several 3010evm can not project the patter which i want, if i create a sequence of patterns ( 1,2,3,4,5), and then i trigger evm to project, but my camera may get the sequence like (1,2,2,4,1)
Hello User,
Welcome to the TI E2E forums and thanks for showing interest in the DLP technology.
Kindly provide more information related to the error that you are getting - Firmware version, Screenshot of Pattern Configuration details etc.
Mayank
Zonda,
Thanks for your feedback. We will work to give you feedback early next week.
Philippe Dollo
Hello Zonda,
Can you try to reproduce the same issue with the latest firmware that is available on ti.com and let us know your findings. You can find the firmware here -
https://www.ti.com/tool/DLP3010EVM-LC
Mayank
Hello Mayank,
Through a simple test, your solution seems to help us. At the same time, we also need to conduct follow-up tests to verify its effectiveness. If you can tell us the cause of the problem and why the latest firmware can solve this problem, then we will rely more on your products in future use.
Zonda
Hello Zonda,
Please refer to the release notes for the firmware. It documents bug fixes and feature improvement.
regards,
Vivek
Hello Zonda,
No, the third point is not related to the issue that you are seeing. I wanted you to try the latest firmware and see if you still see the issue because all the bugs and issues if any are addressed in the future firmware releases based on the top of latest firmware.
Mayank
Hello Mayank,
Thank you for your assistance,
We have forty dlp3010evm, two of which have this error from time to time. We thought it was a hardware problem before, but after updating the latest firmware, this error has not appeared. At least from the current test, the new firmware does Fixed this problem, if this problem occurs in the future, I will reply to you.
Zonda
Zonda,
Thanks for your feedback. Keep us informed of any new issues.
Philippe Dollo
