Other Parts Discussed in Thread: DLPC150
I know that the scan configuration parameters were covered by me. I want to know how to restore the two scan configurations column1 and hadamard1. I added a new one to the local in the scan configuration dialog but the Dig Resolution has not changed the value. 2. Then I want to know the original column1 and hadamard1. What is the scan configuration parameter? When will I add it directly to the local area and then move it over locally?
The picture above is after I did this step, I replaced the reference calibration. After clicking it, my parameters will be replaced, and then the instrument will not be used. Always give me an error saying that the reference scan configuration could not be found. Originally, I saw that on page 30 of the manual, you can save your own settings by adding settings. But I just can't save it. There is no way to save the instrument.
I would like to ask if I can tell you that there are two types of Column and Hadamard Scan Configuration Parameters. Or how to recover these two.
