Part Number: DLP2010EVM-LC
Hi TI members,
I'm developing program using opencv in C++.
Hi TI members,
Hello KangYeol,
When you say sample code do you mean the DLPC-API? If so please note that this is in C and not C++ (obviously the C code can generally be compiled in a C++ environment). Please confirm this is what you have been using. If so have you been able to run the default samples?
Kyle
Hello Kyle,
Thank you for your reply.
Yes, I mean the DLPC-API. I know sample code in C. So I fixed some of the sample codes.(make header.. wrapping .. etc)
I succeeded in InternalPattern control. But I'm fail to upload my images in Internal Patterns..
By the way, do you have any sample codes in C++ ? If you have it, please share it.....
Thanks.
Hi Lee,
No we do not have sample codes in C++.
I will check your code and let you know my findings soon.
Navneet
Hi Lee,
The sample code looks OK, except for setting pattern data to all zeros. It will be helpful to know what exactly is failing. Are the pattern displayed incorrectly ? Did the pattern download fail ? Are you able to load patterns correctly using the original sample code ?
Navneet
