Code Composer Studio v6 aren't start
Other Parts Discussed in Thread: CCSTUDIO
when i execute CCS v6, it close immediately without any control.
(I downloaded latest version of CCS and my laptop uses windows8 64bit.)
To solve this problem,
1. I completely delete all of files of CCS using unistaller and re-install, but it didn't work.
2. stop the all of vaccine programs. even firewall. but it didn't fixed.
3. Considering a little possibility of  collision, i deleted ecilipse and re-install, but it has same problem.
4. When i Change the default work space, it commits R6025 error with same problem..
plz tell me how can i fix this problem.. i've been struggling to solve this problem..
    What exact version of CCSv6 are you using? And how much RAM does your PC have?
    Also try reducing the maximum JVM heap size (try 512 or 384):
    processors.wiki.ti.com/.../FAQ_-_CCSv6
    ki
  • Thank you for your comment.
    I used 6.1.2.00014 version. And my Labtop have 4GB Ram Size. when i adjust "-Xmx" parameter and change the JVM heap size to 512 , 384, 128, 256.. but problem isn't fixed. Would you mind tell me any other solution??
  • Were you ever able to run CCS at all after installation? Or does it fail right after you installed it?
  • thanks for your reply.
    it fails right after i installed it.
    my labtop never started CCS successfully. it fails right after execution with no error message.
  • Inside your workspace folder, there should be a subfolder called .metadata. Inside that folder, do you see a file called .log? If so, can you attach it to this thread?
    Also, are you using Windows 8-64bit Korean version?
  • Sure. I'm using windows8.1 64bit korean version.
    and here is the log.
    !SESSION 2016-01-05 10:53:53.084 -----------------------------------------------
    eclipse.buildId=4.4.1.M20140925-0400
    java.version=1.7.0_60
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ko_KR
    Framework arguments: -product com.ti.ccstudio.branding.product
    Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
    !ENTRY com.ti.common.core 4 0 2016-01-05 10:54:22.866
    !MESSAGE path=ccs_base/DebugServer
    !MESSAGE debugServerDir=C:/ti/ccsv6/ccs_base/DebugServer
    !ENTRY org.eclipse.equinox.event 4 0 2016-01-05 10:54:34.719
    !MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@c0d2ed
    !STACK 0
    org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
    at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
    at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run(UIEventObjectSupplier.java:56)
    at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
    at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
    at org.eclipse.swt.widgets.Display.syncExec(Display.java:4734)
    at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
    at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:53)
    at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
    at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
    at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
    at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
    at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
    at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
    at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
    at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
    at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
    at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
    at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
    at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
    at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
    at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
    at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:210)
    at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:145)
    at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:190)
    at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:564)
    at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:758)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
    at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
    at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
    at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:85)
    at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
    at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1480)
    at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1453)
    at com.ti.ccstudio.debug.ui.licensing.LicenseMonitor.addStatusBar(LicenseMonitor.java:449)
    at com.ti.ccstudio.debug.ui.licensing.LicenseStatusBar.fill(LicenseStatusBar.java:52)
    at com.ti.ccstudio.debug.ui.targetStatus.statusBar.CCSStatusBar.createControl(CCSStatusBar.java:39)
    at org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(WorkbenchWindowControlContribution.java:105)
    at org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(CompatibilityWorkbenchWindowControlContribution.java:90)
    at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
    at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:271)
    at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:186)
    at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:107)
    at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
    at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:50)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(ToolControlContribution.java:65)
    at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:101)
    at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:365)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$3.handleEvent(ToolBarManagerRenderer.java:205)
    at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
    at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
    at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(ToolBarContributionRecord.java:73)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$10.changed(ToolBarManagerRenderer.java:510)
    at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:110)
    at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:319)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(ToolBarManagerRenderer.java:502)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(ToolBarManagerRenderer.java:471)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(ToolBarManagerRenderer.java:430)
    at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(ToolBarManagerRenderer.java:391)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
    at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.handleEvent(PartRenderingEngine.java:289)
    at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:356)
    at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:341)
    at org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(ContributionsAnalyzer.java:369)
    at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(TrimBarRenderer.java:194)
    at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:166)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:547)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:531)
    at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:687)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
    at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
    Caused by: java.lang.IllegalArgumentException:
    at org.eclipse.core.runtime.Assert.isLegal(Assert.java:63)
    at org.eclipse.core.runtime.Assert.isLegal(Assert.java:47)
    at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:142)
    at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:309)
    at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:295)
    at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.getActivePerspective(ModelServiceImpl.java:815)
    at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:670)
    at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:645)
    at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:359)
    at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
    ... 147 more
    !SESSION 2016-01-05 10:59:36.783 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 10:59:40.830
    !SESSION 2016-01-05 11:02:35.196 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:02:39.381
    !SESSION 2016-01-05 11:03:01.313 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:03:04.845
    !SESSION 2016-01-05 11:04:02.367 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:04:06.239
    !SESSION 2016-01-05 11:04:27.144 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:04:30.828
    !SESSION 2016-01-05 11:04:39.122 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:04:42.807
    !SESSION 2016-01-05 11:18:00.226 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 11:18:03.999
    !SESSION 2016-01-05 12:08:52.580 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:09:20.175
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:09:20.190
    !SESSION 2016-01-05 12:09:56.522 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:10:01.584
    !SESSION 2016-01-05 12:19:56.849 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:20:00.678
    !SESSION 2016-01-05 12:21:33.463 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:21:37.448
    !SESSION 2016-01-05 12:23:33.252 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:23:37.714
    !SESSION 2016-01-05 12:29:48.936 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:29:52.665
    !SESSION 2016-01-05 12:33:53.085 -----------------------------------------------
    Framework arguments: C:\Program Files\Java\jdk1.8.0_60\bin\javaw.exe
    Command-line arguments: -os win32 -ws win32 -arch x86 C:\Program Files\Java\jdk1.8.0_60\bin\javaw.exe
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:33:56.844
    !SESSION 2016-01-05 12:54:31.952 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:54:35.983
    !SESSION 2016-01-05 12:54:41.409 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 12:54:45.280
    !SESSION 2016-01-05 13:22:12.320 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-05 13:22:18.476
    !SESSION 2016-01-06 12:17:53.725 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-06 12:18:09.445
    thank you for your help.
  • Thank you. We are wondering if your issue is related to the issue reported in the below thread regarding language localization support support:
    e2e.ti.com/.../1578700
    As a test, can you also try temporarily switching the Windows language to English and see if CCS will start up correctly?
    ki
  • hi ki.
    thanks for your help.
    I changed my language option but it cannot fix the problem.
    here is the log, and i can figure out the language is correctly adjusted, but problem isn't fixed.
    !SESSION 2016-01-07 13:39:04.407 -----------------------------------------------
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
    !ENTRY com.ti.common.core 4 0 2016-01-07 13:41:01.844
    !ENTRY com.ti.common.core 4 0 2016-01-07 13:41:01.953
    !SESSION 2016-01-07 13:41:49.358 -----------------------------------------------
    !ENTRY com.ti.common.core 4 0 2016-01-07 13:41:54.561
    Is there any other solution?
    it's hard to begin..
