DLPLCRC410EVM: I tried to use DMD for experiment for the first time and have some questions about the board
Part Number: DLPLCRC410EVM
Other Parts Discussed in Thread: DLPLCR70UVEVM,
Hello, I'm using DMD for the first time in my experiment, so I have a lot of things I do not know yet so I'm going to ask you some questions
I am going to purchase two models, DLPLCR70UVEVM and DLPLCRC410EVM, to irradiate UV with typical shape, but are there any more parts to buy?
I want to control it with D4100Explorer-2.0. Is this a program that is compatible with the above two models?
And I want to run in Window 7-32bit and 7-64bit, Window 10-64bit. Is it possible to use the above program with this operating system?
I would appreciate your any answer to the question.
Thank you
  • Hi Dowon,
    May I know what is your pattern rates requirements?
    D4100Explorer-2.0 is compatible with DLPLCR70UVEVM and DLPLCRC410EVM. GUI will work on Windows 7 and Windows 10 64bit versions.
    32bit version is not tested but expected to work.
    DLPLCR70UVEVM and DLPLCRC410EVM are enough to get started with.
    But this GUI is only for demonstration and will be slow. To harness pattern rates specified in datasheet, you will need to develop your own apps fpga.
    -ykc
