DLP2000: Using Labview to Project sequences
Part Number: DLP2000
Hi, I am trying to achieve a few key process with Labview, a BeagleBone Black, and a DLP Lightcrafter2000, similar to this previous question
https://e2e.ti.com/support/dlp/f/94/t/414071?Pattern-Sequence-RGB-control-via-LabVIEW
The goal is to either project single frames of an image, or a patterned sequence, and later synchronize a camera with this to take an image for every projected frame, or each sequence projected, similar to this prior question.
Are there any sample codes for Labview I can use to achieve the pattern RGB projection or project single frames to the DLP 2000, or any recommendations on the setup?
