bus 001 Device 018: ID 0451:c900 Texas Instruments, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0451 Texas Instruments, Inc.
idProduct 0xc900
bcdDevice 0.00
iManufacturer 1 Texas Instruments Inc.
iProduct 2 DLPC900
iSerial 3 C900
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 73
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 2 DLPC900
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 29
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 3 C900
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
Report Descriptor: (length is 29)
Item(Global): Usage Page, data= [ 0x00 0xff ] 65280
(null)
Item(Local ): Usage, data= [ 0x00 0xff ] 65280
(null)
Item(Main ): Collection, data= [ 0x01 ] 1
Application
Item(Global): Logical Minimum, data= [ 0x00 ] 0
Item(Global): Logical Maximum, data= [ 0xff ] 255
Item(Global): Report Size, data= [ 0x08 ] 8
Item(Global): Report Count, data= [ 0x40 ] 64
Item(Local ): Usage, data= [ 0x01 ] 1
(null)
Item(Main ): Input, data= [ 0x00 ] 0
Data Array Absolute No_Wrap Linear
Preferred_State No_Null_Position Non_Volatile Bitfield
Item(Local ): Usage, data= [ 0x02 ] 2
(null)
Item(Main ): Output, data= [ 0x00 ] 0
Item(Local ): Usage, data= [ 0x03 ] 3
(null)
Item(Main ): Feature, data= [ 0x02 ] 2
Data Variable Absolute No_Wrap Linear
Item(Main ): End Collection, data=none
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0001
Self Powered
Bus 001 Device 016: ID 0451:c900 Texas Instruments, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idProduct 0xc900
bcdDevice 0.00
iProduct 2 DLPC900
iSerial 3 C900
bLength 9
bDescriptorType 2
wTotalLength 73
bNumInterfaces 2
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
(null)
(null)
Application
(null)
(null)
(null)
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 3 C900
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
(null)
(null)
Application
(null)
(null)
(null)
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Self Powered
Bus 001 Device 013: ID 214b:7250
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x214b
idProduct 0x7250
bcdDevice 1.00
iManufacturer 0
iProduct 1 USB2.0 HUB
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0001 1x 1 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
wHubCharacteristic 0x00e0
Ganged power switching
Ganged overcurrent protection
TT think time 32 FS bits
Port indicators
bPwrOn2PwrGood 50 * 2 milli seconds
bHubContrCurrent 100 milli Ampere
DeviceRemovable 0x00
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.0100 power
Port 2: 0000.0100 power
Port 3: 0000.0100 power
Port 4: 0000.0100 power
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceProtocol 0 Full speed (or root) hub
bMaxPacketSize0 64
Self Powered
Bus 001 Device 012: ID 214b:7250
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idVendor 0x214b
idProduct 0x7250
bcdDevice 1.00
iManufacturer 0
iSerial 0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 4
Port indicators
Hub Port Status:
Port 1: 0000.0507 highspeed power suspend enable connect
Port 3: 0000.0103 power enable connect
Port 4: 0000.0103 power enable connect
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
Self Powered
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.14
iManufacturer 3 Linux 4.14.0-xilinx ehci_hcd
iProduct 2 EHCI Host Controller
iSerial 1 ci_hdrc.0
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0009
Per-port power switching
Per-port overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 10 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
Hub Port Status:
Port 1: 0000.0503 highspeed power enable connect
Self Powered
