Hi TI,
Customer is using TUV TL Mini lamps are slim double-ended UVC (germicidal) lamps used in residential water and air disinfection units. The small 16 mm diameter of the lamp allows for a small system design and design flexibility. TUV TL Mini lamps offer almost constant UV outputover their complete lifetime, for maximum security of disinfection and high system efficacy.
They are planning to design a ballast for 8W Philips UV Tube.
Kindly suggest the part what we can propose and DLP9500 series is this ok to suggest.
Looking forward to hearing from you.
Yashwitha
