dear sir,
i have compiled the following code of hwafft for tms320c5505..i have attached the code..but getting this error..plz solve this..i have read ur each and each forum regarding HWAFFT but couldnt solve the errors..
**** Build of configuration Debug for project hwafft_v3 ****
"D:\\ti\\ccsv7\\utils\\bin\\gmake" -k -j 4 all -O
'Building file: "../test.c"'
'Invoking: C5500 Compiler'
"D:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=large -g --include_path="E:/workspace/hwafft_v3" --include_path="D:/ti/ccsv7/tools/compiler/c5500_4.4.1/include" --define=c5505 --display_error_number --diag_warning=225 --ptrdiff_size=16 --asm_source=algebraic --preproc_with_compile --preproc_dependency="test.d_raw" "../test.c"
69 Assembly Errors, No Assembly Warnings
>> Compilation failure
subdir_rules.mk:16: recipe for target 'test.obj' failed
subdir_rules.mk:16: warning: overriding recipe for target 'test.obj'
subdir_rules.mk:9: warning: ignoring old recipe for target 'test.obj'
subdir_rules.mk:30: warning: overriding recipe for target 'test_cfg.obj'
subdir_rules.mk:23: warning: ignoring old recipe for target 'test_cfg.obj'
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 12: [E0004]
Substitution symbol operand expected
.asg DPH, MDP
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 115: [E0000]
parse error
AADD #-13, SP
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 150: [E0000]
parse error
MOV #1, *SP(#12) ; |37|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 152: [E0000]
parse error
AMOV #_data_br_buf, XAR3 ; |39|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 153: [E0000]
parse error
MOV XAR3, dbl(*SP(#2))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 155: [E0000]
parse error
AMOV #_scratch_buf, XAR3 ; |40|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 156: [E0000]
parse error
MOV XAR3, dbl(*SP(#6))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 158: [E0000]
parse error
MOV #0, *SP(#4) ; |129|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 160: [E0000]
parse error
MOV #0, *SP(#5) ; |130|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 162: [E0000]
parse error
AMOV #_invec_fft_1024pts, XAR3 ; |133|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 163: [E0000]
parse error
MOV XAR3, dbl(*SP(#0))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 165: [E0000]
parse error
AMOV #_refvec_fft_1024pts, XAR3 ; |134|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 166: [E0000]
parse error
MOV XAR3, dbl(*SP(#10))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 168: [E0000]
parse error
MOV #1024, T0 ; |135|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 169: [E0000]
parse error
MOV dbl(*SP(#0)), XAR0
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 170: [E0000]
parse error
MOV dbl(*SP(#2)), XAR1
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 178: [E0000]
parse error
MOV dbl(*SP(#2)), XAR3
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 179: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 181: [E0000]
parse error
MOV *SP(#5), T1 ; |137|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 182: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 183: [E0000]
parse error
MOV dbl(*SP(#6)), XAR1
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 184: [E0000]
parse error
MOV *SP(#4), T0 ; |137|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 191: [E0000]
parse error
MOV T0, *SP(#8) ; |137|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 193: [E0000]
parse error
MOV #1024, T1 ; |138|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 194: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 195: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 196: [E0000]
parse error
MOV dbl(*SP(#10)), XAR2
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 203: [E0000]
parse error
MOV T0, *SP(#12) ; |138|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 205: [E0000]
parse error
MOV *SP(#12), T0 ; |238|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 207: [E0000]
parse error
AADD #13, SP
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 212: [E0000]
parse error
RET
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 268: [E0000]
parse error
AADD #-17, SP
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 306: [E0000]
parse error
MOV T1, *SP(#8) ; |249|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 307: [E0000]
parse error
MOV XAR2, dbl(*SP(#6))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 308: [E0000]
parse error
MOV T0, *SP(#4) ; |249|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 309: [E0000]
parse error
MOV XAR1, dbl(*SP(#2))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 310: [E0000]
parse error
MOV XAR0, dbl(*SP(#0))
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 312: [E0000]
parse error
MOV *SP(#4), AR1 ; |255|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 313: [E0000]
parse error
BCC $C$L1,AR1 != #0 ; |255|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 316: [E0000]
parse error
MOV dbl(*SP(#0)), XAR3
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 317: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 319: [E0000]
parse error
B $C$L2 ; |258|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 323: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 324: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 327: [E0000]
parse error
MOV #0, *SP(#12) ; |264|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 329: [E0000]
parse error
MOV #0, *SP(#16) ; |265|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 331: [E0000]
parse error
B $C$L5 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 336: [E0000]
parse error
MOV dbl(*SP(#6)), XAR3
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 337: [E0000]
parse error
MOV *SP(#12), T0 ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 338: [E0000]
parse error
SFTL T0, #1 ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 339: [E0000]
parse error
MOV dbl(*AR3(T0)), AC0 ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 340: [E0000]
parse error
MOV dbl(*SP(#10)), XAR3
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 341: [E0000]
parse error
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 342: [E0000]
parse error
SFTL T0, #1 ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 343: [E0000]
parse error
SUB AC0, dbl(*AR3(T0)), AC0 ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 344: [E0000]
parse error
MOV AC0, dbl(*SP(#14)) ; |268|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 346: [E0000]
parse error
MOV dbl(*SP(#14)), AC0 ; |269|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 347: [E0000]
parse error
BCC $C$L4,AC0 == #0 ; |269|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 352: [E0000]
parse error
MOV #1, *SP(#16) ; |271|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 357: [E0000]
parse error
ADD #1, *SP(#12) ; |274|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 362: [E0000]
parse error
MOV *SP(#8), AR1 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 363: [E0000]
parse error
MOV *SP(#12), AR2 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 364: [E0000]
parse error
CMPU AR2 >= AR1, TC1 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 365: [E0000]
parse error
BCC $C$L6,TC1 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 369: [E0000]
parse error
MOV *SP(#16), AR1 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 370: [E0000]
parse error
BCC $C$L3,AR1 == #0 ; |266|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 375: [E0000]
parse error
MOV *SP(#16), T0 ; |277|
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 377: [E0000]
parse error
AADD #17, SP
"C:\Users\RnD\AppData\Local\Temp\1236410", ERROR! at line 382: [E0000]
parse error
RET
Errors in Source - Assembler Aborted
gmake: *** [test.obj] Error 1
'Building file: "../test_cfg.c"'
"D:/ti/ccsv7/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=large -g --include_path="E:/workspace/hwafft_v3" --include_path="D:/ti/ccsv7/tools/compiler/c5500_4.4.1/include" --define=c5505 --display_error_number --diag_warning=225 --ptrdiff_size=16 --asm_source=algebraic --preproc_with_compile --preproc_dependency="test_cfg.d_raw" "../test_cfg.c"
1 Assembly Error, No Assembly Warnings
>> Compilation failure
subdir_rules.mk:30: recipe for target 'test_cfg.obj' failed
"C:\Users\RnD\AppData\Local\Temp\0292410", ERROR! at line 12: [E0004]
.asg DPH, MDP
gmake: *** [test_cfg.obj] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
