Other Parts Discussed in Thread: TM4C1297NCZAD, DLP2010, DLPC2607
Hello Team,
I do have a customer which looking forward to starting HUD design with our DLP2000, Before he would start the design he got a few questions
Could you please advise the below:
* There is an extended temperature DLP2000 version, if not what happened to the device in case of working at the edges such as (-)20 or above 70 (C)?
* could this device communicate directly in front of the TM4C1297NCZAD (using the 24 bit parallel I/F)?
* does TI provide a reference design for small footprint PCB design?
* in case the application use case for outdoor but the distance from the viewer is about 10 cm and considering that the product is working on battery,
What are the required currents for lighting in that case (or the recommended Nits)? And if you have some recommendations for RGB LEDs?
Thanks in advance
Shai
