Part Number: DLPLCR9000EVM
Hello all,
I want to use my DMD for beamshaping in a cold atom experiment. One issue is "mirror flickering". This term describes that every 105 usec a pulse is sent such that all the mirrors are released for ~3usec. For a single white image in pattern on the fly mode this means that the intensity drops every 105 usec. Following the procedure in I took a look at the mentioned strb-signal and indeed the strb signal is correlated with the flickering. So every time the intensity drops I can detect three short pulses on the strb line. To control this behaviour I soldered a relais on it such that I can either let the signal pass or not (the switch is located next to TP15)
Even with the line interrupted the mirrors do not stick in their position. I can still measure the strb pulses on the mirror side of the relais. So do you know if there is another line transmitting these strb pulses?
Best C
