Part Number: DLPR410
I would like to confirm the REV_SEL0 and REV_SEL1 pins. DLP0101A_SCH.pdf shows each pins are 4.7k pull-down as below.
However, DLPR410 data sheet (JAJSGM0E –AUGUST 2012–REVISED DECEMBER 2018) says the pull-down must be 10k. Which resistance value is correct?
Also, which REVISION SELECT should be selected(00 or 01)? Do we need to confirm the DLPR410 revision?
Uryyy
