  • TI Thinks Resolved
DLPNIRSCANEVM: Absorption readings file not found
Prodigy 40 points
Part Number: DLPNIRSCANEVM
We have recently purchased a DLPNIRSCANEVM.
I will use it for on field measurement on plant juice
But my problem isthe following one :
the calibration always works, but sometimes i see this error message (please look at the picture), and when i see this message i unplug & replug the usb, to do other calibrations and so on, but the message still appears
If i try few days later the (as today), the scan works perfectly
how am i supposed to solve this problem?
why does it happen ?
In such conditions it is totaly impossible for me to do my measurements
Respectfully
Martin
  • Hello Martin,
    Welcome to DLP  forum and thank you fro your interest in DLP technology.
    Could you please share what OS and version you are using? Please also share the version number of the firmware.?
    regards,
    Vivek
  • In reply to Vivek Thakur:
    hello
    i'm using mac (OS X, 10.11.6) with google chrome (version 78.0.3904.70)
    could this bug occurs also on my other laptop  : windows ten : version 18362.356 ; with google chrome : 77.0.3865.120
  • In reply to Martin Rollet:
    Hi Martin,
    I will investigate to identify condition under which such error are reported.
    Meanwhile, could you please also try on Windows and let me know if this problem continues?
    regards,
    Vivek
    Martin,
    Were you able to evaluate the software on any other operating system platforms?
    Philippe Dollo
    If a post answers your question, please click the "Verify Answer" button.
  • In reply to Philippe Dollo:
    not yet sorry, but i will only use my macbook pro (described above) for my on field measurements, so i need that your device works with this computer
    regards
    martin
    Hi Martin,
    It will be very helpful if you could test this EVM on the windows machine. It will help us isolate the issue and  identify root cause faster.
    Please do share your findings after you have tested on windows machine.
    regards,
    Vivek
    Hi Martin,
    Do you still help with this issue.
    The firmware reports this problem when it not able to read back from files system stored in eMMC.
    I order to debug this issue , you need to the EVM J1 connector via a UART FTDI cable. Via that you can access the linux command prompt and then further investigate into what may be going on.
    Please let us know how you want to proceed.
    regards,
    Vivek
    I will try that kind of cable,
    i will let you informed when i 'll test it
    regards
    Martin
    Hi Martin,
    Thank you. Please let me know your findings.
    regards,
    Vivek
    Hi Martin,
    Any update?
    regards,
    Vivek
